Home » Modeling » TMF (Xtext) » xText Grammer Scoping for SQL SELECT statement(Column Names Scoping for SQL Tables Using Content Assist)
xText Grammer Scoping for SQL SELECT statement [message #552073] Tue, 10 August 2010 13:27 Go to next message
Do you need to know Java coding to implement scoping in xText? Or it can be all implemented in a xText grammer alone.
For example, I have a SQL "SELECT" xText grammer (not to reinvent the wheel, I am adapting this xText grammer, please see link
http://www.eclipse.org/forums/index.php?t=msg&goto=55180 5&S=ae2e996116dc9c0a1864fa097bd3e0e2#msg_551805).
I have two tables, Customer and PhoneNumber. Table Customer has columns called CustomerID and CustomerName.
And Table PhoneNumber has two columns called CustomerID and WorkNumber.
The following SQL statement will retreive the work numbers for all the customers.
SELECT Customer.CustomerName, PhoneNumber.WorkNumber
FROM Customer
INNER JOIN PhoneNumber ON Customer.CustomerID = PhoneNumber.CustomerID
How would I implement scoping for the table Customer so that Content Assist will only show CustomerID and CustomerName?
Likewise, table PhoneNumber will show CustomerID and WorkNumber.
Any help would be greatly appreciated. Thanks.
Re: xText Grammer Scoping for SQL SELECT statement [message #552193 is a reply to message #552073] Wed, 11 August 2010 04:20 Go to previous messageGo to next message
You do need to do some Java coding (in <DSLname>JavaValidator to be exact). The main reason for that (as I understood) is that this is much more performant than an earlier approach which used Xtend, which is interpreted. Another reason is that it's slightly easier to get access to "things living outside" than it is in Xtend. Also, not all algorithmic stuff can be comfortably expressed through functional programming.
If you really want, you can use the XtendFacade to call extensions to do the scoping Smile (In fact, for small and simple grammars that'd be a nice thing to have.)
Also, I don't see a table def. in your and the referenced grammar, so scoping wouldn't be invoked anyway since an EAttribute will be generated instead of an EReference.
Re: xText Grammer Scoping for SQL SELECT statement [message #552219 is a reply to message #552073] Wed, 11 August 2010 06:25 Go to previous messageGo to next message
the grammar lets you restrict the *type* of the referenced objects.
Everything else has to be implemented via scoping.
Alex
Re: xText Grammer Scoping for SQL SELECT statement [message #552319 is a reply to message #552219] Wed, 11 August 2010 13:30 Go to previous messageGo to next message
Appeciated for your response. I learned how to construct a xtext grammer from your postings. Please also see my responses to Meinte Boersma.
Re: xText Grammer Scoping for SQL SELECT statement [message #552321 is a reply to message #552193] Wed, 11 August 2010 13:32 Go to previous messageGo to next message
Appeciated for your response. I learned how to construct a xtext grammer from Alex postings.
Table Definitions will be a cross reference file. For example,
TableDefinitions
Customer{
CustomerID
CustomerName
PhoneNumber{
CustomerID
WorkNumber
Using this approach, the Content Assist will show all the column names. What if I have 500+ tables? The list would be long.
That's why I want to implement scoping to limit the number of columns returning. In other words, scoping will only show the columns
returning from the "FROM", "INNER JOIN" and "OUTER JOIN" tables.
Unfortunately, I am a database backend developer and not a Java developer. However, I do know some Java scripting.
Should I give it up?
I want to figure out how to use XtendFacade to call extensions? Do you have any simple examples to explain the concepts?
On the other hand, I don't think I have enough Java and Eclipse knowledge to code in the JavaValidator.
I did look thru the xtext documentation (see link below) but it's all too technical for me to understand.
http://www.eclipse.org/Xtext/documentation/1_0_0/xtext.html# scoping
Please advise. Thanks.
Re: xText Grammer Scoping for SQL SELECT statement [message #552332 is a reply to message #552321] Wed, 11 August 2010 14:31 Go to previous messageGo to next message
Hello Dennis,
without having a complete grammar giving more advice than to hint to the docs is hard to give.
Maybe this sentence How would I implement scoping for the table Customer was a bit misunderstanding since you define scoping for metaclasses which indicates that customer is a metaclass but i think its an instance of the metaclass TableDefinition.
