Home » Eclipse Projects » Rich Client Platform (RCP) » [HowTo] add "New WIzard" items to the navigator context-menu?
[HowTo] add "New WIzard" items to the navigator context-menu? [message #549987] Wed, 28 July 2010 11:34 Go to next message
--------------040503010607090600010504
WinXP; R3.4 (I know, I know ... but the tool I am working on uses 3.4,
so ...)
I'm adding items to an existing LARGE tool, including a "New Wizard" to
create a project and a "New Wizard" to create a file-resource / model
object; the wizards are added, work, all fine.
However, in the context-menu of an item in the navigator, the wizards
are only visible under the New -> Project... dialog (for my "New Wizard"
that is a new-project wizard) and the New -> Other... dialog (for both
of them). That would be fine, except that other "New Wizards" somehow
make their appearance in that context menu -- e.g., from the JDT, from
JUnit, from Mylyn, etc. -- see attached PNG screen shots.
So, evidently it is possible, but how? The issue is not addressed in
this newsgroup (or the "platform" newsgroup) that I could find. I saw
nothing in the FAQ's. I saw nothing relevant in the docco:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/dialogs_wizards_newWizards.htm
I have tried the "primary wizard" (solves a different problem). I have
tried adding a perspective extension and to that a new-wizard short-cut
(no luck). I have tried adding to the perspective extension an
action-set (solves a different problem).
I looked at how the "org.eclipse.jdt.ui" plugs in its "New Wizards",
such as "New Class", and found only the extension to the
"org.eclipse.ui.newWizards" and the perspective-extension. (I didn't
look at the JUnit or Mylyn plugin.xml ...)
So ... how is the magic accomplished?
thanks,
Paul
Content-Type: image/png;
name="NewWizard-MissingFromMenu.PNG"
Content-Disposition: inline;
filename="NewWizard-MissingFromMenu.PNG"
iVBORw0KGgoAAAANSUhEUgAAAXAAAAEMCAIAAABSm3rSAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
LxNJREFUeF7tnT+IHEnW4Pu8M8dc88bbhTPUcM7AWg2Cu/HU8BknWGMRaxxC hqhPhhByRCND
FGMMhYymTgcDNYagxhjoNhaqxxgoGQu9xkDLEJSMNsqQUUYbZcioe5Ev8+XL iMis/BOZGZH1
kqDJzoqMePFexK9eRFa++C/Td7NHf394JIdooCsN/N//97N0ua6U7bKeUoYD oOzkEA10qAHp
ch0q22VVZQx3RJkuLheSRAMdaKBMv3Q5DqQsRxooY7gMUBaXS0migbY1UKZf OhoCUoxLDZQx
nABFGNq1Bsr0S5fjQMpypAEw3PZuC8fua26JApSuh1Pb3//+l18DKIu33zoa FFJMfQ2A4Vaf
VuvbNWAljykCFAFKixqAZwwm4KoCJaLJRphSnwSO7gTDXVxeLD8sFVPAT7Ed 7oDybnR8dHT8
ZB53IPj33mgmizKHrQF8aKkxxQTKybM5pO+fq7+nry4ev12evb9e/LGBdPHj t5AAKMmJo8Eh
xVTXABhuej4FpoCfopyU1oFy7/T03vHoXfSNJ0A5bJQgROhXEJwpJlAe/7p+ fLke/XM9ulyP
f1/PACWftuu73fzNn3bbG5au1RU6Pk9O0p9ZjBZlRgjccn+ycpuzTGmDyAOG m/w4mf8yv/l4
0w1QRrPXp0cPxhmgRJ5LdESsIdCo66dj1e3mo3t4ImloGuA/qyL7lvRQlh83 y0+b2as/Qdp9
mcUnfGRyOlyNjkqSouTYLo+ekgWGnw0MN/5hPH/fJVAul+MHR6evCRzj05ga +pXZk+PTB6cq
5+X4VCZHA4VpSQ9lcf79zd1OS6vtbvN1t/26mz7/Zvf5DP6ur0aZUZkZ84vR 0WgRXZk8hWoj
hyV1YaJ/ATpwIHfSj04mn7FUKCE+Rleryf34/OS8lEMTPi72t6AfoMQ+CHoi qXuC5lGeyPiB
clXGD07H8Cm4M/h3oCPqwNtVcg0FgQL40BLQRM3Uv252t2e7r6v177lAWZ2f KFJEmBhdpYDA
c/Xp02hKFDMoog/miq8ogiQ38uv7h9nh5OgJKJdL5X08SYBieB/q09folUST ndfop0gaoAZK
PuW5eJsDlB0ABZASA+X6/UPdQyEXiPwOmvhw/0WBJvFZEu6w6Vjs2mRcEZny GKTsDShqFgPm
UshQJzov3o1g7RafB82enMLEJ17HFaYchgbMNZT5j6d2D0X16QQou/XinQEU bd1EgwiHiwaU
ghsznsvh+B/7W9ojUJYLWJ1F34TPemJvBSiTPAyibIcxlsQRAw2YQJn9oICi JjhaioGy3t2O
YeID3MlfQzHnKWpNJH/Kk53g7GxTHj4t2nu+fzwGn6NboAgRRAPlNGACZfom AkrkjfCUuCeT
3W4N1yFbFaAYi7Lpign/yFymjVmzUIu7R2pRlmZMWIIVLsHjYn8DBCgDXJUY gI9jAcrrhxwo
rGtvdusp0ASvTF9npzz7h4CRw/nT5RoyBHuLAEWA4qMGTKBMXimgZI8N/PZk 9wVosqHrkK3B
YMSnwvSQuEFJh3qrAMXH4TQAF6NhEyxAefNo8ubR9MfHyw/z7e1EceTLfLO+ Xr4fwfWzl2k6
1LHsRbsrA6WD4DpShWig6suBXgwmEQKmnJV+KSsaEw10owEBSjd6dl6LAMW5 SqVABxoQoDhQ
Yh9FCFD60LrUuU8DApR9GvL088pAUfEOJIkG2teApyNGxCrUQGWgiD5FAx1o QDyUDpTcRhUC
lDa0KmU21QAHinjE/muA7C1Aadr15f42NCAeShta7aBMAUoHSpYqKmtAgFJZ ZX7cIEDxww4i
RVYDApRAe4QAJVDDDVxsAUqgBhagBGq4gYstQAnUwAKUQA03cLEFKIEauCZQ lpejvBSoIkRs
rzQgQPHKHOWFqQ8UtXFplIQs5dUtOUtqQIBSUlG+ZasLlF9HENqTgEJwoZOb Xx8DaHxrrchj
14B/0dtrAEU2NvahezcCyuTn5dnbBYCD4EInq6sXuUzBvZTwwJ1Q5GhJA6aq rewoA5RurZYH
FNMdXn1cQJLN0lvqQVWLrQmUxS8j2Fkd0zLyVhAuj1/PHz6bwb/rf41jpvya 8VPUdkoUvxc2
YntabrvZqs2S/LhzlanqkkDJZuveagVAMd3hOpull2Go9KLqGqgNlBeAEoDI +Kfl4hd1npcA
PUwq2IjAFrBT2w5SGXs0SvZ5jHY54DsYQOBPifq519RWVbPdM5+O0h05zdGV uZJjtb0iNMiQ
C5To24sS1BBtln6t0l2UtgWbpUfbj2LTBCgNrFNwa02gXLx/sYF9IaOEQEG4 nJ0vXvy4GL25
ePxq/uj5DK7Dp2n1fHuB9KqxN4rKliBDedrJprM4P4IrMlHa2xvsqqZdNeM9 IuKNNYuBklfU
XhkaZCgLlGghL94jfb1vs3QujwClgXVaAMrPZ4AShAiHC1GGTuDTDFC03djg M3M7SH2Da4RL
vNcs7ISS2V+2Hb0EX2regKHr9g300s3AaZnr5PWZ+krvViN5QDHdYZwB0Wbp uph5rOR6SLY8
T3ZE77apw6qtpocy//lsDduhROmCwUXzUAAr8CnTmG22UhYosOACKGFbWA/L Eq5bkzMx3AOU
RAo7013LmF9eeaCouXY0CZo+++b630sLUNgGxcaUx9wRvbs2DrKmmkCZ/aSA gh7KPDrPS/Ap
V5xtec825aGvRL7rUrTUonZpk6OEBnIXZfkOvljOnjWUnPXdEjLUzpIHlDx3 GJliB4p1i2Ja
SdFwU1tiuTHSQF2gvBuvv+wwcbhoHgpQBj7VVB119OxjY3NRNs3BHwP1sDoY dD+xqFo9WYs2
s4oWZWM27wMKKMFaVHvKyQVK5A7npaw7XMhKWZptx3g1gTJ9N159iTyUd8sZ gwtRJsXNu3Fl
yfPm/7JHZGVVhnpDHlD4XNt0iuFTy5SnwENRC3OyJOeyk9QFyvlktd5i4nDB RzyPXs5XX7ZR
2k3PnQFFlmNdWt7vsvKAgu5wXjLd4dzZnGVRNtkR3W/NeC5dfaBMzyeUCC7m CeTxXAUinoca
yAWKc3fYw8aHLFJNoPAmc7JYz0PWj8jejwbygILucF6CT/sRV2pNNOAAKKJM 0YBzDeQC5Xxc
6A4LUJybolqBApRq+pLc3WggHyjpRFvc4W5sUakWAUoldUnmjjRQI3xBR5JJ NYUaEKBIB/FR
AwIUH61SQiYBSgklSZbONSBA6Vzlbip0AxQoZf15DUn6gRuzHHwp0pEC7QIO gEI0EaYE2gk8
FFuA4qFRyohUHyjojxQkyFBGAsnTvwY21xeX15v+5UglqAEUiSnrgwHrAwUd kzyg2Kc/0HHf
T+dxWpR9a9i/7u6D5UrJcLtItD2df4j0bVVmsYYzn25uLuc37bMnDyjLN8eU uAYkpmyp/tB+
pqZAwWmONVn6BO+a0NdLfisKUGr1g83H+fx9Su3Vh+i8JFDyINKVLaxAuXj6 LdcE/Vsnpiwv
qMTL1rUscIg3OQOK1VXRNZrpjqtl1N2jfo9uS/zVl15RxIGvxNipufgI/5GP 08X3ZMg9wupK
MGV+WMA05+YD6HaxMjGRvQIWUcqH43YRn7SsGhMo4Jjs7hYqfbnYfp5v/piu /zVZXZ5Vjilr
Si5AcWdNl0DR/JRiD0VRQ/NQwGcBt1whI/5eNb5UYwbluu7u9BJ8SUyNmbYQ KSI0L2+jD/cB
BTiCM6bVh+SWlhVkBwoGo9bS102dmLLiobRjQcdAQT+FyKJ3C76GQjTRLwI1 oq9NanB2DKSL
AjxPO9oJuNS8uQlXJjdBfI7Kz6TIJUGUg4NTeuWrme5yPJTl7s6Wvm4opuz2 9jpTszW2jhnQ
C2OmpNeTUAbplSiwcVTaREWoku1f7AZ2DJQ9Tor1mzCZ6WS/JxlWrGOgWX89 gLtBgbZZ4R6g
JIoxLLX6ML+5vb7Ald32DwtQXh/DZCc33a0gpuzubrWEbJr3oQd5zAs5yoIt xRgyIs5GfJEY
6QX2dwwUvpJiedBT6FrHk6DN9RKn6+r7MBoSqfeuKBN76e336dBryF2URc+O 22LvlAfyRw+M
OlO+CZTFq+PdelaU7m7g04UJFGvENrQu7hBihoPMizgrm2/sGxWOgVLZQ4mm 5ehjX0TLhBvl
XbNV2KgBmCe7KDst+5BonwoG/Dlb8E4eG5MyY20juo3foVhmTGwBq32V2YHy eQIIKE6KO5qH
0gQoBfe2r4QQa3AMlD0eSogaEpn70IAJlIuXx7tP471JZSsGCosjqyJvw6Zx 6QQn3l5OXVco
MSLOioeyrzM4Bsr+Bz37BJLPRQOgAQtQnh/vPr7Ymy4g2x6g8MXXaG2VMJFs CJ9uCaAt0wpQ
9vXORkDRHuiYP2/L+73jPqnk80PXgAUoz453f4z2potnfzl03fXa/vpA2fsu D05/em2dVB6q
Bqw9Z/7sL3tTqA0eitz1gTIUDUg7fNSAfBX5aJUSMglQSihJsnSuAQFK5yp3 U6EAxY0epRS3
GhCguNVnZ6UJUDpTtVRUQQMClArK8imrAMUna4gsiQYEKIH2BQFKoIYbuNgC lEAN3Ago6w/L
6799f/PmhdZ4uALX4dNAlSJi964BAUrvJqgnQH2gKJr875P1g+/hL2eKogle /4+TmkyR3yPW
M2aNu3xVNQcKf59Dzv3UAHW9+kBZ/Ty7fnCyffUCEpxcP3morjx5yC/ClUwn 5z9kLngNvKCX
+zoAaozldm8JXNXiobTbPVorvT5QQCTljNz/bvt0BGn994dwDn/xXzg3p0Lp SxNwc0FoCQFK
c3tzHQaoagFK8y7QSwmNgKKY8o/R8q/fbf/xePv3NMEVuG5pj0YK+tcWFysb QQtfA11N7sfR
ck7OVyy+VvySaC8a9LTSwFUtQPG0X+0TqylQoPzlveP1//hu+x+PMME5XLHX q7seGBHLFhcr
fnk8CbTH0ROHqDDu2tfUw/o8cFULUALtri6A8ufj9b3vtv/rISY4X/65ClCy s30VrTMvXhZO
lMzwn8prkRif2R5oBUo4qhagHChQ1JTnv/1l+9dTnuBKhSmPuWJihuQj7Vpc lUA137LY1ilP
OKomoFxcQhw/SQFoADt0Iw9F0eRPMU1Wf/7L8k/fwl8kC5xbmJLp0BQOKy8u lnE9XspFZ8T2
acuDNKTiA1c1B8ricinJcw0A9JsCZfVuvvzm2xgf3yh8wBWFGHYRrmQGYcbl ZiupeXGxtOtR
WQu1icFRdlE22fQgpBHfsqyBq1qA4jlBNPEcAAV+tAbsWP/3Y/jLnRFkyiq6 XvOHbS2PNSne
fw3UAcrbb8MahEOS1gFQoFMiU8ypDTJFaOL/uPVWwspAeQvbHm9gy/QhjdKA 2uIGKN52RxEs
dA2YQDl5Nof0/XP19/TVxeO3y7P314s/NpC0zdIrj8N3o+N7o9nwVmo6bJcA JfQRN3D5TaA8
/nX9+HI9+ud6dLke/76eAUo+bdd3u2iz9BuWruGKxpTZk2PaPvD4yTz+lMZb hwOvMuysmHt9
mu6G+GCsyrQ2obhd8OnRkUUbtcAqQBn4gAy9eSU9FNhkcvkp2Sz9ywx3TbfQ JHVAxjAW41EU
