Home » Modeling » GMF (Graphical Modeling Framework) » How to change the order in which the properties are listed ?
How to change the order in which the properties are listed ? [message #551408] Fri, 06 August 2010 06:12 Go to next message
Hi All,
In GMF editor "Show property view" all the properties are listed in ascending order by default. Is it possible to change their order?
regards,
Syed Imran
Re: How to change the order in which the properties are listed ? [message #551449 is a reply to message #551408] Fri, 06 August 2010 08:56 Go to previous messageGo to next message
--------------080007040807060801050700
in the two classes i attach the propertySheetPage represents a sheet
page which uses the custom propertySheetSorter to sort the attributes.
After you modify the sorter to your will, you need to create a third
class (e.g. MyAdvancedPropertySection) that extends the
AdvancedPropertySection and overrides the createControls method to
initialize a MyPropertySheetPage instead of the default
PropertySheetPage as the page member. Finally, you just set the
XXXPropertySection.java located in your XXX.diagram.sheet package to
extend the MyAdvancedPropertySection class.
Hope this helps,
Pantelis
On 6/8/2010 1:12 μμ, Syed Imran wrote:
> Hi All,
> regards,
> Syed Imran
name="MyPropertySheetPage.java"
filename="MyPropertySheetPage.java"
cGFja2FnZSBvcmcuZWNsaXBzZS5nbWYuc25hcHQucHJvcGVydGllczsNCg0K aW1wb3J0IG9y
Zy5lY2xpcHNlLnVpLnZpZXdzLnByb3BlcnRpZXMuUHJvcGVydHlTaGVldFBh Z2U7DQppbXBv
cnQgb3JnLmVjbGlwc2UudWkudmlld3MucHJvcGVydGllcy5Qcm9wZXJ0eVNo ZWV0U29ydGVy
Ow0KDQpwdWJsaWMgY2xhc3MgTXlQcm9wZXJ0eVNoZWV0UGFnZSBleHRlbmRz IFByb3BlcnR5
U2hlZXRQYWdlIHsNCg0KICAgIHB1YmxpYyBNeVByb3BlcnR5U2hlZXRQYWdl KCkgew0KICAg
ICAgICBzdXBlcigpOw0KICAgICAgICBzZXRTb3J0ZXIobmV3IE15UHJvcGVy dHlTaGVldFNv
cnRlcigpKTsNCiAgICB9DQoNCiAgICBAT3ZlcnJpZGUNCiAgICBwcm90ZWN0 ZWQgdm9pZCBz
ZXRTb3J0ZXIoUHJvcGVydHlTaGVldFNvcnRlciBzb3J0ZXIpIHsNCiAgICAg ICAgaWYgKCEo
c29ydGVyIGluc3RhbmNlb2YgTXlQcm9wZXJ0eVNoZWV0U29ydGVyKSkNCiAg ICAgICAgICAg
IHNvcnRlciA9IG5ldyBNeVByb3BlcnR5U2hlZXRTb3J0ZXIoKTsNCg0KICAg ICAgICBzdXBl
ci5zZXRTb3J0ZXIoc29ydGVyKTsNCiAgICB9DQoNCn0gDQo=
name="MyPropertySheetSorter.java"
filename="MyPropertySheetSorter.java"
cGFja2FnZSBvcmcuZWNsaXBzZS5nbWYuc25hcHQucHJvcGVydGllczsNCg0K aW1wb3J0IGph
dmEudXRpbC5IYXNoTWFwOw0KDQppbXBvcnQgb3JnLmVjbGlwc2UudWkudmll d3MucHJvcGVy
dGllcy5JUHJvcGVydHlTaGVldEVudHJ5Ow0KaW1wb3J0IG9yZy5lY2xpcHNl LnVpLnZpZXdz
LnByb3BlcnRpZXMuUHJvcGVydHlTaGVldFNvcnRlcjsNCg0KcHVibGljIGNs YXNzIE15UHJv
cGVydHlTaGVldFNvcnRlciBleHRlbmRzIFByb3BlcnR5U2hlZXRTb3J0ZXIg ew0KDQoJQE92
ZXJyaWRlDQogICAgcHVibGljIHZvaWQgc29ydChJUHJvcGVydHlTaGVldEVu dHJ5W10gZW50
cmllcykgew0KCQlIYXNoTWFwPFN0cmluZywgSW50ZWdlcj4gcHJvcGVydGll cyA9IG5ldyBI
YXNoTWFwPFN0cmluZywgSW50ZWdlcj4oKTsNCgkJcHJvcGVydGllcy5wdXQo IlNlcnZpY2VO