Never the less having a simple grammar like this one
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	elements+=Element*
	mappings+=Mapping*
Element:
	"element" name=ID "{"
		attributes+=Attribute*
Attribute:
	"attr" name=ID
Mapping:
	"mapping" from=MappingPart "->" to=MappingPart
MappingPart:
	element=[Element] "." attribute=[Attribute]
and a very very small ScopeProvider like this
public class MyDslScopeProvider extends AbstractDeclarativeScopeProvider {
	public IScope scope_MappingPart_attribute(MappingPart mappingPart, EReference ref) {
		return Scopes.scopeFor(mappingPart.getElement().getAttributes());
scoping works for a sample model like this
element A {
	attr a1
	attr a2
element B {
	attr b1
	attr b2
mapping A.a1 -> B.b2
Christian
[Updated on: Wed, 11 August 2010 14:35] by Moderator
Re: xText Grammer Scoping for SQL SELECT statement [message #552361 is a reply to message #552332] Wed, 11 August 2010 17:58 Go to previous messageGo to next message
Wow! Your example is simple and very effective. I tried it out but failed.
Here are the error messages:
IScope cannot be resolved to a type
EReference cannot be resolved to a type
MappingPart cannot be resolved to a type
Scopes cannot be resolved
Did I miss something?
Re: xText Grammer Scoping for SQL SELECT statement [message #552369 is a reply to message #552361] Wed, 11 August 2010 19:04 Go to previous messageGo to next message
To adapt to Christian's coding to my grammer, I think I will need to change QualifiedTableReference.
I hope it will work. I cannot try it yet until the "the IScope cannot be resolved to a type" error is fixed.
From this
QualifiedTableReference hidden():ID'.'ID;
To this
QualifiedTable:
name=ID;
QualifiedColumn:
name=ID;
	element=[QualifiedTable] "." attribute=[QualifiedColumn];
And ScopeProvider like this
public IScope scope_QualifiedTableReference_attribute(QualifiedTableReference qualifiedTableReference, EReference ref) {
	return Scopes.scopeFor(qualifiedTableReference.getQualifiedTable().getQualifiedColumn());
Here's the grammer.
grammar org.xtext.newdef.NewDef with org.eclipse.xtext.common.Terminals
generate newDef "http://www.xtext.org/newdef/NewDef"
Model:
TableDefinitions|NameSpaces;
TableDefinitions:{TableDefinition}'TableDefinitions' tables+=Table*;
Table: name=ID'{'columns+=Column*'}';
Column: name=ID;
NameSpaces:{NameSpaces}
(namespace+=NameSpace)*;
NameSpace:
'Namespace' name=ID "{"
(query+=Query)*
Query:
'Query' namespace=[NameSpace] ("." name=QualifiedName) "{"
("[" 'Description:' description=MYSTRING"]")
("[" 'Query:'queryName=[Query|QualifiedName]"]")?
("[" 'Filter:' filter+=Filter (',' filter+=Filter)*"]")?
//no return fragments yet
("[" 'Return:' return+=ReturnElement (',' return+=ReturnElement)* "]")?
("[" 'From:' from=[Table]
joinespression+=JoinExpression*
("[" 'Where:' where=Where"]")?
("[" 'Order:' order+=Order (',' order+=Order)*"]")?)
