Birt 2.6.0 Viewer in RCP Application [message #552868] |
Fri, 13 August 2010 18:19  |
I'm trying to move from Eclipse 3.4.2 / Birt 2.3.2 to Eclipse 3.6.0 / Birt 2.6.0. I have run into a snag when I attempt to use the viewer in my RCP application.
My install is a clean Eclipse 3.6.0 with Birt 2.6.0 install using the update site. I created a new workspace and imported all of my code. I brought the report designs into the designer and it converted them to the new version format. I did some rudimentary tests in the Report Perspective.
My app has a ReportView that extends ViewPart. This is where I run and render the report. All of my code is unchanged. Only the Eclipse and Birt plugins have. When I invoke run() method of IRunAndRenderTask, I get an EngineException. Stack trace below. I'm wondering if anyone else has seen anything like this. I found this, https://bugs.eclipse.org/bugs/show_bug.cgi?id=292109 , which seems to apply, but I can't find out what is causing the BirtException. Any ideas?
Aug 13, 2010 3:01:36 PM org.eclipse.birt.report.engine.script.internal.ScriptExecuto r addException
WARNING: null
org.eclipse.birt.report.engine.api.EngineException
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:158)
at org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleInitialize(ReportScriptExecutor.java:53)
at org.eclipse.birt.report.engine.api.impl.EngineTask.loadDesig n(EngineTask.java:1637)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:95)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:75)
at com.zhone.rtl.tpm.rcp.views.ReportView.previewReport(ReportV iew.java:194)
at com.zhone.rtl.tpm.rcp.views.ReportView.createPartControl(Rep ortView.java:65)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:375)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:2245)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:1071)
at org.eclipse.ui.internal.WorkbenchPage$20.run(WorkbenchPage.j ava:3822)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3819)
at com.zhone.rtl.tpm.rcp.command.handlers.ReportViewHandler.exe cute(ReportViewHandler.java:96)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:820)
at org.eclipse.ui.menus.CommandContributionItem.access$19(Comma ndContributionItem.java:806)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(C ommandContributionItem.java:796)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3552)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3171)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at com.zhone.rtl.tpm.rcp.Application.start(Application.java:25)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: org.eclipse.birt.core.exception.BirtException
at org.eclipse.birt.core.script.ScriptContext.getScriptEngine(S criptContext.java:225)
at org.eclipse.birt.core.script.ScriptContext.compile(ScriptCon text.java:145)
at org.eclipse.birt.report.engine.executor.ExecutionContext.com pile(ExecutionContext.java:736)
at org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:670)
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleScriptInternal(ScriptExecutor.java:61)
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleScript(ScriptExecutor.java:48)
at org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleInitialize(ReportScriptExecutor.java:44)
... 47 more
Aug 13, 2010 3:01:37 PM org.eclipse.birt.report.engine.script.internal.ScriptExecuto r addException
WARNING: null
at org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleBeforeFactory(ReportScriptExecutor.java:82)
at org.eclipse.birt.report.engine.api.impl.EngineTask.startFact ory(EngineTask.java:1669)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:97)
at org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleBeforeFactory(ReportScriptExecutor.java:74)
... 47 more
org.eclipse.birt.report.engine.api.EngineException: cant create data engine
at org.eclipse.birt.report.engine.executor.ExecutionContext.ope nDataEngine(ExecutionContext.java:848)
at org.eclipse.birt.report.engine.executor.ExecutionContext.get DataEngine(ExecutionContext.java:860)
at org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:124)
at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportExecutor.execute(WrappedReportExecutor.java:60)
at org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplciateReportExecutor.execute(SuppressDuplciateReportExec utor.java:42)
at org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportExecutor.execute(LocalizedReportExecutor.java:61)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:170)
at org.eclipse.birt.report.engine.adapter.ModelDteApiAdapter.<init >(ModelDteApiAdapter.java:176)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.<init >(AbstractDataEngine.java:107)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.<init >(DteDataEngine.java:85)
at org.eclipse.birt.report.engine.data.DataEngineFactory.create DataEngine(DataEngineFactory.java:100)
at org.eclipse.birt.report.engine.executor.ExecutionContext.ope nDataEngine(ExecutionContext.java:843)
... 52 more
FUDForum. Page generated in 0.26511 seconds
