Custom handler req'd for standard commands? [message #549486] |
Mon, 26 July 2010 15:56 |
I have a Common Navigator Framework (CNF) implementation to which I'm trying to add some standard pop-up menu commands.
I've added the commands Delete and Rename (org.eclipse.ui.edit.delete and org.eclipse.ui.edit.rename) using org.eclipse.ui.menus and the menuContribution tag.
However, actually executing the command seems confusing. I assume there are default handlers that can take care of this for me, but I can't find any. All I can find are tutorials that imply I have to write the handler for this from scratch.
Is this true? Is it required to add the org.eclipse.ui.handlers extension and implement AbstractHandler or IHandler - basically writing your own handler to delete/rename the selected item in the Navigator?
If the answer to that is yes, might someone know of an example of a delete or rename handler implemention? It's hard to understand what parameters or context one has access to in the AbstractHandler.execute(ExecutionEvent event) method. I'm not sure how to access what is selected in the CNF.
Sorry for the rambling, thanks in advance for any replies!
FUDForum. Page generated in 0.23591 seconds
