Home » Archived » BIRT » Birt upgrade openreports Resolved
Birt upgrade openreports Resolved [message #536812] Mon, 31 May 2010 03:20 Go to next message
OpenReports 3.20 use birt 2 3 2, Eclipse Helios Birt 2.6.0. The rptdesign files produced are not in same format. Eclipse Birt works to update the rptdesign 2 3.2 files.
I would like to update birt (2.3.2) OpenReport to deploy the files generated by eclipse 2.6.0.
Someone should do this or he would give me a track?
Many thank's.
[Updated on: Wed, 09 June 2010 03:19] by Moderator
Re: Birt upgrade openreports [message #536975 is a reply to message #536812] Mon, 31 May 2010 14:12 Go to previous messageGo to next message
[Updated on: Tue, 01 June 2010 07:12] by Moderator
Re: Birt upgrade openreports [message #536976 is a reply to message #536812] Mon, 31 May 2010 14:24 Go to previous messageGo to next message
I use birt runtime2.6.0 to upgrade openreports but i facing trouble with web.xml
Does any people help me
Many thank's
I receive:
GRAVE: Exception lors de l'envoi de l'évènement contexte initialisé (context initialized) à l'instance de classe d'écoute (listener) org.eclipse.birt.report.listener.ViewerServletContextListene r
java.lang.NoSuchMethodError: org.eclipse.birt.report.engine.api.EngineConfig.getLogRollin gSize()I
at org.eclipse.birt.report.engine.api.impl.ReportEngine.intiali zeLogger(ReportEngine.java:220)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.<init>(ReportEngine.java:132)
at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$ 1.run(ReportEngineFactory.java:18)
at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$ 1.run(ReportEngineFactory.java:1)
at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory. createReportEngine(ReportEngineFactory.java:14)
at org.eclipse.birt.report.service.ReportEngineService.setEngin eContext(ReportEngineService.java:328)
at org.eclipse.birt.report.service.BirtViewerReportService.setC ontext(BirtViewerReportService.java:1022)
at org.eclipse.birt.report.listener.ViewerServletContextListene r.contextInitialized(ViewerServletContextListener.java:62)
at org.apache.catalina.core.StandardContext.listenerStart(Stand ardContext.java:3972)
at org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4467)
at org.apache.catalina.core.ContainerBase.addChildInternal(Cont ainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBas e.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost. java:546)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig. java:905)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig .java:740)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig .java:500)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java :1277)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostCo nfig.java:321)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent (LifecycleSupport.java:119)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:785)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:519)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:581 )
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 89)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 4)
the new web.xml i from birt runtime
the old web.xml from openreports has:
<?xml version="1.0" encoding="ISO-8859-1"?>
<!DOCTYPE web-app PUBLIC "-//Sun Microsystems, Inc.//DTD Web Application 2.3//EN" "http://java.sun.com/dtd/web-app_2_3.dtd">
<web-app>
<display-name>OpenReports</display-name>
<context-param>
<param-name>contextConfigLocation</param-name>
<param-value>/WEB-INF/applicationContext*.xml</param-value >
</context-param>
<context-param>
<param-name>contextFactory</param-name>
<param-value>
com.tonbeller.wcf.controller.RequestContextFactoryImpl
</param-value>
</context-param>
<filter>
<filter-name>struts</filter-name>
<filter-class>
org.apache.struts2.dispatcher.FilterDispatcher
</filter-class>
</filter>
<filter>
<filter-name>ResponseOverrideFilter</filter-name>
<filter-class>
org.displaytag.filter.ResponseOverrideFilter
</filter-class>