ZXR3b3JrSWQiLCBuZXcgSW50ZWdlcigxKSk7DQoJCXByb3BlcnRpZXMucHV0 KCJJZCIsIG5l
dyBJbnRlZ2VyKDEpKTsNCgkJcHJvcGVydGllcy5wdXQoIk9yZGVyIiwgbmV3 IEludGVnZXIo
MikpOw0KCQlwcm9wZXJ0aWVzLnB1dCgiU2VydmljZSIsIG5ldyBJbnRlZ2Vy KDMpKTsNCgkJ
cHJvcGVydGllcy5wdXQoIk5hbWUiLCBuZXcgSW50ZWdlcigyKSk7DQoJCXBy b3BlcnRpZXMu
cHV0KCJEZXNjcmlwdGlvbiIsIG5ldyBJbnRlZ2VyKDMpKTsNCgkJcHJvcGVy dGllcy5wdXQo
IlRvdGFsQ29zdCIsIG5ldyBJbnRlZ2VyKDQpKTsNCgkJcHJvcGVydGllcy5w dXQoIlRvdGFs
UmV2ZW51ZSIsIG5ldyBJbnRlZ2VyKDUpKTsNCgkJcHJvcGVydGllcy5wdXQo IlJvbGUiLCBu
ZXcgSW50ZWdlcigzKSk7DQoJCXByb3BlcnRpZXMucHV0KCJQYXJ0aWNpcGFu dElkIiwgbmV3
IEludGVnZXIoMSkpOw0KCQlwcm9wZXJ0aWVzLnB1dCgiRW5hYmxlcklkIiwg bmV3IEludGVn
ZXIoMSkpOw0KCQlwcm9wZXJ0aWVzLnB1dCgiRW5kQ3VzdG9tZXJJZCIsIG5l dyBJbnRlZ2Vy
KDEpKTsNCgkJcHJvcGVydGllcy5wdXQoIkNvc3QiLCBuZXcgSW50ZWdlcig0 KSk7DQoJCXBy
b3BlcnRpZXMucHV0KCJSZXZlbnVlIiwgbmV3IEludGVnZXIoNSkpOw0KCQlw cm9wZXJ0aWVz
LnB1dCgiU291cmNlQnVzaW5lc3NFbnRpdHkiLCBuZXcgSW50ZWdlcig2KSk7 DQoJCXByb3Bl
cnRpZXMucHV0KCJUYXJnZXRCdXNpbmVzc0VudGl0eSIsIG5ldyBJbnRlZ2Vy KDcpKTsNCgkJ
cHJvcGVydGllcy5wdXQoIlNlcnZpY2VJZCIsIG5ldyBJbnRlZ2VyKDEpKTsN CgkJcHJvcGVy
dGllcy5wdXQoIlNlcnZpY2VFbmFibGVtZW50SWQiLCBuZXcgSW50ZWdlcigx KSk7DQoJCXBy
b3BlcnRpZXMucHV0KCJTb3VyY2VFbmFibGVyIiwgbmV3IEludGVnZXIoNikp Ow0KCQlwcm9w
ZXJ0aWVzLnB1dCgiVGFyZ2V0U2VydmljZSIsIG5ldyBJbnRlZ2VyKDcpKTsN CgkJcHJvcGVy
dGllcy5wdXQoIk91dGdvaW5nUG9ydCIsIG5ldyBJbnRlZ2VyKDcpKTsNCgkJ cHJvcGVydGll
cy5wdXQoIkluY29taW5nUG9ydCIsIG5ldyBJbnRlZ2VyKDYpKTsNCgkJcHJv cGVydGllcy5w
dXQoIkluY29taW5nU2VydmljZSIsIG5ldyBJbnRlZ2VyKDYpKTsNCgkJcHJv cGVydGllcy5w
dXQoIk91dGdvaW5nU2VydmljZSIsIG5ldyBJbnRlZ2VyKDcpKTsNCgkJDQog ICAgICAgIGZv
cihpbnQgaT0wOyBpPCBlbnRyaWVzLmxlbmd0aDsgKytpKXsNCiAgICAgICAg CWJvb2xlYW4g
c3dhcHBlZCA9IGZhbHNlOw0KICAgICAgICAJZm9yKGludCBqPTA7IGo8ZW50 cmllcy5sZW5n
dGgtMTsgKytqKXsNCiAgICAgICAgCQlpZihwcm9wZXJ0aWVzLmdldChlbnRy aWVzW2pdLmdl
dERpc3BsYXlOYW1lKCkucmVwbGFjZUFsbCgiICIsICIiKSkuaW50VmFsdWUo KT5wcm9wZXJ0
aWVzLmdldChlbnRyaWVzW2orMV0uZ2V0RGlzcGxheU5hbWUoKS5yZXBsYWNl QWxsKCIgIiwg
IiIpKS5pbnRWYWx1ZSgpKSB7DQogICAgICAgIAkJCXN3YXBwZWQgPSB0cnVl Ow0KICAgICAg
ICAJCQlJUHJvcGVydHlTaGVldEVudHJ5IHRlbXAgPSBlbnRyaWVzW2pdOw0K ICAgICAgICAJ
CQllbnRyaWVzW2pdID0gZW50cmllc1tqKzFdOw0KICAgICAgICAJCQllbnRy aWVzW2orMV0g
PSB0ZW1wOw0KICAgICAgICAJCX0NCiAgICAgICAgCX0NCiAgICAgICAgCWlm KCFzd2FwcGVk
KSBicmVhazsNCiAgICAgICAgfQ0KICAgIH0NCg0KfQ0K
--------------080007040807060801050700--
Re: How to change the order in which the properties are listed ? [message #551486 is a reply to message #551449] Fri, 06 August 2010 11:16 Go to previous messageGo to next message
Hi Pantelis,
Thanks, I am almost there.
The only thing is AdvancedPropertySection does not implement any methods then how to overrides the createControls method in a third class (e.g. MyAdvancedPropertySection).
