Home » Language IDEs » ServerTools (WTP) » "file not found" while publishing on HTTP-Server
"file not found" while publishing on HTTP-Server [message #544881] Mon, 05 July 2010 17:10 Go to next message
Hi there!
I have a problem with publishing with the HTTP-Server Adapter.
Following setup:
One HTTP-Server with runtime publishing directory to /var/www (guess it, i'm on linux)
The worspace resides in /home/macbarfuss/Development/workspace/
I can create a static web project and i did not make any change on config of the project. I can add a HTML-file (which is not html compliant, but that should not matter *g*)
My project name does not include any special characters or spaces.
But when i try to publish the project to the server i get an error:
Error during publish
Error copying file index.html: No such file or directory
workspace log contains following:
!ENTRY org.eclipse.wst.server.http.core 4 0 2010-07-05 23:07:06.987
!MESSAGE Error during publish
!SUBENTRY 1 org.eclipse.wst.server.core 4 0 2010-07-05 23:07:06.987
!MESSAGE Error copying file index.html: No such file or directory
all the error messages does not give me a hint where there is a path wrong or missing. Can anybody here help me, please?
Kind Regards
Matthias G
Re: "file not found" while publishing on HTTP-Server [message #550460 is a reply to message #544881] Fri, 30 July 2010 09:05 Go to previous messageGo to next message
I have the same problem as you and after much searching it seems that the problem is related to the fact that your home directory and the /var/www directory are located on different partitions.
The workaround that I found was:
1) Configure the "Publishing Directory" of the HTTP Server to point to a directory on the same partition
2) Configure the Apache HTTP Server to serve from that location
This worked for me, I hope that it will help you somehow.
However, the root of the problem is still there and I haven't found the reason why eclipse manages to write in the publishing directory only if it is located in the same partition.
Nicolas
Re: "file not found" while publishing on HTTP-Server [message #550488 is a reply to message #550460] Fri, 30 July 2010 10:10 Go to previous messageGo to next message
On 7/30/2010 9:05 AM, Nicolas Vahlas wrote:
> Nicolas
The file copying support in the server tooling writes to a temp folder
first and then moves the file to the desired destination. If the temp
folder and the destination are on different partitions, the move fails,
i.e. https://bugs.eclipse.org/bugs/show_bug.cgi?id=272525 Prior to WTP
3.1.2, the temp folder would be under the ".metadata" folder of your
Eclipse workspace folder. Here it would be easy for the destination to
be on a separate partition. Starting with WTP 3.1.2 (i.e. the fix for
Bug 272525), WTP tries to create a "temp" folder as a sibling of the
"Publish Directory" to avoid this issue. This is likely to avoid the
move issue, but assumes the user running Eclipse has permission to
create such a directory. I'm not sure of the likely this would cause a
problem.
Larry
Re: "file not found" while publishing on HTTP-Server [message #551226 is a reply to message #544881] Thu, 05 August 2010 12:34 Go to previous messageGo to next message
Great!
That solved it! Many thanks.
As workaround, i added an symbolic link to my /var/www, pointing to ~/Website. So I can publish into my homefolder and apache follows the symlink.
Bye!
Re: "file not found" while publishing on HTTP-Server [message #662883 is a reply to message #544881] Fri, 01 April 2011 07:30 Go to previous messageGo to next message
Thank you guys, this helped me.... I thought the whole time I made mistakes applying user-rights...
I used the same solution by creating a symbolic link on my ubuntu machine and it works now.
Re: "file not found" while publishing on HTTP-Server [message #699326 is a reply to message #662883] Thu, 21 July 2011 07:24 Go to previous messageGo to next message
Hello everyone,
I'm having this exact problem after installing WTP on a new Ubuntu install. But aven after moving the workspace to the same partition of Tomcat I keep getting this error message and am unable to deploy any web app. Any other problems that could cause this?
Thanks for the help.
Re: "file not found" while publishing on HTTP-Server [message #699911 is a reply to message #699326] Fri, 22 July 2011 10:46 Go to previous messageGo to next message
On 7/21/2011 7:24 AM, Lu wrote:
> Hello everyone,
As of WTP 3.0, this problem was not an issue for Tomcat servers. It
publishes to a "wtpdeploy" folder under "CATALINA_BASE" (which by
default is down under the ".metadata" folder of your workspace) and uses
a "temp" directory that is also under "CATALINA_BASE". So your issue is
likely a different problem which happens to have the same symptom or
there is something strange with your Tomcat server. There isn't enough
detail here to tell which.
Larry
Re: "file not found" while publishing on HTTP-Server [message #703184 is a reply to message #699911] Wed, 27 July 2011 05:13 Go to previous messageGo to next message
Hi Larry, thank you for your reply.
I can't find any directory with the name you mention, "wtpdeploy". Eclipse is creating deployment directories directly at CATALINA_BASE, such as "CATALINA_BASE/myProject", which is a bit awkward. Strange thing is that these directories are empty, for some reason Eclipse isn't copying the project files there. I experimented increasing permissions on these directories but the result is the same.
Is there any way I can provide more detail on this issue?
Thank you.
Re: "file not found" while publishing on HTTP-Server [message #703340 is a reply to message #703184] Wed, 27 July 2011 08:58 Go to previous messageGo to next message
> Thank you.
What you describe implies you have made changes to the default Tomcat
server configuration in Eclipse. It would be helpful to know what
changes you have made. You could also create a second Tomcat server
with just the default configuration, which I would expect to work fine.
Then start applying your configuration changes to determine which one
or combination causes the "file not found" during publishing to appear.
Larry
Re: "file not found" while publishing on HTTP-Server [message #704159 is a reply to message #703340] Thu, 28 July 2011 06:41 Go to previous messageGo to next message
Thank you Larry, that was the problem. Once I changed the publishing directory to "/usr/local/tomcat/webapps" it all went well.
There was no default web server configured at Eclipse when I installed it, I had to configure one myself following a guide somewhere on the web. I still have to figure how to point it to the 8080 port, but that's just a detail.
Thank you once more.
Re: "file not found" while publishing on HTTP-Server [message #704287 is a reply to message #704159] Thu, 28 July 2011 09:11 Go to previous messageGo to next message
> just a detail.
When you mentioned Tomcat, I assumed you were creating a Tomcat server.
Your solution suggests I'm not correct about this. If I now assume
correctly that this is an HTTP Server, then if you double click on the
server in the Servers view, it will open up the server editor for this
server. In that server editor you will see where to specify the port.
Feel free read the WTP Tomcat FAQ[1] for details about the Tomcat
support. By default, it will create a separate instance of Tomcat which
will not impact your installed Tomcat, provided you alter the Tomcat
server in Eclipse to use different ports (use the server editor).
This would give you a Tomcat that is more easily controlled from within
Eclipse, should you find that useful.
Larry
[1] http://wiki.eclipse.org/WTP_Tomcat_FAQ
Re: "file not found" while publishing on HTTP-Server [message #705056 is a reply to message #704287] Fri, 29 July 2011 07:26 Go to previous message
Larry Isaacs wrote on Thu, 28 July 2011 09:11
Hi Larry, indeed I had the server not defined as a Tomcat server, and so the "Ports" tab wasn't there. This all had to do with the fact that I defined the server from the Static Web Project creation dialog, which has different options. Since this an unrelated issue, I opened a new thread.
Thank you.
Previous Topic:Identifying when a value has been inserted
Next Topic:Invoke WTP XML Formatter from commandline?
Current Time: Sat Jul 26 20:27:07 EDT 2025
Powered by FUDForum. Page generated in 0.04380 seconds
