Text label clipped when exporting to image [message #552677] |
Fri, 13 August 2010 03:27  |
Originally posted by: koen.yskout.cs.kuleuven.be
I'm not entirely sure where to post this, but I suppose this is a
GEF/Draw2d issue...
When exporting a diagram (e.g., an Ecore diagram) to an image (using the
popup menu File > Save as image file), the text labels (especially for
longer names) are clipped at the right, so that one or more letters
disappear in the final image. I see this with PNG, SVG and PDF (didn't
test the others). The diagram appears perfectly fine in the editor.
When exporting to SVG, and editing the resulting SVG in inkscape, I saw
that each label has an associated clip path that apparently is too small.
Is this a known problem, and/or is there a workaround?
(I'm using the Helios release on Ubuntu, GEF/Draw2d version 3.6.0)
Kind regards,
Koen
Re: Text label clipped when exporting to image [message #552688 is a reply to message #552677] |
Fri, 13 August 2010 04:02   |
Apparently this problem has been reported earlier for GMF
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=315028)
This problem still seems to exists in Helios, contrary to the bug report.
Koen
On 13/08/10 09:27, Koen Yskout wrote:
> GEF/Draw2d issue...
> Kind regards,
> Koen
Re: Text label clipped when exporting to image [message #637884 is a reply to message #552688] |
Tue, 09 November 2010 04:04  |
Should somebody still encounter this issue, I found out that this was
presumably caused by the configuration of my machine (Ubuntu). I had the
font resolution (System > Preference > Appearance > Fonts > Details) set
to a lower value (84 dpi) than the display resolution
($ xdpyinfo | grep resolution -> 96 dpi). Setting the font resolution
equal to the display resolution solved the problem.
Koen
> Koen
>> Hi,
>> GEF/Draw2d issue...
>> Kind regards,
>> Koen
FUDForum. Page generated in 0.03460 seconds
