Home » Eclipse Projects » Subversive » SVN authentication issue
SVN authentication issue [message #553802] Wed, 18 August 2010 18:03 Go to next message
We just recently switched to subversion 1.6.6 and switched to the SvnKit 1.6.6. We have a mulyi folder subversion repository.
The issue is the login dialog box pops up every time we want to go to a new folder in the repository. This didn't happen with the v1.5.x repository. We use the save password option.
Is there another setup parameter we missed that will fix this?
Re: SVN authentication issue [message #554099 is a reply to message #553802] Fri, 20 August 2010 03:56 Go to previous message
Hallo Ray,
please try this:
- Create a new and empty workspace
- Create a new repository localtion including saved login information
- perform a fresh checkout of your project
Previous Topic:using linked folders
Next Topic:Subversive unusable, fails with "Unable to locate login configuration"
Current Time: Fri Jul 25 19:53:15 EDT 2025
Powered by FUDForum. Page generated in 0.02742 seconds
