Cannot open launch config (junit run) [message #549918] |
Wed, 28 July 2010 09:06  |
In my Texo eclipse.org build I get a 'cannot open launch config' for a junit test run through Buckminster. I am not sure
why this happens (the launch config file is really there):
https://build.eclipse.org/hudson/job/emft-texo-nightly/ws/bu ild/test/gen-workspace/plugins/org.eclipse.emf.texo.modelgen erator.test/HudsonModelGeneratorTest.launch
What can be all the reasons that the file can't be found?
(see the stacktrace and ant snippet below also)
org.eclipse.core.runtime.CoreException: Cannot open launch config from
org.eclipse.emf.texo.modelgenerator.test/HudsonModelGenerato rTest.launch
[java] at org.eclipse.buckminster.runtime.BuckminsterException.fromMes sage(BuckminsterException.java:57)
[java] at org.eclipse.buckminster.runtime.BuckminsterException.fromMes sage(BuckminsterException.java:53)
[java] at org.eclipse.buckminster.core.commands.Launch.internalRun(Lau nch.java:189)
[java] at org.eclipse.buckminster.junit.JUnitCommand.internalRun(JUnit Command.java:86)
[java] at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:91)
[java] at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:194)
[java] at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:3 17)
[java] at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 36)
[java] at org.eclipse.buckminster.cmdline.Headless.start(Headless.java :156)
[java] at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
[java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
[java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
[java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
[java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:45)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:37)
[java] at java.lang.reflect.Method.invoke(Method.java:599)
[java] at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
[java] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
[java] at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
[java] at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
[java] Cannot open launch config from org.eclipse.emf.texo.modelgenerator.test/HudsonModelGenerato rTest.launch
This is the part of the ant task calling this launch config:
<buckminster command="junit" workspace="${genWorkspacePath}">
<cmdargs>
<arg value="-l" />
<arg value=" org.eclipse.emf.texo.modelgenerator.test/HudsonModelGenerato rTest.launch " />
<arg value="-o" />
<arg value="${testResultsPath}/generate-results-texo-modelgenerator.xml " />
<arg value="--stdout" />
<arg value="${testResultsPath}/gen-stdout.txt" />
<arg value="--stderr" />
<arg value="${testResultsPath}/gen-stderr.txt" />
<arg value="--flatXML"/>
</cmdargs>
</buckminster>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Cannot open launch config (junit run) [message #550607 is a reply to message #550599] |
Sat, 31 July 2010 05:13   |
Hi Martin,
I agree with Achim. Since the file is physically present, the only
option I can think of is that the workspace isn't up-to-date and needs a
refresh.
One way to ensure a refresh is to issue a buckminster build on the
workspace. It stars with a full workspace refresh.
How is the workspace populated?
- thomas
On 07/31/2010 09:06 AM, Achim Demelt wrote:
> Hi Martin,
> This is a strange error indeed. I can't say for sure what causes this error.
> Here's the relevant code in Buckminster:
> IResource launchFile =
> ResourcesPlugin.getWorkspace().getRoot().findMember(launchNa me);
> if (launchFile == null || launchFile.getType() != IResource.FILE ||
> !launchFile.exists())
> throw
> BuckminsterException.fromMessage(NLS.bind(Messages.Launch_Ca nnot_open_launch_config,
> launchName));
> All of these conditions seem unlikely in your case. One thing I can think of
> is that the workspace is somehow not up-to-date.
> Can you execute the build locally? Does the error occur there, too? If so,
> you can then open the workspace in your IDE and try to locate the launch
> file there.
> HTH,
> Achim
> Martin Taal wrote:
>> Hi,
>> junit test run through Buckminster. I am not sure why this happens (the
> workspace/plugins/org.eclipse.emf.texo.modelgenerator.test/H udsonModelGeneratorTest.launch
>> at
> [org.eclipse.buckminster.runtime.BuckminsterException.fromMe ssage(BuckminsterException.java:57)
>> at
> [org.eclipse.buckminster.runtime.BuckminsterException.fromMe ssage(BuckminsterException.java:53)
>> at
> [org.eclipse.buckminster.core.commands.Launch.internalRun(La unch.java:189)
>> at
> [org.eclipse.buckminster.junit.JUnitCommand.internalRun(JUni tCommand.java:86)
>> at
> [org.eclipse.buckminster.core.commands.WorkspaceCommand.run( WorkspaceCommand.java:91)
>> at
> [org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Ab stractCommand.java:194)
>> at
>> [org.eclipse.buckminster.cmdline.Headless.run(Headless.java: 317)
>> at
>> [org.eclipse.buckminster.cmdline.Headless.run(Headless.java: 136)
>> at
>> [org.eclipse.buckminster.cmdline.Headless.start(Headless.jav a:156)
>> at
> [org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclip seAppHandle.java:196)
>> at
> [org.eclipse.core.runtime.internal.adaptor.EclipseAppLaunche r.runApplication(EclipseAppLauncher.java:110)
>> at
> [org.eclipse.core.runtime.internal.adaptor.EclipseAppLaunche r.start(EclipseAppLauncher.java:79)
>> at
> [org.eclipse.core.runtime.adaptor.EclipseStarter.run(Eclipse Starter.java:369)
>> at
> [org.eclipse.core.runtime.adaptor.EclipseStarter.run(Eclipse Starter.java:179)
>> [Method)
>> at
> [sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcc essorImpl.java:45)
>> at
> [sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingM ethodAccessorImpl.java:37)
>> at
>> [org.eclipse.equinox.launcher.Main.invokeFramework(Main.java :619)
>> [java] at
>> [java] at
> [org.eclipse.emf.texo.modelgenerator.test/HudsonModelGenerat orTest.launch
>> <cmdargs>
>> <arg value="-l" />
>> <arg
>> /> <arg value="-o" /> <arg
>> <arg value="--stdout" /> <arg value="${testResultsPath}/gen-stdout.txt" />
>> </cmdargs>
>> </buckminster>
Re: Cannot open launch config (junit run) [message #558767 is a reply to message #549918] |
Tue, 14 September 2010 07:18  |
An old thread, but I forgot to link to a solution for it. For everyone's reference, this bugzilla describes the same
problem and different causes/solutions:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=324878
gr. Martin
On 07/28/2010 03:06 PM, Martin Taal wrote:
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> <cmdargs>
> <arg value="-l" />
> <arg
> <arg value="-o" />
> </cmdargs>
> </buckminster>
The Netherlands
FUDForum. Page generated in 0.26739 seconds
