Home » Language IDEs » Java Development Tools (JDT) » JDT auto completion error
JDT auto completion error [message #485812] Tue, 15 September 2009 03:42 Go to next message
I get the following when I press Ctrl+Space now:
"The 'org.eclipse.jdt.ui.JavaAllCompletionProposalComputer' proposal
computer from the 'org.eclipse.jdt.ui' plug-in did not complete normally.
The extension took too long to return from the
'computeCompletionProposals()' operation."
Eclipse was working fine till yesterday, not sure what happened today. Can
anyone help please?
Gaurav
Re: JDT auto completion error [message #486289 is a reply to message #485812] Thu, 17 September 2009 03:57 Go to previous messageGo to next message
> normally. The extension took too long to return from the
> Can anyone help please?
Does it now always happen? If so, did you follow the advice in the dialog?
Dani
> Gaurav
Re: JDT auto completion error [message #534523 is a reply to message #485812] Wed, 19 May 2010 08:31 Go to previous messageGo to next message
I searched but did not get any answers for the below problem.
I get the following when I press Ctrl+Space now in eclipse.
"The 'org.eclipse.jdt.ui.JavaAllCompletionProposalComputer' proposal computer from the 'org.eclipse.jdt.ui' plug-in did not complete normally. The extension took too long to return from the 'computeCompletionProposals()' operation."
Please help me.
-Abhishek
Re: JDT auto completion error [message #534706 is a reply to message #534523] Thu, 20 May 2010 00:53 Go to previous messageGo to next message
Look at the <workspace>\.metadata\.log for any related messages. Also try to restart eclipse with eclipse -clean and see if you still get those problems.
Re: JDT auto completion error [message #534711 is a reply to message #534706] Thu, 20 May 2010 01:23 Go to previous messageGo to next message
> those problems.
Also try restoring the prefereces at Java -> Editor -> Content Assist ->
Advanced.
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: JDT auto completion error [message #543880 is a reply to message #534711] Wed, 30 June 2010 18:33 Go to previous messageGo to next message
This problem has plagued me for much longer than I would like to admit. Thank you Prakash for the advice on going to the log file to check out the errors.
I get a "Zip Exception: error in opening zip file" exception. My project has a very large collection of libraries, and I usually go to the directory which contains my libraries, and select them all, and add them to a projects library build path. In this process, I accidentally selected several .tar and .tar.gz files which happened to be in the same directory. Needless to say these .tar and .tar.gz files were causing the exception, and causing the super slow content assist. I deleted them, and removed them from my projects libraries build path, and low and behold, I again have a usable eclipse.
Re: JDT auto completion error [message #552131 is a reply to message #543880] Tue, 10 August 2010 21:57 Go to previous messageGo to next message
I had the same issue except that my libraries didn't include any zip files, but I was getting ZipExceptions when looking at the logs. Seems it was some of the Spring JAR files I had included in my project. I had copied them to a directory withing the project, then added them.
I solved my problem by moving the Spring JAR files to a directory external to the project & adding them to the project as external JARs.
As a side comment: kind of new to Java (& especially Spring) so not sure exactly what will happen if I tried to compile/deploy the project (will it pull the external jars into the compiled project, or try to find them externally??). At least I can work more effectively for the time being & cross that bridge when I come to it (moving them to be internal when I want to compile if I have to).
icon14.gif  Re: JDT auto completion error [message #1128186 is a reply to message #485812] Mon, 07 October 2013 08:34 Go to previous message
This Problem is seriously irritating and I wasted so much time for
solving it.Thank you all.
- Harshal
Previous Topic:Java int[] Array [I@24a1a602]
Next Topic:Code is formatted even though Save Action is not enabled
Current Time: Fri Jul 18 07:39:39 EDT 2025
Powered by FUDForum. Page generated in 0.71391 seconds
