Read report design [message #549733] |
Tue, 27 July 2010 14:33  |
I need to store my report designs in a database table rather than storing them in a folder on the server, is there a way to store these in the database and read the design from that table and send the design to the run and render task when a report request is made? I could store these in a column either as xml or as a file. Has anybody done this? I'm having problems implementing this.
Thank you,
Re: Read report design [message #550241 is a reply to message #550236] |
Thu, 29 July 2010 11:11  |
Thanks for posting!
On 7/29/2010 11:08 AM, Kris Chappell wrote:
> Well, I'm not really the best person to ask, I'm not a java programmer.
> But the problem that I had was in my return from fetching the design.
> This is the working method.
> public class RptDbUtil implements RptDbSql
> public static String
> retrieveDesign(String pReportName, String pVersion)
> throws Exception
> Log.debug("Entered RptDbUtil.retrieveDesign");
> CHGSQLService lService = CHGSQLService.getInstance();
> SQLResult lResult = lService.executeQuery(RptDbSql.SQL_SELECT_DESIGN,
> new Object [] {pReportName, pVersion}, 0L); if (lResult.getRowCount() == 0)
> throw new RuntimeException("Report not found " + pReportName + " for
> version " + pVersion);
> return lResult.getRow(0).getValue(0).toString();
> I was returning lResult.getRow(0).toString(); which was returning an
> object instead of a string. The string is passed into the
> openReportDesign using this:
> lDesign = aBirtEngine.openReportDesign(new
> ByteArrayInputStream(RptDbUtil.retrieveDesign("inactiveUsers ",
> "1").getBytes()));
> There may be a more efficient or more elegant way, but this worked for
> me. :)
FUDForum. Page generated in 0.06157 seconds
