Home » Eclipse Projects » Eclipse Platform » Unable to delete/move files after opening(Helios (and also Ganymede) - after opening an XML file, cannot delete it)
Unable to delete/move files after opening [message #550287] Thu, 29 July 2010 14:56 Go to next message
This most frequently occurs with XML files but I don't think it is limited to just them. I've even removed Oxygen XML editor from my configuration thinking that perhaps it was holding a lock, but it had no effect.
Using Helios for JEE on Windows 7.
1. Under WEB-INF, I will right click, create a new XML file.
2. In the XML editor, I just add a root element <hello/>
3. Save the file and then close it.
4. Try and delete it. FAIL.
5. Close the project, and re-open; try to delete. FAIL.
6. Close the project and delete from Windows: FAIL.
7. Open the project and delete from Windows: SUCCEED
Does anyone know about this problem? It is VERY troublesome, as often files cannot be refactored/renamed, moved, or deleted.
On step 4, here is the error details:
An exception has been caught while processing the refactoring 'Delete'.
Reason: Problems encountered while deleting resources.
From Error Log:
Thu Jul 29 14:48:14 EDT 2010
Could not delete 'C:\Users\gkaplan\Documents\Workspace\TestProject\WebContent \WEB-INF\NewFile.xml'.
org.eclipse.core.runtime.CoreException: Problems encountered while deleting files.
at org.eclipse.core.internal.filesystem.local.LocalFile.delete( LocalFile.java:125)
at org.eclipse.core.internal.resources.ResourceTree.internalDel eteFile(ResourceTree.java:304)
at org.eclipse.core.internal.resources.ResourceTree.standardDel eteFile(ResourceTree.java:785)
at org.eclipse.core.internal.resources.Resource.unprotectedDele te(Resource.java:1934)
at org.eclipse.core.internal.resources.Resource.delete(Resource .java:786)
at org.eclipse.ltk.core.refactoring.resource.DeleteResourceChan ge.perform(DeleteResourceChange.java:138)
at org.eclipse.ltk.core.refactoring.CompositeChange.perform(Com positeChange.java:278)
at org.eclipse.jdt.internal.corext.refactoring.changes.DynamicV alidationStateChange.access$0(DynamicValidationStateChange.j ava:1)
at org.eclipse.jdt.internal.corext.refactoring.changes.DynamicV alidationStateChange$1.run(DynamicValidationStateChange.java :98)
at org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation.java:39)
at org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:728)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1975)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:4777)
at org.eclipse.jdt.internal.corext.refactoring.changes.DynamicV alidationStateChange.perform(DynamicValidationStateChange.ja va:101)
at org.eclipse.ltk.core.refactoring.PerformChangeOperation$1.ru n(PerformChangeOperation.java:258)
at org.eclipse.ltk.core.refactoring.PerformChangeOperation.exec uteChange(PerformChangeOperation.java:306)
at org.eclipse.ltk.internal.ui.refactoring.UIPerformChangeOpera tion.executeChange(UIPerformChangeOperation.java:92)
at org.eclipse.ltk.core.refactoring.PerformChangeOperation.run( PerformChangeOperation.java:218)
at org.eclipse.ltk.internal.ui.refactoring.WorkbenchRunnableAda pter.run(WorkbenchRunnableAdapter.java:87)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Contains: Could not delete: C:\Users\gkaplan\Documents\Workspace\TestProject\WebContent\ WEB-INF\NewFile.xml.
Re: Unable to delete/move files after opening [message #550716 is a reply to message #550287] Wed, 04 August 2010 03:59 Go to previous messageGo to next message
> no effect.
You should file a bug report against the XML Editor provider.
Dani
> From Error Log:
> Could not delete
> deleting files.
> LocalFile.java:125)
> .java:786)
> java:1975)
> java:1975)
> java:1975)
> java:1975)
Re: Unable to delete/move files after opening [message #550807 is a reply to message #550287] Wed, 04 August 2010 08:10 Go to previous messageGo to next message
This is happening with HTML files too. Yesterday, I created an empty HTML file, opened it up, then attempted to delete it - same error. Then, I closed the file and tried to delete it - failed. Then I closed the project, re-opened the project, and was able to delete it.
