Home » Modeling » GMF (Graphical Modeling Framework) » How to remove line above node compartment
How to remove line above node compartment [message #550151] Thu, 29 July 2010 06:15 Go to next message
Originally posted by: jan.vandenbergh.uhasselt.be
I am developing a GMF editor for a DSL. This DSL contains several nodes
that contain one compartment. Above this compartment there is a
horizontal line. Can I remove this horizontal line or change its
visualization? I would prefer a solution that only modifies the
..gmfgraph model, if possible.
Many thanks!
Kind regards,
Jan
Re: How to remove line above node compartment [message #550774 is a reply to message #550151] Wed, 04 August 2010 05:57 Go to previous messageGo to next message
Originally posted by: marius.groeger.googlemail.com
Am 29.07.2010 12:15, wrote Jan Van den Bergh:
Late reply, for some reason I couldn't reach the news server for a
couple of days.
You can either modify the compartment's figure in the generated edit
part code, or use the following generic solution which uses a seperate
plugin:
plugin.xml:
<extension
point="org.eclipse.gmf.runtime.diagram.ui.editpolicyProviders ">
<editpolicyProvider class="XXX.policies.EditPolicyProvider">
<Priority
name="Medium">
</Priority>
</editpolicyProvider>
</extension>
XXX.policies.EditPolicyProvider:
private EditPartListener compartmentSilencer = new
EditPartListener.Stub() {
public void childAdded(EditPart child, int index) {
if (child instanceof CompartmentEditPart) {
// remove top border
((CompartmentEditPart)child).getFigure().setBorder(null);
public class EditPolicyProvider implements IEditPolicyProvider {
public void createEditPolicies(EditPart editPart) {
if (editPart instanceof ShapeNodeEditPart) {
editPart.addEditPartListener(compartmentSilencer);
public boolean provides(IOperation operation) {
boolean result = false;
if (operation instanceof CreateEditPoliciesOperation) {
EditPart editPart =
((CreateEditPoliciesOperation)operation).getEditPart();
result = editPart instanceof XXXEditPart;
return result;
I admit this is kind of complicated given the problem to solve, but for
me it's worth it. I prefer not modifying generated code because I want
to keep being able to complete wipe and regenerate it. Also, this method
allows other dynamic "fixes" or additions to be done to the EditParts.
In fact I called the listener "silencer" because in my code it also
registers an editpolicy to inhibit the selection handles and the "delete
from model" context menu entry.
HTH
Marius
Re: How to remove line above node compartment [message #550775 is a reply to message #550151] Wed, 04 August 2010 05:57 Go to previous messageGo to next message
couple of days.
plugin:
plugin.xml:
<extension
<Priority
name="Medium">
</Priority>
</extension>
EditPart editPart =
return result;
HTH
Marius
Re: How to remove line above node compartment [message #553181 is a reply to message #550774] Mon, 16 August 2010 11:30 Go to previous messageGo to next message
>> Hi,
> couple of days.
> plugin:
> plugin.xml:
> <extension
> <Priority
> name="Medium">
> </Priority>
> </extension>
> @Override
> EditPart editPart = ((CreateEditPoliciesOperation)operation).getEditPart();
> return result;
Thank you very much!
This was exactly what I was looking for.
Kind regards,
Jan
> HTH
> Marius
Re: How to remove line above node compartment [message #676770 is a reply to message #553181] Mon, 06 June 2011 09:15 Go to previous messageGo to next message
Hello, I have the same problem as you. But I would like to try this solution. It seems it works well. But I don't understand the code:
Where should I add them?
Thank you very much
Re: How to remove line above node compartment [message #676975 is a reply to message #676770] Tue, 07 June 2011 03:12 Go to previous messageGo to next message
I have the following template for this in aspects/diagram/editparts/ComponentEditPart.xpt
«IMPORT 'http://www.eclipse.org/gmf/2009/GenModel'»
«AROUND createFigure FOR gmfgen::GenCompartment»
	«IF self.editPartClassName = 'xxxCompartmentEditPart'»
		«REM»By default titles are shown even if there are no TitleStyle, we need to switch it off«ENDREM»«-»
		«EXPAND xpt::Common::generatedMemberComment»
		public org.eclipse.draw2d.IFigure createFigure() {
			org.eclipse.gmf.runtime.diagram.ui.figures.ResizableCompartmentFigure result = (org.eclipse.gmf.runtime.diagram.ui.figures.ResizableCompartmentFigure) super.createFigure();
			result.setTitleVisibility(false);
			result.setBorder(null);
			return result;
	«ELSE»
		«targetDef.proceed()»
	«ENDIF»
«ENDAROUND»
Replace xxxCompartmentEditPart with the editpart you want to hide the line. This should do the trick. I provided a way on how to do this in an Eclipse Wiki but I cannot find it anymore..
