Home » Archived » BIRT » Read report design (Is there a way to read a report design from a database table?)
Read report design [message #549733] Tue, 27 July 2010 14:33 Go to next message
I need to store my report designs in a database table rather than storing them in a folder on the server, is there a way to store these in the database and read the design from that table and send the design to the run and render task when a report request is made? I could store these in a column either as xml or as a file. Has anybody done this? I'm having problems implementing this.
Thank you,
Re: Read report design [message #550050 is a reply to message #549733] Wed, 28 July 2010 17:38 Go to previous messageGo to next message
Kris,
Haven't done this specificallly, but I know of quite a few people that have.
The .rptdesign is just a text file, so if you store as text and then pull
it out and feed that into your ReportEngine it should work.
What specific problems are you running into?
Scott Rosenbaum
Innovent Solutions, BIRT PMC
> Thank you,
Re: Read report design [message #550175 is a reply to message #550050] Thu, 29 July 2010 09:03 Go to previous messageGo to next message
Hi Scott,
Thank you so much for replying to my question.
I have tried pulling the information from the database into a String and then just passing the string to the openReportDesign method. I have also tried passing it in using a ByteArrayInputStream getBytes method. Both result in an invalid xml parsing error. I have validated the xml and it is well formed.
I fixed the above problem, but now I am getting
j
avax.servlet.ServletException: org.eclipse.birt.report.engine.api.EngineException: The design file can not be found.
I'm pretty new to java, so it takes me quite a while to whittle away at these issues.
String lReportDesign = RptDbUtil.retrieveDesign("inactiveUsers", "1");
lDesign = aBirtEngine.openReportDesign(lReportDesign);
//create task to run and render report
IRunAndRenderTask lTask = aBirtEngine.createRunAndRenderTask( lDesign );
Thanks again for your reply.
Re: Read report design [message #550195 is a reply to message #550175] Thu, 29 July 2010 09:54 Go to previous messageGo to next message
Whoo hooo!!!! I got it to work. Thanks again Scott for your reply.
Re: Read report design [message #550221 is a reply to message #550195] Thu, 29 July 2010 10:44 Go to previous messageGo to next message
Kris,
Can you post what you did to help others?
Jason
Re: Read report design [message #550236 is a reply to message #550221] Thu, 29 July 2010 11:08 Go to previous messageGo to next message
Well, I'm not really the best person to ask, I'm not a java programmer. But the problem that I had was in my return from fetching the design. This is the working method.
public class RptDbUtil
implements RptDbSql
public static String
retrieveDesign(String pReportName, String pVersion)
throws Exception
Log.debug("Entered RptDbUtil.retrieveDesign");
CHGSQLService lService = CHGSQLService.getInstance();
SQLResult lResult = lService.executeQuery(RptDbSql.SQL_SELECT_DESIGN, new Object [] {pReportName, pVersion}, 0L);
if (lResult.getRowCount() == 0)
throw new RuntimeException("Report not found " + pReportName + " for version " + pVersion);
return lResult.getRow(0).getValue(0).toString();
I was returning lResult.getRow(0).toString(); which was returning an object instead of a string. The string is passed into the openReportDesign using this:
lDesign = aBirtEngine.openReportDesign(new ByteArrayInputStream(RptDbUtil.retrieveDesign("inactiveUsers ", "1").getBytes()));
There may be a more efficient or more elegant way, but this worked for me. Smile
Re: Read report design [message #550241 is a reply to message #550236] Thu, 29 July 2010 11:11 Go to previous message
Thanks for posting!
> public class RptDbUtil implements RptDbSql
> throws Exception
> new Object [] {pReportName, pVersion}, 0L); if (lResult.getRowCount() == 0)
> "1").getBytes()));
> me. :)
Previous Topic:Missing TOC for Word
Next Topic:CSS Highlight property
Current Time: Wed Jul 23 12:28:47 EDT 2025
Powered by FUDForum. Page generated in 0.18699 seconds
