[CDO] Failed to start derby database [message #552153] |
Wed, 11 August 2010 02:33  |
Hi All,
I am trying to play around with CDO.I have setup according to the getting started with CDO Galileo.
I could start the server as well as mutliple clients and perform the necessary transactions.Then i close all of them and now if i want to start the server.I get the following exception.
I use Apache derby.
[INFO] CDO Server starting
!SESSION 2010-08-11 12:00:55.962 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_13
Framework arguments: -product org.eclipse.emf.cdo.server.product
Command-line arguments: -product org.eclipse.emf.cdo.server.product -data C:\Users\I054564\workspace_query2_cvs_eclipse/../runtime-New _configuration -dev file:C:/Users/I054564/workspace_query2_cvs_eclipse/.metadata /.plugins/org.eclipse.pde.core/CDO Server/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.emf.cdo.server 1 0 2010-08-11 12:00:57.648
!MESSAGE CDO Server starting
!ENTRY org.eclipse.core.resources 2 10035 2010-08-11 12:00:57.819
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
[ERROR] SQL Exception: Failed to start database '/Temp/cdodb1', see the next exception for details.
org.eclipse.net4j.db.DBException: SQL Exception: Failed to start database '/Temp/cdodb1', see the next exception for details.
at org.eclipse.net4j.internal.db.DataSourceConnectionProvider.g etConnection(DataSourceConnectionProvider.java:46)
at org.eclipse.emf.cdo.server.internal.db.DBStore.getConnection (DBStore.java:180)
at org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate(DB Store.java:230)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:65)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:94)
!ENTRY org.eclipse.net4j.util 4 0 2010-08-11 12:00:58.335
!MESSAGE SQL Exception: Failed to start database '/Temp/cdodb1', see the next exception for details.
!STACK 0
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:84)
at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Re pository.java:581)
at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOSe rverUtil.java:73)
at org.eclipse.emf.cdo.internal.server.RepositoryConfigurator.c onfigure(RepositoryConfigurator.java:83)
at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplicat ion.doStart(CDOServerApplication.java:51)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplicat ion.java:61)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: SQL Exception: Failed to start database '/Temp/cdodb1', see the next exception for details.
at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
at org.apache.derby.impl.jdbc.Util.generateCsSQLException(Unkno wn Source)
at org.apache.derby.impl.jdbc.EmbedConnection.newSQLException(U nknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unkn own Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection30.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver30.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.EmbeddedDataSource.getConnection(Unkno wn Source)
at org.eclipse.net4j.internal.db.DataSourceConnectionProvider.g etConnection(DataSourceConnectionProvider.java:42)
... 26 more
!ENTRY org.eclipse.osgi 4 0 2010-08-11 12:00:58.335
!MESSAGE Application error
!STACK 1
... 26 more
... 26 more
!ENTRY org.eclipse.jdt.core 4 4 2010-08-11 12:00:58.803
!MESSAGE Unable to read variable and containers file
!STACK 0
java.io.EOFException
at java.io.DataInputStream.readInt(Unknown Source)
at org.eclipse.jdt.internal.core.JavaModelManager$VariablesAndC ontainersLoadHelper.loadInt(JavaModelManager.java:3275)
at org.eclipse.jdt.internal.core.JavaModelManager$VariablesAndC ontainersLoadHelper.loadVariables(JavaModelManager.java:3341 )
at org.eclipse.jdt.internal.core.JavaModelManager$VariablesAndC ontainersLoadHelper.load(JavaModelManager.java:3144)
at org.eclipse.jdt.internal.core.JavaModelManager.loadVariables AndContainers(JavaModelManager.java:2980)
at org.eclipse.jdt.internal.core.JavaModelManager.startup(JavaM odelManager.java:4623)
at org.eclipse.jdt.core.JavaCore.start(JavaCore.java:4965)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:774)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:381)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:457)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:326)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.core.internal.events.BuildManager.instantiateBui lder(BuildManager.java:782)
at org.eclipse.core.internal.events.BuildManager.initializeBuil der(BuildManager.java:735)