Ralph
Re: How to remove line above node compartment [message #677087 is a reply to message #676975] Tue, 07 June 2011 10:39 Go to previous messageGo to next message
Hello, Thank you for you reply. But I don't understand your code. I have tried the first proposition. I have added the extension in the xml file and of cause implemented the class as you told us. I have attached my files as below. But I always have two annoying problems:
1.The service provider src.policies.EditPolicyProvider could not be activated.
2.Ignoring provider src.policies.EditPolicyProvider since it threw an exception or error in the provides() method.
In the java class, I replay your code "result = editPart instanceof XXXEditPart;" by "result = editPart instanceof PlaceEditPart;"
PlaceEditPart is the circle node which will have a small circle node (MarkEditPart) inside. Actually, I don't understand what this line of code is used for.
Do you have any idea?? Thank you very much.
import org.eclipse.gef.EditPart;
import org.eclipse.gef.EditPartListener;
import org.eclipse.gmf.runtime.common.core.service.IOperation;
import org.eclipse.gmf.runtime.common.core.service.IProviderChangeListener;
import org.eclipse.gmf.runtime.diagram.ui.editparts.CompartmentEditPart;
import org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeNodeEditPart;
import org.eclipse.gmf.runtime.diagram.ui.editpolicies.EditPolicyRoles;
import org.eclipse.gmf.runtime.diagram.ui.editpolicies.PropertyHandlerEditPolicy;
import org.eclipse.gmf.runtime.diagram.ui.services.editpolicy.CreateEditPoliciesOperation;
import org.eclipse.gmf.runtime.diagram.ui.services.editpolicy.IEditPolicyProvider;
import rdp.diagram.edit.parts.MarkEditPart;
import rdp.diagram.edit.parts.PlaceEditPart;
	private EditPartListener compartmentSilence = new EditPartListener.Stub()
			if(child instanceof CompartmentEditPart)
				//remove top border
	public void addProviderChangeListener(IProviderChangeListener arg0) {
		// TODO Auto-generated method stub
		if(operation instanceof CreateEditPoliciesOperation)
			result = true;
		return result;
	public void removeProviderChangeListener(IProviderChangeListener arg0) {
		//editPart.installEditPolicy(EditPolicyRoles.PROPERTY_HANDLER_ROLE,
              //  new PropertyHandlerEditPolicy());
			if(editPart instanceof ShapeNodeEditPart)
				editPart.addEditPartListener(compartmentSilence);
<extension
		point="org.eclipse.gmf.runtime.diagram.ui.editpolicyProviders">
		<editpolicyProvider class="src.policies.EditPolicyProvider">
		<Priority
			name="Medium">
		</Priority>
	</extension>
Re: How to remove line above node compartment [message #677095 is a reply to message #677087] Tue, 07 June 2011 10:56 Go to previous messageGo to next message
you could do the following which is not the best but will help you without much effort.
1) Go to your generated plugin
2) Look for a package called xx.edit.parts
3) Open the code of the generated EditPart you want to modify
4) Search for the public org.eclipse.draw2d.IFigure createFigure() method
place the following inside this method:
5) Set the javadoc of this method to @generated no
This will mixup generated code with your handwritten one but is a quick and easy solution.
Ralph
Re: How to remove line above node compartment [message #677110 is a reply to message #677095] Tue, 07 June 2011 11:37 Go to previous message
@Ralph, Could you please tell me what you mean by "generated plugin"? I have only find some Edit->Parts in XX.diagram. In fact, I have four dossier.
abc
abc.diagram
abc.edit
abc.editor
abc.tests
But I have no idea where the plugin->EditPart-createFigure() is ?
Thank you very much for your help.
Vincent
Previous Topic:Visual ID inconsistency after ecore namespace URI change
Next Topic:Diagram Model
Current Time: Sat Nov 01 14:47:24 EDT 2025
Powered by FUDForum. Page generated in 0.03478 seconds