</filter>
<filter>
<filter-name>JPivotController</filter-name>
<filter-class>
com.tonbeller.wcf.controller.RequestFilter
</filter-class>
<init-param>
<param-name>indexJSP</param-name>
<param-value>/index.html</param-value>
<description>
forward to this page if session is new
</description>
</init-param>
<init-param>
<param-name>errorJSP</param-name>
<param-value>/error.jsp</param-value>
<description>URI of error page</description>
</init-param>
<init-param>
<param-name>busyJSP</param-name>
<param-value>/busy.jsp</param-value>
<description>
This page is displayed if a the user clicks on a query
before the previous query has finished
</description>
</init-param>
<init-param>
<param-name>forceExtension</param-name>
<param-value>.faces</param-value>
<description>replace .jsp with .faces</description>
</init-param>
</filter>
<filter-mapping>
<url-pattern>/jpivot.action</url-pattern>
</filter-mapping>
<filter-mapping>
<url-pattern>/JPivot.jsp</url-pattern>
</filter-mapping>
<filter-mapping>
<url-pattern>*.action</url-pattern>
</filter-mapping>
<filter-mapping>
<url-pattern>/*</url-pattern>
</filter-mapping>
<!-- resources initializer -->
<listener>
<listener-class>
com.tonbeller.tbutils.res.ResourcesFactoryContextListener
</listener-class>
</listener>
<listener>
<listener-class>
org.springframework.web.context.ContextLoaderListener
</listener-class>
</listener>
<servlet>
<servlet-name>JspSupportServlet</servlet-name>
<servlet-class>
org.apache.struts2.views.JspSupportServlet
</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet>
<servlet-name>fileServlet</servlet-name>
<servlet-class>
org.efs.openreports.dispatcher.FileDispatcher
</servlet-class>
<load-on-startup>99</load-on-startup>
</servlet>
<servlet>
<servlet-name>MondrianXmlaServlet</servlet-name>
<servlet-class>
org.efs.openreports.dispatcher.XMLADispatcher
</servlet-class>
</servlet>
<servlet>
<servlet-name>XFireServlet</servlet-name>
<display-name>XFire Servlet</display-name>
<servlet-class>
org.codehaus.xfire.spring.XFireSpringServlet
</servlet-class>
</servlet>
<!-- jfreechart provided servlet -->
<servlet>
<servlet-name>DisplayChart</servlet-name>
<servlet-class>
org.jfree.chart.servlet.DisplayChart
</servlet-class>
</servlet>
<servlet>
<servlet-name>GetChart</servlet-name>
<display-name>GetChart</display-name>
<description>
Default configuration created for servlet.
</description>
<servlet-class>
com.tonbeller.jpivot.chart.GetChart
</servlet-class>
</servlet>
<servlet>
<servlet-name>Print</servlet-name>
<display-name>Print</display-name>
<description>
</description>
<servlet-class>
com.tonbeller.jpivot.print.PrintServlet
</servlet-class>
</servlet>
<servlet-mapping>
<url-pattern>/DisplayChart</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/Print</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/GetChart</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/report-images/*</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/report-files/*</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/services/*</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/xmla</url-pattern>
</servlet-mapping>
<welcome-file-list>
<welcome-file>/Login.jsp</welcome-file>
</welcome-file-list>
<taglib>
<taglib-uri>http://www.tonbeller.com/wcf</taglib-uri>
<taglib-location>/WEB-INF/wcf/wcf-tags.tld</taglib-location >
</taglib>
<taglib>
<taglib-uri>http://www.tonbeller.com/jpivot</taglib-uri>
<taglib-location>
/WEB-INF/jpivot/jpivot-tags.tld
</taglib-location>
</taglib>
</web-app>
[Updated on: Mon, 31 May 2010 14:25] by Moderator
Re: Birt upgrade openreports [message #537183 is a reply to message #536976] Tue, 01 June 2010 10:47 Go to previous messageGo to next message
This still looks like a version conflict as the
EngineConfig.getLogRollingSize did not exist in 2.3.2 but does exist in
2.6. Make sure you cleared the
openreports\WebRoot\WEB-INF\platform\workspace folder and cleared
everything in openreports\WebRoot\WEB-INF\platform\configuration except
the config.ini file.
