Home » Modeling » MDT (Model Development Tools) » [BPMN2] Missing namespace export for XSD-based serialization
[BPMN2] Missing namespace export for XSD-based serialization [message #551700] Mon, 09 August 2010 04:54 Go to next message
Using the BPMN2 project to play around a bit I got stuck deserializing BPMN2 models in XSD style (cf. http://www.eclipse.org/forums/index.php?t=msg&th=173115& amp;start=0&S=b232df95af50d48184cbb94714d2827f). I fixed this adding the following entry to the org.eclipse.bpmn2 plugin.xml:
   <extension point="org.eclipse.emf.ecore.generated_package">
      <package
            class="org.eclipse.bpmn2.Bpmn2Package"
            genModel="model/BPMN20.genmodel"
            uri="http://www.omg.org/spec/BPMN/20100524/MODEL"/>
   </extension>
Do I miss something or is this a bug?
Joern
Re: [BPMN2] Missing namespace export for XSD-based serialization [message #551706 is a reply to message #551700] Mon, 09 August 2010 05:45 Go to previous messageGo to next message
Hello Joern,
thanks for using the BPMN 2 project and pointing this out.
This is to some extent a known problem, but I had hoped that it was solved:
We now register the XML namespace separately in code. It could be, however, that Xtext relies directly on the information in plugin.xml.
I'll try to test this myself - if you could supply a small sample that would be useful.
Which "version" of our project do you use? The latest from our git repository?
Henning
Re: [BPMN2] Missing namespace export for XSD-based serialization [message #551727 is a reply to message #551700] Mon, 09 August 2010 07:12 Go to previous messageGo to next message
Hello Henning,
yes - got it from http://git.eclipse.org/c/bpmn2/.
I wrote a small workaround to reference bpmn2 models in xText models. If you drop me a note with your email I can send you the source for the workaround and the corresponding ecore/xText projects.
Essential a sample grammar looks like (assuming a corresponding ecore model)
grammar foo.bar.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
import "platform:/resource/foo.bar.ecore/model/My.ecore"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model:
	elements+=Element*;
Element :
	Modelimport | Greeting
Modelimport :
	'Import'
	importURI=STRING
Greeting:
	'Hello' name=ID '!'
	('Reference' reference=[ecore::EObject])?;
A sample xText model will look like (assuming a bpmn2 model called "My.bpmn2" in the same directory containing an element with the name "MyProcess"):
Import "My.bpmn2"
Hello Henning !
Reference MyProcess
Joern
[Updated on: Mon, 09 August 2010 07:13] by Moderator
Re: [BPMN2] Missing namespace export for XSD-based serialization [message #551732 is a reply to message #551727] Mon, 09 August 2010 07:43 Go to previous messageGo to next message
Joern wrote on Mon, 09 August 2010 07:12
Thanks, that would be helpful: [e-mail address removed]
Henning
[Updated on: Mon, 09 August 2010 10:11] by Moderator
Re: [BPMN2] Missing namespace export for XSD-based serialization [message #551934 is a reply to message #551700] Tue, 10 August 2010 04:45 Go to previous message
This is now fixed in our repository (see bug 320079).
Thank you again for bringing this problem to our attention.
Previous Topic:MDT Installation with sources
Next Topic:[BPMN2] Missing namespace export for XSD-based serialization
Current Time: Sat Jul 26 20:33:34 EDT 2025
Powered by FUDForum. Page generated in 0.03914 seconds
