Home » Eclipse Projects » Eclipse Platform » Unable to control editor tab size in 3.6(org.eclipse.ui/EDITOR_MINIMUM_CHARACTERS property no respected in 3.6)
Unable to control editor tab size in 3.6 [message #550279] Thu, 29 July 2010 14:07 Go to next message
In the past (most recently 3.42 and 3.51) I set the editor minimum characters property to make sure that my editor tabs showed the full file name of the file I was editing.
In the plugin_customization.ini file for the org.eclipse.sdk plug-in I added this line:
# prevent tab namess from being truncated
org.eclipse.ui/EDITOR_MINIMUM_CHARACTERS=80
Now that I have moved to Eclipse 3.6 I edited my plugin_customization.ini file for the org.eclipse.sdk_3.6.0.v201006080911 plug-in. But nothing happened - it truncated my file names to the point I can not figure out what is what.
Not only that for some of my work I am using the classic install and for others I am trying out the new JS install. The new JS install does not have an sdk plug-in. Where do I set this property for that installation?
What happened to supporting this property? I cannot find any mention of changes to it or dropping support for it on the eclipse.org web site.
Any help or advice would be appreciated. Thanks,
Ian
Re: Unable to control editor tab size in 3.6 [message #550433 is a reply to message #550279] Fri, 30 July 2010 07:14 Go to previous messageGo to next message
The place to check is
org.eclipse.ui.presentations.WorkbenchPresentationFactory.cr eateEditorPresentation(Composite,
IStackPresentationSite)
If you put a breakpoint there you can see if the preference is being
set. It might be a bug in CTabFolder, there were some changes in 3.6.
For plugin_customization.ini, you don't have to edit the one provided,
you can provide on on the command line (or in the eclipse.ini):
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/runtime-options.html
You'll have to look in your plugins directory to find the "branding"
plugin for the product that your JS install launches.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
icon14.gif  SOLVED Re: Unable to control editor tab size in 3.6 [message #550555 is a reply to message #550433] Fri, 30 July 2010 15:04 Go to previous message
Paul Webster wrote on Fri, 30 July 2010 07:14
Oh, I like that much better. I can create one file with just what I want to override and not have to edit installed files. I never liked editing installed files.
And now there is no need because when I use the command line option -pluginCustomization it just works no matter what the branding plug-in is.
Thank you very much
Previous Topic:[eclipse plugin ] implement a class to handel a command
Next Topic:Problems with "Synchronize with patch"
Current Time: Sun Jul 27 08:18:17 EDT 2025
Powered by FUDForum. Page generated in 0.04328 seconds
