Home » Modeling » M2T (model-to-text transformation) » [Acceleo][EMTL] Very strange behaviour of the builder
[Acceleo][EMTL] Very strange behaviour of the builder [message #550376] Fri, 30 July 2010 03:26 Go to next message
I have problems with my emtl files (compiled mtl)
and i don't understand what is the problem.
For Gendoc2 (http://gforge.enseeiht.fr/projects/topcased-gendoc/) we use
bundled emtl files to make dynamic dependencies.
We noticed that the acceleo parser can not parse the bundled emtl files
if in the serialization there is references to EPackages using xmi ids
for example http://myEcore/#fezfz456fezvz
but if it is a "common" URI it works (in the serialization) :
http://myEcore/#
And the most weird is if I have two platform my workspace and my runtime:
If i build (indeed if acceleo builds) in my workspace the emtl is
serialized using xmi ids
If i build (indeed if acceleo builds) in my runtime the emtl is
"correctly' serialized.
Do you have any clues about :
Why there is different serializations (the environment seems the same) ?
Why when xmi ids are used the parsing doesn't
To parse we use code generated by Acceleo in a project :
r.getResourceFactoryRegistry().getExtensionToFactoryMap().pu t( "ecore",
new EcoreResourceFactoryImpl());
r.getResourceFactoryRegistry().getExtensionToFactoryMap().pu t( "emtl",
new org.eclipse.acceleo.model.mtl.resource.EMtlResourceFactoryIm pl());
r.getResourceFactoryRegistry().getExtensionToFactoryMap().pu t(Resource.Factory.Registry.DEFAULT_EXTENSION,
new XMIResourceFactoryImpl());
r.getPackageRegistry().put(org.eclipse.ocl.ecore.EcorePackag e.eINSTANCE.getNsURI(),
org.eclipse.ocl.ecore.EcorePackage.eINSTANCE);
r.getPackageRegistry().put(org.eclipse.ocl.expressions.Expre ssionsPackage.eINSTANCE.getNsURI(),
org.eclipse.ocl.expressions.ExpressionsPackage.eINSTANCE);
r.getPackageRegistry().put(MtlPackage.eINSTANCE.getNsURI(),
MtlPackage.eINSTANCE);
r.getPackageRegistry().put("http://www.eclipse.org/ocl/1.1.0/oclstdlib.ecore",
getOCLStdLibPackage());
AcceleoSourceBuffer source = new AcceleoSourceBuffer(textBuffer);
parser.parse(source, r, ServicesExtension.getInstance().getResources());
// this method retrieves the uris of the dynamic dependencies
Re: [Acceleo][EMTL] Very strange behaviour of the builder [message #550388 is a reply to message #550376] Fri, 30 July 2010 04:33 Go to previous messageGo to next message
Hi Tristan
Acceleo's support for Reflective models is poor, so you are probably
using a Runtime workspace.
Are you sure that Acceleo is not using the platform:/plugin myEcore
while you or some tool are expecting it to use the platform:/resource
myEcore?
It's very easy to get confused.
Ed Willink
On 30/07/2010 08:26, Tristan FAURE wrote:
> http://myEcore/#
Re: [Acceleo][EMTL] Very strange behaviour of the builder [message #550390 is a reply to message #550388] Fri, 30 July 2010 04:41 Go to previous messageGo to next message
Hi Ed,
I will try maybe it's because my plugin embedding the ecore is in my
workspace.
Le 30/07/2010 10:33, Ed Willink a écrit :
> Hi Tristan
> myEcore?
> Regards
> Ed Willink
>> Hi,
>> http://myEcore/#
>> runtime:
Re: [Acceleo][EMTL] Very strange behaviour of the builder [message #550419 is a reply to message #550390] Fri, 30 July 2010 05:56 Go to previous messageGo to next message
--------------050904000805020400040709
Hi Tristan,
We've had no problems so far with XMI IDs... But I must admit I am a
little lost with your problem description :
"And the most weird is if I have two platform my workspace and my runtime:
"correctly' serialized. "
I thinks xmi ids is the "correct" serailization of EMF models using xmi
ids ...
"Why there is different serializations (the environment seems the same) ?"
We do not meddle with serialization, EMF is in charge there. If it does
serialize differently, then it would also serialize differently with
plain old ecore models... and either way deserialization should work.
"AcceleoSourceBuffer source = new AcceleoSourceBuffer(textBuffer);
// this method retrieves the uris of the dynamic dependencies "
We don't generate this. If you wish to compile mtl files to emtl
yourself, you might want to take a look at the class "AcceleoCompiler".
If you need to use the AcceleoParser class, you need to have a good
understanding of the dependencies you need, and be sure to compile them
beforehand.
Laurent Goubet
Obeo
> Hi Ed,
> workspace.
>> Hi Tristan
>> myEcore?
>> Regards
>> Ed Willink
>>> Hi,
>>> http://myEcore/#
>>> runtime:
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------050904000805020400040709--
Re: [Acceleo][EMTL] Very strange behaviour of the builder [message #551356 is a reply to message #550419] Fri, 06 August 2010 02:38 Go to previous message
Hi, I have checked solution from Ed and it works.
It seems that when EMF serializes the mtl into emtl, the references to
EPackage in the workspace are serialized using xmi-ids (With standard
behavior it doesn't occur)
Tristan
Le 30/07/2010 11:56, Laurent Goubet a écrit :
> Hi Tristan,
> runtime:
> xmi ids ...
> same) ?"
> does serialize differently, then it would also serialize differently
> with plain old ecore models... and either way deserialization should
> work.
> ServicesExtension.getInstance().getResources()); // this method
> "AcceleoCompiler". If you need to use the AcceleoParser class, you
> need to have a good understanding of the dependencies you need, and be
> sure to compile them beforehand.
> Laurent Goubet
> Obeo
>> Hi Ed,
>> workspace.
>>> Hi Tristan
>>> platform:/resource myEcore?
>>> Regards
>>> Ed Willink
>>>> Hi,
>>>> we use
>>>> files
>>>> http://myEcore/#
>>>> runtime:
>>>> same) ?
Previous Topic:Changing outlet path from within Xpand or Xtend
Next Topic:[Xpand2] Where can I find CppBeautifier / org.eclipse.xpand.support.cdt ?
Current Time: Sat Jul 26 11:39:28 EDT 2025
Powered by FUDForum. Page generated in 0.32195 seconds
