Home » Eclipse Projects » GEF » Unable to bring in gef source for debugging(Cannot attach source to dependency jar gef)
Unable to bring in gef source for debugging [message #549098] Sat, 24 July 2010 07:35 Go to next message
Hi all...
I'm trying to debug through my app and be able to step into org.eclipse.gef source code. I've tried several different ways to get
the source into the run path, but none of them works. When I go to Properties for my plugin, I look under Java Build Path->Libraries and look at the gef.jar. I expand this to see Source Attachments:
I see the org.elcipse.gef jar as the source attachment, but this jar has no source in it. And the Source Attachment says it's non-modifiable so I don't get an edit button to add a different source jar.
Am I doing something wrong here?
I'm running Eclipse 3.4 and I'm using GEF 3.2.1.
Thanks in advance for the help.
Brady
Re: Unable to bring in gef source for debugging [message #549104 is a reply to message #549098] Sat, 24 July 2010 09:22 Go to previous messageGo to next message
On 24/07/2010 12:35, bwdiggs@yahoo.com wrote:
> Hi all...
> don't get an edit button to add a different source jar. Am I doing
> Brady
Did you download the GEF SDK (this has source) or GEF runtime?
PB
Re: Unable to bring in gef source for debugging [message #549115 is a reply to message #549104] Sat, 24 July 2010 14:38 Go to previous messageGo to next message
Yes, I have the GEF source. I just can't seem to get it in the right place for Eclipse to see it. I put it in the build path, in the dependencies, etc. Nothing seems to work. I was basically wondering where I need to put it for a plugin to be able to debug through it.
Re: Unable to bring in gef source for debugging [message #549162 is a reply to message #549115] Sun, 25 July 2010 11:33 Go to previous message
I figured it out. I added the GEF plugin to my target plaform dependencies and removed all other source directories for GEF.
Works fine now. Thanks!
Previous Topic:Flickering in custom feedback figure
Next Topic:Properties Order
Current Time: Sat Jul 26 11:04:25 EDT 2025
Powered by FUDForum. Page generated in 0.25553 seconds
