Home » Eclipse Projects » P2 » Headless Update KO with update site, KO with feature export, OK with product export
Headless Update KO with update site, KO with feature export, OK with product export [message #552504] Thu, 12 August 2010 08:21 Go to next message
One more question,
I want to find the better way to provide an update to my feature based application. My application uses headless updating with the P2Util class.
I identified 3 options :
use an update site,
use the P2 repository generated during feature export (via Export > Deployable features),
use the P2 repository generated during product export.
Only the last option works with my application. Updates are not detected with the update site or the exported feature.
My tests :
product export with feature 1.0.0
plugin modification 1.0.1
feature 1.0.1
update site export with feature 1.0.1
run product 1.0.0
=> no update found
feature 1.0.1
feature 1.0.1 export
repository 1.0.1 generated during feature export used as update site
run product 1.0.0
=> no update found
feature 1.0.1
product export with feature 1.0.1
repository 1.0.1 generated during product export used as update site
run product 1.0.0
=> self update OK, product now with feature 1.0.1
All the exports are made manually with eclipse.
Is there an explanation for this behaviour? Why updates are not detected with the update site or the exported feature?
Simon
Re: Headless Update KO with update site, KO with feature export, OK with product export [message #552549 is a reply to message #552504] Thu, 12 August 2010 11:06 Go to previous messageGo to next message
The answer to this is essentially the same as your other questions, there is
some explanation here:
http://aniefer.blogspot.com/2009/07/composing-and-updating-c ustom-eclipse.html
Simon wrote:
> One more question,
> use an update site,
> Deployable features), use the P2 repository generated during product
> export.
> My tests :
> feature 1.0.1
> run product 1.0.0
> => no update found
> feature 1.0.1
> run product 1.0.0
> => no update found
> feature 1.0.1
> run product 1.0.0
> Simon
Re: Headless Update KO with update site, KO with feature export, OK with product export [message #553928 is a reply to message #552549] Thu, 19 August 2010 08:45 Go to previous messageGo to next message
Thank you for the answer.
I've given up the update site and I will use the product export repository as an update solution.
Re: Headless Update KO with update site, KO with feature export, OK with product export [message #571128 is a reply to message #552504] Thu, 12 August 2010 11:06 Go to previous messageGo to next message
Simon wrote:
> One more question,
> use an update site,
> export.
> My tests :
> feature 1.0.1
> run product 1.0.0
> => no update found
> feature 1.0.1
> run product 1.0.0
> => no update found
> feature 1.0.1
> run product 1.0.0
> Simon
Re: Headless Update KO with update site, KO with feature export, OK with product export [message #571361 is a reply to message #552549] Thu, 19 August 2010 08:45 Go to previous message
Previous Topic:Resolving requirement on A.PDE.Target.Platform
Next Topic:Dependency not found
Current Time: Sat Jul 26 14:49:29 EDT 2025
Powered by FUDForum. Page generated in 0.03344 seconds
