Home » Modeling » UML2 » Retrieving applied stereotypes
Retrieving applied stereotypes [message #553715] |
Wed, 18 August 2010 11:03  |
Hi there!
I'm currently facing problems when trying to read applied stereotypes from a UML model. The model itself is created and exported from 16.5 MagicDraw with the "EMF UML 2.x" export option.
When opening the model back in the UML editor the stereotyped elements are perfectly shown like "<<myStereotype>> <Class> myClass". Therefore I guess the model itself is valid (in the context of applied stereotypes).
I found a bunch of hints and guides on how to do stand alone applications (package registrations, pathmaps, ...) and tried "everything" without success. That's why I'm now here hoping to get some enlightenment.
Below you find the major code lines I'm using. Any comments and the slightest hints why any call to ...#getAppliedStereotypes leads to an empty list are very much appreciated!
import ...
public class SimpleTest {
String filename = "models/myModel.uml";
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(Ecore2XMLPackage.eNS_URI, Ecore2XMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put("http://www.eclipse.org/uml2/2.0.0/UML", UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put("http://schema.omg.org/spec/UML/2.0", UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put("http://schema.omg.org/spec/UML/2.1", UMLPackage.eINSTANCE);
Map<String, Object> extensionToFactoryMap = resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap();
extensionToFactoryMap.put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
extensionToFactoryMap.put("ecore", new EcoreResourceFactoryImpl());
extensionToFactoryMap.put("ecore2xml", new Ecore2XMLFactoryImpl());
extensionToFactoryMap.put(UMLResource.FILE_EXTENSION, XMI2UMLResource.Factory.INSTANCE);
extensionToFactoryMap.put(Resource.Factory.Registry.DEFAULT_EXTENSION, new XMIResourceFactoryImpl());
Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
URI uri = URI.createURI("jar:file:/ABS_PATH_TO_JAR/org.eclipse.uml2.uml.resources_3.1.0.v201005031530.jar!/");
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
URI uriPath = URI.createFileURI(filename);
Resource resource = resourceSet.getResource(uriPath, true);
Model myModel = (Model) EcoreUtil.getObjectByType(
resource.getContents(), UMLPackage.eINSTANCE.getModel());
// load the profile (test purpose)
URI profilePath = URI.createFileURI("models/myProfile.profile.uml");
Resource profileResource = resourceSet.getResource(profilePath, true);
Profile umlProfile = (Profile) EcoreUtil.getObjectByType(
profileResource.getContents(), UMLPackage.eINSTANCE.getProfile());
// end loading the profile
System.out.println("Model " + myModel.getName());
Iterator<Element> it = myModel.getOwnedElements().iterator();
while (it.hasNext()) {
Element e = it.next();
if(e instanceof org.eclipse.uml2.uml.Class) {
org.eclipse.uml2.uml.Class umlClass = (org.eclipse.uml2.uml.Class)e;
System.out.print("Class " + umlClass.getName());
// THIS LEADS TO EMPTY LIST
EList stereotypes = umlClass.getAppliedStereotypes();
System.out.println(" (" + stereotypes.size() + " stereotypes)");
for(Object stereotype : stereotypes) {
System.out.println("\tStereotype " + stereotype.toString());
} else if (e instanceof NamedElement)
System.out.println("Other " + e);
Many thanks for any efforts,
Thomas
[Updated on: Wed, 18 August 2010 11:06] by Moderator
Re: Retrieving applied stereotypes [message #553737 is a reply to message #553715] |
Wed, 18 August 2010 12:12   |
--------------070907070000030103040600
One suggestion is to ensure *all *your paths are absolute. I.e., use
new java.io.File("models/myModel.uml").getAbsolutePath() before creating
a file URI from it.
tomtro13@gmail.com wrote:
> Hi there!
> stereotypes).
> some enlightenment. :)
> import ...
> public static void main(String[] args) {
> resourceSet.getPackageRegistry().put(Ecore2XMLPackage.eNS_UR I,
> resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap();
> extensionToFactoryMap.put(Resource.Factory.Registry.DEFAULT_ EXTENSION,
> URI uri =
> URI.createURI(" jar:file:/ABS_PATH_TO_JAR/org.eclipse.uml2.uml.resources_3.1 .0.v201005031530.jar!/ ");
> URI profilePath =
> stereotypes)");
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
One suggestion is to ensure <b>all </b>your paths are absolute.
I.e., use new java.io.File("models/myModel.uml").getAbsolutePath()
before creating a file URI from it.<br>
<br>
<br>
<a class="moz-txt-link-abbreviated" href="mailto:tomtro13@gmail.com">tomtro13@gmail.com</a> wrote:
<blockquote cite="mid:i4gsne$acm$1@build.eclipse.org" type="cite">Hi
there!
<br>
<br>
<br>
<br>
<br>
<br>
some enlightenment. :) <br>
<br>
<br>
<br>
import ...
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
resourceSet.getPackageRegistry().put(<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/uml2/2.0.0/UML">"http://www.eclipse.org/uml2/2.0.0/UML"</a>,
<br>
resourceSet.getPackageRegistry().put(<a class="moz-txt-link-rfc2396E" href="http://schema.omg.org/spec/UML/2.0">"http://schema.omg.org/spec/UML/2.0"</a>,
<br>
resourceSet.getPackageRegistry().put(<a class="moz-txt-link-rfc2396E" href="http://schema.omg.org/spec/UML/2.1">"http://schema.omg.org/spec/UML/2.1"</a>,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
URI uri =
URI.createURI(<a class="moz-txt-link-rfc2396E" href=" jar:file:/ABS_PATH_TO_JAR/org.eclipse.uml2.uml.resources_3.1 .0.v201005031530.jar!/ ">" jar:file:/ABS_PATH_TO_JAR/org.eclipse.uml2.uml.resources_3.1 .0.v201005031530.jar!/ "</a>);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
URI profilePath =
<br>
true);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
// THIS LEADS TO EMPTY LIST <br>
<br>
stereotypes)");
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------070907070000030103040600--
Current Time: Fri Jul 25 20:38:49 EDT 2025
Powered by FUDForum. Page generated in 0.07495 seconds
