Home » Eclipse Projects » EclipseLink » Java Architecture for XML Binding (JAXB) - Class not found
Java Architecture for XML Binding (JAXB) - Class not found [message #551105] Thu, 05 August 2010 05:16 Go to next message
I am looking for some JAXB experts help!
To save some formatted data, I want to use Java Architecture for XML Binding (JAXB). It is my first time and immediately I got some problems.
It doesn't matter, which version of JAXB I use. Everytime, with
JAXBContext.newInstance(Data.class)
I get the following ClassNotFoundException:
javax.xml.bind.JAXBException
- with linked exception:
[java.lang.ClassNotFoundException: com.sun.xml.internal.bind.v2.ContextFactory]
at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java: 186)
at javax.xml.bind.ContextFinder.find(ContextFinder.java:375)
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:618)
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:565)
Did somebody got the same problem and fixed it?
Would be glad for answers.
Thx
Re: Java Architecture for XML Binding (JAXB) - Class not found [message #551163 is a reply to message #551105] Thu, 05 August 2010 09:30 Go to previous messageGo to next message
JAXB is a standard runtime with multiple implementations, just like JPA. There error you are seeing is that the Metro JAXB implementation (the RI) cannot be found.
If you want to use the EclipseLink JAXB (MOXy) implementation simply add the eclipselink.jar to your classpath and add a file named jaxb.properties with the following entry in with your model classes:
javax.xml.bind.context.factory=org.eclipse.persistence.jaxb.JAXBContextFactory
If you want to use Metro JAXB it is included in Java SE 6, or can be found at https://jaxb.dev.java.net/
For more information on MOXy see:
- http://www.eclipse.org/eclipselink/moxy.php
- http://wiki.eclipse.org/EclipseLink/Examples/MOXy
- http://bdoughan.blogspot.com
-Blaise
Blaise Doughan
Team Lead, EclipseLink JAXB & SDO
Re: Java Architecture for XML Binding (JAXB) - Class not found [message #551439 is a reply to message #551163] Fri, 06 August 2010 09:02 Go to previous message
Thank you Blaise for your answer.
For testing, I created a new project, which includes all needed jars. This works fine. The xml file is written and readed. But this was a "usual" java application. Smile
Now, the reason why I need help is, that the exception occur in a rcp application.
I include the jars via the manifest -> runtime -> classpath. I also tried to fix it by release this jars into a seperate bundle. But everytime I got this ava.lang.ClassNotFoundException: com.sun.xml.internal.bind.v2.ContextFactory]!
... and the class is in the included jars Wink
Is there anybody, who can help?
Previous Topic:foreign key constraint problem
Next Topic:Difficulties Unmarshalling Timestamp
Current Time: Wed Jul 23 11:51:14 EDT 2025
Powered by FUDForum. Page generated in 0.22810 seconds
