java.lang.IllegalAccessError: class cannot access its superclass [message #552527] |
Thu, 12 August 2010 10:08  |
Hi all,
I have the following scenario, and I think my problem is related to osgi since in an osgiless server and in tests it is working but it breaks when running inside the RCP client.
I must extend a package-scoped class from a third-party lib so I've created the very same package in my bundle and created the extending class there. It works in non-osgi environments. So I don't know if I have to add any special header to my bundle manifest to have the access rights to the mentioned class.
I'm using Spring HttpInvokers and it happens when deserializing the response from the server within the RCP client.
com.google.common.collect.ChildrenMultimap is in my bundle and com.google.common.collect.AbstractSetMultimap which is default scope is in a separate bundle which mine depends on.
org.springframework.remoting.RemoteAccessException: Could not access HTTP invoker remote service at [http://localhost:8080/bom-server/remoting/LoginService]; nested exception is java.lang.IllegalAccessError: class com.google.common.collect.ChildrenMultimap cannot access its superclass com.google.common.collect.AbstractSetMultimap
at org.springframework.remoting.httpinvoker.HttpInvokerClientIn terceptor.convertHttpInvokerAccessException(HttpInvokerClien tInterceptor.java:211)
at org.springframework.remoting.httpinvoker.HttpInvokerClientIn terceptor.invoke(HttpInvokerClientInterceptor.java:144)
at org.springframework.aop.framework.ReflectiveMethodInvocation .proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke( JdkDynamicAopProxy.java:204)
at $Proxy9.login(Unknown Source)
at com.tc.bom.ui.dialog.LoginAndChooseAccountDialog.loginPresse d(LoginAndChooseAccountDialog.java:205)
at com.tc.bom.ui.dialog.LoginAndChooseAccountDialog.buttonPress ed(LoginAndChooseAccountDialog.java:280)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3112)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at com.tc.bom.ui.Application.login(Application.java:98)
at com.tc.bom.ui.Application.start(Application.java:74)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.lang.IllegalAccessError: class com.google.common.collect.ChildrenMultimap cannot access its superclass com.google.common.collect.AbstractSetMultimap
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:183)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:576)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:546)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:477)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:465)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:445)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:376)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.MultiSourcePackage.loadClas s(MultiSourcePackage.java:31)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:449)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:321)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
at org.springframework.osgi.util.BundleDelegatingClassLoader.fi ndClass(BundleDelegatingClassLoader.java:99)
at org.springframework.osgi.util.BundleDelegatingClassLoader.lo adClass(BundleDelegatingClassLoader.java:156)
at org.springframework.util.ClassUtils.forName(ClassUtils.java: 211)
at org.springframework.core.ConfigurableObjectInputStream.resol veClass(ConfigurableObjectInputStream.java:56)
at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream .java:1575)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.ja va:1496)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStre am.java:1732)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java :1329)
at java.io.ObjectInputStream.defaultReadFields(ObjectInputStrea m.java:1947)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.j ava:1871)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStre am.java:1753)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java: 351)
at java.util.ArrayList.readObject(ArrayList.java:593)
at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass .java:974)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.j ava:1849)
at org.springframework.remoting.httpinvoker.AbstractHttpInvoker RequestExecutor.doReadRemoteInvocationResult(AbstractHttpInv okerRequestExecutor.java:291)
at org.springframework.remoting.httpinvoker.AbstractHttpInvoker RequestExecutor.readRemoteInvocationResult(AbstractHttpInvok erRequestExecutor.java:242)
at org.springframework.remoting.httpinvoker.SimpleHttpInvokerRe questExecutor.doExecuteRequest(SimpleHttpInvokerRequestExecu tor.java:68)
at org.springframework.remoting.httpinvoker.AbstractHttpInvoker RequestExecutor.executeRequest(AbstractHttpInvokerRequestExe cutor.java:136)
at org.springframework.remoting.httpinvoker.HttpInvokerClientIn terceptor.executeRequest(HttpInvokerClientInterceptor.java:1 91)
at org.springframework.remoting.httpinvoker.HttpInvokerClientIn terceptor.executeRequest(HttpInvokerClientInterceptor.java:1 73)
at org.springframework.remoting.httpinvoker.HttpInvokerClientIn terceptor.invoke(HttpInvokerClientInterceptor.java:141)
... 28 more
Thank you very much.
Gaston.
FUDForum. Page generated in 0.04983 seconds