JlAiOJ6Ok2E/fhCdlwQKz6bOT0/vHY/eRQ/RmlFVgBL6iBu4/JY1lPPvb+52 Wlptd5uvu+3X
HW2Wvr4aZYECBEnGDA7CeOTMR/fir/njB6cw5Rk9iP89fZ1kSz5XQy66K8qT DmY37kY1jwDE
zjZH3W5ty+nYZIQOlNEMnJ0CH6e0bAKUgQ/I0JuXBxTAh5aAJlto7dfN7vZs 93W1/j0LFMsX
LyAm+60eOf8xR2CAKXcmyUMA4nlKDzP3xFFi2IjGvS1qSxmgXC7HD6K2i4cS +pgR+Qs0YALl
4q3yUCxA2QFQACkxUK7fP8wM45JAoTkR5o/wwQ7bt30vWMkb9tbpW5pZTfS0 4/hvj+KlaGpy
g5Vp8VBkOHutARMo8x9P84CikIJA2a0X77JAUb6GdcrDvpPNiUDxd3svKIkr NZqTmcdlHY1y
HgrwF9ZlTp80etQlQPF6OIlwJlBmPyigqAmOlpSyACjr3e0YJj7AnQqLstrc J11hUV/p8SRI
G7H0L009+DQkb0rijkG5i7K5bWEvLpjoTDl1FM31ar7lIECRMeu1BkygTN9E QIngwVPinkyA
KXAdspkrF/yxMccELB/AgYuy8VjKLkbE0wScBPHxlgeR9oGCDoX+2DhaCslt C2EiFyjLRbx4
FBZQNtcX76fzDyp2Eh6rD9P55fXG674twvWgAQtQXj/kQGEybXbrqfJQomP6 Wpvy1Bwh7tdT
6375ByFJTx4KAOVysbyc3yBC1L/zCwFKDwPW9ypNoExeKaBkj83uy2z3BWiS fiVBtiBG4MCE
7BEo16uP84uPqgeAe7L8CEyJPBR0XlRaKAdG/RudRH7MMr2IeRIk+T4uRL6a GrAA5c2jyZtH
0x8fLz/Mt7cTxZEv8836evl+BNfPXqZpYGM1iOb0CZQNAkK5J9cb/KuuTJe3 kdfycY5zIoWb
6MrudhFdSbASuzYyUao5VoO4rfLLgYOeUPjPlH6BEi2dIEEyWEnmQeiPxByB zJE/krowzJEJ
YnCIkNU1IEDxHyJcwp6Bks5oCoCy29xcAllWS5oTyWpL9ZEZ6B0SAjK4wJfY 0xqFgKzcWeMJ
Drsvf8qD05/lhwUuuERTnmQSRAXwpZa888pSyg39a0CCVPdvg1oSeAIUY1EW G5NZms3OetKl
3GTtVoBSqwf4eZMAxU+77JWqW6DsFUcyiAYSzxm6pqQQNTD+Yayew3682d6p 1zbN40i+LmSY
96uBydvp6PnoxfMXZ6/Oxm/G0GUleauB6fn04vJi9WklQOl31EjtuRqYnE9f vHxx9vpscj6Z
/TyDL0BJ3moAaLL8sFzfrrdb8VBkUHupgen5DGgyfau++q7/dQ3utCRvNQC+ iaIJzHe+2juT
THm8HGSHJJRa6nsznv00u/739Wa9gc4qyWsNgG+SQxPotgKUQxq7Xra1zLMD LwUXoWRRVvqA
fxoQoPhnk/oSiYdSX3dypxMNCFCcqNGTQgQonhjicMUQoAzJ9gKUIVkzyLYI UII0W47Q7oDy
eXKSxq47mXwekpY8a0tG1aD00QIEZBdPztO4eZ6JbhFHgOK/jcpL6BQo9ydx R1adO+rlcrSh
AVAvqZrKvxqNrvCfxegoJKALUNroI32V2Q5QVJ9OgJJ+c0a9PBoMk6exM4Nj YHVOzg3lGY3u
qzyjq9UkPolUpJXWl9r6rdcKlFQk0JgApV8LHW7t7QDlanQUf4VmyQIXIyLE 36VptsQAcOXp
IqJGNCTgXzpRBRqlHabhrFMeUsUe3HinMvFQvDNJA4GcAoXWUDJzH76r2WjB uzud8xGC0MES
tJPigdRAC4HdWoSMwOY7oHkBSmDdr1Bcp0AhCvD5jjbbN4FC/ggRpAAo5trB kKxRsi25QAmP
JgKUkjYPJVsLQIGmq6kKrqFAF08mOKgSK1ASTKjFlAIPxSwtXlXh6zW281Cs UVJOK1A4l0uW
40c28VD8sIMbKdoBSrzOmqyw8qmQbcqzSNZoT56O1GQnz0OJ8ZEUZ3WIMovB A33SZAMKW9hW
+gnoybEAxc1Q9qMUd0Dxoz0iRXAaEKAEZ7ICgQUoQ7JmkG0RoARpthyhBShD smaQbRGgBGk2
AcqQzDaktghQhmRN8VCGZM0g2yJACdJs4qEMyWxDaosAZUjWFA9lSNYMsi0C lCDNJh7KkMw2
pLYIUIZkTfFQhmTNINviAChHEG09SaSD6W73PztUCAjw2VYdiAEflTywEEjl bylZclfZ7ED5
7m+gBjlEA11owA1QcDD/Fg1FPO8SKE4QgIXAX2xFmEeuh/LdX4UpYZo0NKld AgXa/p8RSgQo
PXWDoilPNT8ljS3g9A2a0KJ79GTHgKttChT6YkcdwDTHBAqfj8A5uAB4oC/A r+RdxJmLNq+B
uvAiUCzPp4Ab4VM8sCK6xTQaeSg0Wcu7RZOHauHaILZ22Dv2rKFU81PaGPxt lNmhfqWqvRpw
AxSshi9Y0JRHIw7hA8YbDXUae3svwlCHAjm58DwPKLxAzIa8y1tz0fRlvUUr E+ShxqIGAFso
FZ50eOxflP2vyXrKybPZHsEybwnbYjiqDPH1KLxjVJ7m2qQxIsHTieM/hvX6 bIfmG0JVTYEC
Y4ZWZPkqLI0xzEAHjjdIPDP6NdaLMFxp8GNFcGhlajdys/DBj74MHppblGdJ 85ZiedBXgrbw
bB12Ex0oj17NKZEYwBSgyfHTGCjWPDEa0pACthiOPGZHHDMlDZiiXsCP4z+y ECrioXTYG3qp
yg1QTNE1D0UDCp+J0PDOuwi4wYFKONBWfAkoCBpMCCw+78ibeRXo3bwFq9bk IXwgp+DTAsa1
aWYLUOa/ryABNahepAm5KvCRmUcHSl4MxzTkWhRe7IoFcFe4ycaIhEIFKG2a 34ey+wEKdxxo
NFov4iRCewKtDVfkiPUgoGAtGteKDWC9xSoPMhFBA3fhSR+PVexAUT7Iyxgo RJMUKC/Vpwo6
SZ5YLcWBkXjkJHWDAMWH4dy/DK0DBQcbDDM8aMpDwxvXKSAD5wJdxFENH+EB JwgXfrFgUTYP
KLR4XGABDSh4S548KAPKiS4SNblDI+tAefhyPvunQQpDIJXtagV/M59UAkoc 8t425eGBY9Ft
wWrKnHeoO6nKiQYcAMX6AzY+K6FnIjjScNTRRfiX4GK9iGOYT2Sw5fxi3gDW gEKDvIwHgfWa
t1jlgVaQHqDwLn/Ux/qBAZTns+mvNw+f71l/hQx6Nr62WipsvblxT7IDXjYS NQaIVDENBShO
RrBnhTQFSvPm4PjUDuvF5nUNvQQDKM9mk/c3D5/N9ibMVk0/siBSTV8Hkbt/ oFh/U9vlD20H
ZGcdKKdPZ2c/XZdMp08EKAPqCz01pX+gWJ/gWi/2pKKAqjWA8mR6WiUF1FQR 1U8N9AMUvqpC
ixTWi35qzVep9v+wzVfJRa6BaKAfoAxEed41Q4DinUkOTSABypAsLkAZkjWD bIsAJUiz5Qgt
QBmSNYNsiwAlSLMJUIZktiG1pXWg8FeQHSqOfnKGJ5Dyfn3PK+3pB6wO211c lHgonalaKrJr
oHWgtKF4wgeewN/fSgClJHTaEBjKLCNh46oFKI1VKAU004AApZn+St+NQAGo tXlUA4r5omCb
sknZB6GBpkDZG6xMi5lGL+DACYUjoNhr+AoM+R2YmV7btYZoIw8l7/UZ6104 vLXyoWotFBt1
ATMnfoQ/wMNPqTla4dgcnlrDSjWggPxaKIOD6PLSyDY14AAoOJLzgpXxoATU EP7LenzZn3OE
RiBcpNv5+8EFIdo0XeXdRb/ExbrwMEOxITIwg7Uh1pBu1sKxotZQgi2oDBQt 2FKqvfTlQPUu
H7zNN3Eiurz+0+Zg9qHspkD5jY039Ca0kWOOQ8wAN8LBl2xpbPMS8LVgqgVV Bv+WeZ037y7t
OgrDKyWIaDlNg3HHBMuxFg43amppx/bVgFIUDrKlkd9Sse1oU0qtoYGmQKFx gsPJDFZmBgog
lwTENYMq0djjjckL0Vbc4Ly7tOsouTUUG5TPZ0xWoIAG8ODlUE7NW6HMNUxV 4pYKQNkTsNoy
8lWsExV2QFkIwppgfDaJKVvCLIeUpSlQcCAVBCvTgIIuCY2rkkCBAc9dEviX 5ikFxsq7S7uO
8uSFYsPyIQOhgWrEixo7rIVTCR0D5eFzS0xZEIZvqWGPKatNedLgshhrOpoB SUzZQyJFybY6
AEpxsDIOFAQBj43I0YDn8FcbqNgSPp4LQrRpzc67i6BG3oqGDI0LKICGA01O Wq8xC+8LKNZ4
sZpvYo8pmzM3UaGnuZ8iMWVLjrODyeYAKHzsmcHKtJhp/GEHkgXpgIsR+EjI ChQc0pgoQGQZ
M1nvwiqwKDroIl0n2UyamIwwW2oWXkbgBnn2x5Q1t/uCULKWmLJ5ix0quj2b +AhQGlhrkLc6
AMog9RJmo9zFlLUDBZZRYMoTxaMG+vI8ElM2zB7jXGoBinOV9lhgGzFl6bFx GoB6h7vwZNZZ
JKZsj3b3qGoBikfGaCyKPaYsBG2TmLKNdSsFlNKAAKWUmgLJJDFlAzHUcMUU oAzJtjpQvv/H
RGLKDsnA/rdFgOK/jcpLWOGHbeULlZyigfIaEKCU15X/OQUo/tto4BIKUIZk YAHKkKwZZFuG
A5TaoeHgFxXW360FaE8BSoBGG5bIwwFKJbv8ZnsNp1IJXmYWoHhplkMS6qCB Ar4JHuaLf2H2
AQFKmHYbkNRugGINuUYvwuA7Oziz0C6iJq1x0kqGcSNbaKHh0AfBGvmBYvCE V+Avf8uxQDCP
rZ8BCphWkmigGw2kw/DdbPzDeP5+fvPxZnu3rTNY8kKu8ThsHCh0jpVZ46SV DOPGxdXKodea
y7zXh28DAoMQQwWC1VFQd/eIh9KdrqUmqwaaeih7Q65BrThWyRFAOcyL6DXA sbdMM2iTBibu
mFinM5owRB+8TsiDf+EgwbzvQwIU7000dAGbAqUgQhKOxmKgWOOklYy6pJmG U4Z7JSWBAsgj
jiDU0EsyJ00edwkBisfGOQzRWgEKfqvjECWgWC9a46Q1BAqAjKYtWqVkU8xD yCNp6XpxADdf
+4YAxVfLHIxcTYEC1KDRi+fIEW2Ioj7NiziACT1wglMhs0wNE6aBtPhGlIEH vrcCxQoXq2De
9woBivcmGrqATYEC+jFDriE7KHFHwLyIQxcThTgrH8aNDKQBhSq1LrhwPGmo QqLBYRXM7/4g
QPHbPgcgnQOgWLVkXbmwXjwAJXfWRAFKZ6qWiuwaEKAMqWcIUIZkzSDbIkAJ 0mw5QhcBZXk5
sqYhtV/a0rsGWgQKrWJQI62/MetdBQMSoAgo69tr1dKvmXTz62OgzIA0IE3p WQNtAaXnZh1o
9UVAWbz+BhIqZvs1TqurFw6YEu2tAcfoqrTeZU/S0qoKK6MAJSx7FUubC5QI JRtkyvXlC2LK
+l/jmCm/Zv2UTET74p3Sk101KilSgELq0velx/0D1B4DyeFop/pKBqqbWYBS V3M+3mcHysXL
b3b/fri7u8AE/yqmgJOyTdPiF0WZ9OADXvX4ZJcMs9XFn+ZpSYDCgZLul0ZX cQuk8A4BSng2
y5c410OZP1VMgb/q5POZ+lseKOrb0tx2B782+Rfp0dH9yeSpmvqokZB+8cZf sLiNqTpg/ERA
iTJXnCsNyVzYlqI91cJrrQAlPJvVAArcMvs/30ACjsBf9FA2d2m6eJ/vocS7 AiI+GFloB/V0
K3VaRjFyMkdm8TTeJCxec0nLH5ItSrdl35Tn5HxVuqz+M/YPlN+yr95UUkmT eytVFEhmu4eC
iyarTze4Fgv/wl9OEzif/3yWaSPv5eSQW7s+fcHqs6R0DSDyWdCXMXiU+xUd iMqbi7ln9ldr
iaq5VHVL8AUoyn2ufiBQ6t1bvTb/77AABfCBD3dwRRaZst7oyQKU1O+wUYCU kQcUy7oA+jgR
VjT62DP7r3AXEu4Bympy//AWZSnkGoVHw6GOCSO2wYE/vceLkBNAwF/5ITSY Ady03+xjmdZ7
sSIsGf9CRVgpiQEZ8qog2UhgolUI7w1YgMKf7+CDHliLNYEy+8nwUGiQ407G SiNse+NioJg5
P09GsesejZArtYYSu/IHvkBrbf7VKJ4P1lvzdgG6emU48FB4PCR6s858sRjk w6iOOLAJHzT4
sQHWAG5IBBzb/B1C7V5SAeYnZtFJQRWmbFrhgQIFPBT1lCd5xANLs/CvYsqX TJq9G2c6ULaX
R+up0fekORWyeihQlp4zXb5ViwLioZhE5gZg2qvw6556DHB6lwOgaF/+IB6O ZzpoKOIgx0Mj
DsKCj2F0FuiAG3HM8xixxUBR/Z8VgkjKq8KULa8VTvXvtrDcNZT4+U70oAdo svqip6kGFLdy
SWkHo4GmQNFGHeoNw53RwYGC4IDDCpTiOGkaTTQAcZMRRzR8gLR5VZAHRLJx GHGBPe4bRb+U
xac8iibrrZmm51kPxeNGimg+a6AVoMC41YACgzNvfPIxXxAnDWc6mjfE7+Va 5gIQKXA6Zq3C
KtvAgHL9xxrS9HySl3zupiJbKBpoChTtq5vCo9EwJm9FG5+Uk0MBz2HY40Fc IN8ErvAMJYGC
BWKN1iryZDPdFr/tKuEL/LbPAUjnACjIFO35CA7RggXUvIiNdCPdy5dpkTK0 tqKBgOzFrxOA
qByzCg1MJJv2LIlI52vHEKD4apmDkcsNUA5GXZ43VIDiuYGGL54AZUg2FqAM yZpBtkWAEqTZ
coQWoAzJmkG2RYASpNkEKEMy25DaIkAZkjXFQxmSNYNsiwAlSLP146Ec+Es3 Q+oprbVFgNKa
anso2LWHkgSLVW8IP13khAKq0s5MAIRyEcnKU6x8zioiS95KGhCgVFKX55ld AiV6ITAd83FU
pIZxBviYdx5XSYDiQfd0BhTrjp/QQP5jUw/a60wE/o61s0KbFuQQKLYwHPzF 4iR4I8Y9zYR3
hP+N+I9xyzJjPorqlsaC1AJHRv+ii8QiwkXVUnyQ9A3m0RUIHMsUVoizpjb3 7H43QMGtiM3j
c851z5QwGHHcAcUahiPGQRoVRXEEp0KJL6McGWukSNQxA4q6F4PLpvtvGCWn t5jRJxVBMq/2
i4fiQUd2AJTf8qkhQOnWxE6BYs5ucMTqoR5t4R15+Ecevb0gnEoWNymkqFKt TBMfApRue5u1
NgdA0d61gWrwtWB8o488F+QOpuLgaSiomZMaQOXjO82ILayLCrdexBLMcG1c Zl4mFqIJTIVo
sV20t5n6MK47oCgvw4g8mAsUbKstvKOmhWIKWFCVODVl8CFA6aPPaXU6AAp/ /RdHJvECRz4B
AphC4x8vWuOz4cjUPiW5oUwcyTja4S+e8Iv0qXYxr8a8MgvE0CQn6PS6ZuQQ KLgsYl2UtUx5
MuEdP9siRaL99nCheMqj7Uxom/KEuZeNBxxwJkJToNCoRokAGXwxBf7FL3zt OjKI30sQ0XJq
DeVLoXg7JwtmxrgnmmDmRapxb5nW9WYOFMIZ1K7h1ZmhShXkEihQYbrUqj02 Tmcu+jZ38YKo
ObVB+fc6GnrJ7BbrdCmZB+FiyiLa6EcWZUt1lnYyuQEKyabFaiOgWGO45QVP 4zMmrdV8GNcA
