Home » Archived » BIRT » Number formatting in BIRT 2.3.1
Number formatting in BIRT 2.3.1 [message #551885] Mon, 09 August 2010 20:17 Go to next message
Hi all,
Am trying to get some numeric data in the following format
##,##,###.00
In other words, the 3 least significant digits need to be together and grouping is of every 2 digits after that.
eg: 12,12,223.45
Is this possible using custom number formatting in BIRT 2.3.1?
Re: Number formatting in BIRT 2.3.1 [message #552009 is a reply to message #551885] Tue, 10 August 2010 10:12 Go to previous messageGo to next message
BIRT has number formatting and can also call java classes if you want to
do something different than the default. I tried with the pattern you
posted and it did not come out like you needed. Can you produce what
you need with Java number formatting?
Jason
On 8/9/2010 8:17 PM, Amit Bhargava wrote:
> Hi all,
> ##,##,###.00
> eg: 12,12,223.45
Re: Number formatting in BIRT 2.3.1 [message #552642 is a reply to message #552009] Thu, 12 August 2010 22:39 Go to previous messageGo to next message
Thanks for the reply, Jason. It turned out the normal formatting was sufficient for our purposes.
Just in case, could you please give me an example of how a custom Java class would be called to provide formatting?
Re: Number formatting in BIRT 2.3.1 [message #552819 is a reply to message #552642] Fri, 13 August 2010 11:59 Go to previous message
You can import any class that is in the classpath. For example suppose
I wanted to format dates a different way. I could do this in script or
an expression like:
var mydt1 =params["date1"].value
var mydt2 =params["date2"].value
importPackage( Packages.java.text );
var sdf = new SimpleDateFormat("MMM d, yyyy");
var mydtf1 = sdf.format( mydt1 );
var mydtf2 = sdf.format( mydt2 );
mydtf1 + "-" + mydtf2
Jason
> Thanks
Previous Topic:subtotals for multipage tables
Next Topic:Multiple Charts on a Canvas
Current Time: Sat Jul 26 02:53:07 EDT 2025
Powered by FUDForum. Page generated in 0.04526 seconds
