Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [TEXO] overriding templates question
[TEXO] overriding templates question [message #551464] |
Fri, 06 August 2010 10:33  |
Hi !
I read about that Texo is not supporting emf's EOperation during code generation process.
I am wondering if it makes sens to override "entity_addition.xpt" template to generate code for my EOperations defined in my Ecore file which are not generated by Texo itself.
Texo documentations states that:
The template is called with model annotations as the main class. The model annotation enriches the domain model with code generation specific information (for example the java class). In addition you have access to the underlying model element (EPackage, etc.). There are model annotation for each of the main model elements (EPackage, EClass, EStructuralFeature, EReference, EAttribute, EDataType, EEnum).
So I guess it is possible to get EClass and using EMF API's extract EOperation's and generate methods signatures ?
Did any one tried that ? Or maybe I have totally misunderstood the whole concept ?
With regards, e1n
Re: [TEXO] overriding templates question [message #551529 is a reply to message #551464] |
Fri, 06 August 2010 16:01   |
Hi Michal,
You understand it completely correct! The default entity_addition.xpt has this code:
«DEFINE root(ModelController modelController) FOR EClassModelGenAnnotation-»
«ENDDEFINE»
so the 'this' inside the DEFINE is an instance of the EClassModelGenAnnotation class. This expression can be used to get
to the eclass:
this.EClass
and from there you can find the eoperation.
Btw, I would like to add eoperation support to Texo (just to be complete..), so if you are interested and your
implementation is generic then contributions are always wellcomed!
gr. Martin
On 08/06/2010 04:33 PM, e1n wrote:
> Hi !
> generation process.
> Texo documentations states that: The template is called with model
> EDataType, EEnum).
> concept ?
> With regards, e1n
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TEXO] overriding templates question [message #551626 is a reply to message #551529] |
Sun, 08 August 2010 09:01   |
Hi Martin !
I have faced a problem during template overriding. I have copied all templates files from orignal plugin to my templates folder and placed them on correct path (templates/org.eclipse/emf/texo/modelgenerator/templates).
I tried to regenerate whole model code to ensure that every thing would work just fine but when I right clicked on my ecore file and selected "Generate Model Code" option. Nothing happened . Later i have found the cause of such behavior in my system console:
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] Aug 8, 2010 2:53:07 PM org.eclipse.emf.mwe.core.WorkflowRunner prepare
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] INFO: --------------------------------------------------------------------------------------
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] INFO: EMF Modeling Workflow Engine 0.7.2, Build v200908120417
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] INFO: (c) 2005-2009 openarchitectureware.org and contributors
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] INFO: running workflow: /org/eclipse/emf/texo/generator/generate_model.oaw
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] Aug 8, 2010 2:53:07 PM org.eclipse.emf.mwe.core.container.CompositeComponent internalInvoke
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] INFO: ArtifactGenerator: generating 'org::eclipse::emf::texo::modelgenerator::templates::model::root(modelController) FOREACH modelController.EPackages' => [src, java:src]
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] java.lang.IllegalStateException: Exception loading resource org/eclipse/emf/texo/modelgenerator/templates/model.xpt
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.TexoResourceManager.loadResource(TexoResourceManager.java:108)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xpand2.XpandExecutionContextImpl.findTemplate(XpandExecutionContextImpl.java:195)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xpand2.XpandExecutionContextImpl.findTemplate(XpandExecutionContextImpl.java:188)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xpand2.XpandExecutionContextImpl.findDefinition(XpandExecutionContextImpl.java:145)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.ast.ExpandStatement.invokeDefinition(ExpandStatement.java:174)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.ast.ExpandStatement.evaluateInternal(ExpandStatement.java:145)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.ast.Statement.evaluate(Statement.java:39)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xpand2.Generator.invokeInternal2(Generator.java:334)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.ArtifactGenerator.invokeInternal2(ArtifactGenerator.java:88)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflowComponent.invokeInternal(AbstractExpressionsUsingWorkflowComponent.java:191)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:124)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.mwe.core.container.CompositeComponent.internalInvoke(CompositeComponent.java:101)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.mwe.core.container.CompositeComponent.invoke(CompositeComponent.java:86)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.mwe.core.WorkflowRunner.executeWorkflow(WorkflowRunner.java:412)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.WorkFlowStarter.runWorkFlow(WorkFlowStarter.java:169)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.WorkFlowStarter.runWorkFlow(WorkFlowStarter.java:123)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.WorkFlowStarter.generateModelCode(WorkFlowStarter.java:77)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUris(GenerateCode.java:55)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:120)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:99)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.access$0(BaseGenerateAction.java:81)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction$1.execute(BaseGenerateAction.java:71)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1800)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] Caused by: org.eclipse.internal.xtend.xtend.parser.ParseException: no viable alternative at character '?' on line 1
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandParseFacade$3.handleError(XpandParseFacade.java:77)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandParseFacade$1.reportError(XpandParseFacade.java:57)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.antlr.runtime.Lexer.nextToken(Lexer.java:119)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.antlr.runtime.CommonTokenStream.fillBuffer(CommonTokenStream.java:95)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.antlr.runtime.CommonTokenStream.LT(CommonTokenStream.java:238)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandLocationAddingParser.start(XpandLocationAddingParser.java:43)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandLocationAddingParser.template(XpandLocationAddingParser.java:289)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandParseFacade.file(XpandParseFacade.java:44)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandParseFacade.file(XpandParseFacade.java:31)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xpand2.XpandExecutionContextImpl$1.parse(XpandExecutionContextImpl.java:92)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.TexoResourceManager.loadResource(TexoResourceManager.java:103)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] ... 25 more
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] Aug 8, 2010 2:53:07 PM org.eclipse.emf.mwe.core.WorkflowRunner executeWorkflow
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] INFO: workflow completed in 37ms!