irXGgjILdM4pw72SIQGlnS5XsVTnT5cr1i/ZK2nADVBgbONBBKF/0YnQruMI LIjPpr7MbN/2
1sEPmfkwNgNlQ4aCcG0NgUJcwyYLUCr1v8LMuCgT0iYS7toeaklNgYJDiICi jSi+KEvZtBhu
wBorjMySEUw0pcJzvJ1O+PA2L2qQQsxZy9QwYZo3L0AUX0LqvFM4nvJ0Lr9U GLwGHADFHEK4
PAEJJy+IGxyieJEOukjX6WFN3uomZcAhjcuuVKM2+6DrKAMXg0tillkVKFR+ 3g/8OukpApRO
1CyV5GvAAVD4N3xfqrZONHqdffSiCQFKL2qXSlMNOAAKFJb3S9nONC1AQUcN zNmZzqUi0YCp
ATdAgXJh9gGuSl+HAEWA0lffk3q5BpwBpV+1Whdc8lZh+hW1zdrFQ2lTu1J2 CQ0MBCglWnoI
WQQoh2Blr9soQPHaPBWFaxkonrws01yM5iVUNMzhZBegDMnWroHSRsQ2/hJz vYFdcFfJArVs
/Ef9Jd8GKlkRdK7yOQfREwUogzBj3AiXQGk9YlvtwdYGUAhzzn/pL0BpMsI+ Gz+crVca/1kt
/TTWWpT2llCZ6n5zJGSZurrN4xAoHURsy4QmmETv9cGhXvOLBmF0RQvjFv0M Pxmi7N1F/Hl+
Nmhb6nckP94v9cpii3Hk9Lh23XaObmpz4KHg+KSj+c/JkEoljxpAgZJ7/+FM ydZVzOYOKGrs
GUGk45HsJmKbahoLnhTHXkMHIRr5STQ2I1ab+Z0Pd0HguIzLY0Z4Y0EVzClP 4qG0GEeOqTSK
azfMwxlQ1DdEdAQBFJCz15duWupMToHSUsQ2cw1Fi6tkCQrHg7XFYWhXiA/6 hOLO6gFoY78H
g9equzLcSf7NK0fLTFBgKGTCMdnIwmm9SQCqlozvR7FNgcJfosF5Cv5FF+A3 1khrnDSuBGuc
N3pbB3NqsdrgCvdQoDqShweFo+tcHjjnbxX5YY6GUrgDSjcR22hYakO9YPDT CFdjm81lTKBo
QCwGSsnMJlAKbrTCi+LaNTS1r7c3BYqyb3ZJAl+6g+GKwxgPa2Q2jSbWOG/a jVqsNg0o5uvF
WtXam3uD++WbQ6C0E7Ety6k0xnUBUKIRaAlGzQARz1OQNfFMzYwalwa1TPPb x7z2aMZRHLnP
k2xcO1+R0EyuVoCCaEDQaMRBD0I7OHrgI/iXfAcCijWuGgeKVgjChRcFmbVp DkVOaaZDf+52
CRRolfuIbfGYT2YJmluBn2pTHvOWBCUYn01FTHk6oulMGrTNnBAlT8F5/qiD stmQFTFpUcna
B91inXbZ48hNovAuA48p1wpQYBhzoORFZqOBmBfnDTKQT5EXWonuzQsKR6Gk oTRtFja4ZRTH
QPGHlN5J4vzpsnctrClQ60D5vC8ym+aS4L98roT+zl6gaM4ILeUQUEASbY4j HkrNXnPQt0kc
uSLzOwaKNmjRI8CL6LaY+MCLPAN/pkseCqcMnmOB3DHhv14xg2PzaE9apc2f TPkxxMRD8cMO
ByyFM6CgDpEddJALgNcx5T1b4RkIDXwZ1RqrjQOFauFV0NMljiQSFW7RcBZy ZxCghGy9Qcju
ACih6EGDHeBJHhuHYjuRMxQNHBBQzF+soHsyoEM8lAEZM8ymHBBQaKEE5z7w d3CHAGVwJg2t
QQMHCi2gDO43bNaOJkAJbfwNTt6BA2Vw9ipuUAYoYFpJooFuNED9UoAyJOaI hzIkawbZFgFK
kGbLEVqAMiRrBtkWAUqQZhOgDMlsQ2qLAGVI1hQPZUjWDLItApQgzSYeypDM NqS2CFCGZE3x
UIZkzSDbIkAJ0mzioQzJbENqiwBlSNYUD2VI1gyyLQKUIM0mHsqQzDaktghQ hmRN8VCGYs1g
twcToAylC6p2uAMKD5VacnfOqorkYVnNLTuqlhZ8/miXMnOjj71kyVhKBdiN 9jwzjr3lOFKg
AMWRIr0oxilQ2tudE3XVVRf3wjJ7hVDaGI3u528Mwkso3mbEWldX2hag7DV1 QBnaAYrayCLe
wsq2PWiyW6gaD2w7UURGEuadthBNSmDbhlLMei0/D7s/dBcGNhg4OV9ByH74 y2ib3VyVemKJ
fYsyW7sWb9IalZZatll/F6A0059fd7cClFK7c/Jtt9RuFUAZ2xaifIcdfcpj zR9vWzHgvTuj
HpTsJE3B9IvngxpQ+MaK2kauZoF77dKsSwtQmunPr7udAqXS7pwZjzraUuuK 7RMabYKe2QyU
T3loLx4+MGIkJful+6Vn19Kk2kt2I7MDBQPuZ46T12fpFqvmXNIsR19zsW2f 2qB9ApQGyvPu
VqdAqbQ7pxUoxdt0an09d5I//C2BMxuqwbIqzHoqeShlLFVQoNPlFQGKd1Ro IFBXQGHbg1q2
E43d7JwtRPlCAD4/iju0Jf8h7N0ZzXfYXquoPT7+zadsJdZQ9G3hlWOC88d9 dmnQ/+BWAUoz
/fl1d2dA4QuuCRRST5zt18nnTcY3YbxtqGVRFh+gph5+vFTpl7YdSaOrJZkw Jn5Hurlq3qJs
dg6kJpvm42cASbRza+z+FNqlScMEKE2059u97oBStWVO3eaqlUt+fzQgQPHH Fs0lEaA016GU
0EgDApRG6vPs5v6A4pkiRJy+NCBA6UvzbdQrQGlDq1JmBQ0IUCooy/usAhTv TTR0AQUoQ7Kw
AGVI1gyyLQKUIM2WI7QAZUjWDLItApQgzVYAlG52ipNaRAN5Ghj/MJ6/n998 vNnebYc0ug6w
LbCDc+YAi64+rS4uL6bn08mPE7C0JNFA2xqAzgZdDjqeACV0BhlA2W7Xt+vl hyUYeP7LHL43
JIkG2tYAdDboctDxtlvxUMJGig6U3dcdfEuAaeHrAlxQSaKBDjQAnU3RBOY7 X8MeTiK9ARRQ
CTAFjjtJooEONQC+idAkfCDZgBJ+q6QFogHRQC8aEKD0onapVDQwTA0IUIZp V2mVaKAXDQhQ
elG7VCoaGKYG/j+EvSYG+1xj4AAAAABJRU5ErkJggg==
name="NewWizard-AddedToMenu.PNG"
filename="NewWizard-AddedToMenu.PNG"
iVBORw0KGgoAAAANSUhEUgAAApoAAAFrCAIAAAD+SL6JAAAABGdBTUEAALGP C/xhBQAAdKpJ
REFUeF7tvT+I3Mj69+ub3dChw9fZb+EGx3CDu3CSd8DwvoZfsAO/4DewwWE4 wWHYYOjXgRmc
mGYCM2xgmgmGxoGhHRjagaEdLPRssNAOFvoEC+PA0BNM0IGDDhx04ED3KT1S 6VFVSS2ppW79
+YpiRi2Vqp76llqfekrVVf/X8PXoHjYoAAWgABRomgLH/zhqmsmwt0oFCOce NigABeqhAL6P
9aiHBlhBt8p6tbRDA0yHidUocA+Pj2qERapQoIgC+D4WUa2T1+BW6WS1pxU6 wvnk4xQBCkCB
/SqAZzSe0RkVwK2SUajuRIvhfPpxhgAFoMAeFcAzujsP3y1LiltlSwHbdzlw jhYMFKiRAnhG
t+8hW1GJ1Lvzb2vavO8V5YBkG6YAcF6jR/kenUJkXRMFNuJ8drf64R+Dk1dT /aSZXj5s2FMH
5pahAN0qiy+L5d2SoA6il6Fo49MAzoFzKLAfBegHK3YbIi/OfZavQPTGP4nz F4BulcnHyezT
TBGdfHRsnVegPJy/7j26d+/RL+PgCUUf/9Yb4WU8FIACCQrw708NoufC+eTV QwqE83Cn88+z
LglAt8rwakhEJx9dOejYOq9AqTj/2+Hh3x71Xvu+DnAOjEGBVAX0dBKS6Ck4 v/lwtv664M72
xd1q/PKBt56r8M0P67k6EtsWg8d+Jo8Hiy2fdLeDg2j2i17U0Z+SLF2SMd/s MbcsRbsup1tl
8Gowfj+++XwDnLerbguWplyc90bnh/d+uojh3Pfa/c0nvca8On54oZ53497f eAcBCnRIATk7
lL75k3B+8/6Mv+Ly3fnoxQMK3nIU7DgfAqXAUiZy3SuhfSBNLcXCgg/ABl9G t8rFrxfjd8B5
gyuxXNPLxvnH2cVP9w7PNbYvDgNmm0dGvzw6/OlQxfx4cYhueTRluqdAFu98 eDnkQB3qKnxf
aZzTG1MKw2f3vds+/aV996MhhOXiSjvYB4Nbz1MOt/azpz1/34yjU4wR14/s HxmcUiH8RCL3
3f9IyNe9AtEpP1+1UQrB1rsOuxDu3Tu42rYTodyHY81TA85rXkG7N698nAf+ N3vhkWvO317l
hV/8pNz0i58OL+gsufL8t3tPcxS54wpkeXc+eDUavJ556xvv+5pAfvJmRiEY 2U4H/TB8en+5
XFPMdJxHZ4m1p4q509N7vWv/cHjEjhMcEThXyKdedB/SweU+nnlfnfUTV4BX ne1BQ0EcUfwO
L/STh3de6MEPnBeSrc0XVYDzjzPlef8S4tzyvNXZc/bI/W72c/bREaBAtxTI OLK9/3LkfZux
X/7j6Shg+feVOhgGFSdp07CU77/5rXbE9dBvtuNwsvZxyWBjX/vrIfXFa4XA rY+54cB5IcQA
54Vka/NFleBc9Z/TN1gBW+2YtH7doxFzPAZ+9MshdbkHo+dAdCjQeQXsd+dn L8b0SzTCeSzQ
ERFUnHScKx4LZgeD1MhRpr7xaY8/uuMkONDZcW4MiLPhDZwXQgxwXki2Nl9U Ec5nUxoTx365
7G8PPHVifDgAXkfr/HMc/RNQgBSwcd57PvaWEwrE7I3B8azikWt2b7kflfrG e6e94KV1Qhx3
f7j5Nj2lsz3ete65Otujt/htftqWWzbgvFw9W5BaeTgHj6EAFNhaARvnJ8+I 5UR0FQjts69e
UlDgjzY93CxwyulNOW8HxG/tMccGxKm36Y44ztfbhkttDIWTlzg76qOhcMpi zhdD4XIRBTjP
JVcXIgPn3XpfCw+45grYOD9+OvHuhhSI69M7Lyko6tdqK/33bLUqXQ2MAc5r UAn1MgE4B86h
QI0UcOP8dkhQn3xeJwWF/Bpt3DGgf5ZWI8vaZIrC+Xl/9GY4/zRb3S3WqyWH NpURZcmlAHBe
o0d5zR1HmLcDBWycH51Oj36ZjP9cJwWKkOs7j8jtUADeeTvqscRSxHA++ThF gAJQYI8KOGeF
O/qFiJ4YSnwcIKkGKQCcN6iydmNqhPPd5IdcoAAUSFFg4xIsUA8KsALAOe4E QwHgHLcEFKiR
AsB5jSqj3qYA5/Wunz1YB5zvQXRkCQWSFADOcW9kVAA4zyhUd6IB592pa5S0 AQoA5w2opHqY
CJzXox5qZAVwXqPKgClQADjHPZBRAeA8o1DdiVYyzsUCi5vmeLKnkTJUx0zO 3bkNUdJQgQI4
n14+hH4dVAA472Clpxe5TJwHKycGGS4Gp/66DilbOrCBc9yt3VMgL859lq9A 9O7dKRjZ3sE6
31DkEnFOU0G55oFK8cLl0o2PB4Nwvmh/LWS1TkMwffTVQqzPSAtAYYMCrVXA xvnB0zGFJ8/U
38MXk5PLWf/dfPrXisLk1UMKhPNwp7WyoGC2AvDOcVcYCpSHc7czraZ79PGs 1m66Z0xfFV+J
maOpNZj1co3BQhGpiaBKoUCLFHAswfJhefJx2ftt2fu4vPhjOSKQf1kvv3nj lw+89Y0Ic3VE
b3Lhk4zrlWXvD8ses0VVU7eiAOd1q5G921MFzkPHOr4so+9hx33ruHce9Mzb B42VlTM+m/Yu
LQyAAvkVyOidzz6vZl9WoxcPKHhfR8GOzE5+a0pfDQU4z1+zpV8BnJcuadMT LA/nXryznb/w
6SQGzpt++8D+shWwcT69enLzzTPCYu2tvnvr797w2X3vtk9/l9e9mC3meuS9 qX/Ef6Xlt6qN
t2CEfNp0x1j4pmtwy6nq5Vapsy3+IqxsBZBeRgWA84xCdSdaiTj3u9PlOspq P3Nnu3khP27Y
m0dne3duyK6XNAnnBG8jEMvXpNb3lXfX974vln8k4jz4Yvr8Dl5pOb9TQQuA vm5hL1pwRPE7
vNCvIHjnNbhPgfMaVEK9TCgT51Qyxw/VkobCyeOGEx+ifeoPjjvAULh63TOw pkIFbJxPLpV3
7sC5RzgnoAc4n787Mr3zwMMWPrfdaA7c9NBf5x41faHaCdz62K9UgPMKb4Gs SQPnWZXqTLyS
cd4Z3VBQKFCJAjbOx68Ok3CugM4495bT1xbONbzZ0oRGc9QNZr8gsy9MOlKJ GEg0TQHgHPeH
oQBwjlsCCtRIARvno18VzlXXuhGU1YTzpXd3QV3uRH3TO0/B+YbO9njXuv+r UbOzXXbIb9yv
kcDtMUXh/Lw/ejOcf5qt7hbr1ZJDe0qIkuRUADjPKRiiQ4EqFbBxPnzp49xH twyhaz4gotNx
ipYH59ZQOOm+y/52c3BcwPX4izDxrt2J9ioV62za8M47W/VJBQfOcUtAgRop 4MD5+ZHEubB1
5S2Hyjv3t+F5vLO9QJlK/z1bARtwSWYFgPPMUnUlInDelZpGORuhgI3zwQuF 8/i2ot+ae1+J
5St9nKJtUUD+HZprVsctEsWllSoAnFcqbxMTB86bWGuwubUKOHD+8njw8nj4 6mT2aby+GyiK
fx2vlvPZux4d7z+PQmtFQcFcCgDnuC8MBYBz3BJQoEYK5F2CpUamw5TdKgCc 71bvBuQGnDeg
kmBidxQAzrtT11uWFDjfUsD2XR7DOd0fCFAACuxXgfY9ZVCiKhQAzqtQtdFp wjtvdPXB+LYp
AO+8bTVaWXmA88qkbWrCwHlTaw52t1IB4LyV1VpFoYDzKlRtdJrAeaOrD8a3 TQHgvG01Wll5
gPPKpG1qwsB5U2sOdrdSAYnz/b7CR+71VEDf9sB5K58A2xQKON9GPVwLBUpW AN55yYK2Nzng
vL11W7BkwHlB4XAZFKhCAeC8ClVbmSZw3spq3aZQwPk26uFaKFCyAsB5yYK2 NzngvL11W7Bk
wHlB4XAZFKhCAeC8ClVbmSZw3spq3aZQwPk26uFaKFCyAsB5yYK2NzngvL11 W7BkwHlB4RyX
0SrRvDg0NihQVAHgvKhynbtO4fy8P3oznH+are4W69WSQ+eEQIFDBUrG+eLq QC206G8HV2Wg
bSMjKYLMa2P8pLqXF6o09WKRtHZkb5ol2SxxcOdBgVQFgHPcIBkVgHeeUaju RCsT54rlkXuq
VlAuh+jptaEg2us9DulbnKk+tv28qCAHjw961/6H7Almj9md+wslzakAcJ5T sO5GB867W/cJ
JS8R54RD7dEKEAa4DVz2iJGhDz+4DZA5OI3HYYuZkf7ftAjXvXunPos1U32v nbsJdBaqu0Ad
Z2wvBo8DfnNW09PA/ulpb3rdC9oivJNiRpTRvaA1Ex3x04+Z5M4a9yUUYAUK 4Hx6+RDqdVAB
4LyDlZ5e5PJw7vBNw25qjXmCrkJp5AdHmKQT7A1THPkGWnM0PYKCsZ9CYIaV RZgped69056f
17QXf9WtnHL1gmAxOKVX4MHZWLI+p+N2qk6IuB8fHVHdFaqRERiTkjXuSyiQ HedH/98PWi6f
5SsQvYP3D3DewUqvAc5jPfAHg2vtN7P3HH8zbTQLhFscvIp3Roj78cqb1+/w OYvQ+VaeN50l
