Home » Eclipse Projects » Remote Application Platform (RAP) » Current UI update is always triggered by the next UI event
Current UI update is always triggered by the next UI event [message #552125] |
Tue, 10 August 2010 19:55  |
I have a background job to load stuff from the database and update the TreeViewer. The scenario of the background job is
1. a TreeItem is expanded
2. loads data from DB
3. updated the UI by populating the children of the TreeItem using Display.async
It is pretty much similar to the background job example from here http://wiki.eclipse.org/RAP/FAQ#How_to_update_the_UI_from_a_ background_thread_using_Jobs.3F
In Safari and Opera, the UI is not refreshed (#3) until the next UI event comes, e.g., clicking any other widget to trigger the next UI event. In the debug mode, I saw that the body of the Runnable from Display.async is not executed until the next event comes. Even if I manually execute Display.readAndDispatch, it fails to execute the current UI update. The current UI update is always triggered by the next UI event. Here is what the code looks like:
private class ResourceLoadingJob extends Job {
private void loadResource() {
// running get children in session;
UICallBack.runNonUIThreadWithFakeContext(display, new Runnable() {
public void run() {
// load the resource with session on
display.asyncExec(new Runnable() {
public void run() {
try {
if (!treeViewer.getControl().isDisposed()) {
treeViewer.refresh(resource, true);
} catch (Exception e) {
// handle exception
This issue doesn't happen on other browsers. I am wondering how can I fix it? It looks like a defect in RAP's UI update thread which sleeps and forgets about the UI update.
Owen
Re: Current UI update is always triggered by the next UI event [message #552172 is a reply to message #552125] |
Wed, 11 August 2010 03:13   |
Hi Owen,
what is the RAP version used? Did you try to activate the UICallback
manually? Does your code work in Firefox and IE, and you have problems
only with Safari and Opera?
Best,
Ivan
On 08/11/2010 2:55 AM, Owen wrote:
> Display.async
> @Override
> public void run() {
> @Override
> public void run() {
> try {
> // handle exception
> Owen
Re: Current UI update is always triggered by the next UI event [message #552174 is a reply to message #552172] |
Wed, 11 August 2010 03:40   |
Hi Ivan,
I am using RAP 1.3. I didn't manually invoke UICallback but I am using Display.async. From the FAQ, isn't it that I either update the UI with the Display API ( http://wiki.eclipse.org/RAP/FAQ#How_to_update_the_UI_from_a_ background_thread_using_Jobs.3F) or use UICallback to activate the UI ( http://wiki.eclipse.org/RAP/FAQ#How_to_update_the_UI_from_a_ background_thread).
Yeah, the problem is not obvious in Firefox. Not sure about IE. But it happens on Safari 5 and Opera 10.
Is there anyway I can fix this?
Owen
Ivan Furnadjiev wrote on Wed, 11 August 2010 03:13 | Hi Owen,
Best,
Ivan
> Display.async
> @Override
> public void run() {
> @Override
> public void run() {
> try {
> // handle exception
> Owen
Re: Current UI update is always triggered by the next UI event [message #552181 is a reply to message #552174] |
Wed, 11 August 2010 03:50   |
Hi Owen,
please file a bugzilla with a self running snippet/project to reproduce it.
Best,
Ivan
On 08/11/2010 10:40 AM, Owen wrote:
> Hi Ivan,
> the Display API
> Owen
>> Hi Owen,
>> problems only with Safari and Opera?
>> Best,
>> Ivan
>> > Hi,
>> the > TreeViewer. The scenario of the background job is
>> > Display.async
>> > http://wiki.eclipse.org/RAP/FAQ#How_to_update_the_UI_from_a_ >
>> > manually execute Display.readAndDispatch, it fails to execute the >
>> current UI update. The current UI update is always triggered by the >
>> > @Override
>> > public void run() {
>> > @Override
>> > public void run() {
>> > try {
>> > // handle exception
>> I > fix it? It looks like a defect in RAP's UI update thread which
>> sleeps > and forgets about the UI update.
>> > Thanks,
>> > Owen
Re: Current UI update is always triggered by the next UI event [message #552320 is a reply to message #552174] |
Wed, 11 August 2010 13:30   |
Owen,
just to clarify: if you are *not* using Jobs you will have to
activate/deactivate the UICallBack yourself.
Display#asyncExec() just puts your code in a list that gets processed
when readAndDipach() is called the next time. The UICallBack takes care
that the client is informed that there is code to be executed on the UI
thread.
HTH
Rüdiger
On 11.08.2010 09:40, Owen wrote:
> Hi Ivan,
> the Display API
> Owen
>> Hi Owen,
>> Best,
>> Ivan
>> > Hi,
>> > 3. updated the UI by populating the children of the TreeItem using >
>> Display.async
>> > It is pretty much similar to the background job example from here >
>> > event. In the debug mode, I saw that the body of the Runnable from >
>> Display.async is not executed until the next event comes. Even if I >
>> > @Override
>> > public void run() {
>> > @Override
>> > public void run() {
>> > try {
>> > // handle exception
>> > Thanks,
>> > Owen
Rüdiger Herrmann
http://eclipsesource.com
Re: Current UI update is always triggered by the next UI event [message #552326 is a reply to message #552320] |
Wed, 11 August 2010 14:04   |
Hi Rudiger,
Yes, I am using Job. But the Job is running on the background and it never ends (pretty much as a daemon). That's why I didn't activate with the UICallBack. Can I do something like that with Job in RAP? Or I have to switch to the Thread & UICallBack way as indicated in example?
Owen
Rüdiger Herrmann wrote on Wed, 11 August 2010 13:30 | Owen,
thread.
HTH
Rüdiger
> Hi Ivan,
> the Display API
> Owen
>> Hi Owen,
>> Best,
>> Ivan
>> > Hi,
>> Display.async
>> > @Override
>> > public void run() {
>> > @Override
>> > public void run() {
>> > try {
>> > // handle exception
>> > Thanks,
>> > Owen
Rüdiger Herrmann
Re: Current UI update is always triggered by the next UI event [message #552602 is a reply to message #552326] |
Thu, 12 August 2010 14:28  |
Owen,
for a Job to be able to "update" the UI it must be started from the UI
thread. The common pattern to reschedule jobs at their end with a
JobListener doesn't work in RAP.
The UICallBack (that is used by Jobs in RAP under the hood) must be
called from the UI thread in order to instruct the client that there is
a background thread that potentially calls Display#asyncExec().
If your code is free from such obstacles, you may have run into this bug:
315418: Progress Dialog will not automatically close during UICallback
https://bugs.eclipse.org/bugs/show_bug.cgi?id=315418
HTHJ
Rüdiger
On 11.08.2010 20:04, Owen wrote:
> Hi Rudiger,
> Owen
>> Owen,
>> care that the client is informed that there is code to be executed on
>> the UI thread.
>> HTH
>> Rüdiger
>> > Hi Ivan,
>> > the Display API
>> background_thread).
>> > Thanks,
>> > Owen
>> >> Hi Owen,
>> >> Best,
>> >> Ivan
>> >> > Hi,
>> >> Display.async
>> >> > @Override
>> >> > public void run() {
>> >> > @Override
>> >> > public void run() {
>> >> > try {
>> >> > // handle exception
>> >> > Thanks,
>> >> > Owen
>> Rüdiger Herrmann
Rüdiger Herrmann
Current Time: Mon Jul 21 00:38:55 EDT 2025
Powered by FUDForum. Page generated in 0.24221 seconds