kindy
Syed Imran
Re: How to change the order in which the properties are listed ? [message #551604 is a reply to message #551486] Sat, 07 August 2010 18:50 Go to previous messageGo to next message
--------------090602080507000809070108
hello,
i checked this out, i have created MyAdvancedPropertySection class which
is an exact copy of the original AdvancedPropertySection's code with the
only difference being that the "page" member is of MyPropertySheetPage
type. I attach it, if that helps
Pantelis
On 6/8/2010 6:16 μμ, Syed Imran wrote:
> Hi Pantelis,
> Thanks, I am almost there. The only thing is AdvancedPropertySection
> kindy
> Syed Imran
name="MyAdvancedPropertySection.java"
filename="MyAdvancedPropertySection.java"
cGFja2FnZSBvcmcuZWNsaXBzZS5nbWYuc25hcHQuZGlhZ3JhbS51aS5wcm9w ZXJ0aWVzOw0K
DQppbXBvcnQgb3JnLmVjbGlwc2UuY29yZS5jb21tYW5kcy5vcGVyYXRpb25z Lk9wZXJhdGlv
bkhpc3RvcnlGYWN0b3J5Ow0KaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5jb21t b24ubm90aWZ5
Lk5vdGlmaWNhdGlvbjsNCmltcG9ydCBvcmcuZWNsaXBzZS5lbWYuZWNvcmUu RU9iamVjdDsN
CmltcG9ydCBvcmcuZWNsaXBzZS5lbWYuZWRpdC5kb21haW4uRWRpdGluZ0Rv bWFpbjsNCmlt
cG9ydCBvcmcuZWNsaXBzZS5lbWYuZWRpdC5kb21haW4uSUVkaXRpbmdEb21h aW5Qcm92aWRl
cjsNCmltcG9ydCBvcmcuZWNsaXBzZS5lbWYudHJhbnNhY3Rpb24uTm90aWZp Y2F0aW9uRmls
dGVyOw0KaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi50cmFuc2FjdGlvbi5UcmFu c2FjdGlvbmFs
RWRpdGluZ0RvbWFpbjsNCmltcG9ydCBvcmcuZWNsaXBzZS5nbWYucnVudGlt ZS5kaWFncmFt
LnVpLnByb3BlcnRpZXMuc2VjdGlvbnMuQWJzdHJhY3RNb2RlbGVyUHJvcGVy dHlTZWN0aW9u
Ow0KaW1wb3J0IG9yZy5lY2xpcHNlLmdtZi5ydW50aW1lLmVtZi51aS5wcm9w ZXJ0aWVzLnNl
Y3Rpb25zLlVuZG9hYmxlTW9kZWxQcm9wZXJ0eVNoZWV0RW50cnk7DQppbXBv cnQgb3JnLmVj
bGlwc2UuZ21mLnNuYXB0LnByb3BlcnRpZXMuTXlQcm9wZXJ0eVNoZWV0UGFn ZTsNCmltcG9y
dCBvcmcuZWNsaXBzZS5qZmFjZS52aWV3ZXJzLklTZWxlY3Rpb247DQppbXBv cnQgb3JnLmVj
bGlwc2UuamZhY2Uudmlld2Vycy5JU3RydWN0dXJlZFNlbGVjdGlvbjsNCmlt cG9ydCBvcmcu
ZWNsaXBzZS5zd3QuU1dUOw0KaW1wb3J0IG9yZy5lY2xpcHNlLnN3dC5jdXN0 b20uQ0xhYmVs
Ow0KaW1wb3J0IG9yZy5lY2xpcHNlLnN3dC5sYXlvdXQuRm9ybUF0dGFjaG1l bnQ7DQppbXBv
cnQgb3JnLmVjbGlwc2Uuc3d0LmxheW91dC5Gb3JtRGF0YTsNCmltcG9ydCBv cmcuZWNsaXBz
ZS5zd3Qud2lkZ2V0cy5Db21wb3NpdGU7DQppbXBvcnQgb3JnLmVjbGlwc2Uu dWkuSUFjdGlv
bkJhcnM7DQppbXBvcnQgb3JnLmVjbGlwc2UudWkuSVdvcmtiZW5jaFBhcnQ7 DQppbXBvcnQg
b3JnLmVjbGlwc2UudWkudmlld3MucHJvcGVydGllcy5JUHJvcGVydHlTb3Vy Y2VQcm92aWRl
cjsNCmltcG9ydCBvcmcuZWNsaXBzZS51aS52aWV3cy5wcm9wZXJ0aWVzLnRh YmJlZC5UYWJi
ZWRQcm9wZXJ0eVNoZWV0UGFnZTsNCg0KcHVibGljIGNsYXNzIE15QWR2YW5j ZWRQcm9wZXJ0
eVNlY3Rpb24gZXh0ZW5kcyBBYnN0cmFjdE1vZGVsZXJQcm9wZXJ0eVNlY3Rp b24gew0KDQog
ICAgLyoqDQogICAgICogdGhlIHByb3BlcnR5IHNoZWV0IHBhZ2UgZm9yIHRo aXMgc2VjdGlv
bg0KICAgICAqLw0KICAgIHByb3RlY3RlZCBNeVByb3BlcnR5U2hlZXRQYWdl IHBhZ2U7DQog
IA0KICAgIC8qIChub24tSmF2YWRvYykNCiAgICAgKiBAc2VlIG9yZy5lY2xp cHNlLnVpLnZp