yvJfucWOs+8eevBJZhhv3MOOhMjUjFnjxoQCyd759LI3e3msQ/+/Dm4+DJb/ nk5ePaRAOA93
thMRb4u202/HVwPnOxa8/tmV550rHzSps12P9/bjEM6NEeA2FLVy2XHuv/Pu XUWd88ZIPHX2
mn1uH9LX7KPLzXejw+OLq97gNvTgt8N5hqzrf6vAwl0o4Oxsn50fLa6Hyz9H FObvLia/nq2X
N+OXD7z1XIVvfljP1RH5xYlatLGXSonFAM53UcOl5QGclyZlWxIqEeeKpo6h cPIZEXSkiw5q
1rEknPvd2vwC28rCz4VGzPEbcUI1dbmrd+oGz0/VILjgOL01D+PLd+fxToKo ERMW3+5sz5R1
W+4olGMrBZw4n744IpB736arv0Y3vw2Gp0erzxPv+3L04gEFbzkKdmTOju/d JsOA800K1eo8
cF6r6qiDMWXi3Mdk1MltjXoLOr0DfmvXwe6gdr471weTOttZTv3q3R6hJvsP jDf0YVXEWiTy
TXlKJ4EaEOCPuDsl/Pv9EMZQOJW46LpIyLoOdwNs2LsCbpw/Vzgnlvs4HxLO 6eP6y9RbLYbP
7nu3ffXX2GJfk2j0hv4ZadiW9VvA/NKLe7b4S+T3tImvs/jliPzmxu72eOfc 3qVsuwHAedtr
OHf5Ssa5I380+XNXCi7orgJOnE+eHlIfO/nlxPLZm/7Zfx7wx8Wn8erLfPjU YjlTNmwBx7vN
wlavGjhCb53CgZz6EtUYtTrng1+OOAd+hpHxTd/tbQuc71bvBuQGnDegkmBi dxSwcU7j2Gns
G3nkHIjlHPjj7O1g/mE0eHri8M4NNzrmSfvvpOyOrnDcaJCa0cXlHPhpjTnt TmXtt6TA+X71
r2Hu1eO8hoWGSVCgrgo4vfPRv57IoXDEcvlxdtXP1Cum2Byfbcn13moa/LqS 3xnF48v3RPbr
p7pK2la7gPO21mzhcgHnhaXDhVCgfAXcOP/nE2MonPw4+ueTrDg3u99dne3+ FA7R1El+0mKY
pzH9omvMafmqIEWHAsA5bgtDAeActwQUqJECTpwPf1Y4N4bCRR9/zoZzn9PJ wzbFUDj/hyFE
dEf8cOCnSscc+BkeqZGcbTYFOG9z7RYqG3BeSDZcBAWqUSAB58HYNx4KR6/M 5ci44c8H1diS
mqqeVnkPeSNLpQBwjvsA3jnuAShQXwXc08hc9gY/H+hAI+Pkx9llb2fl0f46 z7SIbY8KAOd7
FL+eWcM7r2e9wKqOKpBlCRY5Z3tHZUKx4Z3jHrAUAM5xU0CBGimQBec1Mhem 7E8B5Z2f90dv
hvNPs9XdYr1actifRch5zwoA59VUAKbUqEbX1qcKnLe+issq4ObO9lvPu5cQ hv5xilBg42tl
+N1P5f8kpJliBl+Ya0syu0Bx2LBiIuSyeVeRS8a5nOQ1WC98q5KoH9IY27bJ OueILZ2+pSe4
lYxlXCxnFDEmG+Eh08ayOmXk2cE0gPMOVnqxIm/GuUz3f3mewU4iWQGayjSN FDgL+puSsm1G
rsIzgO0t6bgdkyyUKWwvQi77K45cJs7dS7CUUoAS6Zg+5Xsp1lIiJRpclklb ppNcIvUzZT1f
/Za5dP5y4Lzzt0BWAWqKczafsE3Our3VBOeEf96A84TbLWWB1F4vdLKtdVn8 WSl8VAzCH8Va
65YadJRzX+gVVzdloY1O984jH9QwTI3jNVekiMzmUb7mahbxEllm61sq6/d3 r/EScE6aGFOO
7NXKxmcOnDe+CndVgNw4p05yuXE/M/eQ/y5O6L70jQ8op3euUyJyGzky5u2D 0ip27inQjkyK
D7K1G48zpynIvKg4xjsCPpJLBCPZ7Frt5K4ozzt3PO79dZzkVJFqDgoiX7C+ kyqgniqSTvDq
484Fx4zE9W9eeSdLFlpNs9NYTl6dapisjyhfvYKFNcGWXSLD7J1UcGmZuDrb A5breiwts+4m
BJx3t+5zljwfzgmENs7ZV6agGUnRtFdNZ9OJbrx4NjxvhqWx2WbICNqn16Cl s7IFwLDnLek4
E5c2WZbo+R9/X87thiwi2Mnm0ipn5RaLvhOcR29VQ2faWLbBXtrBKI3ZVgi4 S928qhEQO5uQ
RVSd0UpT6picetomlu3K51rXlTONEombXazG9nWVo7lmjWzA6/Ota6cAzqeX D7fOFgk0T4ES
cM6AZ3bqHfpIm6ZXijDpOOdEiJRyS8E5e7rBMzPcp8tlm4A+stee8bhtPBeW y8gWZhHByK6A
VikylneqPJzLJb2DKvHB6WSt8dzPjXM19qp3HTrTWbLQkqV0ttvEMgxLWcEi 5ZW8OBUzu7xa
3EVK6aMB2jdWYBeaOvJIwfn8r9nR696TV8c/nh8+eXVE+4vbhc/yFYi+p+ra Z7Yl4JwopclE
OwQ29o+5Wzt9Yy7KLctouxScS2dXJ84m6Y0M5o9Jx+mU7q53FoFTpr+86QaH kaMtgpFsLq02
aVnW+RJxrtdpYNuCaZ9jrnPQkW4t25Af534Hu79QBG3y8qQstGBp786zGhYM +osl5V7NwjRP
ml1WHe4mHeB8Jzon4bz/YUAUP3l70nt/RmH4aTj5azJ59ZAC4Tzc2WQiWl2b FGrQ+Xw4J/wY
eDNIRjxj/1ji05BD01Q9da2YBs4pst3Zbpuhs3DiXOZIMXWaScej53zCMDfG Nv3lLa8IfDnl
vlGrfdxJZeKc7Jc/VLNGvVE/dTgxpOzWNjx45xPH3dMrFneKeu8TssiEc14U MtysBaHNFSmS
u+J7V6JL36R+aPY+6rt4nsB5ce1yXOnEObH80YuD/oezyV/j2e10djtbrpbj lw+89VyFb35Y
z9URY5MrpvAoE7wQyVEbtY66Fc6dVNOs4nIbyDT4R2eN9oF8124kpYVMwTkl qPHP+/RXEpf2
5VA42ZNvDJHTppIZxiYLXkwEbg1k0Wrnt0/JOHfYX9ETxF56eefaFcnQOdCv SEK4pp0K2Din
Pnbyy8/e96ZfzFnSRy8eUPCWo2AnLonfto5mVp+e+uNSgfO23Di5cW4P89ZS aMeaKcUhyU3X
3c4GLOW19ltzzotsSBnZzlTmrn4JfmmS4VtrU/m4TsF4r69LykbyJvfpY4oI zmSzaLXbm62p
OA8GwQW10piHVMzs3dY0cmuEAjbOj656x2+OqXed7Z9+mQyuL/ofL2h/tV4N n933bvvqr7nR
2x+rHyjEufmTS9mv5vM+igD81/W+yYfzupYCdpWoQPU4L9FYJAUF2q6AjfOD X48OL4+Gn0ZU
9MXXxfHrYw4nbwnzJ/QGffj0/ujPsSmMem1kLXpme+fRTy6DyIETH16rPrZd 84aWDzhvaMVV
ZzZwXp22SBkK5FbAxvmjF08ePT+4uFbe+ex2/sPzAx3o1Mm7s+mX2cnbMwfO bcda49wYIxLM
gKTJzRMiAeS5q2+XFwDnu1S7EXkB542oJhjZFQWc3vmP50967/skAY2A+/Hl Ib1Kp0Ae+fjf
k6PXJ+S+U7AEsmZppBiMc8VyMYw0Ni2EpDigXuu7DjivdfXswzjgfB+qI08o kKCAjfPjNz1C
OGF7vV7TReyLs7NOR+j44eXxyTsFe2NLHAonutz1Ty57/JtPz3/jfj2IfbxF bdVRAeC8jrWy
V5uA873Kj8yhQFwB58j2h09/JGafve/Tu3MdffltdXE9OLo6prM0+t0ppPzh aDAdsu+Lmz+5
FMsN+HM5RKsPbLuAIeq3MgWA88qkbWrCwHlTaw52t1KBpN+d0/vyg18Paezb 2Yd+/7cL+kv7
h1fH9PqcfpXeSilQqHQFFM7P+6M3w/mn2epusV4tOUC3zioAnHe26lHwOiqQ MiscEZ18dEJ4
EC6P6QhYXsda3IlN8M53InOTMqkS55izokl3QiFbt6ni9GvD6cwcq+UWsrSG F9GoM9uq9Dnb
D69ODl4ecaA525P62GtYWJhUugKZcC7XNSndgrISvI1PvFpWst1Lp1Sci1+/ lLYGdpQmfjZT
h9vTX0VNj4WWP3zaON/IxtsjArwYlb2xxSAjyDHbch3eOihn2cCTCRuHC6yo VsvCwajKFciE
c2nF765J1MsyM2/iRvykWeTKMs+ZTl6bdyZm0VKXiHP5w5hpr8QJojc+0IsW HtflVkDVRa+n
pxtLx3ms4vLcHnIKFGftmykHTT21/vrjg2ixgI0tjNzlL/MCvTiATBQ4L1Pi VqdVEOfkClex
MRqzJ27E3yPOs9ts47zYtVXo76dZLs7jDrT/zB2cBk8ta0UWP3JsXgu+nPw/ RzpqRK8zwcqk
QcK2AoqXVwsaFx1fyy5a+Dw2EDoBukGydm0G8aNh1fdU0yG4f5JTpnHawa+o 1RRm170gpt6p
a0VGywYJHx04r2t11c6uTDjnmc+JOnrac95hDnFXvP7I0fgvXcXENaZY5/j2 9O8yfUqBr7Uj
q8e4yxg54zpdqzfDQrsSdAS9Howza24u6AnhMwqiCBlfsp3L7hSzBjdIiTgP f/1Cfjlvfudq
QHFr3VL1ExoVM1iznD72Tnt+5GkvaTV0R4I1kLBDJoTTgOuFZHJ45xluD2dq m71zNcG4j/DF
4JR+hRXcP/WfHh/eeYe+OhUUNRPO7VVHGeS0yVO8GBoDT+Nf73B8ZphxoS4X A1InrinIx+3N
js8roLANSRYa6ciRAXoBFWfWvGwMt0Ls5ktKdmwPl4t29LI0hv2uIu7+WJk4 D6znQUxGZ7ue
jkq+dvVnkWTXKpgpmq/SDQJOMftTfvf6dSpH+922G+fCvQ6RFfnWWW4P43W4 OW2ZdGv9fgK+
Z4I7h3t3rD6e+tUU3p3Xr06aZNFWOJc00pzW6OKzvDHM+FTKJhM0IhsObvBU t/DPrNVZOy00
DLA7D5Ky5maKLhFF03lRRsa+FoTj04XcGpALwkrzUoXZ5ckKcK7M931u+6Fs jlpSOFd++TV7
VP4j+Jp9dLEB57u8I5Lzis1Jci/kKLM2gw8tEt50eyTiPEzDzM5PMLxzFle9 wa3Vx1MPDaUV
eUe2168EsGifCmTFue4YlwSig4QoXvdTU4oj2Gz73T+o10U1ljlnDezEtTYZ cc65aBucFkq9
Kb7dwuCr7KxTeg4oR9rSszNYbpSXLeGQtKrsTu6U8nAuvWqnL66e+8pvY1qH ne2KBDS0ir03
ehBTlzs567ENON/JrbApE/WCPGppcX+7Y+iDSMagsnwLI69V341wLnG7caDe sGxeGYz6eGgQ
XHDn0Fvz8I7aVKjanS/w7nx6+bB2xYBB1SuwLc5t9hCWNI00/3QnNpeIHs4b 8SzToUskSrUs
nI5+1Bs95HScO9JT6MgQNTZn1pyX3uy86FRKdmyG0RNg2F99dWfJoTycK99a 94L6D1anj+W/
//Y3uXxT9CCOfgQV3D0i/kanLUuJEaeYAg6HWE3urZb08BPkeUOTB6xluD0S 3sRvSlnlHsw9
Lu6Zhv5gPe1355+Wg5ez3j8mvZ9VoP3F55XPcv6LrVsKbIVzphHBjzemIP/l TZ+lI/ZoOLrc
2DhBfVzvG+6yvkrGt68lS5wWGpnKImg77aw5Kb3pmLYNhiCsA/dG0CmZnWGz pcdeDpSI873Y
j0yhQKsUSML56HJOCD/7ZXrxYsZh+mExefWQAuE83KlMig7M6lOZdlUlXBDn BlBlF7HEnkYX
j5jjbnkOmtmyZAYy+WOKey3j27hlrOpEUtLRVhmvDOQlBnoppvGengtiZydH C2qiy8hV1W3B
dIHzgsLhMihQhQJOnBPLj/9rTAgfXc3Hb28ozK6X45cPvPVchW9+WM/Vkehh bXeDxe11Dndw
F8m11moVhUeaeRTIhPM8CSJu0xUAzpteg7C/VQrYOKce9eP/HF08m45f38ii rr6uRy8eUPCW
o2DHUCId2Nlx7hy+0CrVG1kY4LyR1Val0cB5leoibSiQUwEb5/SO/OyXSf/p lMLw1ZzTI++c
Ps4/LYfP7nu3ffXX3uJjEeITOsVn/olGtESjXvz4NMBFzuozmNJ0EeG8PuGQ 1SiCGq9gJJWz
+IieXQHgPLtWHYkJnHekolHMZihg45zGvp389/jk5yBwMejFOR+ZvL2Zvj6a vI/WQY/KGfvd
gTGhkxypGkzlpC7UPzHQE0Dpg4Z+9DZd/VQh/nsHOU9+du+/GTVTOyuB89pV yb4NAs73XQPI
HwoIBWycH/80Ovrffng8pMBx6fU5f+w/m9IL9Yvn4VSMUsz0X3jGYS+m5onP GGHgPHK+/ZV4
DGbLs7Ffr6COy1cAOC9f04anCJw3vAJhfrsUcHrn9O7cJ/qQQoRz+khE90lP HrxDhuw4T5pW
mRONgT/8Tak9t0SSH9+uCqpPaRTOz/ujN8P5p9nqbrFeLTnUx0JYsmMFgPMd C47soECaAjbO
h7/Oj38ak4+uoP6fI76Y+thpn46o8NOIhr4XwXkw90M0uVOQiO1zW9P7hD/0 tzvbxVxDqOoq
FYB3XqW6jUw7hnO6PxCgABTYrwLGg2R5uz78n0N6TU796vLU7HpBR8gvp7M0 +t18/Mj5mhLm
X4rm59nYhR6fLEjNF3RKU++F8/uGPfXxoXB+b3wjn4rNMBo4b0Y97dBKeOc7 FBtZQYFNCjh/
d04D2qlH/eyfE3pHLgMxnhx3Pdx9U9o43yoFaopzPa+LPQNrFvntSeiyXLVN nFsxQw7PRZM0
k902uezkWuB8JzIjEyiQTYGkWeGY6L1/TmSgI2B5Nl1bGKu+OCdA0vZ78hRy KbWxY5wzy3kj
g3loCnDewq8LigQFdq7Ahjnbz2f0ozV6X05/hy9n9LvznRuIDOuiQN1xTjrp 6VSza7ZjnDvn
rAXOs9cXYkIBKJCkQIEV1SBmNxXYjHN2PfkvkZXdZbmeCi8jZiydwtH00iMk rh2BDjq5q3Pk
KpFx9PqqcpE0bYCecV1eIlsDzsu1qbSjN7tQSfeHMSW7TEEa6cyaZTH0tI/s 9tZEZ/tu9UZu
UCBVAeAcN0hGBTbjnGlH0NJE5x3eJMyIWHSKAawRxRTnS/gsM4yS5cuNldbo oEyfscobr62u
I3BqRgROVuOcF33hmM7Lpf3aGGehQivM/0nLyUjv3Jk1Y5tF4HLZR5IyrfI4 cF6lukgbCuRU
ADjPKVh3o2fFORGRgiarDWmNIsaSdpSZ3BTkoDaNc6fwHJmDdnAltg1L7AYB 41yy3Hk5ZWQ4
0BSNE+cWgCxUiqnOUxrnSVlLQSgFQ6L93ZLA+f60R85QwFIAOMdNkVGBzTjX 7DQ4R/hhYjE1
Nb+ZgoxD3qeYEsD6YJKJTrBJj1mnloRAu2fbeTkjX29salKhnNZSfNkgkHE0 zp1ZU0xtpHxH
wA0IaVXGiiwvGnBenpZICQpsrQBwvrWEXUlgM84lsWTHNZNPOtCsmZPcSTh3 draXgnOmrO7z
dzLVPkh2OguVdDsktSco/kacS7koHb2xVvLIbm9GB85nH3tJYbe2ITco0DkF gPPOVXnRAufG
OWOGe7MN8NApfn0uu5H1a+ykd+e2J+pkpDzI+2yJJJ/Mi89yTDLJebk8yL4y xXQWKkVeOeyO
mwKctcZ5kuU6TakMH7SPpBhQ9ik3zr3vHgdwvWzBkR4USFOgAM6nlw+haQcV 2IxzxpvGDLNK
