Home » Modeling » OCL » [OCLinEcore] Resolving attributes in OCL Constraints(Resolving attributes across package boundaries)
[OCLinEcore] Resolving attributes in OCL Constraints [message #551134] Thu, 05 August 2010 07:26 Go to next message
I have a problem with the OCLinEcore-Editor. The editor is not able to resolve attributes in OCL Constraints if the attribute is specified in a different package than the OCL Constraint.
I attached two examples:
-----WORKING EXAMPLE----------------------------------------------------------------------
-- This is the working example.
import ecore : 'http://www.eclipse.org/emf/2002/Ecore#/';
package tutorial : tut = 'http://www.eclipse.org/mdt/ocl/oclinecore/tutorial'
  class NamedElement
    attribute name : String;
  class Parameter extends NamedElement
  	property _'signature'#parameters : Signature[1];
  class Signature
  	invariant parameterMustHaveUniqueNames: self.parameters->isUnique(p:Parameter | p.name);
	property parameters#_'signature' : Parameter[0..*] { composes };
-----NOT WORKING----------------------------------------------------------------------
-- This does not work. The reference p.name in the OCL constraint cannot be resolved.
-- For 'name', the OCLinEcore Editor shows the following error:
-- "Couldn't resolve reference to NamedElementCS 'name'".
  package core : cre = 'http://www.eclipse.org/mdt/ocl/oclinecore/tutorial/core' {
	class NamedElement
  class Parameter extends core::NamedElement
  class Signature
(If these examples are copied to a bugzilla bug report, I would be really glad if my email address is NOT cited....)
Thank you very much!
Kind Regards.
Re: [OCLinEcore] Resolving attributes in OCL Constraints [message #551222 is a reply to message #551134] Thu, 05 August 2010 12:11 Go to previous messageGo to next message
Hi Fabian
Thanks. This looks like a variant of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321171 that yoiu reported
last week.
Sorry about the email pasting; if you raised bugzillas for bugs that
you've done such a good job of demonstrating, I wouldn;t need to
identify the origin.
Ed Willink
> -----WORKING
> EXAMPLE----------------------------------------------------- -----------------
> class NamedElement
> class Signature {
> self.parameters->isUnique(p:Parameter | p.name); property
> -----NOT
> WORKING----------------------------------------------------- -----------------
> be resolved. -- For 'name', the OCLinEcore Editor shows the following
> error: -- "Couldn't resolve reference to NamedElementCS 'name'".
> class NamedElement
> class Signature {
Re: [OCLinEcore] Resolving attributes in OCL Constraints [message #551241 is a reply to message #551222] Thu, 05 August 2010 13:17 Go to previous messageGo to next message
Hi Fabian
> last week.
Very similar, but in a different source file, so raised as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321903 where you can find
a patch.
Thanks for the excellent repro.
Ed Willink
Re: [OCLinEcore] Resolving attributes in OCL Constraints [message #552993 is a reply to message #551134] Sun, 15 August 2010 15:37 Go to previous messageGo to next message
In CompleteOCL Edit in Eclipse 3.6, I have a very similar error message for an OCL def (definition). Even within the same context, the def name cannot be resolved. See this simple example:
context AnyType
def: x: Integer = 1
inv test: x = 1
There error is: Couldn't resolve reference to NamedElementCS 'x'.
I notice that the distributed example has the same error commented out.
See RoyalAndLoyal.ocl, line 211:
--inv invariant_noEarnings2 :
-- programs.isSaving implies account->isEmpty()
The example refers to programs, where its type defines (using def) isSaving. Uncommenting the original invariant shows the same error.
Use of def's is common for complex OCL. I hope this can be fixed soon. Now, I still using QVT's OCL editor!
Re: [OCLinEcore] Resolving attributes in OCL Constraints [message #552994 is a reply to message #552993] Sun, 15 August 2010 16:22 Go to previous messageGo to next message
Hi W
The plan was to migrate the M2M/QVTd editor to MDT/OCL for Helios, but
we hit very late IP problems because IMP has not been through a release
review. We therefore had to do a late redevelopment using Xtext. This
will be much better, but currently it has only partial functionality.
The main Xtext emphasis was on OCLinEcore to support the OCL delegates.
It is hopefully more complete. Complete OCL is sort of just there.
It is intended to produce an MDT/OCL 3.1.0 release in October in time
for Eclipse Summit Europe. I hope the Xtext editors will be more
comprehensive at that point.
Sorry for the trouble. Certainly if you're happy with the M2M/QVTd
editor stick with it.
Ed Willink
> context AnyType
> def: x: Integer = 1
> inv test: x = 1
Re: [OCLinEcore] Resolving attributes in OCL Constraints [message #753898 is a reply to message #552994] Sun, 30 October 2011 07:59 Go to previous messageGo to next message
Hi....i'm using essentialocl in my grammar and I receive the same error ... how to fix it?
Re: [OCLinEcore] Resolving attributes in OCL Constraints [message #753919 is a reply to message #753898] Sun, 30 October 2011 11:18 Go to previous messageGo to next message
It cannot be the same error since
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321171#c4
claims that it was fixed in 3.0.1 and 3.1.0.
If you have a new error please raise a Bugzilla with a simple repro.
Ed Willink
Re: [OCLinEcore] Resolving attributes in OCL Constraints [message #753920 is a reply to message #753919] Sun, 30 October 2011 11:27 Go to previous messageGo to next message
hi Edward ... this is my grammar snippet on ocl...
Filter:
"#" specification=SpecificationCS
SpecificationCS returns essentialocl::ExpSpecificationCS:
ownedExpression=ExpCS | exprString=UNQUOTED_STRING
terminal UNQUOTED_STRING: // Never forward parsed; just provides a placeholder
'£$%^£$%^' // for reverse serialisation of embedded OCL
trying to type an ocl expression like:
# self.name
i receive: Couldn't resolve reference to NamedElement 'name'.
Re: [OCLinEcore] Resolving attributes in OCL Constraints [message #753924 is a reply to message #753920] Sun, 30 October 2011 12:18 Go to previous messageGo to next message
Please read the replies that you receive.
I wrote:
"claims that it was fixed in 3.0.1 and 3.1.0.
If you have a new error please raise a Bugzilla with a simple repro. "
You have failed to
a) identify that you are using 3.0.1 and 3.1.0.
b) raise a Bugzilla
c) provide a repro
A repro is something that can be reproduyced with a minimal amount of
effort.
Just about all your queries require significant development and
telepathy to interpret.
It is clear that you are attempting to do something way beyond your
capabilities.
Please attempt to learn the facilities of Eclipse gradually. You cannot
hope to start by tackling extension of code that is not ready for
extension when you have no familiarity with OCL, Xtext, EMF, Eclipse or
even debugging.
Would you try to learn biology and chemistry by studying the human
genome as your first example?
Ed Willink
> Filter: "#" specification=SpecificationCS
> placeholder
> embedded OCL ;
> # self.name
Re: [OCLinEcore] Resolving attributes in OCL Constraints [message #754014 is a reply to message #753924] Mon, 31 October 2011 09:17 Go to previous message
I opened a new bug...(if it's a bug)...like you suggested me... i was trying to learn and the forum is also a good tool to do it..
kind regards
Previous Topic:describe mutiple classes as OCL
Next Topic:real sum approximation problem
Current Time: Sun Jul 20 20:24:10 EDT 2025
Powered by FUDForum. Page generated in 0.05336 seconds
