| Re: Remove search and Run menu for menu bar [message #554937 is a reply to message #554833] |
Tue, 24 August 2010 15:50   |
I tried the following code and it removed single entries from the menus but not the menus itself (like the Run or Search menu).
public void postWindowCreate() {
// remove unwanted menu entries
List<String> unwantedItems = Arrays.asList(
"org.eclipse.ui.openLocalFile",
"converstLineDelimitersTo",
"org.eclipse.ui.cheatsheets.actions.CheatSheetHelpMenuAction",
"org.eclipse.debug.ui.actions.BreakpointTypesContribution" ,
"ExternalToolsGroup" ,
"org.eclipse.ui.externaltools.ExternalToolMenuDelegateMenu" ,
"navigate" ,
"org.eclipse.search.menu",
"org.eclipse.ui.run"
IMenuManager menuManager = getWindowConfigurer().getActionBarConfigurer().getMenuManager();
removeUnwantedItems(unwantedItems, menuManager);
private void removeUnwantedItems(final List<String> unwantedItems, final IMenuManager menuManager) {
IContributionItem[] items = menuManager.getItems();
for (IContributionItem item : items) {
if (item instanceof IMenuManager) {
removeUnwantedItems(unwantedItems, (IMenuManager) item);
if (unwantedItems.contains(item.getId())) {
menuManager.remove(item);
Any ideas why Run and Search are not removed?
FUDForum. Page generated in 0.06055 seconds