+7V8Vr7n5iP0lzftf+ux4hyZ03FudMrZg829+twXLfvJtQGy11qnTwc5Nefl 2iqKr4tpF0oX
X5dLWq4NkO0YORTOzlof0VrZR9IzTdZvyzMunH/orQXONdr1zs2HE8L8lhnj 8jYrgMUxi9Zu
Cs6Xf81Gzw+Hv/w4+McP9Jf2ab0Nn+UrEL2o3g2+bjPOG1y4PKYzwlO2pEZG nkxyx91Hpok4
H7yd9S+nhG2Ndr2zuD5LJDqtgqw3tRwytnYpYNevk9xZcI5bxXVrJOF8+vqM KD4+Pxo9fcJh
8e/p5NVDCoTzcKddNxtKk6oAcB7Is3HWF/KeCa473vaRqQPn0/e99drjMPM9 dUb7yfn46OmI
Pi7/vAiI/iHmo6tFloI1mpRy09MeeL7jW6jS7Nz1mxHn8Wi4VZJqyolzxfKf H06vevPfRhxo
Qczxywfeeq7CNz+s5+qI3sylx8OFTSu9RZD4DhUAzgOx9zr6bIcVvjkrJ87P COSE8Is3s+l7
tZ8UCPwiB1oq0fXIkCs7UWz1WO/1HgcuvFqCyZNrLNJajXjubK62fcRw1q+q O954ia3BKe32
pjbjY0cSbpV9lKpuedo4pz528ssnr04oGNaOXjyg4C1HwY48naWDpG6Fhz15 FOg0zuXr/Ns8
qrU6rgPnk3dnq28eB8Y5o71/NT17Ne29nJy8GB8/G9FxOhv3Bmx3PFpKWTlk 1P2u6B4CW3W3
+pfQDvfM651Wi97IwqmKc3W3aGz47Ta/fcaNtvjimMYanc6kGqlLyUbbOB89 e0KvyTlwZotP
k9n7AYXFX7Phs/vebV/9NbaEKvDbW2oLFjPV1cTxRWu7dx201YI6LbmgSG5b BRTOz/ujN8P5
pxn11tBACg7bpovrG6uAC+dv+wRyRrhEu2a83qGzMZzbyxvbD/HYU0b74rSj UEELMOPZUdN7
Kcnbkzg32KBKotpzxnZw3jdhX9My78EsG+c06m14eiBxPn3T14CnN+jDp/dv Pk0cOJe6M6p1
e4vazQG8w1aXxjm3tlVTO9zBsuV7uBE2Z9lp73yzPF2M4cD5+G1/ufI4TATa De+coE5nhWau
fvKsOGeQB1DvYj00oMwJ70E24DwsmLsZ14Bi79hEG+fU037x80MOhjHU/U5n b/4YD37+IaN3
vuB4kS9u4Zzh7azWHWuB7FIVAM5xgxgKOHA+eqNwzt752N9PCnRWJuca3+Tq bNeNfXYR9POF
3IGr4BPqqYYKJA6F455zo+mW0tlO3cUYNZlQwU7vfPDPHzjwRfOPw8lljwL5 6HycPHjgvIZf
mUpNAs4rlbeJibtw/vpi+dXjINFueOfEeDprlNl/TIcbvw63h8JFMeS7WAyP asD946hf/xWJ
HgoXc/5kgay+emdSDZCgYhNtnI9fHA3++Yj62ylw5rO3ff6ow/jlcUGch4MY VHXI7nd45xVX
9PbJb8a5Mf1LdTOK63lUbrcvVnIKcsoXPSlNlRk2Lm0HzoevLxZffe/89Wwk 0K4ZH8H+9UXu
Aie9gpWeeu5EcQEUaIkCzpHtF//9cPj0gIJRyJvrEf0Anc7S6HcHzmNjFg4G 12J8Yvg11I0q
/mGCPxQOne3NuJc245zL8fumWVZyRbO1yZj+9qLudf7U7c3fQQounF8NFss1 B4l2HtZ+/Hy8
+Lr2gze8Kg3nGAS3g8pGFvVXIOl35/TifPivH2dvL2SgWWXo3Tn9Kr3+5YKF pSuQA+dJS4dJ
m5jKBdxr51ospZeWEtSLsleReCvSdON8eDXQQaPd3qE4rRABhYACdVEgZVY4 RfSnB3pWONqn
I2B5XWpu53YUxznPu6L7qwnhRj82Q1331fNHjqYj01mdiL5ci2CvcyoTlGu3 GLmkyJjU2jCK
wynIyBxB2s9TttFxe8H1nddjiRluWCBVct25X6IpSAoKQIENc7Y/PaD36IN/ PaK/o+dPHH3s
ULAzChTHObOWSaaxp2nHAsoVSNkt1iA3ztreOa+kTptMk7HNG0UgmjpzSak+ +905pc+pGcUx
ysI4p8CjB/is3knJsWmnsN5502oM9rZagQIrqrVaDxQuUYGsOLenNJdj4vQM qRKBcp8hSps8
KBFu4Fximy/hzXaFnbkkFdcgtIxmF4fJrTeJc0rHsIo+tmUDzttSkyhHKxQA zltRjbsoRFac
E9uMd+d2R7RBa24B8Hh13TEuKSjLZ+BcuvX6EoOvfLkzl2I410iW/eoGzrUx smWgWzO7qLHK
8wDOK5cYGUCB7AoA59m16njMgjg3qOz0ztnDNhoBVeDcziUvzp3FcR6UzRrd oNHd/q24mYDz
VlQjCtEWBYDzttRk5eUoB+fEM36JLn1W3if+8cYgzIhziqw7unmf05EJcqbO XFJkk50KOpph
lS6O3QNh4Jyt0vErr65dZACc70Jl5AEFMioAnGcUCtE249yeRoYYxvyjv7zp rnKDi/yRA7vp
RgRdAbaDq2eV4cR1d71O0OjAl7lwsk5y28Uhk5KKY0TWBdfp0xEuvjRPy9LM 28uB89nHnh2a
WTpYDQUapgBw3rAK25+5m3G+P9u2yplAm+WH8lvlYV28l0zLLQK1guzHx+xD z/vuyXDz4YQA
X3bWSA8KQAFTgQI4n16aS7NA1i4o0Fqc84/Cd7ztJdOyy5iI83VI9KY66/Zs smrNx3Cl53Qd
k2aiLVt9pAcFDAVScD78ODt4Nnr0y/CHfw7o79HL8fLrymc5/8XWLQVai/Nu VWOZpXXgfPq+
RyznOdv7l9N8znqITIVNXoJl602u1ZFjyTVzCchwfc8sqDbi+KvIRFlnSWHr UiOBbiqQhPMn
zwYnr8ZE9NlfCw43d6vJq4cUCOfhTjc162ipFc7P+6M3w/mn2epusV4tOXRU DhTb2dk+fX+2
Xns6MM61s047i+sz1f1Ox+NbFateBgs9BRmp5VazEt2BZLmAW2rl29c+7vUe Hwxu/auAc3xz
KlPAiXNi+fiPOX31dKD8xy8feOu5Ct/8sJ6rI+ZGCxXei5YhLmx2+j2P5dcK C7vFhfDOtxCv
nZc6vPP+q5EMhrNOmF/+ecFEp1NClYQVTu0FUhUag8WeeteUgHri+Du0hT50 xO8QonzE9Lkj
uAon3r8kFlO1A6JNrxkVHBKc1pHkct2cFHU86CVf/bOuHIOi9a79x+i9sFyR CPHitPOmQqmK
K2DjnDzyo2cjBjk56NTTTn/JO6c8Ri8eUPCWo2DHzlbduqIlWtiujDgvnD4u zK8AcJ5fs5Zf
4cb5au3pYDjr0nGnU5E8ili2+6s4yqhW8CMcqmgh0lTPvH+JJqXekfCOVQEl 2JvKh4vzHTln
lLbgo59OLJfIVNP/DrMIln1LyZGLpsoV7ijw23m1/K5C8QorYOP84OmIiE4s P3s9mX9W3exE
9IsPyllfrdfDZ/e9277669roS0e9WXTfBn1a/q078NenD9qa9hFuNIdR/O9I 0DZVq9pfLcxW
rDzLq6zaKThzKawRLvQVAM5xIxgKuHFO65/26cX51ZQWRTWcdeNjDOfSo7V5 zLyPsVD74gHw
zGVSHT5BMs6jZ5Dfu5iOcxnZf7KlNRGMvkT5UXrzdpejtiG28nTmPn/crd1T wMb5o38NCeEE
b6I44Zza2TQgjnFOmB//cTN86ma5j2HZrAw4HfSEUaOTvya6D4mPqNZnvAnO eLa/3VZ/VRjN
2YgPe6qCXLpXtWWXGDgvW9HGp+fC+a+j6e1ah/6vI+msy306JQQw+sn9M4Yb nYhzzwe58GKD
dK00kzrbpdMv46Qg1ng8pXj84hS5Jr2r0O/X3Qwbmw72o7Dxdw4KUIkCNs6J 4hrntLP6tiac
D3+bE9rp1OLrKtGO6L51jQNN+Srp25Wb4I4vctg+1b643En/1jtbBpVo2fJE c+OcZlbZ73qg
cnWWsirnd2u6m7JSbmA6Dpz3zodGkM5679dJ73xy/HxMBymaLLJrKJyrna4f FrKd7nsJ9jA3
eyic8i30U4b78GWnunEkCefCBQmLEDUd4pkaron/Gj4lR/nsC3IX3fgNvEVg 8i4VcOD8Xwrn
1Ixmrl+8m9IOBYI6EV2NUU3Y5E9CuJ/cbF7Hb2P3wBQD53a72b7hgfOd3DH5 cH7rmoZ9GzuZ
o+lbljib0kg7Tz8W3/2EM9sYXPG1DpyPXl8sv66XXz0OJ88G0lmX+3TKMC/2 BNEDx+R7uFgv
t+x2ThhJFxtxpkfMRcPQDsLXdeTf8xYcSfeY+RlkDHwLf2Wn0wxKZ/gTYSvE naMD5668Kq5X
JN9QBWycHz5X786X6zWPg6Nws1zxb9V4fFwSzcUIU388RxZ4p3S2W2561Oo1 nfjURjy885Ju
zXw450XBNwI4u22MamolpGxZ4mTP0YjJDRRsQgEHzodXF+R563B8enH8NAy0 H/+YW8ykL/PG
N2p4CuTWGhc0TwHnyPaDf6lOdSK3pLg/FM5L7Gw3vy9+59O1eAWe1Nkea+lG DW5uvPLAuli7
2dc4OJs6FE4NkZON3eZVTr0szoFzxqoBV31EroLqPMgXctBLp+gjcnUyPfs6 s9aII+dvN9Jk
aZ25J6me0lZISpyskhmxkdpU3des53vX07nTVfqgTqRet4Ovn+PxcTUgog+D vxeGs74IvXZy
3OlU7hIlUNkcBOdKN3yO4LdeuVXHBU1RwPm7896rsSY6z77MQ1iI5XS8KUWD neUqkAPnvHi5
5iXbwf46M8xAsnGQKUsbk4833qe/OjXOQh434hjrndhpOk0Kc3D8N9ZZ0TFs gw1LOAIf5BJp
2+QLfr26jLScF5er5bZ5RTXDWZeOO52qZaFgFBRoqgJJs8Ix0eWscGrOV/9I U4sKu7dTICvO
iVuawXI9UNspJ3vsg/JyjiAxzGCTCGRG8sb7Gn4aiklpOk3KqBIv40abM3Hn QWmeXllON3F0
vjKaxn9Gq3YbLQvOY86677VzUB78bq1FblCg5Qpkn7OdhsJN/clksHVTgaw4 Nzq99dgxCVoN
afsgoVoON3PiXDqv6Thnvz8pTadJ2WuXbXMmLq2iBKV3LtM3qM+nOEFuLsju 9+yG7SrmZpzv
yhLkAwWggJobBCpAgSwKZMK5wSf9MQvemHkUDJzTtbRxCryfF+fONJ0mZRFC x0kxOEt5KR1D
Lk6Z+x6aMIQeOM91vyAyFKhWAeC8Wn1blHomnMvedc1ggpaBN47mPEhXaWxL x1fiXFKQ9+mv
zo5i8qY7tJ1pJuXurDKOzLnwRkWwOx6kwbbrb+TI6chkpSw6L9qpK9qBc+fN goNQYD8KAOf7
0b2BuW7GuRNXzFQ+RX95SzlIZzmy4aEaiXNfNHdH6xHsdhw9etxO02mSRqw2 VdcUYVW+R5Bz
oDgNNsbN0eVOfZjouiycnU6w3m46cN7A7zFMbq8CwHl767bkkm3GeckZ7ik5 4m5dveE9KZKY
LXBetxqBPZ1WADjvdPXnKXxXcE7uPhEdWwYFNuP84mpCyzxQoJ0MCSIKFIAC xRUAzotr17Er
Fc7P+6M3w/mn2epusV4tOXRMBhQ3UmADzvuvxuPf5jrQR4gHBaBAdQoUwPn0 8mF19iDl2irQ
Fe+8thVQP8PcOF9+ns2ujin0XoyGb2cDP9AOfRy/OKTjFKF+ZYFFtVEAM/IW rYoUnM/Of9BB
J++zfAWiF9W7wdcB5w2uvGpMd+P85sPZejk/Ph30LydGODod0Kn5+zPTnsS1 VVINx3O/mnqt
KtVwlRo1a7deYid9nXvblFilJy69U1UR6p1uEs4n/3ogDb959QN9nLx6SIFw Hu7UuGz2Nx3f
/e2qCzjfTr8WXp2Gc8J2Upi/6zlw7lz5NF00fKWbc1O5FsA1Vo8NC7Ph2S0Q jhsgfgM4cU5O
ufd1SGF9O1j9dbH842x9Nxu/fOCt5yp888N6ro7ITbSw7aWHy7zvYk15aujJ lRIz3hJlmtOR
tIDzjlR09mIm4Pw9eeczemSov8vZ9OOFEai/PQ3najVx9ZUW66UG66ZERxT7 6bEers7EizGH
nwa32YuAmLtRwOlGixr0V9MaqOW2etNNrhjdBgFgrnvVkmY32pSXSyLOmdwy fF+NXjyg4C1H
wU7MDH8JteB7NO1xV0pFW5Y22aZboiLTWpwscN7iyi1WtGSc303XYSCW8zpO HBbXZ5MP1uIr
4usaLYSsjaJOWnqg6HWR1YqKfhM+uipoAagrsjwdihUXVxVWQNRdLA1dWX5r rHftn9z47Ob7
wV9YM7iksGHtujAR599mx39/5H2bxcL35fDZfe+2T39Xt8ZwFvGF0hJFLWbj 2xdWmV9xQZtM
XaVWLudNVVNSg9v5hU3KS7ry3J9nJGva0K4KLq80mXCulzm3p0axLTFmO5cR 5JwzWxbBmM7F
mNxty8Rvrdni5Kqs6mazIqTnaEyrx5HlkjNbGlzq5W6cU1/6+naiA8GbFlem 0XBHT0frtbf8
88JBdPtbGvui3runvrr8dBB9cXEYhI+OhP66UkuOxPIpkNTGkjWo37bEWmmi Vv1d3x1n2JBz
7+qYzWdZq2LbOL/4+cAO3tdJENbL4dP73np5c/WjIUSwoHDkl6tvHzeeVIOb m9dGlck2md95
JhpbyQ1uR2d7Ul7R8TB3K9mYDa2q3HILkxXncrq0dAuScM4ILH0rF+TaPL0a LB/hdozefs9Z
FifOS5eipAQTcP62t/4y0mHyfkAUN8L4fXw5NadDprv7YmcF1J0wKKlsSKZU BWTnrUh4A87D
mNbtMT09GFwPDirtBC61/LtJzIlzbz1dfRoQ1KOd5Yj62IOwXtDO7OUjt4U8 etGGt/FOhCvI
BrxO1MHsxMo1Gwo6r4QGRKwdj865bLcacO7WSTZKGN7GdLa5VkVrAc5nb3rr z0Mdxu8Gq2/K
O+9fTk/Ox+Sj00c6GFMztX816H6/HfSUZ0Zb+CI26sIVzfZsdzNi7ViBxKFw 3N2SQgLjLNvt
YwY97UYlOnFOLL9516fOdt5RXL8dGGHyLOXX574HbFRQAZzbP2Fg69PfrfB3 PKm5kH7tjm/x
RmW3Fc415wh12n03vHPdUa+XEmd9dG/5Ldd+yEsGZ/bOANs71znyrK72Qm2c oxHNqDVtD6fA
kflC2nSmtgLOgkic6yVkZAc+J2jM8U4Z6YO0s6vN7Z3PXp+s/7rQYfR2SPw2 Ah2MGelqUwfd
fdS/6o+TCjvbdY+rSoDjqA5YZ3f9roRAPlkUEGMbwx+q6RoMqthPJtMz2vVy N4sRrY5j4JwQ
zj3ttMNBf/S+XIjQn5zGcU5VoHs+gupwdYCHb750gzvqfnd0tic0vxzf/ZTO djEqNnwmxFp1
8M6z3eFZcS7XKdHdzsaiZ5yjxLnEGBORN4lYOk4IZApyBHl2YymM9/G6k5wT pL+/i9na9b4d
zc6I4lB82rgU+qNM0FbAWRCtA7dpKI4tgm7EOCPIdeQ2arJdhAScX52s/93X YfhmtFzFvHP6
WGD6qu1MxdVQoP0KpHS2q6Fwutf9r54XD2MD5+JnI9RaDoa4Ry3mYMiCbp8F DW4DpaKFHR8K
