Home » Eclipse Projects » Equinox » Implications of Contributions from Multiple Developers to OSGI
Implications of Contributions from Multiple Developers to OSGI [message #553941] Thu, 19 August 2010 09:40 Go to next message
I posted this in the newcomers forum which was probably the wrong place. Any feedback is very much appreciated.
Are there any concerns as far as having several different areas contribute to the same OSGI framework? Are there any standards that you should put in place to make sure that one plugin doesn't negatively affect another?
For example, if two people submit a plugin with the same ID, would this have consequences? Do we need a system in place to make sure they submit plugins with unique IDs?
This is for Lotus Notes plugins which are built on the eclipse 3.2 platform.
[Updated on: Thu, 19 August 2010 09:42] by Moderator
Re: Implications of Contributions from Multiple Developers to OSGI [message #554031 is a reply to message #553941] Thu, 19 August 2010 14:26 Go to previous message
Am 19.08.2010 15:40, schrieb Ryan Plymire:
You need to think of the security implications. For example, do you mind
if bundles from one group are allowed to see services/code from bundles
of other groups?
Yes. You should definitely avoid this. For example, you could assign
namespaces to developer groups.
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Previous Topic:Unable to open eclipse in solaris 10.
Next Topic:Resource loading with HttpService
Current Time: Wed Jul 23 08:46:59 EDT 2025
Powered by FUDForum. Page generated in 0.47927 seconds
