Home » Language IDEs » ServerTools (WTP) » JSP EL can not be parsed correctly during editing in JSP editor(JSP EL can not be parsed correctly.)
icon7.gif  JSP EL can not be parsed correctly during editing in JSP editor [message #548862] Fri, 23 July 2010 06:41 Go to next message
Code like:
<button>
${<cursor position>} //EL region
</button>
In this way, the region type is JSP EL
Then follow this way:
1. Remove the "}"
It is not a valid EL region.
the type would be xml_content
2. Add the "}" again
It is a valid EL region.
but the type would still be xml_content, instead of JSP EL
It will cause the different proposals for same jsp content.
The reason is that parser will only update the xml Content region's start and length, instead of creating a new JSP EL region.
Re: JSP EL can not be parsed correctly during editing in JSP editor [message #548895 is a reply to message #548862] Fri, 23 July 2010 08:25 Go to previous messageGo to next message
I can reproduce this as well. Can you please open a bug and report that bug number back here for tracking purposes.
Thank You,
~Ian
Re: JSP EL can not be parsed correctly during editing in JSP editor [message #549199 is a reply to message #548895] Mon, 26 July 2010 01:10 Go to previous message
Thanks for your quick response.
Has reported a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=320861
Previous Topic:deploy a dynamic webproject headless
Next Topic:JspEditor: Code completion can not work for "${" when "${" is at the end of a f
Current Time: Sun Jul 27 13:54:00 EDT 2025
Powered by FUDForum. Page generated in 0.03328 seconds