x0Nhws0JYCMvHSecuiBs4suhcH6ywHm22zwrzm13magmXydrsGmcGxE0BTVo yUKNcHkwF7ok
zuXgMk6QNwlIipMUzVCMWxXaMG2V3nEq4CwI41yy3MA5Wah771lJLRdbtcPu ejfOp4TzP890
GLweLb96y69r/28QBlejbHcdYkEBKJBVgZTOdvLLdWc7wdsIWTNAvLYoUBzn Rqe6jXMjguYT
H2e2aYZJ+mbX1rjK7lfnpDSAmetJ0Yx82U7ZOmFrdSvBqYCzIM6OfefC7Zw+ aWWMpbffKWRX
KWfMBJxfnizen6w/9ThcXI0XX73F13X4l3bWdDBnXogOBaDABgWyjmyHkJ1X oDjONZ5ZQ+0B
S/7JNUkpPoOQnWNjuVInBZ21I/Olq2Q6SZzmaHQh8zgjztkk3QfOH9m5582p gLMglDvbqVNj
Mzgp4xImd9Irf6cmpR5M+N35H+PJq+PJr8eTl0fj88P+5dgZSrUEiUEBKJD2 Dkt1tmODAqEC
xXHOcCIU0Sb9VLkvfUo9FI7pRcTijXb49bnsuk+vIH05Y09v9FEnwvs6F+4P 4I8p0Yx89bsA
Ps4fucj6CH/UpXYWRBps9PzTtcYl3CUgjTQG4hlGlv1x8wKpZeeI9KAAFEhU AENScHNkVCAr
zoku9sYcMlxtuwtax9Ek0xfqa50UZIJKfGobdPe1cZYbDdyNL/urDauSohll 1F41H7fH6NkK
OAuih9FxInrIvfTOdUHk0Hcui0R7xnrdIhpwvoV4uBQKlK0AcF62oq1NLxPO 91V6wpjRJ78v
S/abb1JbpxqrgPNqdEWqUKCQAsB5Idm6eJHC+Xl/9GY4/zRb3S3WqyWHWmih u8drYc3+jDC6
Fio2BDivWGAkDwXyKACc51Gr03Fr7Z13umZE4Xc4rJ1yBc5x30GBGikAnNeo MuptCnBe0/rh
8f/24LvqzQXOq9cYOUCBzAoA55ml6npE4Lzrd4BV/kScLz/N5j8/uXl5ZlxC R+g4nYWUUAAK
lK6Ae4HUv5Y//GNw+BwzPZSud4MTBM4bXHnVmO7GuWL5fx8sf3pCfyXRFcv5 +H8dFCQ6ZnCs
piLrkirqd7uaSML5Q8L5C+B8O3HbdTVw3q76LKE0bpwv3o7mPx2sX5xRoJ35 L0fqyC9H8iAd
ieUfXz8xcaWslMc9SFBChVaWBOq3Mmllwsk4HzYV5/heV3PnAOfV6NrgVBM7 25Uj/vjH9WmP
wvIfR7RPf/kj7dud8NYKx9kXXwrlw9e+zjeSubwm6reS2nLj/LPf2f4iaEDP X/7AYZMFtAyx
v5J40sKmm66Pzpu1H67p4mVYFs9e1qWAPaI1qVZfdG4de4DkwPnvYnDWDn4O 7lx0RM7HQtUn
x4tpk27j88FxNDl5HEfQM8nIiVez38ztjZk2FO7mn73Z339c//Nk/Y8o0BE6 7hAk6UsbfQ/9
R4COZhwXC0DFF0vVD472VkIjSob63Uk1bexslxTXXE9DezmQi7BNi7AdPD4I ut+yJJ4lzgZt
KXfRgNALvxpXlZDRTuq4pEyy4lzPZZYlXwb/lptBbkqNMUx/edOzxvJHuU6a Xv+UTxlztdrm
GfG3tLzhl28Y2T7726Pl//vj+r+OOdA+HXEX2fwu8fdfNN45QhDNOq6q3I+g UnedbbjQjTcf
9buTKjRwPvtreXI5PbmckHdOO2TC6t9j79vN8o+zxYeet57rMDtPcNbDihNr 1YcN63Cxc/2N
M+OIIk9PA6BOT3vT617gIusd13Kog1PqGehNY0ujHgyuo+eAH0FtUeMgOGD0 KLj6ANL9gZ1U
1n4zyYRz5mj2jXlJV22zpePcRjLlpS+R865wTKMdIJ11RY0yDN6msHW6dhPO /+PR8m8/rv/3
EQfan/1HHpzHX7hG3237uMS582ydVOuiLU6co37LvhVMnH9e0itzZvnqr3HQ x/596enwbeb5
YSPOI0tpxXHfwZ2ehhwNj9hx9BHllKte7sXglNrc057f8g5TINwGSakGASXu 3xgxD14d8RdZ
1816HYFyV6lFicTe3PkWUEZqi/zydH+g7FqpZXqZcJ6OZ93jTVBkLspQGOrp OHd2xRtrlHHW
3K8gcW7PygKci5tzU2f7//hh/fdDGWb/44ccne1291fMR49/S2Q/fIG3a7X8 yrXHKGdnO+q3
7ApO+t05sVxnFetjXy+9rxMK0xcbvHNGbLDx9yvietiVbcfRudIp5rRiKr2V JzbzX9mv5u9L
j5zP+h64iilxrr/j9jMhqducDGaop/sDZVdKPdPLhHMyXb6llp66XJWEF0ZT tVOGs5uE85T0
5Qri+nK9Zjk1Smijv8aLfzpirCJTz6ralVXJQ+HoxfmDgOWL//hh9uAh/WWu 076D6LFvoG5o
ixa3/DLLlrh8XgTfeeuqXcmBfBIVQP3u5OZIwjk53+vbgbuPfb3w7kbT56k4 V/wTzA5QyjwO
XG2fkXYcXWzfIb7usc+9uOoNbsWFks02zh8Ppuy1p+A88NEF8t2C+2Y4eZ/U CNhJxe0+k6w4
l5YZS50ywuX76RJxbjQjuCXBALY3Y+EyslNbokkvka+T2sHIvt1XbdEcE36o 9no8u/8wgPd9
Be/F67EaGScO0pFYprH2shi/ZrT3pQtuvSfjLrX4ULgyxuUWVQfXRQqgfndy N6TgnDvVjaD6
2L/deF8uJs8eug1kTArUqf7wkL603zsNX4QnxIl4fqoGwakBrbTRW/PH3P1O m6uz3XC+/Q7z
4KsdtyfsWhfj3eyuIN3NHpxytfh1f/5OamrvmRTBOcObmMqvqJnu9tBxrmK5 0SW6H57RKz8a
kbmHXIKW4vNHvtDYKDvZo8626ZfodAlbaFwIv9wSMnEaGSL38v95RH+lI85E X/jHC04js/cv
AQyAAjVWIAnnqi/d71Q3Ah1f/jlysVwBz9/0ELbwM/HbcKZDQYJX1HSNjBOe le2A2NtxihC1
9lzd79EQ1zBlCWy9z33pvMVet4W/uBPFcbw7CF+xJ/6Srcb1XsC0bXHuxKFB 1gJm0SV2Z7uk
uP3+21iMnG3QP0Ljj0R3XmKcNzoIvzwjzika0dpgOV/LRAfLi93nuAoKpCuQ iHPqS78bebcX
6q8IiX3sjRbaHprX6OJUY/xmnDMICaV6IwQyBY1TFEcep7PbbEkD1jhN7oTX WchfqelMjd+n
GePbt7Gt1ddiCZZWVy8K1zQF0nD+5YI61VX43Nd/E/vYm1Zwslf3DUTj5hpY ip2ZvBnnZApx
Wg5WNxxcu8OcMb/lJmnNSRnJ8kcOTidbNzv4csN9pyPO4fFbmt38y4Hz5tch StAiBVJWVCNy
26FFRUdR8imgcH7eH70Zzj/NVneL9WrJIV8qiN0iBYDzFlUmitJ8BbBAavPr cEclyOSd78gW
ZFMLBYDzWlQDjIACrABwjjshowLAeUahuhMNOO9OXaOkDVAAOG9AJdXDROC8 HvVQIyuA8xpV
BkyBAsA57oGMCgDnGYXqTjTgvDt1jZI2QAHgvAGVVA8TgfN61EONrIjhnO4P BCgABfarQI0e
DzClxgoA5zWunP2YBu98P7ojVyjgVKCAdz69TJjeFRK3WgHgvNXVW6RwwHkR 1XANFKhIgcQ5
218+moVBZu2zfAWiV1QddU4WOK9z7ezFNuB8L7IjUyjgVsCJ88lpzP/WHyev HlIgnIc7OVVN
Wt82ZzKIvhcFgPO9yF7nTIHzOtcObOucAjbOySn3vk1V+DpZ345Xfw2Xfw4W H/vjlw+89VyF
b35Yz9URvTlXBDfkBM6bfH8B502uvUpsB84rkRWJQoFiCrhxztg2wvfV6MUD Ct5yFOzILLMs
/g2cF6ukelwFnNejHmpkBXBeo8qAKVAgwTt3rHSuFj7/vho+u+/d9unv+m4e U8+J86RlTKUr
zyuTRkf89VX91AantECpv/4pthooAJzXoBLqZQJwXq/6gDUdV8CB8/NHzpXO g4PfFsOn971v
ixlFM7zzaPFwxrBaAb13rSKplctPpwzphTgujoTY5jg+3flabDVRADivSUXU xwzgvD51AUug
gGPO9umLR9Sdnha+3dDZqY1z9rP1Jv11hefeVKNaxxTwFo2BMCbqp04KAOd1 qo1a2AKc16Ia
YAQUYAVs71zh/HawMahoSfDm47lwntIUQFXVQwHgvB71UCMrgPMaVQZMgQI2 zifPH3lfLjYG
FS0d52md7f4Lcu6EN7rf7aYAKqkeCgDn9aiHGlmxGed6wssaWZ1kyt10/G5I YXbXAGPbbOJq
Pvk4X+UqYYFLdPrp1zbqrnDg/Nkj7/PZxjChaBtwLge4+a/Gtb9+TW/V1XZw 2vPfpsuY9xTg
s4yTz1XdiLy1Agrn5/3Rm+H802x1t1ivlhy2ThgJNFWBDTinO2Z5u+SwYfpJ eqT6KPXD+Cbf
s7wU+RazEvMNGaCK8yn2CjLN1rxMyhu/FJ22ScSWxVmETOVa3XwcjjX19SVZ rhU32+TzyrMv
iY6Iu2JjyrF7eD+NQgfOnz7y/uptDJOnP2xTsbi2cQrAO29clVVtcCbvPBPR 5bNSPRanmRlY
UhnLy3T1eTwW9i8+ZS7LRmAYZc0bvySpiiXjliUjzt3Enc4+hi2/dJzHLpft tsWMGlspMsq7
YqOp5j28B6I7G83jpz9sDMXqFFc1VwHgvLl1V5Hlm3FOGWsfPc1BNx+4IQIj j8d/cKto9BDn
LnHfP9N941FM/9oYnukJrg86OwAogu4bUD7fzSf6aFwSfkwyINCYrHL1Ltjm BbnoIgTFoRIF
LmOsr0JZqI4HRaMs4vErquHSknXKIorwaUod7IHsae5yqPLnMamx+CQ0UZ56 giZJdxcn5p/1
sw7rIogv7oqw0oPa0bIYCJfvCGQLI6hKfQv5rxKiW5TMni5sM/KLX2AJlvyZ 4Io2KACct6EW
Sy3D5s52fneu+9v5o8MG+VikLtngsRhiOHzmrtQT0Iel6rYNd1Rk9eTld97K C/T7t+lZH7wF
p8jqiJWatCP+8A1fn1vJJhoQpuX28p3pCPO4vJEILlODlAUXG+Sdu2URRfab O4Hsm3EeiqBv
lRzeuboxYi9BZNacoDO1XN65uh24Eu07M6hculFnn6Z+kRczzlQrEH0F8n1f gfN8enU4NnDe
4cp3F30zznVP+4Yu98h5jb8QlU4zPRzt5ywfMZwkdqwDitPjO/TsjdSScG6/ kdW+VJIBTnct
yYeTBZEUd/hz7DIGfRV+f3Xoj8bwX/s7M6nlsQGc8V4Tv/rib7vDnnM3zhMu Z7X4Rb7R2W7c
TonOtyvlf8/iI/h8bLvuTL4h1VsYOssGOM3IX6vAeX7NOnoFcN7Rik8u9ubO djkaLm1AXIxk
oqfdGOGcC+eq69V3j0zf11WgjQ4Z+5cbca68Mauz3X6mOzmR7mKGBAq63JuF c6cszqaMs1zx
1gA3a3SIAX6jDx2rfBdxy/LOkxuayi+/49vSv0XvfB89semQ47EDnOcQq9tR gfNu17+j9Jtx
Thflfneu3CYmetRRGWSeSFNHZ7vigt+fGfLPSm2jd273lG7Gud/bbw6Fc3W2 O0dlJxU8UIM7
b8X4r92PGSz6JUgcCqfHKDg7RTi7GKTVC/Lox4R297itiUFK/VsDJ3FTcL4x 5aj1qWvcdWeu
5jSIj2/L1ecp3aLhuJDw53lJnRmbxAfONymE84ECwDluBUOBTDhnom/+oZpw xP1Hv9VD7nzO
OjqoxUhydqm11epj6NVt9Ps1SJLGMSU7/TH3keERZR0fDxVnFb/WjQ+F47cP oi0SNXeC18CR
v17vO9Qhiz/EQRXZHwqn+GbC2zpios5v39xFP1WPNJT1HlV3NFwuuseMrBO6 STakLO8u2UNj
VH3QMgvbZPbrf6cC2WoWOM+mE2KpZ/LFrxfqK/D5Zv1tDUWggBvneuoYm+Ip p6AmFIACWyoA
nG8pYHcuB867U9cZS5rVO8+YHKJBASiwjQIFcD69fLhNjri2oQoA5w2tuOrM Bs6r0xYpQ4Hc
CiThfPaxZ4TF5ykFn+UrED230M2/ADhvfh2WXALgvGRBkRwU2EaBFJx73z0j TF49pEA4D3cy
5IzZ1zOI1IgowHkjqmmXRgLnu1QbeUGBDQok4vxDb/3d04FSGb984K3nKnzz w3qujuhNrWgu
N9fq5qiNJisAnDe59iqxHTivRFYkCgWKKZAV576nPnrxgIK3HAU7MsskLxze ebGKqd9VwHn9
6mTPFgHne64AZA8FpAJJOJ++P1uvPRm443347L5321d/jc3GNh/RxyP3PVjs HBXRLAWA82bV
1w6sBc53IDKygAJZFciOc4V2v/t9+PT+/N8zB87TOtunvXv+kue0wV/PWjn1 igec16s+amAN
cF6DSoAJUCBUIAnnk3dnq2+eHZjobpyTL253v2sf3YA9qqBpCiicn/dHb4bz T7PV3WK9WnJo
Wjlgb2kKAOelSYmEoMD2CiTi/G3fiXM+OHnbd3jn6Tg3zm5vOlLYrQLwzner dwNy2wfOk97q
FZYLvYWFpcOF+1OA3GM78yScj9/2lysvKdDZfDj3qLP9Xu96f4VHzlsrAJxv LWHbEigP5/Ef
xrifFMZgHC2mweNYUuEbPlt5OagHrkbb7sz2l4d7u41yJuF89CYN53Q2J879 V+a6vx1fnwbe
bsB5AyutWpNLxbl+KKS7yxu9cxnhuncv6VkDnFd7byD1ahXQMJXZJOL89cXy q5cURq8vqrUV
qddPAeC8fnWyZ4uqwTkx+HQaGzEr/XLHT2XuxZgd430wBHdxpX0J/l3NYvA4 eB4enPboFziD
0+AjuhD3fE8h+2wKyLFo+ooknA9fXyy+ekmBzmbLE7HaowBw3p66LKkkpeI8 ej75xJVUduBc
vL2zO9tDj1xR3PDOua1AW7xZEFA8xZsvSTIkAwVKUSCXdz68ulgs10mBzpZi EhJpkALAeYMq
azemlopzo7M9Hef2WV1i51s9+6Czsx3D4nZz4yCXrRXI9e58eDVID1ubgwQa pgBw3rAKq97c
anCuxs2Gc0RzGWzvPB3n9m9s7oVzV9kUT0mqegWRAxQopkCuke3FssBVLVYA OG9x5RYrWjU4
5x5v5U8H49KDPvPYyHZCfkBos0c9daxcFFmnD5wXq3xcVT8FCqx3Xr9CwKJd KACc70LlRuVR
Ks6jd+eC4v5BHq0WzBet6UvUl2dlZ7s1mn0ajnQLkvIj80F5BDNWNur2g7Gm AsA57omMCgDn
GYXqTrTycN4dzVBSKFCZAsB5ZdK2LWHgvG01unV5gPOtJUQCUKA8BYDz8rRs eUrAecsrOH/x
gPP8muEKKFCZAgVwPr18WJk5SLi+CgDn9a2bPVkGnO9JeGQLBVwKJOF89v7Y CDd/DhdfZtPL
Hzxv5f/F1i0FgPNu1XeG0gLnGURCFCiwKwUScf7hxPvuyUATvk5ePaRAOA93 yrYyyywOWeKU
a9fucyzX/pJSA85LErI9yQDn7alLlKQFCqTgnNY1Z5zzzvjlA289V+GbH9Zz dURvyTMtmiql
TOSQBZyxONHUy/pnLgdXsVXXE+vI+fNUY1H22C9dW1DbWxUBON9KvjZeDJy3 sVZRpsYqkNzZ
