[XPAND] Problems with getting started with defining extension [message #553116] |
Mon, 16 August 2010 09:59  |
I am still new in generating text via Xpand. I want to use java Code in my Template. For this I implemented the following java class
public class Helper
public static String ReplaceWS(String s)
return s.replace(' ', '_');
Then I defined and extension class called GeneratorExtension.ext, with the following content
«IMPORT autoMaisDimension»
java.lang.String ReplaceWS(String s) :
JAVA Helper.ReplaceWS();
In my template file, I use this lines to call the code:
«EXTENSION GeneratorExtension»
«DEFINE csClass FOR Dimension»
«ReplaceWS("Hello World")»
I get the following error.
828 INFO CompositeComponent - Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/
1219 ERROR AbstractExpressionsUsingWorkflowComponent - Error in Component of type org.eclipse.xpand2.Generator:
EvaluationException : mismatched input '«' expecting EOF on line 1
GeneratateDimension.xpt[469,24] on line 24 'ReplaceWS("Hello World")'
[23,45] on line 1 'EXPAND GeneratateDimension::csClass FOR model'
1219 ERROR WorkflowRunner - Workflow interrupted. Reason: mismatched input '«' expecting EOF on line 1
1219 ERROR WorkflowRunner - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: ReplaceWS("Hello World"); Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1219 ERROR WorkflowRunner - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: EXPRESSION: ReplaceWS("Hello World"); Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1219 ERROR WorkflowRunner - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: org.eclipse.internal.xpand2.ast.FileStatement@1581593; Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1219 ERROR WorkflowRunner - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: csClass : Dimension; Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1219 ERROR WorkflowRunner - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: EXPAND GeneratateDimension::csClass FOR model; Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
Any idea what I made wrong? Do I have to define my extension in the workflow file?
Thanks a lot
Yvette
Re: [XPAND] Problems with getting started with defining extension [message #559451 is a reply to message #553116] |
Thu, 16 September 2010 12:33  |
Originally posted by: till.tillamma.de
comment below.
Till
On 08/16/2010 03:59 PM, Yvette wrote:
> Hello,
> public class Helper
As far as i know there is no use of the Guilletmots in an extension. The
correct Syntax would be:
import autoMaisDimension;
> java.lang.String ReplaceWS(String s) : JAVA Helper.ReplaceWS();
> Component of type org.eclipse.xpand2.Generator: EvaluationException :
> on line 1(Element:
> model' => src-gen/)
> workflow file?
> Thanks a lot
> Yvette
FUDForum. Page generated in 0.06394 seconds