Filter: column=ID (multi?='*')?;
ReturnElement: ref=[Column|QualifiedTableReference] ('As' asname=ID)?;
Where: column=[Column|QualifiedTableReference] (expression=WhereExpression)
(("And"|"Or") equals+=ColumnEqualsExpression)*;
Order: ref= [Column|QualifiedTableReference] (direction=Direction)?;
enum Direction: ascending="Asc"|descending="Desc";
JoinExpression: InnerJoinExpression|OuterJoinExpression;
InnerJoinExpression:
(optional?='Optional')? 'Inner' 'Join' jointablename=[Table]
"On" equals+=ColumnRefEqualsExpression
OuterJoinExpression:
('Optional')? 'Left' 'Join' jointablename=[Table]
ColumnEqualsExpression:ColumnRefEqualsExpression|ColumnStringEqualsExpression|ColumnOtherExpression;
ColumnRefEqualsExpression: left=[Column|QualifiedTableReference] '='
right=[Column|QualifiedTableReference];
ColumnStringEqualsExpression: left=[Column|QualifiedTableReference] ('='|'<>')
right=STRING;
ColumnOtherExpression: left=[Column|QualifiedTableReference] right=WhereExpression;
WhereExpression:
IntCompareExpression|NullExpression|NotNullExpression|StringEqualsExpression;
NullExpression: "Is" "Null"{NullExpression};
NotNullExpression: "Is" "Not" "Null"{NotNullExpression};
IntCompareExpression: comparator=Comparator value=INT;
StringEqualsExpression: '=' value=STRING;
enum Comparator: equals = "="| greater=">"|less="<"|
lessequals="<="|greaterequals= ">="|notequals= "<>";
MYSTRING hidden(): (ID|WS|INT|STRING|'not'|','|ANY_OTHER)*;
QualifiedName hidden():ID('.'ID)*;
//QualifiedTableReference hidden():ID'.'ID;
QualifiedTable:
name=ID;
QualifiedColumn:
name=ID;
Re: xText Grammer Scoping for SQL SELECT statement [message #552397 is a reply to message #552369] Thu, 12 August 2010 02:04 Go to previous messageGo to next message
The Class Scopes and the Interface IScope are Part of Xtext and EReferene is Part of EMF so a Simple Organize Imports should do the Trick. ~Christian
Re: xText Grammer Scoping for SQL SELECT statement [message #552581 is a reply to message #552397] Thu, 12 August 2010 13:10 Go to previous messageGo to next message
Thanks again. Simple Organize Imports did resolve the Iscope error.
I am having issues with
After I typed in "mapping A.", Content Assist (control space) gave me a blank list to select from.
Also when I typed "mapping ", a red x appeared. When I clicked the red x, the message was "mismatched input '<EOF>' expecting RULE_ID".
The grammar was fine or"Done" when I generated xText Artifacts. Exporting was no issues either. What could go wrong here?
Here's the code again
Re: xText Grammer Scoping for SQL SELECT statement [message #552585 is a reply to message #552581] Thu, 12 August 2010 13:28 Go to previous messageGo to next message
Hi, does it work without changes to scoping. Have you doublechecked grammar and Model? ~ Christian
Re: xText Grammer Scoping for SQL SELECT statement [message #552592 is a reply to message #552369] Thu, 12 August 2010 14:09 Go to previous messageGo to next message
The modified definition of the QualifiedTableReference makes no sense the way you use it.
First you do not want to reference elements of type QualifiedTable of QualifiedColumn but Table and Column, otherwise your TableDefinitions will not be used.
Second the places where you used the rule before are now incorrect
Example:
should be
ReturnElement: ref=QualifiedTableReference
Alex
Re: xText Grammer Scoping for SQL SELECT statement [message #552593 is a reply to message #552585] Thu, 12 August 2010 14:10 Go to previous messageGo to next message
Issue 1:
It does not work without Content Assist.
mapping A.a1 -> B.b1
The error message is: Multiple markers at this line: Couldn't resolve reference to Attribute 'b1', Couldn't resolve reference to Attribute 'a2'.
Issue 2:
Using Content Assist, it was able to verify the grammar.
For example, if I type in
mapping A.b1 -> B.b1
it will complaint about A.b1. Somehow it knows b1 or b2 does not belong to A. However, by pressing ctrl-space, content assist does not offer a list.
Re: xText Grammer Scoping for SQL SELECT statement [message #552594 is a reply to message #552593] Thu, 12 August 2010 14:12 Go to previous messageGo to next message
Can you please post the grammar you are actually using?
Re: xText Grammer Scoping for SQL SELECT statement [message #552598 is a reply to message #552594] Thu, 12 August 2010 14:17 Go to previous messageGo to next message
Here is the grammer
grammar org.xtext.scope.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/scope/mydsl/MyDsl"
Model:
	elements+=Element*
	mappings+=Mapping*
Element:
Attribute:
	"attr" name=ID
Mapping:
MappingPart:
Re: xText Grammer Scoping for SQL SELECT statement [message #552601 is a reply to message #552598] Thu, 12 August 2010 14:30 Go to previous messageGo to next message
right, i missed to tell that you have to use SimpleNameProvider in this case
public class MyDslRuntimeModule extends org.xtext.example.mydsl.AbstractMyDslRuntimeModule {
	public Class<? extends IQualifiedNameProvider> bindIQualifiedNameProvider() {
		return SimpleNameProvider.class;
or you change the grammar like this and don't have to implement any scoping at all.