3iOKD97O+pfTk/Px0dMRLXM+evGAgrccBTuy1AVwbjcFcuM8TCLLhUYdpc42 EYtbIPHG3g8p
hiucn/dHb4bzT7PV3WK9WnJoY1lRpkwKAOeZZEIkKLAbBZJwPn3fW689M3z3 hs/ue7f90TPh
l7OhTpz7B+OLFZlLGS2sxY2Ucx1NsSwmZ0xZX9XOPVwvyV8/Sa3XEHjtKmVK U5ihvfkkwMvu
hFiyu6miuuRSxDv/P543tOynI/Ig7f+vkspIdU0rAKsar37bZV7Vl6ZYDsB5 Md1wFRSoRIFE
nL9TOCfv/OLNrH81PXs17b2cnLwYk8s+fHr/5q+5aU0Szu/dMxcr2tzZHqxq KFoJyesnORoT
9uXcPqDJpoji1uTNuiRRG4KhHc4bHRjsSraSOqlporlxTiwnuBobU1Dye0uc /x7PhRKnIxVt
u8yroiKUmixwXqqcXUtsm27P9GvDGQNbvNxtrjnbJ2/PqHfdGYjo80+TrDg3 1kmiyzbiPAmr
DnKHVhjzLhuvwP1YvORx9GY9S2e7fHduW9Wxb18+nBvk01oRyIm4EvOl4Jxa CbztAOe7yasJ
d1epOBdfsKzjX5qgEWwUCvidoilISBHLuD3SHt/RfP6ZZu1t5o2Xa0W1sY9z 2zs/fqZeoo/f
nFWLc3tJJPsekBYYOLfmbFZx/RbbVjh3JtuZr2s+nJNrTsHYmPH8V0PRxjnz njvkObI8otOk
FPQp3uEj9Jc7BuhavVFqOo60ykg5KVrGvLQBWZJNykubp5s+3JmRK/Gd3JYl 4lw8gundGC9J
jq1lCqjHdK9nd5A6Xe3YQev2SPHOg55Y/s6o173m2Oj0lBuiea71zsdv+suV lxTGry2cq/fT
YT82u8L0lXRSVqsdeyftL7sQdWuHXfSBtsnrJ3EEs4KMyykGd5XH223hik1B JhvenYsO/4bU
eLlm5sO500smLDHj5VmJc+2469aAjskwszcNOT7FPfm/h+0APijbFnSWLuGY nKA+64wmc9yY
F0fIkuzGvLRWOtPsiZdb8cmplYvzYOWVKLvIbZJPB/+86Dfzx+bwteorGrwo u3YNwNmVLsjH
qQBRgdwpWvkmGsekWOsax6SrOEhIvOnkI/4NEBuWJeAR3ASq6RAOdpK/dzJp Yd14Tag/2QOt
7U16dz56rXDu9M7p+MiBc/n1CTtUEpxmeykj84js2ebWVdL6SaJyo0aYebkg sUonqL4g0yJD
4USPUROqvhQbc+DcwB5n/7vgMbFKj4bTOJcR7EvoiLOJYOSl3Xo+rr74ojNA s9bOyxnNEC5X
XjwM0JnsxrzYcQ/ubVdBUhIvpbKzJVIizoP1zZQTEGzRlzbROfC/5+H7UUUF 8a6060NdstXg
LmOFA5d4AVz1zQxd580+tHV7yKrXK+oaycosZEHj2QWr7TWtQyiXd65w/tVL CsOr/i7vA+RV
BwVy49ww2ugY16PhpHeuu5fZiTf64TPinFCtKa4T4e532f/vzMuOFnsOxF8T 2D0HzGm5cRGM
ZJ0H5VXSd9dpZkx8h/dKmTgPzOZmu92zpwemBm0cnwQp79hki57Hte5QF2Tl UCCqrLCP1I3z
qIvFMZdI0u0hb4bEuyJbyg2pvFzvzodXF4uvvnf+esbD2o+fjxdf137whpfA eUNqvTwzc+Oc
8KM3QqzknPxovztnblEcCnIMPL8XNzaOrI8biKXj7Okm/RZO55UeLYDIpryc xLVz35hXdpyn
FK28qk9KqQKcq6x8x9p4KBfAebeHulRf+/ly4KHIMULn8c5FZq7bIxPOwzQS 37tbXfr5irjT
2LlGtiucL9dJYQCc77TqapFZDpyTvQZ6Ze86ndUQpX3nyHZ9ud5JGgAvce5E u8yLsjOaCNrU
jdG02dx0SMlLVpcz2Y15kZG69cP79Jev2pj4Dm+W8nBOT1jd22mNoIk620Mn Wx0xvHP/FWy8
s90eQbNDbZBVTIF47djd43b3idGeM24P2wV3Ng70QK3Y10aMj3PceA2uuaR3 58OrgQyDV30j
NLjMML2QAvlwLvltc4gM0DPMaE5zjzQHRqam5kb3WkbWpeMxcTIRnU56XknZ yYIYheK8nCXl
gxx0J4HzoKwXbSELRX+zJ16ofgtcVB7OxXgo+vmJP/eTHIwTdJVrD+/gtGd2 tsfi+yC3B+AU
KCIuKUUB0yH2+9uvI6ya45i4NqP+FTmbt397ZMQ5dfWokZLiF00bUy6lvHtK pMACqXuyFNnu
WYF8OCe2Ga7kns1H9uUrUCLOyzcOKUKBrikAnHetxguXNx/OKRvnrHCFs8eF 9VMAOK9fncCi
DisAnHe48vMVPTfOKXnqJSY3HVtLFQDOW1qxKFYzFQDOm1lve7C6CM73YCay 3J0CwPnutEZO
UGCjAsD5RokQgRUAznEnGAoA57gloECNFCiA8+nlwxoVAKbsSgHgfFdKNyYf 4LwxVQVDu6CA
jfPZx54zLD5PKfgsX4HoXbg3jDIqnJ/3R2+G80+z1d1ivVpy6KAUKDIrAJzj ToACNVLAiXPv
u+cInjd59ZAC4TzcqVFBYErVCsA7r1rhxqUPnDeuymBwmxVw4PxDj1je+0iT vC4l1McvH3jr
uQrf/LCeqyOxLfytvzlfU8I6dXRt4jR/ctoA16I4SXWSNH9fuIJLMCF0m6u0 qrKVj3PnpK3K
6XNN5ppULGfkXClUJViedLdc9J2zkgu35Mm8cFzgvLB0uBAKlK+AE+fr797J xz7hnHZ0ILSP
Xjyg4C1HwY7THAaqgdXEWXLDJJIibLzQsMEV359LKlqCYXqK5RiK3Egl4/w2 YZ6ZpOPumy0h
kW7ivEitbnXNnnAets3FlK5bFQMX70eBvA93aWX6tR24QzLO2T59f7Zee8fv zwjnMtDB5bfV
8Nl977av/qb7x06c+wdda9QmrHhLWdjphL46TwQZTeyfuHJuuC5f3GCxIkAw p2Q8KSyXbFZw
Y3Ceq0GwnweZlWsp3vnOy1IezmMLoIWTvLrLE67HlaW02wAjS/qIk08B/0Gv p25NX4LFdtTC
9VvUcul2zUZHxB2y4QYo2gmcr9SVxM64ohrj/PD1ydG7s6P3Z8T14w/9kw99 Otj/bUjO+vBp
Mss1gJNwrpcnTlmjNrERZi1hLCbYD3xuZy2nr45IlvB6jNE66OS+Y7nkrXGu VyCVq5nJZUnl
LLBJx7kD2V7QhQ86J57TOOc4emF1Y9JZPWm8/W2TF/4uZlznpDh9/kuJcASd C0Vw2sy56KsM
2yTOZWFpn9LnTVuijxiW89TuvPGFWiW7jGUcKRXn8imf8o11LqqRVBjgvIxq Li0NVR293mMx
J7+9QrnOLFZ3sg037Rnr5xr2yTvEeQOkNQVKK2vVCWVc73zy7mz1zTt8e0J/ nWH+71maqSmd
7ZmnzY/SNy6RS+yprzyvYCs6z7PXlPQH1E0VTyrmLWC5ZFUh+bxzXuSbtlsB Y7kuC/Obt6Tj
cp1QikNJpUSOngMhxviIToTpqzdJSnmQrZJX/S4KQrv0kZPiohmLozhtNmyT yvApjXNOk0tK
mzZSJpvUEDGy1o2Myl49VINzoykd644TS1Y/HkyjNTe1Qx9F6F3HO/2ir7T/ vIi6CvHuTXwr
qtyl/k9yrGlNFOVeh1WwEKvvBMfZBhPn8WpK7OmVdwg1HVwDr7JDoko1tkxb olAnZb87n7zt
E8WfvDmZ3y1koIP0Uf3dI87dSxgLEjtaY67OOfXVttqISpQwKTTrrbstB87l mCzmE22/x99z
00f22pOO84X0l6mWnohhreGIczqcESfo7Nw2LLFtY7jqdHTR2EL66LRZ2iYj 0HG95pu2x7BB
52j0cMjOAJ2+xLlsuzgbLoZihT5Wg3PuuFMGubrInN9M7mEz10iVSFBfbH7X LpZbxQqqhaq9
4EXhW09dv+md7fGK5oXR/Fr2N79xFgyeSOnp7bx3PvZx/uOvRwdXxwevj5+8 Pjl80zt62+OD
9JcipNVnUFkxiEbfIOO9iaxQZweb2USLfwFvBz1u56kvcrhunpWOYyicSFYv nRxPKvr6F7x5
W3dZDpxLrmjmGQQlbjGi0o9zd7r2qpMiG2obONfU1H0GRve4vlz2+du2MRd1 iXiH/tLGp9g8
w2Zpm7yEjts414nzVTpZu1+BsuNWDgVWUnrtThe/7HuyVJxrdyPW6y6dkMir 5i+9uQRqitdl
9vL1pmiwl303bEgvEjxkgxvnwr2WL8s5dR7jZnS2Gx3CdidwYFlyyg28GTK+ Ox+98XF+qcjt
DBTBVXFaK3u14nD0Q0pnu3NdWv7CSo/c3UMeW9DWsb6tHDEXtvCC1h6thMtL Jwd+uUjKzGvH
d3/tstsW54Qf6WIyjWhLOs4uvrwkJbKhltM758sZ5EYE4/LbkKOGbdrL11Zp ajKYnTbbtlFM
3jLi3G4ekYX2pnHO9uutSd65+taF3arprpXdwwac1+6hERkkxh6HD9k83rko md9nk8KSRJyH
abSls92ubbuzffT6YrnyHl0eGp3tdJCO0F+KUOO7BqZVpUAOnDM1eeN9Bpjk ihzF5jzOTOIL
OR2GaFIistzSN5UspDjsfzs7q50p6KRkf7jEOVvIr/+TbDZS5ks4Mm/pQ+Eo vo7J9tO19paE
czk0wXVd4WOleue62a48MCa6q4vMxYCgh83Z2W4l5egqLCwALsyqgBrHEP2w 0O4et/tmDSrL
bnbjl9Dp3nl6ymx/A71zp/A2zoc+zn84f/Lo1eGPr44OLo8Pr06Ornp8kP5S hKx1iHgtUiAH
zqnUTGsKzBg54lr3DxsdwvZxBp7sT2Y95UEn23QE2zGVaDRqR9ss09Q2aITz EW0JJcjllQPc
bJt1XtI2Soo3iXM9MJ5jcvr6YLr9xth7Tjxp6JxR/Pwfq8F50JmmX56FXa7W KGirhy3W/c7w
iDrrot42q9M+f8lxRT4FTF76/e3XUdero081don8RVl4Y6S8uBU9uptS9svR YpxfKZynhOEV
cJ7vXm5H7Hw4r22ZK3NVs5Z4y65vagHIjvSsuVYSrzycV2IeEoUC3VLA4Z1f DYabQrc0QmnZ
P6QlWH69GL8b33y+WX9bN1IVZiH93eO2Jc7rNOEMcL7H+whZQwFTgQILpELE birQBpzXgYVb
4nzLy0u9d4HzUuVEYlBgOwWA8+3069DVbcB5ZW+Rc9wHBboH5Nv0/XYtxMsJ nOeod0SFAlUr
AJxXrXBr0m8DzltTGfUoCHBej3qAFVDAVwA4x42QUQGF8/P+6M1w/mm2ulus V0sOGS9HtPYp
AJy3r05RogYrUADn08uHDS4wTC+qALzzosq19jrgvLVVi4I1UYG8OPdZvgLR m1jXW9oMnG8p
YPsuB87bV6coUYMV2Ijzi6uJDpNXDykQzsOdBhccpudVoAjOk4ae/Z7nB2PG tCp6aLeeIVWW
JH2g2cbpXZ2ikLX29LS3qfrtZgi9VEbPc5dL27w3QTx+DOd0fyBAASiwXwVS vtG9F6Pxb/Mg
vHzgrecqfPPDej6mI9tsbZmKZxsNGnRtbpzLaVztcqafdepi/EbL+ZOt7OPG GXtZNjZV85s/
0uUp225wLg3Qq8vQwQLaZtHBigPvvJBsuAgKVKNAind+fDroX05kGL14QMFb joKdyCQ5B59r
hVmn8cB5NXVaUar5cJ4FlnknaKsC5xrSKarxNOma31lmfd89zqkgss2RV9tC Nw1wXkg2XAQF
qlEgCefTjxfed88Ow2f3vdu++rs9oYHzauq0olTz4dxY+IRt4knIZbewsWBa uukbcS6RxpE5
R7m+Ku1zNOfc6U4DpNl8rVxoVV6iXy5onBsdADqC07xtas7AOZU9l7aFsgbO C8mGi6BANQrk
xTkBfvg0geVkYZzQYk28YNXU6IhcFEctoRQuq1pNMZHq9grkw7mNXgabgfns fePcGiBo6c3u
8ZZIkz60vjDjSqNSLE5TX8ivqyWt7ZXI6fKNEZzmFa4kbrgY/M6lbaGsgfNC suEiKFCNAkk4
n3xwe+eEc3UqaUtyuAnYvOR8uFrd9DRcslYucFxNGZFqKQrkwLnEKuXNsHFu zuFsSeYafLKv
lRlJp1yDvwDOGcwaz+yX64x4hxsZxqpoDNekCE7zitWTk+WUVC5tC2UNnBeS DRdBgWoUSMT5
+8F67TnD5P0gK86jNQnv3VNr1qn1i8O1jPVihry0Mba6K5Ab57JA7IxKhvHZ 7K94CZlGm8DG
Vfqq4ZSdHGnPCTKJUza+hCMzOOmvvFZ2vOv3CNISZwSZtd3NsMmo2HnbL8+r ba7sRGTgvKhy
uA4KVKBAEs7H7wbrb54z0KlEQ4wl53UXesxrD6HuH5xeHSjHHVvtFciNc5uU Goq6sOkeJIFT
rjJudCbLZdQ5QU1rzkhv0jvXxJVIThFfX8vU1Mnqhggz3vgJnMS5HSHJvAL3 ACWV9I4c3nkB
PXEJFGiuAkk4H70drr55zkCnsuI8XEVevTL3X5b3rhb+tTQSPlq9nhaYPwiO N1fI9lueA+ck
RpLju/H9tyGkpilBUb6lpmgGjyUjDV5q9Ob1zmUW/OsvbYPst7fHuhsj240I SeYl3USySUE6
sLy8k7JlibMpjQ05bJy2Yrv0cTUUgAI5FEj6PtLx5cpzhrSvcPzdOXGat4PT HjniYWe7f4T4
HUVW/jqInqPa9hE1H85lLzqDkAORTG8Gj5NaALqjXl6rE9EpS3fcSFlT3Ma5 VNI2QHKX/W8N
UdrROcp9TtDAuREhyTy60ClCCs6T3lYYWVRzw6CzvRpdkSoUKKRAEpsHV6Pl V88Z6FShrHBR
sxXIh3ObcHbpCa66o5jiV//DqrQK2MaAjSMANkZgy7axwSib1Lay+86N8x9/ Tu6+q8wUJAwF
oEASzi8ux4uvnjPQKejWQQXy4ZwESp+bjHlPTiRvPFx8j1thA6gI6UPqNkbQ pS5sg6GboW1l
qiZ65z/+HUSvTHUkDAUSFEjCef9ynBIgZwcVyI1z0oge6k5IM2/2y++yqnDj BHAbI5RlCaez
Q23TOtvz+ejRb2BK/aELZqoq995CavVWAGNZ6l0/NbKuCM5rZH5lpsj38c5M NkaozLSqE97w
7jyfj14FeqtIs2pRkT4UKKoAcF5Uuc5dp3B+3h+9Gc4/zVZ3i/VqyaFzQqDA oQKbh8L93+F7
9IOnm0bcaPSqnV7vsT9FxXWwGkTvmqecDI77p3wrDLfeT2SghuCSlx+tJIFx trhpu6AAcN6F
Wi6ljPDOS5GxTYmYOD9+MdZBl5OITix/dBrg3BknADP/sFUR2p/zWU/+TDs8 KbSeyEKdImCr
n8Qw19VvYYOJJ0PSc1Lhj2XbpDvKAgWcCgDnuDEyKgCcZxSqO9EcOB//saBA zNYqMMu1m06n
7DgmzjXX5Y45F1U0c0XopocTR+u8gfPu3IwoKY1Ver2pDwwqQQFfAeAcN4Kh gBvnyv9+HuBc
szzC+XN1ViE/jBMkGutsD9104Bw3HRTIrABwnlmqrkcEzrt+B1jlN3F+9Hw8 +s3itHWZina9
oL+xM7lwzt3vzs522bsu13fKso8ahgJNVkDinPYRoIChgL67gfMmf9Ersd3C +bPR8MPN0bMN