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] Aug 8, 2010 2:53:07 PM org.eclipse.emf.mwe.core.WorkflowRunner logIssues
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] SEVERE: [ERROR]: Exception loading resource org/eclipse/emf/texo/modelgenerator/templates/model.xpt(Element: EXPAND org::eclipse::emf::texo::modelgenerator::templates::model::root(modelController) FOREACH modelController.EPackages; Reported by: ArtifactGenerator: generating 'org::eclipse::emf::texo::modelgenerator::templates::model::root(modelController) FOREACH modelController.EPackages' => [/Users/michabartoszewski/Documents/workspace/MagisterkaTexo/src, java:/Users/michabartoszewski/Documents/workspace/MagisterkaTexo/src])
8/8/10 2:53:46 PM Spotlight[162] /SourceCache/Spotlight/Spotlight-398.26/menu/Application/../Models/MDQueryWorker.m -[MDQueryWorker startQuery:withFlags:] Can't execute query '(* = "termin*"cdw || kMDItemTextContent = "termin*"cdw)'
With regards, e1n
Re: [TEXO] overriding templates question [message #551648 is a reply to message #551529] |
Sun, 08 August 2010 18:15   |
Hi Martin,
I have programmed some support for EOperations generation.
But right now it is just draft of working implementation.
I was reading Texo code and studying it's ecore files etc.
But I couldn't managed to find piece of code which is responsible
for transformation of EMF basic types like EString, EBoolean etc. to Java types like String, Boolean etc.
Can you give me a hint where I could find it ?
With regards, e1n
Martin taal wrote on Fri, 06 August 2010 16:01 | Hi Michal,
«ENDDEFINE»
to the eclass:
this.EClass
gr. Martin
> Hi !
> generation process.
> EDataType, EEnum).
> concept ?
> With regards, e1n
The Netherlands
Re: [TEXO] overriding templates question [message #551696 is a reply to message #551648] |
Mon, 09 August 2010 04:22  |
Hi Michal,
This is done in java through the GenUtils class:
org.eclipse.emf.texo.modelgenerator.annotator.GenUtils.getIn stanceClassName(eDataType)
But it is probably better to get the model annotation class for the edatatype. So if 'this' is the edatatype then this
call in xpand will give you the ModelEDataTypeAnnotation:
modelController.getAnnotation(this, ModelcodegeneratorPackage::eNS_URI)
on this instance you can call:
getInstanceClassName()
to get the type name to use in java
This do this call you need to have these imports in the top:
«IMPORT org::eclipse::emf::ecore»
«IMPORT org::eclipse::emf::texo::generator»
«IMPORT org::eclipse::emf::texo::modelgenerator::modelannotations»
gr. Martin
On 08/09/2010 12:15 AM, e1n wrote:
> Hi Martin,
> With regards, e1n
>> Hi Michal,
>> has this code:
>> «ENDDEFINE»
>> EClassModelGenAnnotation class. This expression can be used to get to
>> the eclass:
>> this.EClass
>> complete..), so if you are interested and your implementation is
>> gr. Martin
>> > Hi !
>> > generation process.
>> > EDataType, EEnum).
>> whole
>> > concept ?
>> > With regards, e1n
>> The Netherlands
The Netherlands
Re: [TEXO] overriding templates question [message #623128 is a reply to message #551529] |
Hi Martin !
