Problem with Emfatic + OCL Annotation [message #550887] |
Wed, 04 August 2010 10:28  |
I'm trying to write a GMF editor using Eugenia. And I want to add
some OCL constraints to specify the metamodel better.
I have found a example that uses a
@"http://www.eclipse.org/OCL/examples/ocl" annotation. I want to specify
two different things:
1. Derived references
2. Constraint the kinds of values some elements can have.
One example of the first OCL annotation is the one shown below, in this
case I have tested the constraint with the OCL console, so I suppose is
correct.
class EntryPort extends Port{
@"http://www.eclipse.org/OCL/examples/ocl"(
derive="self.tasks->collect(outputSlots)")
derived val Slot[+] slots;
One example of the second kind of OCL annotation is the one shown below,
specifying that there can not be two tasks with the same name.
@Ecore(constraints="noDuplicateTask")
@"http://www.eclipse.org/ocl/examples/OCL"(noDuplicateTask="self.tasks->forAll(t1
: Task |
self.tasks->forAll(t2 : Task | t1 <> t2 implies t1.name <>
t2.name))"
The problem is that it seems the annotations have no effect. Is
sufficient with writing the annotations or do I need to configure
something else?
How can I check if the code for the derived reference is correctly
generated?
Thanks in advance,
Toñi
Re: Problem with Emfatic + OCL Annotation [message #550964 is a reply to message #550945] |
Wed, 04 August 2010 13:11   |
Hi Ed,
thanks for the reference. Regarding to OCLinEcore, as far as I
understood, it needs Eclipse Helios, isn't it?
The reason for using Emfatic is that I'm also using Eugenia to
facilitate the generation of GMF editors. I don't know if these two
tools are well integrated.
El 04/08/2010 18:22, Ed Willink escribió:
> Hi Toni
> If you really want to do the EAnnotations the hard way you should read
> the first part of http://wiki.eclipse.org/MDT/OCLinEcore so that get all
> the package constraints that you've omitted.
> Alternatively, you might want to look at the second part and use
> OCLinEcore rather than Emfatic. OCLinEcore provides first class syntaxes
> for invariants and such like and automates the additional control
> annotations. OCLinEcore allows the model to be persisted as *.ecore
> (currently without comments and whitesapce preservation) or as
> *.oclinecore (textual equivalent). OCLinEcore also gives you syntax and
> partial semantic validation of your OCL. Full semantic validation in the
> next release.
> [I considered using the Emfatic syntax for OCLinEcore but rejected it in
> favour of something that more closely resembles the style of OMG
> specifications. I'm not sure whether Emfatic supports generics.
> OCLinEcore successfuly round-trips Ecore.ecore.]
> Regards
> Ed Willink
> On 04/08/2010 15:28, Toñi Reina Quintero wrote:
>> Hi,
>> I'm trying to write a GMF editor using Eugenia. And I want to add some
>> correct.
>> : Task |
>> self.tasks->forAll(t2 : Task | t1 <> t2 implies t1.name <> t2.name))"
>> something else?
>> generated?
>> Thanks in advance,
>> Toñi
Re: Problem with Emfatic + OCL Annotation [message #550979 is a reply to message #550964] |
Wed, 04 August 2010 14:18  |
i Toni
Thanks for the Eugenia mention; looks like it does some of the things I
dislike most about GMF not doing. Next time I play with graphics I'll
give it a try.
OCLinEcore certainly needs Helios.
http://download.eclipse.org/modeling/gmt/epsilon/interim/ lists a
27-July build so it's probably Helios.
Ed Willink
On 04/08/2010 18:11, Toñi Reina Quintero wrote:
> Hi Ed,
>> Hi Toni
>> next release.
>> Regards
>> Ed Willink
>>> Hi,
>>> correct.
>>> : Task |
>>> something else?
>>> generated?
>>> Thanks in advance,
>>> Toñi
FUDForum. Page generated in 0.04748 seconds
