java.sql.Statement has been closed strangely when inner joining 2 datasets [message #553357] |
Tue, 17 August 2010 05:17  |
Hi friends,
Our company uses DataDirect drivers for accessing most of the popular databases. We also integrated those drivers into birt designer. We created a plugin extending org.eclipse.birt.report.data.oda.jdbc.driverinfo.
But I met a curious issue which I think it may be due to the datadirect driver. because I could not recreate the issue with database-provided driver.
Here are the steps to recreate the issue:
1.Create a birt report with two datasources(using datadirect driver) which must point to different database with the same type. That means use the same driver. You can use either two Oracle databases or two DB2 databases or two SQLSERVER databases.
Datasource1:
rkyoem.jdbc.oracle.OracleDriver (Data Direct Driver for Oracle)
jdbc:rkyoem:oracle://machine1:1521;SID=TEST
scott/tiger
Datasource2:
jdbc:rkyoem:oracle://machine1:1521;SID=ORCL
scott/tiger
2.Create two datasets based on the above datasources.
DataSet1
SQL: SELECT 'AAA' AS TEST FROM DEPT.(preview successfully. This sql can return 4 rows with the same value 'AAA').
DataSet2
SQL: SELECT 'AAA' AS ORCL FROM DEPT.(preview successfully. This sql can return 4 rows with the same value 'AAA').
3.Create a Joint Data Set(inner join) with the above datasets. join them by their columns TEST AND ORCL.
4.Click the "preview results" in the dataset wizard page. You will get the follow error:
!ENTRY org.eclipse.birt.data 4 1001 2010-08-17 16:54:14.723
!MESSAGE A BIRT exception occurred.
!STACK 0
org.eclipse.birt.data.engine.core.DataException: Cannot execute the statement.
SQL statement does not return a ResultSet object.
SQL error #1: [RKYOEM][Oracle JDBC Driver]Object has been closed.
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:559)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execut e(DataSourceQuery.java:670)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:331)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:904)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:233)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:161)
at org.eclipse.birt.data.engine.impl.PreparedJointDataSourceQue ry$JointDataSetQueryExecutor.executeOdiQuery(PreparedJointDa taSourceQuery.java:629)
at org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.populateRecords(ResultSetPreviewPage.java:549)
at org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.access$3(ResultSetPreviewPage.java:543)
at org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage$5.run(ResultSetPreviewPage.java:463)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
java.sql.SQLException: [RKYOEM][Oracle JDBC Driver]Object has been closed.
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery (Statement.java:445)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.doExecuteQuery(OdaQuery.java:443)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.executeQuery(OdaQuery.java:408)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:545)
... 13 more
Caused by: java.sql.SQLException: [RKYOEM][Oracle JDBC Driver]Object has been closed.
at rkyoem.jdbc.oraclebase.BaseExceptions.createSQLException(Unk nown Source)
at rkyoem.jdbc.oraclebase.BaseExceptions.createException(Unknow n Source)
at rkyoem.jdbc.oraclebase.BaseExceptions.getException(Unknown Source)
at rkyoem.jdbc.oraclebase.BasePreparedStatement.executeQuery(Un known Source)
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery (Statement.java:441)
... 16 more
!SUBENTRY 1 org.eclipse.birt.data 1 1001 2010-08-17 16:54:14.723
!MESSAGE Plug-in Provider:Eclipse.org
!MESSAGE Plug-in Name:BIRT Data Engine
!MESSAGE Plug-in ID:org.eclipse.birt.data
!MESSAGE Version:2.3.1.v20080829
!SUBENTRY 1 org.eclipse.birt.data 4 1001 2010-08-17 16:54:14.723
!MESSAGE Error Code:odaconsumer.CannotExecuteStatement
!MESSAGE Error Message:Cannot execute the statement.
I downloaded birt source to debug where the error is. But in the debug envioroment, I get the same error(object has been closed) if I try to previewing any dataset. Even for a simple dataset, I get the follow error even I use the database-provided driver:
java.sql.SQLException: Closed Statement
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaUsing DefaultPolicy(Statement.java:352)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaData( Statement.java:294)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.doGetMetaData(OdaQuery.java:388)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.getMetaData(OdaQuery.java:356)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.g etRuntimeMetaData(PreparedStatement.java:365)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.g etProjectedColumns(PreparedStatement.java:335)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.d oGetMetaData(PreparedStatement.java:305)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:533)
Caused by: java.sql.SQLException: Closed Statement
at oracle.jdbc.driver.SQLStateMapping.newSQLException(SQLStateM apping.java:70)
at oracle.jdbc.driver.DatabaseError.newSQLException(DatabaseErr or.java:110)
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseE rror.java:171)
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseE rror.java:227)
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseE rror.java:439)
at oracle.jdbc.driver.OracleClosedStatement.executeQuery(Oracle ClosedStatement.java:2282)
at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQue ry(OraclePreparedStatementWrapper.java:1202)
... 17 more
I do not know the reason. From the stack, I believe it is not plugin's problem. So, I am not able to find the issue by debuging birt. Does anyone have suggestion on it? Any feedback is welcome !
[Updated on: Tue, 17 August 2010 05:22] by Moderator
Re: java.sql.Statement has been closed strangely when inner joining 2 datasets [message #553980 is a reply to message #553869] |
Thu, 19 August 2010 10:53  |
Glad to hear.
On 8/19/2010 5:05 AM, Ricky wrote:
> Thank you jason.
> I finally found the issue exists in our extension. Your guess was right.
> I do not know why the spy log was ok yesterday but has exception today.
> From the log, there is a connection was closed sometime by our code but
> later birt used the statement created by the closed connection. That's
> reason. The database-provided drivers not having his problem are because
> they are not integrated with our plugin(extension).
> We explicitly close the connection in our code.
> We have a class in our extension which implements
> org.eclipse.birt.report.data.oda.jdbc.IConnectionFactory.
> The getConnection method is coded below:
> // Check if the connection is open
> if (i_connection != null && !i_connection.isClosed())
> // We need to close the connection as it causes problems at times
> c_log.info(" Closing connection object ");
> i_connection.close();//We explicitly close the connection here, but
> someone add a comment saying this should be done. I need to investigate
> why he did this.
> // Establish a connection
> createConnection(driverClass, url, connectionProperties);
> if (c_log.isInfoEnabled())
> c_log.info("Established connection to the Oracle server : "
> + i_connection);
> return i_conection;
> -Ricky
FUDForum. Page generated in 0.08685 seconds
