Home » Language IDEs » Java Development Tools (JDT) » Creating a new customized Outline-View
Creating a new customized Outline-View [message #550691] Wed, 04 August 2010 03:21 Go to next message
I want to create a new view that is very similar to the current Outline-View. The new Outline-View has to list some special contents of a CompilationUnit. I want the view to be updated if the current CompilationUnit in the JavaEditor is changed or exchanged by changing the current editor tab.
How can I do that? I searched through the JavaEditor code and recognized that a JavaOutlinePage is created by the JavaEditor. So I will have to subclass JavaEditor and rewrite some Methods that the Editor is able to create the new Outline-Page. How can I tell the Plugin to use the new JavaEditor?
I hope that I could explain what I want to do.
Thanks in advance.
Jochen
Re: Creating a new customized Outline-View [message #550727 is a reply to message #550691] Wed, 04 August 2010 03:38 Go to previous messageGo to next message
Jochen Huck wrote:
You don't need to subclass JavaEditor. You can update your view (input)
via part listener and listen for changes to the CU using an
org.eclipse.jdt.core.IElementChangedListener.
Dani
> Thanks in advance.
> Jochen
Re: Creating a new customized Outline-View [message #550998 is a reply to message #550727] Wed, 04 August 2010 15:17 Go to previous messageGo to next message
Thanks for your reply. I think this will solve the problem with updating the input for my view.
But I'd like to have another nice feature that the Outline-View offers. You can doubleclick on an element from the Outline-View and the JavaEditor automatically highlights the appropriate source code. It would also be nice to have this feature the other way around. Is something like that possible? Or will I have to create my own editor to do things like that?
Thanks again.
Jochen
Re: Creating a new customized Outline-View [message #551070 is a reply to message #550998] Thu, 05 August 2010 01:59 Go to previous messageGo to next message
@see ITextEditor#setHighlightRange(int, int, boolean)
@see ITextEditor#showHighlightRangeOnly(boolean)
Dani
> Thanks again.
> Jochen
Re: Creating a new customized Outline-View [message #551344 is a reply to message #551070] Fri, 06 August 2010 01:52 Go to previous message
Thanks again for your help.
For everyone who is interested:
I solved the problem of refreshing my views input after a change in the java editor. A very good link is: http://pookzilla.net/wp/2006/10/link-to-editor/
Previous Topic:need a good way for calculating composite's size with a text widget inside
Next Topic:Name clash error appears after migrating to Helios
Current Time: Sun Jul 20 21:13:55 EDT 2025
Powered by FUDForum. Page generated in 0.09438 seconds