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] INFO: ------------------------------------------------------------ --------------------------
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] INFO: ArtifactGenerator: generating 'org::eclipse::emf::texo::modelgenerator::templates::model:: root(modelController) FOREACH modelController.EPackages' => [src, java:src]
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.TexoResourceManager.loadResou rce(TexoResourceManager.java:108)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xpand2.XpandExecutionContextImpl.findTemplate(Xp andExecutionContextImpl.java:195)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xpand2.XpandExecutionContextImpl.findTemplate(Xp andExecutionContextImpl.java:188)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xpand2.XpandExecutionContextImpl.findDefinition( XpandExecutionContextImpl.java:145)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.ast.ExpandStatement.invokeDefini tion(ExpandStatement.java:174)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.ast.ExpandStatement.evaluateInte rnal(ExpandStatement.java:145)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.ast.Statement.evaluate(Statement .java:39)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xpand2.Generator.invokeInternal2(Generator.java: 334)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.ArtifactGenerator.invokeInter nal2(ArtifactGenerator.java:88)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflo wComponent.invokeInternal(AbstractExpressionsUsingWorkflowCo mponent.java:191)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invok e(AbstractWorkflowComponent.java:124)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.mwe.core.container.CompositeComponent.intern alInvoke(CompositeComponent.java:101)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.mwe.core.container.CompositeComponent.invoke (CompositeComponent.java:86)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.mwe.core.WorkflowRunner.executeWorkflow(Work flowRunner.java:412)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.WorkFlowStarter.runWorkFlow(W orkFlowStarter.java:169)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.WorkFlowStarter.runWorkFlow(W orkFlowStarter.java:123)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.WorkFlowStarter.generateModel Code(WorkFlowStarter.java:77)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.gene rateFromUris(GenerateCode.java:55)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateActio n.generate(BaseGenerateAction.java:120)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateActio n.generate(BaseGenerateAction.java:99)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateActio n.access$0(BaseGenerateAction.java:81)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateActio n$1.execute(BaseGenerateAction.java:71)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:106)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:118)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandParseFacade$3.handle Error(XpandParseFacade.java:77)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandParseFacade$1.report Error(XpandParseFacade.java:57)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.antlr.runtime.CommonTokenStream.fillBuffer(CommonTokenSt ream.java:95)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.antlr.runtime.CommonTokenStream.LT(CommonTokenStream.jav a:238)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandLocationAddingParser .start(XpandLocationAddingParser.java:43)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandLocationAddingParser .template(XpandLocationAddingParser.java:289)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandParseFacade.file(Xpa ndParseFacade.java:44)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.internal.xpand2.parser.XpandParseFacade.file(Xpa ndParseFacade.java:31)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.xpand2.XpandExecutionContextImpl$1.parse(XpandEx ecutionContextImpl.java:92)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] at org.eclipse.emf.texo.generator.TexoResourceManager.loadResou rce(TexoResourceManager.java:103)
8/8/10 2:53:07 PM [0x0-0x25025].org.eclipse.eclipse[271] SEVERE: [ERROR]: Exception loading resource org/eclipse/emf/texo/modelgenerator/templates/model.xpt(Elem ent: EXPAND org::eclipse::emf::texo::modelgenerator::templates::model::r oot(modelController) FOREACH modelController.EPackages; Reported by: ArtifactGenerator: generating 'org::eclipse::emf::texo::modelgenerator::templates::model:: root(modelController) FOREACH modelController.EPackages' => [/Users/michabartoszewski/Documents/workspace/MagisterkaTexo /src, java:/Users/michabartoszewski/Documents/workspace/Magisterka Texo/src])
8/8/10 2:53:46 PM Spotlight[162] /SourceCache/Spotlight/Spotlight-398.26/menu/Application/../ Models/MDQueryWorker.m -[MDQueryWorker startQuery:withFlags:] Can't execute query '(* = "termin*"cdw || kMDItemTextContent = "termin*"cdw)'
With regards, e1n
Re: [TEXO] overriding templates question [message #623129 is a reply to message #623128] |
Sun, 08 August 2010 10:30  |
Ok i have figured out what was wrong. It was issue with encoding. Eclipse was using MacRoman encoding and Xpand uses those «,» characters which where surrounded with some additional control characters in my case.
I have changed encoding globally to UTF-8 and manual edited templates files. Now everything is ok.
With regards, e1n
Re: [TEXO] overriding templates question [message #623130 is a reply to message #551529] |
Hi Martin,
With regards, e1n
> Hi Michal,
> «ENDDEFINE»
> to the eclass:
> this.EClass
> gr. Martin
> > Hi !
> > generation process.
> > EDataType, EEnum).
> > concept ?
> > With regards, e1n
> The Netherlands
Re: [TEXO] overriding templates question [message #623133 is a reply to message #623130] |
Hi Michal,
gr. Martin
> Hi Martin,
> With regards, e1n
>> Hi Michal,
>> has this code:
>> «ENDDEFINE»
>> the eclass:
>> this.EClass
>> gr. Martin
>> > Hi !
>> > generation process.
>> > EDataType, EEnum).
>> whole
>> > concept ?
>> > With regards, e1n
>> The Netherlands
The Netherlands
Current Time: Sat Jul 19 00:50:41 EDT 2025
Powered by FUDForum. Page generated in 0.04626 seconds