ZXdzLnByb3BlcnRpZXMudGFiYmVkLklTZWN0aW9uI2NyZWF0ZUNvbnRyb2xz KG9yZy5lY2xp
cHNlLnN3dC53aWRnZXRzLkNvbXBvc2l0ZSwgb3JnLmVjbGlwc2UudWkudmll d3MucHJvcGVy
dGllcy50YWJiZWQuVGFiYmVkUHJvcGVydHlTaGVldFBhZ2UpDQogICAgICov DQogICAgcHVi
bGljIHZvaWQgY3JlYXRlQ29udHJvbHMoZmluYWwgQ29tcG9zaXRlIHBhcmVu dCwNCiAgICAg
ICAgICAgIFRhYmJlZFByb3BlcnR5U2hlZXRQYWdlIGFUYWJiZWRQcm9wZXJ0 eVNoZWV0UGFn
ZSkgew0KICAgICAgICBzdXBlci5jcmVhdGVDb250cm9scyhwYXJlbnQsIGFU YWJiZWRQcm9w
ZXJ0eVNoZWV0UGFnZSk7DQogICAgICAgIENvbXBvc2l0ZSBjb21wb3NpdGUg PSBnZXRXaWRn
ZXRGYWN0b3J5KCkNCiAgICAgICAgICAgICAgICAuY3JlYXRlRmxhdEZvcm1D b21wb3NpdGUo
cGFyZW50KTsNCiAgICAgICAgRm9ybURhdGEgZGF0YSA9IG51bGw7DQoNCiAg ICAgICAgU3Ry
aW5nIHRhYmxlTGFiZWxTdHIgPSBnZXRUYWJsZUxhYmVsKCk7DQogICAgICAg IENMYWJlbCB0
YWJsZUxhYmVsID0gbnVsbDsNCiAgICAgICAgaWYgKHRhYmxlTGFiZWxTdHIg IT0gbnVsbCAm
JiB0YWJsZUxhYmVsU3RyLmxlbmd0aCgpID4gMCkgew0KICAgICAgICAgICAg dGFibGVMYWJl
bCA9IGdldFdpZGdldEZhY3RvcnkoKS5jcmVhdGVDTGFiZWwoY29tcG9zaXRl LA0KICAgICAg
ICAgICAgICAgICAgICB0YWJsZUxhYmVsU3RyKTsNCiAgICAgICAgICAgIGRh dGEgPSBuZXcg
Rm9ybURhdGEoKTsNCiAgICAgICAgICAgIGRhdGEubGVmdCA9IG5ldyBGb3Jt QXR0YWNobWVu
dCgwLCAwKTsNCiAgICAgICAgICAgIGRhdGEudG9wID0gbmV3IEZvcm1BdHRh Y2htZW50KDAs
IDApOw0KICAgICAgICAgICAgdGFibGVMYWJlbC5zZXRMYXlvdXREYXRhKGRh dGEpOw0KICAg
ICAgICB9DQoNCiAgICAgICAgcGFnZSA9IG5ldyBNeVByb3BlcnR5U2hlZXRQ YWdlKCk7DQog
ICAgICAgIFVuZG9hYmxlTW9kZWxQcm9wZXJ0eVNoZWV0RW50cnkgcm9vdCA9 IG5ldyBVbmRv
YWJsZU1vZGVsUHJvcGVydHlTaGVldEVudHJ5KA0KICAgICAgICAgICAgT3Bl cmF0aW9uSGlz
dG9yeUZhY3RvcnkuZ2V0T3BlcmF0aW9uSGlzdG9yeSgpKTsNCiAgICAgICAg DQogICAgICAg
IHJvb3Quc2V0UHJvcGVydHlTb3VyY2VQcm92aWRlcihnZXRQcm9wZXJ0eVNv dXJjZVByb3Zp
ZGVyKCkpOw0KICAgICAgICBwYWdlLnNldFJvb3RFbnRyeShyb290KTsNCg0K ICAgICAgICBw
YWdlLmNyZWF0ZUNvbnRyb2woY29tcG9zaXRlKTsNCiAgICAgICAgZGF0YSA9 IG5ldyBGb3Jt
RGF0YSgpOw0KICAgICAgICBkYXRhLmxlZnQgPSBuZXcgRm9ybUF0dGFjaG1l bnQoMCwgMCk7
DQogICAgICAgIGRhdGEucmlnaHQgPSBuZXcgRm9ybUF0dGFjaG1lbnQoMTAw LCAwKTsNCiAg
ICAgICAgaWYgKHRhYmxlTGFiZWwgPT0gbnVsbCkgew0KICAgICAgICAgICAg ZGF0YS50b3Ag
PSBuZXcgRm9ybUF0dGFjaG1lbnQoMCwgMCk7DQogICAgICAgIH0gZWxzZSB7 DQogICAgICAg
ICAgICBkYXRhLnRvcCA9IG5ldyBGb3JtQXR0YWNobWVudCh0YWJsZUxhYmVs LCAwLCBTV1Qu
Qk9UVE9NKTsNCiAgICAgICAgfQ0KICAgICAgICBkYXRhLmJvdHRvbSA9IG5l dyBGb3JtQXR0
YWNobWVudCgxMDAsIDApOw0KICAgICAgICBkYXRhLmhlaWdodCA9IDEwMDsN CiAgICAgICAg
ZGF0YS53aWR0aCA9IDEwMDsNCiAgICAgICAgcGFnZS5nZXRDb250cm9sKCku c2V0TGF5b3V0
RGF0YShkYXRhKTsNCg0KICAgICAgICBzZXRBY3Rpb25CYXJzKGFUYWJiZWRQ cm9wZXJ0eVNo
ZWV0UGFnZS5nZXRTaXRlKCkuZ2V0QWN0aW9uQmFycygpKTsNCiAgICAgICAg DQogICAgfQ0K
DQogICAgLyoqDQogICAgICogU2V0cyBhbmQgcHJlcGFyZXMgdGhlIGFjdGlv bkJhcnMgZm9y
IHRoaXMgc2VjdGlvbg0KICAgICAqICANCiAgICAgKiBAcGFyYW0gYWN0aW9u QmFycyB0aGUg
YWN0aW9uIGJhcnMgZm9yIHRoaXMgcGFnZQ0KICAgICAqIEBzZWUgb3JnLmVj bGlwc2UuZ21m
LnJ1bnRpbWUuY29tbW9uLnVpLnByb3BlcnRpZXMuVGFiYmVkUHJvcGVydHlT aGVldFBhZ2Uj
