Home » Eclipse Projects » Eclipse Platform » Error "org.eclipse.jface"
Error "org.eclipse.jface" [message #551932] Tue, 10 August 2010 04:44 Go to next message
I keep getting this error in my .log
!ENTRY org.eclipse.jface 4 2 2010-08-10 10:37:22.148
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.IllegalArgumentException
at org.eclipse.jdt.internal.core.util.Util.scanTypeSignature(Ut il.java:2710)
at org.eclipse.jdt.core.Signature.getReturnType(Signature.java: 1644)
at org.eclipse.jdt.core.Signature.getReturnType(Signature.java: 1657)
at org.eclipse.jdt.internal.ui.viewsupport.JavaElementLabelComp oser.appendMethodLabel(JavaElementLabelComposer.java:461)
at org.eclipse.jdt.internal.ui.viewsupport.JavaElementLabelComp oser.appendElementLabel(JavaElementLabelComposer.java:236)
at org.eclipse.jdt.ui.JavaElementLabels.getElementLabel(JavaEle mentLabels.java:521)
at org.eclipse.jdt.ui.JavaElementLabels.getStyledElementLabel(J avaElementLabels.java:496)
at org.eclipse.jdt.ui.JavaElementLabels.getStyledTextLabel(Java ElementLabels.java:424)
at org.eclipse.jdt.internal.ui.viewsupport.JavaUILabelProvider. getStyledText(JavaUILabelProvider.java:178)
at org.eclipse.jface.viewers.DelegatingStyledCellLabelProvider. getStyledText(DelegatingStyledCellLabelProvider.java:195)
at org.eclipse.jface.viewers.DecoratingStyledCellLabelProvider. getStyledText(DecoratingStyledCellLabelProvider.java:192)
at org.eclipse.jface.viewers.DelegatingStyledCellLabelProvider. update(DelegatingStyledCellLabelProvider.java:103)
at org.eclipse.jface.viewers.DecoratingStyledCellLabelProvider. update(DecoratingStyledCellLabelProvider.java:134)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:932)
at org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:102)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:1012)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:481)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2111)
at org.eclipse.jface.viewers.StructuredViewer.internalUpdate(St ructuredViewer.java:2094)
at org.eclipse.jface.viewers.StructuredViewer.update(Structured Viewer.java:2033)
at org.eclipse.jface.viewers.ColumnViewer.update(ColumnViewer.j ava:554)
at org.eclipse.jface.viewers.StructuredViewer.update(Structured Viewer.java:1977)
at org.eclipse.jface.viewers.StructuredViewer.handleLabelProvid erChanged(StructuredViewer.java:1140)
at org.eclipse.jdt.internal.ui.viewsupport.ProblemTreeViewer.ha ndleLabelProviderChanged(ProblemTreeViewer.java:214)
at org.eclipse.jface.viewers.ContentViewer$1.labelProviderChang ed(ContentViewer.java:97)
at org.eclipse.jface.viewers.BaseLabelProvider$1.run(BaseLabelP rovider.java:74)
at org.eclipse.jface.viewers.BaseLabelProvider.fireLabelProvide rChanged(BaseLabelProvider.java:72)
at org.eclipse.jface.viewers.DecoratingStyledCellLabelProvider$ 1.labelProviderChanged(DecoratingStyledCellLabelProvider.jav a:77)
at org.eclipse.ui.internal.decorators.DecoratorManager$1.run(De coratorManager.java:430)
at org.eclipse.ui.internal.decorators.DecoratorManager.fireList ener(DecoratorManager.java:428)
at org.eclipse.ui.internal.decorators.DecorationScheduler$3.run InUIThread(DecorationScheduler.java:530)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
Every time it happens I get a modal dialog in the IDE and I have to stop working and close it. It doesn't seem to affect anything but it stops my productivity. I'd like to resolve this.
Not sure if this is the right forum as I'm using WTP but it seems like a platform issue.
Version is:
Eclipse Java EE IDE for Web Developers.
Build id: 20090920-1017
We have a standard Eclipse here that everyone uses so I can't update to a later version.
Re: Error "org.eclipse.jface" [message #551939 is a reply to message #551932] Tue, 10 August 2010 04:59 Go to previous messageGo to next message
It looks like a JDT-Problem - JFace is only catching the Exception but
is not the reason for it and it has to do with the ProblemView probably.
Tom
Am 10.08.10 10:44, schrieb Matt Rossner:
> !STACK 0
> il.java:2710)
> java:145)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> Viewer.java:2033)
> ava:554)
> Viewer.java:1977)
> rovider.java:74)
> onizer.java:134)
> a:3855)
> a:2405)
> (Realm.java:332)
> bench.java:493)
> ava:149)
> tarter.java:368)
> tarter.java:179)
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> platform issue.
> Version is:
> a later version.
Re: Error "org.eclipse.jface" [message #551951 is a reply to message #551939] Tue, 10 August 2010 05:25 Go to previous message
I restarted Eclipse with -clean and for now it seems to have fixed the problem.
Previous Topic:Common Navigator and IMArker
Next Topic:Simple Eclipse multi-page editor question
Current Time: Sun Aug 31 09:57:46 EDT 2025
Powered by FUDForum. Page generated in 0.03552 seconds