PX4UwYwmR7QlcV0u6BSuzOgcCscTSfPGM1MGk1DGrgp/EYclHSu5N5DoHhSA d74H0ZuZJXDe
zHqr0GoL509Hg3c3R09HGwNHy2caXoTn0wuxO6cAcN65Ki9aYOC8qHKtvc7E +eHpqP9mnjEc
/gKct/bOQMH2ogBwvhfZm5gpcN7EWqvUZgvnvwwP84RKjUPiUKBrCgDnXavx wuUFzgtL19YL
N08j09aSo1xQoIYKAOc1rJR6mgSc17Ne9mgVcL5H8ZE1FDAVAM5xT2RUADjP KFR3ogHn3alr
lLQBCgDnDaikepgInNejHmpkBXBeo8qAKVAAOMc9kFEB4DyjUN2JBpx3p65R 0gYoUADn08uH
DSgYTCxbAeC8bEUbnx5w3vgqRAHapEBenPssX4HobboHMpYFOM8oVHeiAefd qWuUtAEK2Dg/
eDqm8OSZ+nv4YnJyOeu/m0//WlGYvHpIgXAe7uywgJgSaodiO7MCzvddA7XL Px/O7eVYalcg
GAQFmqyAjfOTD8uTj8veb8vex+XFH8sRgfzLevnNG7984K1vRJirI3qLTais ZklWCxaXuAHn
JYpZKCmF8/P+6M1w/mm2ulusV0sOhRLDRW1QIB/OqcTGYqlt0ABlgAK1USCj dz77vJp9WY1e
PKDgfR0FO7IUVeO26vRrUyO1NQTeeW2rZl+G5cY5LZPKRDctrsgbwFNjX7cG 8t2HAjbOp1dP
br55RlisvdV3b/3dGz6779326e/yuhez1/HFmfZ4KSPa1LdV+euLqwO1wJG/ yJFy39VVvd5j
9bl3vRgEO7Hj/ik+Ei6CLFPYh2jdzBM472a9p5Q6H871kudEdAfO5cKmZSkN nJelJNJpggJJ
OCd4G4FYvqYSfV95d33v+2L5h4XzENTqf4ReWoeQOG31vdOCxadTjXmPPjLg eSHjEP9KQnWq
Nw2+mNREEAsbVvEEaEKt7cVG4Hwvstc50xw4//Hvw7SSZPEGrqO2f9DGDxwF fvD4zwU/nYFa
FJWfO2HLn70KbFCg1QrYOJ9cKu/cgXOPcE5AD3A+f3e0yTtX59kdD3z02LfP R37K0sYRqgnh
BwP1XWbMyy1Ee6vrqCaFA85rUhH1McNe73x8/CII0soff45YriPQThTH+GI7 vQG7je+pDkDV
d8cPmsA/CI6oo/DO63OzwJLqFbBxPn51mIRzBXTGubecvs6Ec9+3Nrvcoy9a AZzDI6/+rnDm
AJzvSfj6ZmvinAg9/mNBQaLa8MudcZK4G/MGYmwWbXzWR8Fed+KFkgHn9b15 YFn5Ctg4H/2q
cK661o2gMiecL727C+pyJ+pn8M65b9z/6t3G2srqe5rRO9fd7wrkUXM83rIX PfCyN17vl69c
51IEzjtX5ZsK7Ma58r+fB5639Ms5NTpFQSE/jJPmRhvegLPLDjjfVE843xEF bJwPX/o499Et
Q+iaD4jodJyimTiPdYMTvwV6+f23503VWy1/INxpL+g81/1qcifW9xa9FFMv wOSpWJ+caKPL
L3hHKrL6YgLn1WvcsByszvbn49FvcU67SnRE0a4X9DfWJHd0uyV6A8EQG2dn u0yHXXb7cZB0
vGH6w1woEFPAgfPzI4lzEXvlLekVWPA74+F5vLO9XF3RSVaunmWkBpyXoWKr 0rDfnY+GH26O
nlkD1+OlpghmNMcP1SxvwG7jx1r38VZ/mCM7EGrwTha0t6p2UJjOKWDjfPBC 4Ty+rei35t5X
YvlKH6doFYoFnFcobsGkgfOCwrX3MgvnT0eDdzeHvwyPno7SA0WjCPmUwUMh n16I3TkFHDh/
eTx4eTx8dTL7NF7fDRTFv45Xy/nsXY+O959HoXNidbvAwHm3699RehPnh6ej /pt5xnD4C3CO
OwoKlKlA3iVYyswbaTVKAeC8UdW1C2NNnD/554Bc8+xhFzYiDyjQGQWA885U 9bYFBc63VbB1
1+eYRqZ1ZUeBoEDtFADOa1cldTUIOK9rzezNLuB8b9IjYyhgKwCc467IqABw nlGo7kQDzrtT
1yhpAxQAzhtQSfUwETivRz3UyArgvEaVAVOgAHCOeyCjAsB5RqG6Ew04705d o6QNUEDinPYR
oIChgL6JFc7P+6M3w/mn2epusV4tOTTgLoeJ1SgAnFejK1KFAoUUgHdeSLYu XgTvvIu1nlrm
GM7REIYCUGDvCuAhBQWyKACcZ1GpU3HgnXequlHYuisA77zuNVQb+4Dz2lRF XQwBzutSE7AD
CpACwDlug4wKAOcZhepONOC8O3WNkjZAAeC8AZVUDxOB83rUQ42sAM5rVBkw BQponE8+ThGg
gFMB/poA53hcGAoA57gloECNFJA4n36cIUABQwECPHBeo29snUwBzutUG7Cl 8woA5+B3ugLA
eecfEokCAOe4N6BAjRQogvPLh0BgdxQAzmv0da2ZKcB5zSoE5nRbgdw4v3zo easpiN6ZFxPA
ebefEGmlz4Hz6fl9CpASCkCB6hSwcX7wdEzhyTP19/DF5ORy1n83n/61ojB5 9ZAC4Zx3cnuo
r3uP/tYbdQaEufXJrswOlQTOq/v2NT3lrDj3Qb4Czpte37C/5grYOD/5sDz5 uOz9tux9XF78
sRwRyL+sl9+88csH3vpGhDkdMYg1+uXRvXB79Ms4OKvZs0MIVYjS7NAtEPP8 UAt476cLVQqn
aOlK0tl79xz6F7Dn4ww4r/lXeI/mZcL59IViucL5i/sctrX4usdfkt515pRu BwePB4vM0RER
CjRRgYze+ezzavZlNXrxgIL3dcQ7DpZHzvcFcSkgCnCejaN+Y+jwIox88ZO/ nxHnMpraPzz8
26Pea/+nCtu1ooDzJn6vd2PzZpxPnt/3vg68bxMd1l/66qCxEW6jduzB4DbF /mnvXnoE17XA
+W7uiKRcYvWrWmL+z2WoKvWWv073W6Ja5u54d3715OabZ4TF2lt999bfveGz +95tn/4ur3tx
nBO/Q34wkAKKjHt/C6rs0U+H1Nne+yn4eHgeRgvPK/z4V/lxIrA11dXORvGw dCRUXEB1uVO9
wwub0CbOeyNy9FP8+8y2Aee1/OLWwqgMOFfPizPv61CG9V+92RW9tBObxK16 9PPjPgHMKWdT
roJ3vsd7xt2cIpwnV/QerW1s1kk4J3gbgVi+pmJ+X3l3fe/7YvlHHOcOF5AA H/cv/U7ggOIE
G+XKh3E0/mWczMhpA+9VwV0tGNm3odXLgvOPs4uffLXhnTf261lzwzfjnAow Pr3v/fuInADa
kfuJOFdOW/iUj7w69t6kP3fv3uPB4DR09cyY3uIqdPgJ5D5O/Mg5e+lrXgNN MQ8430lN2Tif
XCrv3IFzj3BOQA9wPn93FINoRpzr3niO78NbbC6/syNQT4Ku81VFFFm91DC2 Rz8fB0MOtchb
jECEd76TL2IjM8mEc0X0XxTR1d/4flRo+binV+OBJx3nOh/UMX1+h6/PrZjC xZ+e9qYycpR+
I0VvpNGbOtsPrjCwoYSKtXE+fnWYhHMFdMa5t5y+juNc+dnOznbhHdodwule ZkdAHhTTEjD2
ziLuZGfzzqm9Re/jD3/Z6gcFMZyf90dvhvNPs9XdYr1acijhLkQSzVTAjXM9 gl3+OG30r/sU
uJh6J4Zz3SjVveJOBkicp8VkP154+TIyOt53fMNtGLtQaDzEjovQhOxsnI9+ VThXXetGUMUh
nC+9uwvqcifq5xgKZ/S6R2/WlXMZdL8b9NIfdRe07I5O6ppucgsgcShconpi Ul67qRS1Eu75
7zUKzuAL77wJ3+P92OjAufxNmtr/nu33aTGf28VgXcAknLsJHULdeDcPnO/4 htmA88XgMYbC
lVAlNs6HL32c++iWIXTNB0R0Ok7R7DfW8odqEtL0Epc2HgoXcCX+SjhomXP3 u2RPEsLbiHN2
ps0fqvmvwBPV05BOxPlsGgxTAM5L+L4gCalAAs5pfM23SeCaf1+t78abf3Fu dLaLkc/mr9Gc
OPffqcdi3g56Qf+tj4pr8UM1jHLf/V3s1Py6F1RZ+uDH3Vvb2BwdOD8/kjgX JVt5y6Hyzv1t
eG50thekRRtGsRV1fBtRdnjnjf1yV254As6p+078Mo326cdps8sHaebEH/f+ KDbfXZP97fa7
c+lkmzGjQXPqvSy888pvhtQMnDgXVZZjCoH9FqTeuds4H7xQOI9vK/qtufql iZoNItgoWiNo
BCO3VAA4r/c3eJ/Wud+dq5+Vf4n/
Re: [HowTo] add "New WIzard" items to the navigator context-menu? [message #550096 is a reply to message #549987] Thu, 29 July 2010 03:07 Go to previous messageGo to next message
> so ...)
> to create a project and a "New Wizard" to create a file-resource /
> model object; the wizards are added, work, all fine.
> Wizard" that is a new-project wizard) and the New -> Other... dialog
> (for both of them). That would be fine, except that other "New
> Wizards" somehow make their appearance in that context menu -- e.g.,
> from the JDT, from JUnit, from Mylyn, etc. -- see attached PNG screen
> shots.
If you want to do this in one of your perspectives then you use the
following in your perspective factory:
org.eclipse.ui.IPageLayout.addNewWizardShortcut(String)
If you want to add this to another perspective use the
'newWizardShortcut' element of the
'org.eclipse.ui.perspectiveExtensions' extension point.
Dani
> The issue is not addressed in this newsgroup (or the "platform"
> newsgroup) that I could find. I saw nothing in the FAQ's. I saw
> short-cut (no luck). I have tried adding to the perspective extension
> an action-set (solves a different problem).
> thanks,
> Paul
Re: [HowTo] add "New WIzard" items to the navigator context-menu? [message #550350 is a reply to message #550096] Thu, 29 July 2010 22:37 Go to previous messageGo to next message
>> so ...)
>> shots.
> Dani
But as I said (below) I have tried that and it does not work. I suppose
the LARGE tool must have found some way to block that extension-point ...
oh well,
Paul
>> I have
>> thanks,
>> Paul
Re: [HowTo] add "New WIzard" items to the navigator context-menu? [message #550359 is a reply to message #550350] Fri, 30 July 2010 01:25 Go to previous messageGo to next message
>>> WinXP; R3.4 (I know, I know ... but the tool I am working on uses
>>> 3.4, so ...)
>>> I'm adding items to an existing LARGE tool, including a "New Wizard"
>>> However, in the context-menu of an item in the navigator, the
>>> wizards are only visible under the New -> Project... dialog (for my
>>> "New Wizard" that is a new-project wizard) and the New -> Other...
>>> dialog (for both of them). That would be fine, except that other
>>> "New Wizards" somehow make their appearance in that context menu --
>>> e.g., from the JDT, from JUnit, from Mylyn, etc. -- see attached PNG
>>> screen shots.
>>> So, evidently it is possible, but how?
>> Dani
> suppose the LARGE tool must have found some way to block that
> extension-point ...
Oops, I didn't read that. Maybe the tool defines capabilities which hide
some contributions. Take a look at General > Capabilities preferences.
Dani
> oh well,
> Paul
>>> I have tried adding a perspective extension and to that a new-wizard
>>> thanks,
>>> Paul
Re: [HowTo] add "New WIzard" items to the navigator context-menu? [message #551481 is a reply to message #550359] Fri, 06 August 2010 10:48 Go to previous message
>> extension-point ...
Hmm, I did finally get around to looking at that, and maybe I just don't
grok the UI, but it seems to give me a LONG list of enabled, disabled,
and "locked" capabilities, with brief descriptions, but no data in any
of them about blocking contributions ...
-Paul
Previous Topic:Strange behaviour with detached views
Next Topic:Convert RCP to normal plug-in?
Current Time: Wed Jul 23 12:52:11 EDT 2025
Powered by FUDForum. Page generated in 0.10897 seconds
