Home » Eclipse Projects » Rich Client Platform (RCP) » Errors while integrating CDT wit RCP app(NullPointerExceptions and SWTException )
Errors while integrating CDT wit RCP app [message #552530] Thu, 12 August 2010 10:18 Go to next message
I'm trying to bundle CDT along with my RCP app. RCP app runs perfectly fine when executed through IDE but fails when executed as product i.e. it throws null pointers and SWT exceptions and so on which I don't see when i run my RCP app through IDE.
As far as the RCP app is concerned, it works fine in both the cases, executed using ide or as product. But when executed as a product, CDT never works. Even if right click in Project Explorer throws SWT and NullPointer exceptions.
I have tried following things,
- handled dependencies
- validated
- have not made any change in CDT code
And here is the stack trace,
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3527)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3174)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at com.apm.vhp.mamba.Application.start(Application.java:20)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
at org.eclipse.cdt.ui.CElementSorter.compare(CElementSorter.jav a:271)
at org.eclipse.ui.navigator.CommonViewerSorter.compare(CommonVi ewerSorter.java:140)
at org.eclipse.jface.viewers.TreePathViewerSorter$1.compare(Tre ePathViewerSorter.java:105)
at java.util.Arrays.mergeSort(Arrays.java:1270)
at java.util.Arrays.sort(Arrays.java:1210)
at org.eclipse.jface.viewers.TreePathViewerSorter.sort(TreePath ViewerSorter.java:103)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildr en(AbstractTreeViewer.java:620)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:801)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:778)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:644)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:749)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitial izeTree(AbstractTreeViewer.java:1492)
at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree( TreeViewer.java:833)
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractT reeViewer.java:1476)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1422)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(Tre eViewer.java:403)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1383)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(Ab stractTreeViewer.java:1469)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:274)
at org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1664)
at org.eclipse.ui.internal.navigator.resources.actions.WorkingS etActionProvider.setWorkingSet(WorkingSetActionProvider.java :308)
at org.eclipse.ui.internal.navigator.resources.actions.WorkingS etActionProvider$3.propertyChange(WorkingSetActionProvider.j ava:223)
at org.eclipse.ui.internal.navigator.extensions.ExtensionStateM odel.firePropertyChangeEvent(ExtensionStateModel.java:135)
at org.eclipse.ui.internal.navigator.extensions.ExtensionStateM odel.setBooleanProperty(ExtensionStateModel.java:90)
at org.eclipse.ui.internal.navigator.resources.actions.WorkingS etActionProvider$4.run(WorkingSetActionProvider.java:344)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
... 23 more
Am I missing anything here?
Please provide some pointers. Stuck badly. Any help would be great.
Thanks in advance,
Vrushali.
Re: Errors while integrating CDT wit RCP app [message #552570 is a reply to message #552530] Thu, 12 August 2010 12:23 Go to previous message
I would look at the CDT source code and figure out why they are having an NPE there.
Maybe post this on the CDT newsgroup.
It could be that they are doing something to depend on the ProjectExplorer which it likely not present in your RCP app.
One open would be just to create the ProjectExplorer in your RCP app. You can look at the code and configuration in org.eclipse.ui.navigator.resources (in fact if you just include the plugin you should just get it).
Previous Topic:Help with the Project Explorer View
Next Topic:[Databinding] Dynamic UI
Current Time: Fri Jul 18 21:56:21 EDT 2025
Powered by FUDForum. Page generated in 0.18731 seconds