c2V0QWN0aW9uQmFycyhvcmcuZWNsaXBzZS51aS5JQWN0aW9uQmFycykNCiAg ICAgKi8gICAN
CiAgICBwdWJsaWMgdm9pZCBzZXRBY3Rpb25CYXJzKElBY3Rpb25CYXJzIGFj dGlvbkJhcnMp
IHsNCiAgICAgICAgaWYgKGFjdGlvbkJhcnMgIT0gbnVsbCkgew0KICAgICAg ICAJYWN0aW9u
QmFycy5nZXRNZW51TWFuYWdlcigpLnJlbW92ZUFsbCgpOw0KICAgICAgICAJ YWN0aW9uQmFy
cy5nZXRUb29sQmFyTWFuYWdlcigpLnJlbW92ZUFsbCgpOw0KICAgICAgICAJ YWN0aW9uQmFy
cy5nZXRTdGF0dXNMaW5lTWFuYWdlcigpLnJlbW92ZUFsbCgpOw0KDQogICAg ICAgIAlwYWdl
Lm1ha2VDb250cmlidXRpb25zKGFjdGlvbkJhcnMuZ2V0TWVudU1hbmFnZXIo KSwgYWN0aW9u
QmFycw0KICAgICAgICAJCQkuZ2V0VG9vbEJhck1hbmFnZXIoKSwgYWN0aW9u QmFycy5nZXRT
dGF0dXNMaW5lTWFuYWdlcigpKTsNCiAgICAgICAgDQogICAgICAgIAlhY3Rp b25CYXJzLmdl
dFRvb2xCYXJNYW5hZ2VyKCkudXBkYXRlKHRydWUpOw0KICAgICAgICB9DQoN CiAgICB9DQoN
CiAgICAvKioNCiAgICAgKiBSZXR1cm5zIHRoZSBQcm9wZXJ0eVNvdXJjZSBw cm92aWRlci4g
VGhlIGRlZmF1bHQgaW1wbGVtZW50YXRpb24gcmV0dXJucw0KICAgICAqIHN0 YXRpYyBhZGFw
dGVyIGZhY3RvcnkgZm9yIHRoZSBwcm9wZXJ0aWVzIHNlcnZpY2VzLiBJZiB0 aGUgZXh0ZW5k
aW5nDQogICAgICogY2xhc3MgbmVlZHMgdG8gdXNlIGEgZGlmZmVyZW50IHBy b3ZpZGVyIHRo
ZW4gdGhpcyBtZXRob2QgaGFzIHRvIGJlDQogICAgICogb3ZlcndyaXRlbi4N CiAgICAgKiAN
CiAgICAgKiBAcmV0dXJuIFRoZSBQcm9wZXJ0eVNvdXJjZSBwcm92aWRlcg0K ICAgICAqLw0K
ICAgIHByb3RlY3RlZCBJUHJvcGVydHlTb3VyY2VQcm92aWRlciBnZXRQcm9w ZXJ0eVNvdXJj
ZVByb3ZpZGVyKCkgew0KICAgICAgICByZXR1cm4gcHJvcGVydGllc1Byb3Zp ZGVyOw0KICAg
IH0NCg0KICAgIC8qKg0KICAgICAqIFJldHVybnMgdGhlIGxhYmVsIGZvciB0 aGUgdGFibGUu
IFRoZSBkZWZhdWx0IGltcGxlbWVudGF0aW9uIHJldHVybnMgbnVsbCwNCiAg ICAgKiB0aGF0
IGlzLCB0aGVyZSBpcyBubyBsYWJlbC4NCiAgICAgKiANCiAgICAgKiBAcmV0 dXJuIFRoZSBs
YWJlbCBmb3IgdGhlIHRhYmxlDQogICAgICovDQogICAgcHJvdGVjdGVkIFN0 cmluZyBnZXRU
YWJsZUxhYmVsKCkgew0KICAgICAgICByZXR1cm4gbnVsbDsNCiAgICB9DQoN CiAgIA0KICAg
IC8qIChub24tSmF2YWRvYykNCiAgICAgKiBAc2VlIG9yZy5lY2xpcHNlLnVp LnZpZXdzLnBy
b3BlcnRpZXMudGFiYmVkLklTZWN0aW9uI3NldElucHV0KG9yZy5lY2xpcHNl LnVpLklXb3Jr
YmVuY2hQYXJ0LCBvcmcuZWNsaXBzZS5qZmFjZS52aWV3ZXJzLklTZWxlY3Rp b24pDQogICAg
ICovDQogICAgcHVibGljIHZvaWQgc2V0SW5wdXQoSVdvcmtiZW5jaFBhcnQg cGFydCwgSVNl
bGVjdGlvbiBzZWxlY3Rpb24pIHsNCiAgICAgICAgSUVkaXRpbmdEb21haW5Q cm92aWRlciBw
cm92aWRlciA9IChJRWRpdGluZ0RvbWFpblByb3ZpZGVyKSBwYXJ0DQogICAg ICAgICAgICAu
Z2V0QWRhcHRlcihJRWRpdGluZ0RvbWFpblByb3ZpZGVyLmNsYXNzKTsNCiAg ICAgICAgaWYg
KHByb3ZpZGVyICE9IG51bGwpIHsNCiAgICAgICAgICAgIEVkaXRpbmdEb21h aW4gdGhlRWRp
dGluZ0RvbWFpbiA9IHByb3ZpZGVyLmdldEVkaXRpbmdEb21haW4oKTsNCiAg ICAgICAgICAg
IGlmICh0aGVFZGl0aW5nRG9tYWluIGluc3RhbmNlb2YgVHJhbnNhY3Rpb25h bEVkaXRpbmdE
b21haW4pIHsNCiAgICAgICAgICAgICAgICBzZXRFZGl0aW5nRG9tYWluKChU cmFuc2FjdGlv
bmFsRWRpdGluZ0RvbWFpbikgdGhlRWRpdGluZ0RvbWFpbik7DQogICAgICAg ICAgICB9DQog
ICAgICAgIH0NCiAgICAgICAgDQogICAgICAgIC8vIFNldCB0aGUgZU9iamVj dCBmb3IgdGhl
IHNlY3Rpb24sIHRvby4gVGhlIHdvcmtiZW5jaCBwYXJ0IG1heSBub3QNCgkJ Ly8gYWRhcHQg
dG8gSUVkaXRpbmdEb21haW5Qcm92aWRlciwgaW4gd2hpY2ggY2FzZSB0aGUg c2VsZWN0ZWQg