I don't know how to file a bug report for Eclipse. If you can point me in the right direction, I will file the bug report. This problem has existed for several versions of Eclipse - definitely in Ganymede as well, because I remember that this was one of my main motivators for upgrading each time. I've also read on the net that some others have had this problem too.
Thanks.
Re: Unable to delete/move files after opening [message #550819 is a reply to message #550807] Wed, 04 August 2010 08:35 Go to previous messageGo to next message
Go to https://bugs.eclipse.org/bugs/ , get an account, file a bug.
Remember to check if this is a known bug first.
Steffen
> Thanks.
Re: Unable to delete/move files after opening [message #550820 is a reply to message #550819] Wed, 04 August 2010 08:42 Go to previous messageGo to next message
That's the wrong URL to report bugs for the Oxygen editor.
Dani
> Cheers,
> Steffen
>> Thanks.
Re: Unable to delete/move files after opening [message #550859 is a reply to message #550820] Wed, 04 August 2010 10:02 Go to previous messageGo to next message
Sorry, must have missed the bit were it said that this is Oxygen specific.
Steffen
> Dani
>> Cheers,
>> Steffen
>>> Thanks.
Re: Unable to delete/move files after opening [message #550863 is a reply to message #550859] Wed, 04 August 2010 10:14 Go to previous messageGo to next message
No, this is not Oxygen specific. In fact, I uninstalled Oxygen to test this out. It happens even with HTML files that are opened in the local editor.
I opened a bug. Hopefully someone will look into it. It is terribly inconvenient.
I wonder if it has anything to do with CVS. I will try this on a non-CVS project as well.
Re: Unable to delete/move files after opening [message #550865 is a reply to message #550863] Wed, 04 August 2010 10:17 Go to previous messageGo to next message
Just created a TestProject, added an HTML file, then immediately tried to delete it, and got the same problem. The project is not under source code control, and this has nothing to with XML>
Could not delete 'C:\Users\gkaplan\Documents\Workspace\TestProject\WebContent \Test.html'.
Could not delete: C:\Users\gkaplan\Documents\Workspace\TestProject\WebContent\ Test.html.
eclipse.buildId=I20100608-0911
java.version=1.6.0_21
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
Error
Wed Aug 04 10:15:12 EDT 2010
Contains: Could not delete: C:\Users\gkaplan\Documents\Workspace\TestProject\WebContent\ Test.html.
Re: Unable to delete/move files after opening [message #550883 is a reply to message #550863] Wed, 04 August 2010 10:30 Go to previous messageGo to next message
> editor.
What do you mean with "local" editor? Which editor is it exactly?
Dani
> inconvenient.
Re: Unable to delete/move files after opening [message #550884 is a reply to message #550865] Wed, 04 August 2010 10:32 Go to previous messageGo to next message
Normally, adding a new file opens an editor. Is that the case here too?
If so, which editor (it's the one with the bullet in the 'Open With'
context menu)?
Dani
> XML>
> Could not delete
> Could not delete:
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Error
> Could not delete
> deleting files.
> LocalFile.java:125)
> .java:786)
> java:1975)
> java:1975)
> java:1975)
> java:1975)
Re: Unable to delete/move files after opening [message #550885 is a reply to message #550884] Wed, 04 August 2010 10:48 Go to previous messageGo to next message
The HTML file opens with "HTML Editor".
Re: Unable to delete/move files after opening [message #550923 is a reply to message #550885] Wed, 04 August 2010 11:36 Go to previous messageGo to next message
OK, then you need to file the bug against the 'wst.html' comonent in
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20So urce%20Editing
Dani
Re: Unable to delete/move files after opening [message #550927 is a reply to message #550923] Wed, 04 August 2010 12:03 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321713
I hope that is correctly filed.
Previous Topic:[plug-in] Comparing two remote branches in Synchronize view
Next Topic:Convert Line Delimiter Programmatically
Current Time: Sun Jul 27 22:59:00 EDT 2025
Powered by FUDForum. Page generated in 0.06706 seconds
