Home » Eclipse Projects » Eclipse Platform » Unable to run Eclipse Helios on windows 7 with jdk(Eclipse crashing on startup in windows 7)
Unable to run Eclipse Helios on windows 7 with jdk [message #550346] Thu, 29 July 2010 21:56 Go to next message
I am attempting to run Eclipse Helios on windows 7 32-bit. I have 32 bit Helios and 32 bit JDK.
I previously asked about this issue on the newcomers forum and it was suggested I ask here.
my original post: http://www.eclipse.org/forums/index.php?t=msg&th=172802& amp;start=0&
when I try to run Eclipse it will always crash by exiting without an error message. It will also hang if I try to interact with the workspace setting window.
I reverted to JDK 6 update 20 in case it was an issue with update 21 but it made no difference. Specifying the VM directly in the ini also makes no difference.
Here is the log:
!SESSION 2010-07-28 21:29:57.439 -----------------------------------------------
eclipse.buildId=I20100608-0911
java.version=1.6.0_20
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_AU
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product -data c:\temp\ws -debug
!ENTRY org.eclipse.osgi 4 0 2010-07-28 21:29:59.756
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: Cannot initialize Drop
at org.eclipse.swt.dnd.DND.error(DND.java:266)
at org.eclipse.swt.dnd.DND.error(DND.java:227)
at org.eclipse.swt.dnd.DropTarget.<init>(DropTarget.java:144)
at org.eclipse.ui.internal.EditorSashContainer.addDropSupport(E ditorSashContainer.java:542)
at org.eclipse.ui.internal.EditorSashContainer.createControl(Ed itorSashContainer.java:534)
at org.eclipse.ui.internal.EditorAreaHelper.<init>(EditorAreaHelper.java:41)
at org.eclipse.ui.internal.WorkbenchPage.init(WorkbenchPage.jav a:2425)
at org.eclipse.ui.internal.WorkbenchPage.<init>(WorkbenchPage.java:563)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation. createWorkbenchPage(Workbench3xImplementation.java:39)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:768)
at org.eclipse.ui.internal.Workbench$23.runWithException(Workbe nch.java:1220)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3660)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$31.runWithException(Workbe nch.java:1566)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2537)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
any help would be much appreciated.
Re: Unable to run Eclipse Helios on windows 7 with jdk [message #550693 is a reply to message #550346] Wed, 04 August 2010 02:45 Go to previous messageGo to next message
raf wrote:
> Hi
Please add your comments to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=299192
Dani
> my original post:
> Here is the log:
> !STACK 1
> at
> chWindow.java:768)
> nch.java:1220)
> onizer.java:134)
> nch.java:1566)
> onizer.java:134)
> (Realm.java:332)
> bench.java:663)
> tarter.java:369)
> tarter.java:179)
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
Re: Unable to run Eclipse Helios on windows 7 with jdk [message #551177 is a reply to message #550693] Thu, 05 August 2010 10:09 Go to previous messageGo to next message
Posted the following to the bug post:
I managed to fix the issue over the weekend, hopefully this is helpfully to anyone having the same issue.
I had this same issue
!STACK 1
I have windows 7 32bit. I am using 32 bit versions of both jdk and Eclipse.
Issue persisted across Java 6 update 20 and 21.
I managed to fix the issue by removing the following software from my system:
Proxifier
http://www.proxifier.com/
Widecap
and
worldoflogs client <--------uses the JVM to run
http://www.worldoflogs.com/help/client/
I have been unable to re-produce the error by re-installing them individually
so far, however, removing these three programs definitely fixed the issue.
Re: Unable to run Eclipse Helios on windows 7 with jdk [message #1000696 is a reply to message #551177] Tue, 15 January 2013 04:21 Go to previous message
I had the same problem and removing Widecap fix it.
Previous Topic:Target Definition
Next Topic:SWTBot in Indigo
Current Time: Sat Jul 26 15:22:01 EDT 2025
Powered by FUDForum. Page generated in 0.11729 seconds
