Home » Language IDEs » Java Development Tools (JDT) » Eclipse Hot Code Replace failed(Hot code replace failed - class version number not supported by VM )
Eclipse Hot Code Replace failed [message #552651] Fri, 13 August 2010 00:04 Go to next message
I am using
Eclipse Platform 3.5.2, Eclipse IDE for Java EE Developers 1.2.2.20100217-2310, Build id: 20100218-1602
for some 6 months now. I am recently trying to do the Hot code replace in debug perspective when connecting to a remote server.
I am able to do remote debug without any problems. Once i try to change code during debugging the remote server, and when i tried to compile the class, iam getting a error that hot code replace is failing.
Below is the full description of the error.
The current target virtual machine[Java HotSpot(TM) Server VM]from launch was unable to replace the running code with the code in the workspace.
It is safer to continue running the application, but you may notice discrepancies when debugging this application.
Reason:
Details:
java.lang.UnsupportedClassVersionError
i am using weblogic 9.2 which connects to a remote data server, which iam trying to debug and do hot code replace.
Please help me fix this problem so i can do the hot code replace, as doing build for every small code change & deploying the jar file to the remote server, restarting the remote server, restarting weblogic and testing is very painful! Sad
Immediate help would be very helpful as iam in the middle of a important release delivery. This should be a very familiar error, as many of you may be using the eclipse's hot code replace!
[Updated on: Fri, 13 August 2010 00:06] by Moderator
Re: Eclipse Hot Code Replace failed [message #552657 is a reply to message #552651] Fri, 13 August 2010 01:12 Go to previous messageGo to next message
On 8/13/2010 9:34 AM, Anuradha wrote:
> I am using Eclipse Platform 3.5.2, Eclipse IDE for Java EE Developers
> workspace.
Hot code replace depends on the VM you are using, and not all sorts of
changes work
http://wiki.eclipse.org/FAQ_What_is_hot_code_replace%3F
> Reason:
> testing is very painful! :(
> Details:
From
http://geekexplains.blogspot.com/2009/01/javalangunsupported classversionerror.html
"This happens in the cases when a higher version of Java Compiler is
used to generate the class file than the JVM version which is used to
execute that class file."
Re: Eclipse Hot Code Replace failed [message #552792 is a reply to message #552657] Fri, 13 August 2010 10:21 Go to previous messageGo to next message
According to your comment,
can you suggest me what should i do to correct this problem?
Re: Eclipse Hot Code Replace failed [message #552857 is a reply to message #552792] Fri, 13 August 2010 14:46 Go to previous messageGo to next message
"Anuradha" <anuradha.jayaraman@jpmchase.com> wrote in message
news:i43kea$qt$1@build.eclipse.org...
Change the compiler compliance level for you project to a level supported by
the web server.
Re: Eclipse Hot Code Replace failed [message #554689 is a reply to message #552651] Tue, 24 August 2010 02:24 Go to previous message
Previous Topic:error on importing android package
Next Topic:JDT source code plug-ins in Helios
Current Time: Wed Nov 05 15:20:23 EST 2025
Powered by FUDForum. Page generated in 0.06757 seconds