Jason
On 5/31/2010 2:24 PM, panoramix wrote:
> web.xml
> I receive:
> at
> at java.security.AccessController.doPrivileged(Native Method)
> xt.java:4467)
> ainerBase.java:791)
> nfig.java:321)
> ce.java:519)
> ssorImpl.java:57)
> <web-app>
> <context-param>
> </context-param>
> <context-param>
> <param-value>
> </param-value>
> </context-param>
> <filter>
> <filter-class>
> </filter-class>
> </filter>
> <filter>
> <filter-class>
> </filter-class>
> </filter>
> <filter>
> <filter-class>
> </filter-class>
> <init-param>
> <description>
> </description>
> </init-param>
> <init-param>
> </init-param>
> <init-param>
> <description>
> </description>
> </init-param>
> <init-param>
> </init-param>
> </filter>
> <filter-mapping>
> </filter-mapping>
> <filter-mapping>
> </filter-mapping>
> <filter-mapping>
> </filter-mapping>
> <filter-mapping>
> </filter-mapping>
> <listener>
> <listener-class>
> </listener-class>
> </listener>
> <listener>
> <listener-class>
> </listener-class>
> </listener>
> <servlet>
> <servlet-class>
> </servlet-class>
> </servlet>
> <servlet>
> <servlet-class>
> </servlet-class>
> </servlet>
> <servlet>
> <servlet-class>
> </servlet-class>
> </servlet>
> <servlet>
> <servlet-class>
> </servlet-class>
> </servlet>
> <servlet>
> <servlet-class>
> </servlet-class>
> </servlet>
> <servlet>
> <description>
> </description>
> <servlet-class>
> </servlet-class>
> </servlet>
> <servlet>
> <description>
> </description>
> <servlet-class>
> </servlet-class>
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
> <servlet-mapping>
> </servlet-mapping>
> <servlet-mapping>
> </servlet-mapping>
> <servlet-mapping>
> </servlet-mapping>
> <servlet-mapping>
> </servlet-mapping>
> <servlet-mapping>
> </servlet-mapping>
> <servlet-mapping>
> </servlet-mapping>
> <welcome-file-list>
> <taglib>
> </taglib>
> <taglib>
> <taglib-location>
> </taglib-location>
> </taglib>
> </web-app>
Re: Birt upgrade openreports [message #550427 is a reply to message #537183] Fri, 30 July 2010 06:42 Go to previous messageGo to next message
Originally posted by: headerhound.yahoo.co.uk
Did this ever get sorted? I too have tried upgrading the 2.3 jars etc in
Open Reports to 2.6 and redeploying a new war without any success. I
guess its more an OReports issue but theres very little documentation
with it.
> Jason
>> Hi,
>> web.xml
>> I receive:
>> at
>> xt.java:4467)
>> ainerBase.java:791)
>> e.java:771)
>> .java:740)
>> .java:500)
>> nfig.java:321)
>> .java:443)
>> ce.java:519)
>> .java:710)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> ssorImpl.java:57)
>> <web-app>
>> <context-param>
>> </context-param>
>> <context-param>
>> <param-value>
>> </param-value>
>> </context-param>
>> <filter>
>> <filter-class>
>> </filter-class>
>> </filter>
>> <filter>
>> <filter-class>
>> </filter-class>
>> </filter>
>> <filter>
>> <filter-class>
>> </filter-class>
>> <init-param>
>> <description>
>> </description>
>> </init-param>
>> <init-param>
>> </init-param>
>> <init-param>
>> <description>
>> </description>
>> </init-param>
>> <init-param>
>> </init-param>
>> </filter>
>> <filter-mapping>
>> </filter-mapping>
>> <filter-mapping>
>> </filter-mapping>
>> <filter-mapping>
>> </filter-mapping>
>> <filter-mapping>
>> </filter-mapping>
>> <listener>
>> <listener-class>
>> </listener-class>
>> </listener>
>> <listener>
>> <listener-class>
>> </listener-class>
>> </listener>
>> <servlet>
>> <servlet-class>
>> </servlet-class>
>> </servlet>
>> <servlet>
>> <servlet-class>
>> </servlet-class>
>> </servlet>
