Home » Eclipse Projects » Remote Application Platform (RAP) » No layout registered with default id(I encounter a java.lang.IllegalArgumentException when running a simple RAP application.)
No layout registered with default id [message #544792] Mon, 05 July 2010 10:21 Go to next message
I am trying to run a simple (i.e. hello world) RAP application which contains a view with a label.
When I try to run the application I am encountering the following error:
osgi> 2010-07-05 16:56:31.593:INFO:org.mortbay.log:Logging to STDERRorg.mortbay.log via org.mortbay.log.Slf4jLog
2010-07-05 16:56:31.671:INFO::jetty-6.1.x
2010-07-05 16:56:32.140:INFO::Started SelectChannelConnector@0.0.0.0:1532
!SESSION 2010-07-05 16:56:30.421 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_20
Command-line arguments:  -dev file:D:/work/eclipse_workspaces/.metadata/.plugins/org.eclipse.pde.core/Cat Shelter Manager/dev.properties -os win32 -ws win32 -arch x86 -consoleLog -console -consolelog
!ENTRY org.eclipse.rap.ui 4 0 2010-07-05 16:56:48.781
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.IllegalArgumentException: no layout registered with default id (LayoutRegistry.DEFAULT_LAYOUT_ID) or no layout activated over branding extension.
	at org.eclipse.rap.ui.interactiondesign.layout.ElementBuilder.<init>(ElementBuilder.java:96)
	at org.eclipse.rap.internal.design.example.builder.DummyBuilder.<init>(DummyBuilder.java:23)
	at org.eclipse.rap.internal.design.example.managers.CoolBarManager.<init>(CoolBarManager.java:140)
	at org.eclipse.rap.internal.design.example.business.BusinessPresentationFactory.createCoolBarManager(BusinessPresentationFactory.java:31)
	at org.eclipse.ui.internal.WorkbenchWindow.createCoolBarManager2(WorkbenchWindow.java:3742)
	at org.eclipse.jface.window.ApplicationWindow.addCoolBar(ApplicationWindow.java:288)
	at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:347)
	at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:29)
	at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1676)
	at org.eclipse.ui.internal.Workbench.access$11(Workbench.java:1674)
	at org.eclipse.ui.internal.Workbench$16.runWithException(Workbench.java:954)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:1019)
	at org.eclipse.ui.internal.StartupThreading.runWithWorkbenchExceptions(StartupThreading.java:55)
	at org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Workbench.java:952)
	at org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Workbench.java:1799)
	at org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbench.java:1735)
	at org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWindow(WorkbenchConfigurer.java:188)
	at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:790)
	at org.eclipse.ui.internal.Workbench$25.runWithException(Workbench.java:1341)
	at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:110)
	at org.eclipse.ui.internal.Workbench.init(Workbench.java:1336)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2315)
	at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2206)
	at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:424)
	at org.eclipse.jface.internal.databinding.realmadapter.RealmAdapter.run(RealmAdapter.java:44)
	at org.eclipse.rap.ui.internal.RealmAdapterHook.runWithDefault(RealmAdapterHook.java:48)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:427)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
	at catshelter.CatEntrypoint.createUI(CatEntrypoint.java:18)
	at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createUI(EntryPointManager.java:92)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:244)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:113)
	at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:102)
I am running RAP version 1.3 on Eclipse Helios. I have successfully ran the org.eclipse.rap.demo application so I don't think it is a problem with the RAP installation. Does anyone have an advice for this issue?
Thank you,
Ionut.
Re: No layout registered with default id [message #544941 is a reply to message #544792] Tue, 06 July 2010 03:18 Go to previous messageGo to next message
could you post the plugin.xml of your example project?
Ralf
Ionut wrote:
> Hello,
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> file:D:/work/eclipse_workspaces/.metadata/.plugins/org.eclip se.pde.core/Cat
> !STACK 0
> extension.