at org.eclipse.core.internal.events.BuildManager.getBuilder(Bui ldManager.java:480)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:199)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:309)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:341)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:140)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:238)
!ENTRY org.eclipse.core.resources 4 2 2010-08-11 12:00:58.944
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
at org.eclipse.core.runtime.Plugin$1.run(Plugin.java:369)
at org.eclipse.core.runtime.Plugin.getPluginPreferences(Plugin. java:372)
at org.eclipse.jdt.internal.launching.environments.Environments Manager. <init>(EnvironmentsManager.java:148)
at org.eclipse.jdt.internal.launching.environments.Environments Manager.getDefault(EnvironmentsManager.java:138)
at org.eclipse.jdt.launching.JavaRuntime.getExecutionEnvironmen tsManager(JavaRuntime.java:2550)
at org.eclipse.jdt.internal.launching.JREContainerInitializer.g etExecutionEnvironmentId(JREContainerInitializer.java:175)
at org.eclipse.jdt.internal.launching.JREContainerInitializer.g etDescription(JREContainerInitializer.java:332)
at org.eclipse.jdt.internal.core.JavaModelManager.initializeCon tainer(JavaModelManager.java:2638)
at org.eclipse.jdt.internal.core.JavaModelManager.getClasspathC ontainer(JavaModelManager.java:1813)
at org.eclipse.jdt.core.JavaCore.getClasspathContainer(JavaCore .java:2652)
at org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(J avaProject.java:2578)
at org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(J avaProject.java:2679)
at org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:1866)
at org.eclipse.jdt.internal.core.JavaProject.computeExpandedCla sspath(JavaProject.java:469)
at org.eclipse.jdt.internal.core.JavaProject.getExpandedClasspa th(JavaProject.java:1485)
at org.eclipse.jdt.internal.core.builder.NameEnvironment.comput eClasspathLocations(NameEnvironment.java:93)
at org.eclipse.jdt.internal.core.builder.NameEnvironment.<init >(NameEnvironment.java:41)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.initialize Builder(JavaBuilder.java:603)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.build(Java Builder.java:167)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:627)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
!ENTRY org.eclipse.core.resources 4 2 2010-08-11 12:00:59.428
!STACK 0
at org.eclipse.jdt.internal.core.JavaModelManager$VariablesAndC ontainersSaveHelper.save(JavaModelManager.java:3794)
at org.eclipse.jdt.internal.core.JavaModelManager.saveVariables AndContainers(JavaModelManager.java:3746)
at org.eclipse.jdt.internal.core.JavaModelManager.saving(JavaMo delManager.java:3992)
at org.eclipse.core.internal.resources.SaveManager.executeLifec ycle(SaveManager.java:343)
at org.eclipse.core.internal.resources.SaveManager$1.run(SaveMa nager.java:160)
at org.eclipse.core.internal.resources.SaveManager.broadcastLif ecycle(SaveManager.java:163)
at org.eclipse.core.internal.resources.SaveManager.save(SaveMan ager.java:1012)
at org.eclipse.core.internal.resources.SaveManager.save(SaveMan ager.java:991)
at org.eclipse.core.internal.resources.DelayedSnapshotJob.run(D elayedSnapshotJob.java:44)
at org.eclipse.core.internal.resources.SaveManager.shutdown(Sav eManager.java:1216)
at org.eclipse.core.internal.resources.Workspace.close(Workspac e.java:414)
at org.eclipse.core.resources.ResourcesPlugin.stop(ResourcesPlu gin.java:356)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:843)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:836)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:474)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.susp end(AbstractBundle.java:546)
at org.eclipse.osgi.framework.internal.core.Framework.suspendBu ndle(Framework.java:1098)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ecFWSL(StartLevelManager.java:593)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:261)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:216)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundl e.suspend(InternalSystemBundle.java:266)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:685)
at org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:583)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(Ecl ipseStarter.java:409)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:200)
[Updated on: Wed, 11 August 2010 02:34] by Moderator
FUDForum. Page generated in 0.07506 seconds