>> <servlet>
>> <servlet-class>
>> </servlet-class>
>> </servlet>
>> <servlet>
>> <servlet-class>
>> </servlet-class>
>> </servlet>
>> <servlet>
>> <servlet-class>
>> </servlet-class>
>> </servlet>
>> <servlet>
>> <description>
>> </description>
>> <servlet-class>
>> </servlet-class>
>> </servlet>
>> <servlet>
>> <description>
>> </description>
>> <servlet-class>
>> </servlet-class>
>> </servlet>
>> <servlet-mapping>
>> </servlet-mapping>
>> <servlet-mapping>
>> </servlet-mapping>
>> <servlet-mapping>
>> </servlet-mapping>
>> <servlet-mapping>
>> </servlet-mapping>
>> <servlet-mapping>
>> </servlet-mapping>
>> <servlet-mapping>
>> </servlet-mapping>
>> <servlet-mapping>
>> </servlet-mapping>
>> <welcome-file-list>
>> <taglib>
>> </taglib>
>> <taglib>
>> <taglib-location>
>> </taglib-location>
>> </taglib>
>> </web-app>
Re: Birt upgrade openreports [message #550495 is a reply to message #550427] Fri, 30 July 2010 10:32 Go to previous messageGo to next message
Can you post the error you are getting?
Jason
> with it.
>> in 2.6. Make sure you cleared the
>> except the config.ini file.
>> Jason
>>> Hi,
>>> web.xml
>>> I receive:
>>> at
>>> xt.java:4467)
>>> ainerBase.java:791)
>>> e.java:771)
>>> java:546)
>>> java:905)
>>> .java:740)
>>> .java:500)
>>> nfig.java:321)
>>> ava:1053)
>>> ava:1045)
>>> .java:443)
>>> ce.java:519)
>>> .java:710)
>>> ssorImpl.java:57)
>>> <web-app>
>>> <context-param>
>>> </context-param>
>>> <context-param>
>>> <param-value>
>>> </param-value>
>>> </context-param>
>>> <filter>
>>> <filter-class>
>>> </filter-class>
>>> </filter>
>>> <filter>
>>> <filter-class>
>>> </filter-class>
>>> </filter>
>>> <filter>
>>> <filter-class>
>>> </filter-class>
>>> <init-param>
>>> <description>
>>> </description>
>>> </init-param>
>>> <init-param>
>>> </init-param>
>>> <init-param>
>>> <description>
>>> </description>
>>> </init-param>
>>> <init-param>
>>> </init-param>
>>> </filter>
>>> <filter-mapping>
>>> </filter-mapping>
>>> <filter-mapping>
>>> </filter-mapping>
>>> <filter-mapping>
>>> </filter-mapping>
>>> <filter-mapping>
>>> </filter-mapping>
>>> <listener>
>>> <listener-class>
>>> </listener-class>
>>> </listener>
>>> <listener>
>>> <listener-class>
>>> </listener-class>
>>> </listener>
>>> <servlet>
>>> <servlet-class>
>>> </servlet-class>
>>> </servlet>
>>> <servlet>
>>> <servlet-class>
>>> </servlet-class>
>>> </servlet>
>>> <servlet>
>>> <servlet-class>
>>> </servlet-class>
>>> </servlet>
>>> <servlet>
>>> <servlet-class>
>>> </servlet-class>
>>> </servlet>
>>> <servlet>
>>> <servlet-class>
>>> </servlet-class>
>>> </servlet>
>>> <servlet>
>>> <description>
>>> </description>
>>> <servlet-class>
>>> </servlet-class>
>>> </servlet>
>>> <servlet>
>>> <description>
>>> </description>
>>> <servlet-class>
>>> </servlet-class>
>>> </servlet>
>>> <servlet-mapping>
>>> </servlet-mapping>
>>> <servlet-mapping>
>>> </servlet-mapping>
>>> <servlet-mapping>
>>> </servlet-mapping>
>>> <servlet-mapping>
>>> </servlet-mapping>
>>> <servlet-mapping>
>>> </servlet-mapping>
>>> <servlet-mapping>
>>> </servlet-mapping>
>>> <servlet-mapping>
>>> </servlet-mapping>
>>> <welcome-file-list>
>>> <taglib>
>>> </taglib>
>>> <taglib>
>>> <taglib-location>
>>> </taglib-location>
>>> </taglib>
>>> </web-app>
Re: Birt upgrade openreports [message #550525 is a reply to message #550495] Fri, 30 July 2010 12:26 Go to previous messageGo to next message
Snip
Ok, basically I replaced the 2.3.2 files with the 2.6 files I could see
a mapping for. so for Web_inf/lib I put these files in ...