> at
> org.eclipse.rap.ui.interactiondesign.layout.ElementBuilder.<init >(ElementBuilder.java:96)
> at
> org.eclipse.rap.internal.design.example.builder.DummyBuilder . <init>(DummyBuilder.java:23)
> at
> org.eclipse.rap.internal.design.example.managers.CoolBarMana ger. <init>(CoolBarManager.java:140)
> at
> org.eclipse.rap.internal.design.example.business.BusinessPre sentationFactory.createCoolBarManager(BusinessPresentationFa ctory.java:31)
> at
> org.eclipse.ui.internal.WorkbenchWindow.createCoolBarManager 2(WorkbenchWindow.java:3742)
> at
> org.eclipse.jface.window.ApplicationWindow.addCoolBar(Applic ationWindow.java:288)
> at
> at
> org.eclipse.ui.internal.tweaklets.Workbench3xImplementation. createWorkbenchWindow(Workbench3xImplementation.java:29)
> at
> org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workben ch.java:1676)
> at org.eclipse.ui.internal.Workbench.access$11(Workbench.java:1 674)
> at
> org.eclipse.ui.internal.Workbench$16.runWithException(Workbe nch.java:954)
> at
> org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
> at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:187)
> at
> org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
> at
> org.eclipse.ui.internal.StartupThreading.runWithWorkbenchExc eptions(StartupThreading.java:55)
> at
> org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:952)
> at
> org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1799)
> at
> org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1735)
> at
> org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:188)
> at
> org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:790)
> at
> org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1341)
> at
> at
> at
> org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
> at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 06)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.jface.internal.databinding.realmadapter.RealmAda pter.run(RealmAdapter.java:44)
> at
> org.eclipse.rap.ui.internal.RealmAdapterHook.runWithDefault( RealmAdapterHook.java:48)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:427)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
> at
> org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
> at
> org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:244)
> at
> org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:113)
> at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.jav a:102)
> Thank you,
> Ionut.
Re: No layout registered with default id [message #544999 is a reply to message #544792] Tue, 06 July 2010 06:26 Go to previous messageGo to next message
Here is the plugin.xml code:
<?eclipse version="3.2"?>
<plugin>
   <extension
         point="org.eclipse.rap.ui.entrypoint">
      <entrypoint
            class="catshelter.CatEntrypoint"
            id="catshelter.entrypoint1"
            parameter="cats">
      </entrypoint>
   </extension>
   <extension
         point="org.eclipse.ui.perspectives">
      <perspective
            class="catshelter.CatManagerPerspective"
            id="catshelter.perspective1"
            name="Main Perspective">
      </perspective>
   </extension>
   <extension
         point="org.eclipse.ui.views">
      <view
            class="catshelter.CatShelterView"
            id="catshelter.view1"
            name="CatShelter"
            restorable="true">
      </view>
   </extension>
</plugin>
I am following the Chapter 4 of the book Eclipse Rich Ajax Platform from FirstPress.
Thank you for your help,
Ionut.
Re: No layout registered with default id [message #545020 is a reply to message #544999] Tue, 06 July 2010 08:39 Go to previous messageGo to next message
I have also tried following the HelloWorld example from http:// help.eclipse.org/helios/index.jsp?topic=/org.eclipse.rap.hel p/help/html/getting-started/launcher.html and I received the same error at runtime.
I have found bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=311156 on Bugzilla which seems related to my issue but there are no updates to this bug.
Re: No layout registered with default id [message #545149 is a reply to message #544792] Tue, 06 July 2010 14:57 Go to previous messageGo to next message
did you switched the presentation with the preferences? If yes please
delete your browser cookies and try to reload the application.
If not, please file a bug at bugzilla. It would be good if you can
provide a sample project (with launch config) to reproduce the error.
Thanks.
Regards Holger
On 2010-07-05 16:21:08 +0200, Ionut <judge4life@playful.com> said:
> Hello,
> !STACK 0
> branding extension.
> at
at
at
at
at
at
at
> at
at
> at org.eclipse.ui.internal.Workbench$16.runWithException(Workbe nch.java:954)
> at
at
> at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
> at
at
> at
at
> at
at
at
> at
at
> at
at
> at
at
at
at
> at
at
> at
at
> Thank you,
> Ionut.
http://eclipsesource.com
http://twitter.com/eclipsesource
Re: No layout registered with default id [message #545196 is a reply to message #545149] Wed, 07 July 2010 02:32 Go to previous messageGo to next message
Can you please tell me where can I check if the presentation with the preferences is switched?
Thank you,
Ionut.
Re: No layout registered with default id [message #545211 is a reply to message #545196] Wed, 07 July 2010 03:38 Go to previous messageGo to next message
You can do this only manualy within the preferences page. So, I gues
you didn't do this. Did you start your application with the bundle
org.eclipse.rap.design.example?
Regards Holger
On 2010-07-07 08:32:09 +0200, Ionut <judge4life@playful.com> said:
> Hello,
> Thank you,
> Ionut.
Re: No layout registered with default id [message #550895 is a reply to message #544792] Wed, 04 August 2010 11:08 Go to previous message
Open Run Configuration of your RAP application and then select the Bundles tab. Unselect the rap.demo bundles. This should fix your problem.
Miro
Previous Topic:Menu not showin Radio or Check option.
Next Topic:Disabling select row in table on mouse right click
Current Time: Tue Sep 16 13:23:54 EDT 2025
Powered by FUDForum. Page generated in 0.09413 seconds
