Home » Modeling » Papyrus » Realizing Constraints
Realizing Constraints [message #552954] Sun, 15 August 2010 01:45 Go to next message
I'm trying to emulate Slide 44 of
http://www.eclipse.org/modeling/mdt/uml2/docs/presentations/ EclipseCon2008_LongTalk_NewFeaturesOfUML2_files/frame.htm
using Papyrus.
The support for Constraints seems very counter-intuitive.
a) A Constraint must be dropped as a top-level diagram element;
a Properties entry does not seem to be present.
b) The Constraint can then be given a Context from the Properties
drop-down; an edge does not seem to be possible.
c) The Properties offers a large 'Constrained Elements' entry field,
but only a small Specification field.
d) The Specification field allows only selection of literals already
defined; no ability to create a new OCL expression.
e) Giving an operation constraint a BodyCondition role is not possible
using e.g. a <<body>> sterotype.
f) The Specification is not displayed within the {} of the Constraint.
It seems that Papyrus provides some creation help through the Constraint
node but full entry requires detailed understanding of UML and use of
the UML2 model level editing.
Am I missing something?
Ed Willink
Re: Realizing Constraints [message #553088 is a reply to message #552954] Mon, 16 August 2010 08:47 Go to previous messageGo to next message
I thinks that these problems comes from a lack of functionnality in papyrus.
A value specification can be attached to a constraint. By defaut this is a
string expresssion.
It could more interesting to attached a opaque expression and change if the
user want the kind of the value expression.
If not, in papyrus you put a constraint everywhere and display it in the
diagram.
if you want add an edge, you can use 'link' tootip. It will fill the feature
constrained element.
Patrick
"Ed Willink" <ed@willink.me.uk> a
Re: Realizing Constraints [message #553337 is a reply to message #553088] Tue, 17 August 2010 04:16 Go to previous messageGo to next message
I thank you for your report, and I think that ti is an important
funtionality
Could you add your enhancement in the bugzilla.
thanks,
Patrick
"Patrick Tessier" <Patrick.Tessier@cea.fr> a
Re: Realizing Constraints [message #553504 is a reply to message #553337] Tue, 17 August 2010 13:07 Go to previous message
Hi Patrick
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=322933
Ed Willink
> funtionality
> thanks,
> Patrick
> "Patrick Tessier"<Patrick.Tessier@cea.fr> a écrit dans le message de news:
> i4bc23$lfc$1@build.eclipse.org...
>> Hi,
>> papyrus.
>> string expresssion.
>> the user want the kind of the value expression.
>> diagram.
>> feature constrained element.
>> Patrick
>> "Ed Willink"<ed@willink.me.uk> a écrit dans le message de news:
>> i47ut9$ono$1@build.eclipse.org...
>>> Hi
>>> using Papyrus.
>>> using e.g. a<<body>> sterotype.
>>> node but full entry requires detailed understanding of UML and use of the
>>> Regards
>>> Ed Willink
Re: Realizing Constraints [message #606020 is a reply to message #552954] Mon, 16 August 2010 08:47 Go to previous message
string expresssion.
diagram.
Patrick
Re: Realizing Constraints [message #606023 is a reply to message #553088] Tue, 17 August 2010 04:16 Go to previous message
funtionality
thanks,
Patrick
Re: Realizing Constraints [message #606027 is a reply to message #553337] Tue, 17 August 2010 13:07 Go to previous message
Hi Patrick
Ed Willink
> funtionality
> thanks,
> Patrick
>> Hi,
>> papyrus.
>> string expresssion.
>> diagram.
>> Patrick
>>> Hi
>>> using Papyrus.
>>> Regards
>>> Ed Willink
Previous Topic:Realizing Constraints
Next Topic:Papyrus Extensions
Current Time: Fri Jul 18 02:17:56 EDT 2025
Powered by FUDForum. Page generated in 0.10930 seconds