RU9iamVjdA0KCQkvLyB3aWxsIGJlIHVzZWQgdG8gZGVyaXZlIHRoZSBlZGl0 aW5nIGRvbWFp
bi4NCgkJaWYgKCFzZWxlY3Rpb24uaXNFbXB0eSgpICYmIHNlbGVjdGlvbiBp bnN0YW5jZW9m
IElTdHJ1Y3R1cmVkU2VsZWN0aW9uKSB7DQogICAgICAgICAgICBPYmplY3Qg Zmlyc3RFbGVt
ZW50ID0gKChJU3RydWN0dXJlZFNlbGVjdGlvbikgc2VsZWN0aW9uKQ0KICAg ICAgICAgICAg
ICAgIC5nZXRGaXJzdEVsZW1lbnQoKTsNCiAgICAgICAgICAgIA0KICAgICAg ICAgICAgaWYg
KGZpcnN0RWxlbWVudCAhPSBudWxsKSB7DQogICAgICAgICAgICAJRU9iamVj dCBhZGFwdGVk
ID0gdW53cmFwKGZpcnN0RWxlbWVudCk7DQogICAgICAgICAgICAJDQoJICAg ICAgICAgICAg
aWYgKGFkYXB0ZWQgIT0gbnVsbCkgew0KCSAgICAgICAgICAgICAgICBzZXRF T2JqZWN0KGFk
YXB0ZWQpOw0KCSAgICAgICAgICAgIH0NCiAgICAgICAgICAgIH0NCiAgICAg ICAgfQ0KICAg
ICAgICANCiAgICAgICAgcGFnZS5zZWxlY3Rpb25DaGFuZ2VkKHBhcnQsIHNl bGVjdGlvbik7
DQogICAgfQ0KDQogICAgLyogKG5vbi1KYXZhZG9jKQ0KICAgICAqIEBzZWUg b3JnLmVjbGlw
c2UudWkudmlld3MucHJvcGVydGllcy50YWJiZWQuSVNlY3Rpb24jZGlzcG9z ZSgpDQogICAg
ICovDQogICAgcHVibGljIHZvaWQgZGlzcG9zZSgpIHsNCiAgICAgICAgc3Vw ZXIuZGlzcG9z
ZSgpOw0KDQogICAgICAgIGlmIChwYWdlICE9IG51bGwpIHsNCiAgICAgICAg ICAgIHBhZ2Uu
ZGlzcG9zZSgpOw0KICAgICAgICAgICAgcGFnZSA9IG51bGw7DQogICAgICAg IH0NCg0KICAg
IH0NCg0KIA0KICAgIC8qIChub24tSmF2YWRvYykNCiAgICAgKiBAc2VlIG9y Zy5lY2xpcHNl
LnVpLnZpZXdzLnByb3BlcnRpZXMudGFiYmVkLklTZWN0aW9uI3JlZnJlc2go KQ0KICAgICAq
Lw0KICAgIHB1YmxpYyB2b2lkIHJlZnJlc2goKSB7DQoNCiAgICAgICAgcGFn ZS5yZWZyZXNo
KCk7DQogICAgfQ0KDQogICANCiAgICAvKiAobm9uLUphdmFkb2MpDQogICAg ICogQHNlZSBv
cmcuZWNsaXBzZS51aS52aWV3cy5wcm9wZXJ0aWVzLnRhYmJlZC5JU2VjdGlv biNzaG91bGRV
c2VFeHRyYVNwYWNlKCkNCiAgICAgKi8NCiAgICBwdWJsaWMgYm9vbGVhbiBz aG91bGRVc2VF
eHRyYVNwYWNlKCkgew0KICAgICAgICByZXR1cm4gdHJ1ZTsNCiAgICB9DQoN CiAgICAvKioN
CiAgICAgKiBVcGRhdGUgaWYgbmVzc2VzYXJ5LCB1cG9uIHJlY2VpdmluZyB0 aGUgbW9kZWwg
ZXZlbnQuDQogICAgICogDQogICAgICogQHNlZSAjYWJvdXRUb0JlU2hvd24o KQ0KICAgICAq
IEBzZWUgI2Fib3V0VG9CZUhpZGRlbigpDQogICAgICogQHBhcmFtIG5vdGlm aWNhdGlvbiAt
DQogICAgICogICAgICAgICAgICBldmVuIG5vdGlmaWNhdGlvbg0KICAgICAq IEBwYXJhbSBl
bGVtZW50IC0NCiAgICAgKiAgICAgICAgICAgIGVsZW1lbnQgdGhhdCBoYXMg Y2hhbmdlZA0K
ICAgICAqLw0KICAgIHB1YmxpYyB2b2lkIHVwZGF0ZShmaW5hbCBOb3RpZmlj YXRpb24gbm90
aWZpY2F0aW9uLCBFT2JqZWN0IGVsZW1lbnQpIHsNCiAgICAJaWYgKCFpc0Rp c3Bvc2VkKCkp
IHsNCgkJCXBvc3RVcGRhdGVSZXF1ZXN0KG5ldyBSdW5uYWJsZSgpIHsNCg0K CQkJCXB1Ymxp
YyB2b2lkIHJ1bigpIHsNCgkJCQkJaWYgKCFpc0Rpc3Bvc2VkKCkgJiYgIWlz Tm90aWZpZXJE
ZWxldGVkKG5vdGlmaWNhdGlvbikpDQoJCQkJCQlyZWZyZXNoKCk7DQoJCQkJ fQ0KCQkJfSk7
DQoJCX0NCgl9DQogICANCiAgICAvKiAobm9uLUphdmFkb2MpDQogICAgICog QHNlZSBvcmcu
ZWNsaXBzZS5nbWYucnVudGltZS5lbWYuY29yZS5lZGl0LklEZW11eGVkTUxp c3RlbmVyI2dl
dEZpbHRlcigpDQogICAgICovDQogICAgcHVibGljIE5vdGlmaWNhdGlvbkZp bHRlciBnZXRG
aWx0ZXIoKSB7DQogICAgICAgIHJldHVybiBOb3RpZmljYXRpb25GaWx0ZXIu Y3JlYXRlRXZl
bnRUeXBlRmlsdGVyKE5vdGlmaWNhdGlvbi5TRVQpLm9yKA0KICAgICAgICAg ICAgTm90aWZp
Y2F0aW9uRmlsdGVyLmNyZWF0ZUV2ZW50VHlwZUZpbHRlcihOb3RpZmljYXRp b24uVU5TRVQp
