multi-page form editor lazy construct [message #551311] |
Thu, 05 August 2010 17:26  |
Can you folks please help with an issue ?
I develop a RAP appl (I know this is a RCP forum, but I think this is the appropriate place to post this issue) and I created a multi-page form editor. In each page I have some Text, tables and other controls. On "doSave" I go through all the controls in all pages to get their values for further processing.
Now here comes the issue: if a user only opens let's say the 1st and the 2nd page to modify something, and he doesn't open the 3rd and the other pages (which is a common use case), then, when I try to get the values of the controls in the 3rd page I get a null pointer exception, because the pages are constructed lazily and the controls on 3rd page does not exist.
What is the best approach to solve this issue ?
Thank you,
Vlad
Re: multi-page form editor lazy construct [message #551345 is a reply to message #551311] |
Fri, 06 August 2010 01:02  |
Ideally approach would have been to have a model and update the model
elements when there are changes in the associated UI elements. Finally
when you save, you should be persisting the model.
> exist.
A workaround is to show all the tabs before save (this has the side
effect of creating all the controls)
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
FUDForum. Page generated in 0.06726 seconds
