connecting to kdb [message #553399] |
Tue, 17 August 2010 08:16  |
I want to connect to a kdb database but having no luck.
KDB offers both web based connection or jdbc but I can't get it working either. So far I have downloaded jdbc.jar from kx but I get the following error:
Could not connect to asd.
Error creating ODA Connection Factory connection to asd. (Error: There is an error in get connection, No suitable driver found for jdbc:kx://t[hostnae]:[port].)
There is an error in get connection, No suitable driver found for jdbc:kx://[hostname]:[port].
I guess that my connection string is bad or else the jdbc.jar is not the correect one...
Anyway please share with me how I can connect to a kdb database.
Thank you!
Re: connecting to kdb [message #553747 is a reply to message #553553] |
Wed, 18 August 2010 12:11   |
Where do you specify the db at?
Jason
On 8/17/2010 7:44 PM, ivan wrote:
> Jason, thank you for the reply. I have checked that the driver is indeed
> copied as follows:
> Directory of C:\Program
> Files\eclipse\plugins\org.eclipse.birt.report.data.oda.
> jdbc_2.6.0.v20100524\drivers
> 17/08/2010 08:20 PM <DIR> .
> 17/08/2010 08:20 PM <DIR> ..
> 17/08/2010 08:20 PM 41,358 jdbc.jar
> 13/08/2010 09:53 AM 173,714 nzjdbc.jar
> 12/08/2010 11:59 PM 1,996,228 ojdbc5.jar
> 13/08/2010 08:12 AM 2,111,220 ojdbc6.jar
> 09/06/2010 08:07 PM 80 readme.txt
> Also, I had the connection string from the below site:
> http://www.kx.com/a/kdb/connect/jdbc/jdbc.txt
>> jdbc:kx://host[:port] ('kx' is a registered sub-domain.)
FUDForum. Page generated in 0.17845 seconds
