Home » Eclipse Projects » Rich Client Platform (RCP) » AntRunner fails in RCP application
AntRunner fails in RCP application [message #550672] Wed, 04 August 2010 02:34 Go to next message
I tried to call AntRunner from an RCP application, but it fails with the stacktrace below.
at org.eclipse.ant.core.AntCorePreferences.findHighestAntVersio n(AntCorePreferences.java:491)
Does the ant.core plugin contain an ant installation?
But it even failed when I set anthome.
AntRunner ant = new AntRunner();
ant.setAntHome("D:/java/apache-ant-1.8.1");
URL url = new URL("platform:/plugin/org.eclipse.SamplePlugin/mybuild.xml");
URL fileURL = FileLocator.toFileURL(url);
File f = new File(fileURL.toURI());
ant.setBuildFileLocation(f.toString());
ant.run();
org.eclipse.core.runtime.CoreException: BUILD FAILED
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:388)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:475)
at org.eclipse.SampleHandler.execute(RunCoxHandler.java:97)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:468)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:786)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:885)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:567)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:508)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:123)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:125 3)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1103 )
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1099 )
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1508)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4268)
at org.eclipse.swt.widgets.ToolBar.WM_CHAR(ToolBar.java:1202)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4160 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4886 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 59)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3655)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at org.eclipse.sample.rcp.Application.start(Application.java:31 )
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
at org.eclipse.ant.core.AntCorePreferences.getDefaultAntHomeEnt ries(AntCorePreferences.java:440)
at org.eclipse.ant.core.AntCorePreferences.getDefaultAntHome(An tCorePreferences.java:304)
at org.eclipse.ant.core.AntCorePreferences.restoreAntHome(AntCo rePreferences.java:292)
at org.eclipse.ant.core.AntCorePreferences.restoreCustomObjects (AntCorePreferences.java:197)
at org.eclipse.ant.core.AntCorePreferences.<init>(AntCorePreferences.java:163)
at org.eclipse.ant.core.AntCorePlugin.getPreferences(AntCorePlu gin.java:221)
at org.eclipse.ant.core.AntCorePlugin.getNewClassLoader(AntCore Plugin.java:252)
at org.eclipse.ant.core.AntRunner.getClassLoader(AntRunner.java :523)
at org.eclipse.ant.core.AntRunner.getInternalAntRunner(AntRunne r.java:396)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:323)
... 48 more
Re: AntRunner fails in RCP application [message #552830 is a reply to message #550672] Fri, 13 August 2010 12:13 Go to previous message
The ant.core plugin does not contain an ant installation. The
org.apache.ant bundle is the ant install.
The NPE here seems to be setting the default preferences which expects the
ant install to be part of the osgi runtime.
You can just include org.apache.ant in your rcp product, or if you want to
use an external ant, it looks like you will need to set some preferences
before calling the ant runner.
I would suggest getting the org.eclipse.ant.core source and looking at
AntCorePreferences.restorCustomObjects to see the preferences it is reading
and set those as appropriate.
-Andrew
Juergen Weber wrote:
> stacktrace below. Caused by: java.lang.NullPointerException
> URL url = new
> URL("platform:/plugin/org.eclipse.SamplePlugin/mybuild.xml"); URL fileURL
> = FileLocator.toFileURL(url); File f = new File(fileURL.toURI());
> ant.run();
> rProxy.java:293)
> (Realm.java:332)
> bench.java:663)
> tarter.java:369)
> tarter.java:179) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
> Method)
> ssorImpl.java:39)
> thodAccessorImpl.java:25) at
> java.lang.reflect.Method.invoke(Method.java:597)
> (AntCorePreferences.java:197) at
> gin.java:221)
> Plugin.java:252)
> r.java:396) at org.eclipse.ant.core.AntRunner.run(AntRunner.java:323)
> ... 48 more
Previous Topic:product run error
Next Topic:Where are the branding infos taken from: .product or plugin.xml?
Current Time: Sat Jul 19 18:15:12 EDT 2025
Powered by FUDForum. Page generated in 0.03760 seconds