KS5vcigNCiAgICAgICAgICAgIE5vdGlmaWNhdGlvbkZpbHRlci5jcmVhdGVF dmVudFR5cGVG
aWx0ZXIoTm90aWZpY2F0aW9uLkFERCkpLm9yKA0KICAgICAgICAgICAgTm90 aWZpY2F0aW9u
RmlsdGVyLmNyZWF0ZUV2ZW50VHlwZUZpbHRlcihOb3RpZmljYXRpb24uQURE X01BTlkpKQ0K
ICAgICAgICAgICAgLm9yKE5vdGlmaWNhdGlvbkZpbHRlci5jcmVhdGVFdmVu dFR5cGVGaWx0
ZXIoTm90aWZpY2F0aW9uLlJFTU9WRSkpDQogICAgICAgICAgICAub3IoDQog ICAgICAgICAg
ICAgICAgTm90aWZpY2F0aW9uRmlsdGVyDQogICAgICAgICAgICAgICAgICAg IC5jcmVhdGVF
dmVudFR5cGVGaWx0ZXIoTm90aWZpY2F0aW9uLlJFTU9WRV9NQU5ZKSkuYW5k KA0KICAgICAg
ICAgICAgICAgIE5vdGlmaWNhdGlvbkZpbHRlci5jcmVhdGVOb3RpZmllclR5 cGVGaWx0ZXIo
RU9iamVjdC5jbGFzcykpOw0KICAgIH0NCg0KICAgDQogICAgLyoNCgkgKiAo bm9uLUphdmFk
b2MpDQoJICogDQoJICogQHNlZSBvcmcuZWNsaXBzZS5nbWYucnVudGltZS5k aWFncmFtLnVp
LnByb3BlcnRpZXMuc2VjdGlvbnMuQWJzdHJhY3RNb2RlbGVyUHJvcGVydHlT ZWN0aW9uI2Fk
ZFRvRU9iamVjdExpc3QoamF2YS5sYW5nLk9iamVjdCkNCgkgKi8NCiAgICBw cm90ZWN0ZWQg
Ym9vbGVhbiBhZGRUb0VPYmplY3RMaXN0KE9iamVjdCBvYmplY3QpIHsNCiAg ICAgICAgLyog
bm90IGltcGxlbWVudGVkICovDQogICAgCXJldHVybiB0cnVlOw0KICAgIH0g IA0KDQp9
--------------090602080507000809070108--
Re: How to change the order in which the properties are listed ? [message #639501 is a reply to message #551604] Tue, 16 November 2010 13:47 Go to previous messageGo to next message
Hi Pantelis and Syed,
Pantelis, I have followed your instructions to implement my own sorting: I have created MyPropertySheetPage, MyPropertyShorter, MyAdvancedPropertySection and made MyPropertySection extend MyAdvancedPropertySection.
I just one to preserve the original order of the properties in the ecore model, don't need to do any additional ordering, but it is not working:
The "sort" method of MyPropertySorter is empty (in order to keep the original order), and it is correctly called, but it seems that properties have already been alphabetically ordered somewhere before. So I would need to reorder the properties of each object individually...
Any ideas?
By the way Pantelis, I cannot see the attachments you put on your messages... Could you please reattach them.
Thank you very much!
Re: How to change the order in which the properties are listed ? [message #645119 is a reply to message #639501] Wed, 15 December 2010 11:16 Go to previous message
Hi all,
After some time struggling with this problem, I have found a solution to preserve the order of the attributes in the properties view in a GMF generated diagram editor, as they are defined in the ecore model.
It is a bit long, but it is working fine. I leave it here just in case it is useful for anybody.
The key is that the alphabetical ordering is done not only in the PropertySheetSorter, but also in two places inside the PropertySheetEntry. So I have modified the code to remove this sortings.
So, to achieve this, it is necessary to use custom PropertySheetPage, PropertySheetSorter, and also PropertySheetEntry.