17/06/2010 13:04 6,451,211 com.ibm.icu_4.2.1.v20100412.jar
09/06/2010 20:07 771,550 js.jar
17/06/2010 13:06 211,682
org.eclipse.emf.common_2.6.0.v20100614-1136.jar
17/06/2010 13:06 219,248
org.eclipse.emf.ecore.xmi_2.5.0.v20100521-1846.jar
17/06/2010 13:06 1,231,338
org.eclipse.emf.ecore_2.6.0.v20100614-1136.jar
and for Web_inf/platform/plugins ......
17/06/2010 13:05 138,224
org.eclipse.birt.chart.device.extension_2.6.0.v20100521.jar
17/06/2010 13:05 12,906
org.eclipse.birt.chart.device.pdf_2.6.0.v20100304.jar
17/06/2010 13:05 66,595
org.eclipse.birt.chart.device.svg_2.6.0.v20100527.jar
17/06/2010 13:05 58,472
org.eclipse.birt.chart.device.swt_2.6.0.v20100519.jar
17/06/2010 13:05 275,478
org.eclipse.birt.chart.engine.extension_2.6.0.v20100601.jar
17/06/2010 13:05 1,543,550
org.eclipse.birt.chart.engine_2.6.0.v20100607.jar
17/06/2010 13:05 253,199
org.eclipse.birt.chart.reportitem_2.6.0.v20100604.jar
17/06/2010 13:05 144,244
org.eclipse.birt.core.script.function_2.6.0.v20100524.jar
17/06/2010 13:05 429,213
org.eclipse.birt.core_2.6.0.v20100526.jar
17/06/2010 13:05 122,711
org.eclipse.birt.data.aggregation_2.6.0.v20100524.jar
17/06/2010 13:05 1,648,451
org.eclipse.birt.data_2.6.0.v20100524.jar
17/06/2010 13:05 26,910
org.eclipse.birt.report.data.oda.jdbc.dbprofile_2.6.0.v20100 524.jar
29/07/2010 21:46 <DIR>
org.eclipse.birt.report.data.oda.jdbc_2.6.0.v20100524
17/06/2010 13:05 21,845
org.eclipse.birt.report.data.oda.xml_2.6.0.v20100524.jar
17/06/2010 13:05 11,537
org.eclipse.birt.report.engine.dataextraction.csv_2.5.2.v201 00115.jar
17/06/2010 13:05 14,692
org.eclipse.birt.report.engine.dataextraction_2.5.2.v2010011 5.jar
17/06/2010 13:05 23,794
org.eclipse.birt.report.engine.emitter.config_2.6.0.v2010030 4.jar
17/06/2010 13:05 13,074
org.eclipse.birt.report.engine.emitter.excel.config_2.6.0.v2 0100527.jar
17/06/2010 13:05 11,853
org.eclipse.birt.report.engine.emitter.html.config_2.6.0.v20 100304.jar
17/06/2010 13:05 79,630
org.eclipse.birt.report.engine.emitter.html_2.6.0.v20100603. jar
17/06/2010 13:05 13,887
org.eclipse.birt.report.engine.emitter.pdf.config_2.6.0.v201 00512.jar
17/06/2010 13:05 28,567
org.eclipse.birt.report.engine.emitter.pdf_2.6.0.v20100513.j ar
17/06/2010 13:05 14,446
org.eclipse.birt.report.engine.emitter.postscript.config_2.6 .0.v20100512.jar
17/06/2010 13:05 60,385
org.eclipse.birt.report.engine.emitter.postscript_2.6.0.v201 00526.jar
17/06/2010 13:05 13,698
org.eclipse.birt.report.engine.emitter.ppt.config_2.6.0.v201 00512.jar
17/06/2010 13:05 27,293
org.eclipse.birt.report.engine.emitter.ppt_2.6.0.v20100429.j ar
17/06/2010 13:05 105,868
org.eclipse.birt.report.engine.emitter.prototype.excel_2.6.0 .v20100601.jar
17/06/2010 13:05 12,486
org.eclipse.birt.report.engine.emitter.wpml.config_2.6.0.v20 100512.jar
17/06/2010 13:05 65,822
org.eclipse.birt.report.engine.emitter.wpml_2.6.0.v20100520. jar