Model:
	elements+=Element*
	mappings+=Mapping*
Element:
Attribute:
	"attr" name=ID
Mapping:
MappingPart:
	attribute=[Attribute|FQN]
FQN: ID ("." ID)*;
~Christian
Re: xText Grammer Scoping for SQL SELECT statement [message #552605 is a reply to message #552601] Thu, 12 August 2010 14:51 Go to previous messageGo to next message
Note however, that this is back to the original grammar where columns are already referenced using fully qualified names. In some cases columns are to be referenced by their simple names, which caused the screw-up of the QualifiedTableReference definition rather than just adapt the grammar where columns are to be referenced by their simple names and adapt the corresponding scoping.
Make sure you don't miss my earlier post in this thread, as it was published right in the middle of your exchange with Christian
Alex
Re: xText Grammer Scoping for SQL SELECT statement [message #552622 is a reply to message #552601] Thu, 12 August 2010 17:28 Go to previous messageGo to next message
For scoping, I tried both ways and they worked. For content assist, it did not prompt any attributes for me to choose. Is there a way to do that?
Re: xText Grammer Scoping for SQL SELECT statement [message #552623 is a reply to message #552605] Thu, 12 August 2010 17:29 Go to previous messageGo to next message
Thanks, Alex. I get scoping working but not content assist. Is there a way to do that?
Re: xText Grammer Scoping for SQL SELECT statement [message #552636 is a reply to message #552592] Thu, 12 August 2010 21:08 Go to previous messageGo to next message
Hi Alex, I modified the grammar to
element=[Table]"."attribute=[Column];
ReturnElement: ref=QualifiedTableReference ('As' asname=ID)?;
Now, it didn't like the column name. However, content assist will prompt the table names.
Using the old grammar, content assist will prompt the column names with the table names.
Re: xText Grammer Scoping for SQL SELECT statement [message #552669 is a reply to message #552636] Fri, 13 August 2010 02:26 Go to previous messageGo to next message
> the table names.
No wonder, the column names are not proposed, as the default
implementation will propose fully qualified names and not the simple
names. My adaptions to Pam's grammar already contain a comment to that
effect.
You will have to adapt the scoping for the column. Sample code is
already contained in this thread.
Alex
Re: xText Grammer Scoping for SQL SELECT statement [message #552678 is a reply to message #552636] Fri, 13 August 2010 02:34 Go to previous messageGo to next message
Also please debug whether your scoping function for the columns is
invoked at triggering content assist. It is well possible that the
context object is not of the type you expect it to be. See also
http://www.eclipse.org/forums/index.php?t=msg&th=172683& amp;start=0&S=5cbabccf11b6630a41fb285f7087dbad
Alex
Re: xText Grammer Scoping for SQL SELECT statement [message #552715 is a reply to message #552073] Fri, 13 August 2010 05:14 Go to previous messageGo to next message
Dennis,
Alex is right, I just did the debug test on the context object.
It wasn't the type I expected it to be.
However I did not get in my thread the solution. Don't give up though!
Good luck, and let me know if you reach a solution.
Cyril
Re: xText Grammer Scoping for SQL SELECT statement [message #552863 is a reply to message #552601] Fri, 13 August 2010 16:55 Go to previous messageGo to next message
Thank you, Christian! It works using SimpleNameProvider. It will prompt me for the element's attributes. Now, I will need to adapt this to my grammar. Alex Nittka helped me quite a bit too. Many thanks again! Cheers!
Re: xText Grammer Scoping for SQL SELECT statement [message #552898 is a reply to message #552863] Sat, 14 August 2010 03:13 Go to previous messageGo to next message
Note that you need to be careful if columns in different tables can have
the same name.
Alex
Re: xText Grammer Scoping for SQL SELECT statement [message #555510 is a reply to message #552592] Thu, 26 August 2010 17:15 Go to previous message
Alex, I was on vacation for a week. After I came back and I got scoping to work for my grammar. Thank you for all your assistance.
Previous Topic:no syntax highlighting and no code completion
Next Topic:Code generation like Domain Model?
Current Time: Thu Jul 24 21:58:23 EDT 2025
Powered by FUDForum. Page generated in 0.39176 seconds