To do so, follow the next 5 steps:
1. Go to package: xxx.sheet inside the diagram plugin.
2. Create class XXXPropertySheetSorter as an extension of PropertySheetSorter, and override method sort(IPropertySheetEntry[] entries) to remove properties ordering, which is alphabetical.
The class code should result in something like this:
public class XXXPropertySheetSorter extends PropertySheetSorter
   public void sort(IPropertySheetEntry[] entries)
3. Create class XXXPropertySheetPage as an extension of PropertySheetPage, and override the constructor to use the XXXPropertySheetSorter created in the previous step:
public class XXXPropertySheetPage extends PropertySheetPage
   public XXXPropertySheetPage()
      super();
      setSorter(new XXXPropertySheetSorter());
4. Create class XXXPropertySheetEntry as an extension of UndoableModelPropertySheetEntry and override methods:
protected List computeMergedPropertyDescriptors();
protected Map computePropertyDescriptorsFor(IPropertySource source);
The code of both methods also does some ordering, so we remove that ordering in order to keep the original order.
The class would result in something like the following piece of code, where the important modifications are between "/////////////////////////////////////////////////////" (I could not find the way to color pieces of code):
public class XXXPropertySheetEntry extends UndoableModelPropertySheetEntry
   public XXXPropertySheetEntry(IOperationHistory operationHistory)
      super(operationHistory);
    * Overrides the super method to avoid ordering attributes, and so keep the
    * order defined in the ecore model.
    * @return sorted <code>List</code> of all the <code>IPropertyDescriptor</code>s for the objects
      if (values.length == 0)
         return new ArrayList(0);
      // get all descriptors from each object
      Map[] propertyDescriptorMaps = new Map[values.length];
      for (int i = 0; i < values.length; i++)
         Object object = values[i];
         IPropertySource source = getPropertySource(object);
         if (source == null)
            // if one of the selected items is not a property source
            // then we show no properties
         // get the property descriptors keyed by id
         propertyDescriptorMaps[i] = computePropertyDescriptorsFor(source);
      // intersect
      Map intersection = propertyDescriptorMaps[0];
      for (int i = 1; i < propertyDescriptorMaps.length; i++)
         // get the current ids
         Object[] ids = intersection.keySet().toArray();
         for (int j = 0; j < ids.length; j++)
            Object object = propertyDescriptorMaps[i].get(ids[j]);
            if (object == null ||
            // see if the descriptors (which have the same id) are
                  // compatible
                  !((IPropertyDescriptor) intersection.get(ids[j])).isCompatibleWith((IPropertyDescriptor) object))
               intersection.remove(ids[j]);
      // Sort the descriptors
      List descriptors = new ArrayList(intersection.values());
      // Commented to avoid alphabetically sorting of properties!
      //       Collections.sort(descriptors, new Comparator() {
      //           Collator coll = Collator.getInstance(Locale.getDefault());
      //           public int compare(Object a, Object b) {
      //               IPropertyDescriptor d1, d2;
      //               String dname1, dname2;
      //               d1 = (IPropertyDescriptor) a;
      //               dname1 = d1.getDisplayName();
      //               d2 = (IPropertyDescriptor) b;
      //               dname2 = d2.getDisplayName();
      //               return coll.compare(dname1, dname2);
      return descriptors;
    * The difference with the super method is that a LinkedHashMap is used instead of a HashMap,
    * in order to keep the properties order.
    * @param source a property source for which to obtain descriptors
    * @return a table of descriptors keyed on their id
      IPropertyDescriptor[] descriptors = source.getPropertyDescriptors();
      // Use LinkedHashMap instead of HashMap to preserve order
      Map result = new LinkedHashMap();
      for (int i = 0; i < descriptors.length; i++)
         result.put(descriptors[i].getId(), descriptors[i]);
      return result;
5. We are almost done! Now, create class XXXAdvancedPropertySection as a copy of AdvancedPropertySection, and modify method createControls to use XXXPropertySheetPage and XXXPropertySheetEntry instead of the originals.
The resulting method is as follows, where the important modification are highlighted:
   public void createControls(final Composite parent, TabbedPropertySheetPage aTabbedPropertySheetPage)
      super.createControls(parent, aTabbedPropertySheetPage);
      Composite composite = getWidgetFactory().createFlatFormComposite(parent);
      FormData data = null;
      String tableLabelStr = getTableLabel();
      CLabel tableLabel = null;
      if (tableLabelStr != null && tableLabelStr.length() > 0)
         tableLabel = getWidgetFactory().createCLabel(composite, tableLabelStr);
         data = new FormData();
         data.left = new FormAttachment(0, 0);
         data.top = new FormAttachment(0, 0);
         tableLabel.setLayoutData(data);
      // Use VadPropertySheetPage to provide custom properties behavior
      page = new VadPropertySheetPage();
      // Use VadPropertySheetEntry to provide custom properties behavior
      UndoableModelPropertySheetEntry root = new VadPropertySheetEntry(OperationHistoryFactory.getOperationHistory());
      root.setPropertySourceProvider(getPropertySourceProvider());
      page.setRootEntry(root);
      page.createControl(composite);
      data.right = new FormAttachment(100, 0);
      if (tableLabel == null)
      else
         data.top = new FormAttachment(tableLabel, 0, SWT.BOTTOM);
      data.bottom = new FormAttachment(100, 0);
      data.height = 100;
      data.width = 100;
      page.getControl().setLayoutData(data);
      setActionBars(aTabbedPropertySheetPage.getSite().getActionBars());
Carlos
Previous Topic:Error 'Received wrong transfer data.'
Next Topic:Programmatically hide one property from properties view
Current Time: Sun Jul 27 11:25:36 EDT 2025
Powered by FUDForum. Page generated in 0.24901 seconds
