Home » Modeling » M2T (model-to-text transformation) » [XPAND] Problems with getting started with defining extension
[XPAND] Problems with getting started with defining extension [message #553116] Mon, 16 August 2010 09:59 Go to next message
I am still new in generating text via Xpand. I want to use java Code in my Template. For this I implemented the following java class
public class Helper
	public static String ReplaceWS(String s)
		return s.replace(' ', '_');
Then I defined and extension class called GeneratorExtension.ext, with the following content
«IMPORT autoMaisDimension»
java.lang.String ReplaceWS(String s) :
   JAVA Helper.ReplaceWS();
In my template file, I use this lines to call the code:
«EXTENSION GeneratorExtension»
«DEFINE csClass FOR Dimension»
«ReplaceWS("Hello World")»
I get the following error.
828  INFO  CompositeComponent - Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/
1219 ERROR AbstractExpressionsUsingWorkflowComponent - Error in Component  of type org.eclipse.xpand2.Generator:
	EvaluationException : mismatched input '«' expecting EOF on line 1
	GeneratateDimension.xpt[469,24] on line 24 'ReplaceWS("Hello World")'
	[23,45] on line 1 'EXPAND GeneratateDimension::csClass FOR model'
1219 ERROR WorkflowRunner     - Workflow interrupted. Reason: mismatched input '«' expecting EOF on line 1
1219 ERROR WorkflowRunner     - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: ReplaceWS("Hello World"); Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1219 ERROR WorkflowRunner     - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: EXPRESSION: ReplaceWS("Hello World"); Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1219 ERROR WorkflowRunner     - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: org.eclipse.internal.xpand2.ast.FileStatement@1581593; Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1219 ERROR WorkflowRunner     - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: csClass : Dimension; Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1219 ERROR WorkflowRunner     - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: EXPAND GeneratateDimension::csClass FOR model; Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
Any idea what I made wrong? Do I have to define my extension in the workflow file?
Thanks a lot
Yvette
Re: [XPAND] Problems with getting started with defining extension [message #553132 is a reply to message #553116] Mon, 16 August 2010 10:31 Go to previous messageGo to next message
your extension has a totally wrong syntax. have a look into the docs.
it works with this extension:
   JAVA Helper.ReplaceWS(java.lang.String);
Christian
Re: [XPAND] Problems with getting started with defining extension [message #553144 is a reply to message #553132] Mon, 16 August 2010 10:41 Go to previous messageGo to next message
Thanks Christian,
do mean this doc http://www.openarchitectureware.org/pub/documentation/4.3.1/ html/contents/core_reference.html ?
But the change leads to the same error
Re: [XPAND] Problems with getting started with defining extension [message #553154 is a reply to message #553144] Mon, 16 August 2010 11:05 Go to previous messageGo to next message
yes i mean the oaw docs or the newer ones at eclipse http://help.eclipse.org/helios/index.jsp (Section Xpand Docu)
Have you verified that the template works when leaving out the extension? I Tried it with the project created by the sample wizard and it works.
Christian
Re: [XPAND] Problems with getting started with defining extension [message #553173 is a reply to message #553116] Mon, 16 August 2010 11:26 Go to previous messageGo to next message
Hi Christian,
thanks a lot. I tried it without the extension and it works fine.
But it might be something else, I think the error message is quite strange:
	GeneratateDimension.xpt[470,24] on line 25 'ReplaceWS("Hello World")'
1328 ERROR WorkflowRunner     - Workflow interrupted. Reason: mismatched input '«' expecting EOF on line 1
1328 ERROR WorkflowRunner     - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: ReplaceWS("Hello World"); Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1328 ERROR WorkflowRunner     - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: EXPRESSION: ReplaceWS("Hello World"); Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1328 ERROR WorkflowRunner     - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: org.eclipse.internal.xpand2.ast.FileStatement@1fe1feb; Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1328 ERROR WorkflowRunner     - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: csClass : Dimension; Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
1328 ERROR WorkflowRunner     - [ERROR]: mismatched input '«' expecting EOF on line 1(Element: EXPAND GeneratateDimension::csClass FOR model; Reported by: Generator: generating 'GeneratateDimension::csClass FOR model' => src-gen/)
Encoding problems?
Thanks Yvette
[Updated on: Mon, 16 August 2010 11:27] by Moderator
Re: [XPAND] Problems with getting started with defining extension [message #553175 is a reply to message #553173] Mon, 16 August 2010 11:31 Go to previous messageGo to next message
can you post a bit more of your template - maybe the place where you call the extension makes no sense?
Christian
Re: [XPAND] Problems with getting started with defining extension [message #559451 is a reply to message #553116] Thu, 16 September 2010 12:33 Go to previous message
Originally posted by: till.tillamma.de
comment below.
Till
On 08/16/2010 03:59 PM, Yvette wrote:
> Hello,
> public class Helper
As far as i know there is no use of the Guilletmots in an extension. The
correct Syntax would be:
import autoMaisDimension;
> java.lang.String ReplaceWS(String s) : JAVA Helper.ReplaceWS();
> Component of type org.eclipse.xpand2.Generator: EvaluationException :
> on line 1(Element:
> model' => src-gen/)
> workflow file?
> Thanks a lot
> Yvette
Previous Topic:[xpand] problem calling xpand from Java
Next Topic:InstantiationException while assigning vaiables
Current Time: Tue Sep 16 21:46:54 EDT 2025
Powered by FUDForum. Page generated in 0.03389 seconds