org.eclipse.birt.report.engine.fonts_2.6.0.v20100428
17/06/2010 13:05 26,615
org.eclipse.birt.report.engine.script.javascript_2.6.0.v2010 0408.jar
17/06/2010 13:05 2,612,238
org.eclipse.birt.report.engine_2.6.0.v20100609.jar
17/06/2010 13:05 260,529
org.eclipse.birt.report.item.crosstab.core_2.6.0.v20100531.j ar
17/06/2010 13:05 165,874
org.eclipse.birt.report.model.adapter.oda_2.6.0.v20100528.ja r
17/06/2010 13:05 2,740,417
org.eclipse.birt.report.model_2.6.0.v20100603.jar
org.eclipse.core.runtime.compatibility.registry_3.3.0.v20100 520
29/07/2010 21:47 <DIR> org.mozilla.rhino_1.7.1.v20090608
29/07/2010 21:47 <DIR> org.w3c.sac_1.3.0.v20070710
The war built ok but when I deploy I get
30-Jul-2010 16:57:48 org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance
of class org.springframework.web.context.ContextLoaderListener
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'birtProvider' defined in ServletContext resource
[/WEB-INF/applicationContext.xml]: Instantiation of bean failed; nested
exception is org.springframework.beans.BeanInstantiationException: Could
not instantiate bean class [org.efs.openreports.providers.BirtProvider]:
Constructor threw exception; nested exception is
Caused by: org.springframework.beans.BeanInstantiationException: Could
at
org.efs.openreports.providers.BirtProvider.startBirtEngine(B irtProvider.java:121)
at
org.efs.openreports.providers.BirtProvider.<init>(BirtProvider.java:75)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
etc etc
I had hoped to get it going without refactoring src code .....
Re: Birt upgrade openreports [message #550564 is a reply to message #550525] Fri, 30 July 2010 15:50 Go to previous message
The Web_inf/lib directory should contain all the jars in the 2.6
runtime/ReportEngine/lib not just the five you posted. You also should
replace the Web_inf/platform/configuration directory with the one in the
runtime. Verify that that it only contains config.ini. I am not
certain this will fix the problem but its worth a try.
Jason
> Snip
> 17/06/2010 13:06 211,682 org.eclipse.emf.common_2.6.0.v20100614-1136.jar
> 17/06/2010 13:06 219,248 org.eclipse.emf.ecore.xmi_2.5.0.v20100521-1846.jar
> 17/06/2010 13:06 1,231,338 org.eclipse.emf.ecore_2.6.0.v20100614-1136.jar
> 17/06/2010 13:05 429,213 org.eclipse.birt.core_2.6.0.v20100526.jar
> 17/06/2010 13:05 1,648,451 org.eclipse.birt.data_2.6.0.v20100524.jar
> 29/07/2010 21:46 <DIR> org.eclipse.birt.report.engine.fonts_2.6.0.v20100428
> at
> at org.efs.openreports.providers.BirtProvider.<init>(BirtProvider.java:75)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
> etc etc
Previous Topic:Sequence with OnRender
Next Topic:Customize/Limit available locales in Designer?
Current Time: Wed Jul 23 06:11:58 EDT 2025
Powered by FUDForum. Page generated in 0.17684 seconds
