Home » Eclipse Projects » Eclipse 4 » Enable/Disable ToolItem
Enable/Disable ToolItem [message #548900] Fri, 23 July 2010 08:14 Go to next message
Is it possible to enable/disable toolitem programatically ?
- Walter.
Re: Enable/Disable ToolItem [message #548901 is a reply to message #548900] Fri, 23 July 2010 08:28 Go to previous messageGo to next message
Sure get access to the model and call setEnabled() but often this is
controlled by the Command-Attached to it.
Tom
Am 23.07.10 14:14, schrieb Walter Prabhakar:
> - Walter.
Re: Enable/Disable ToolItem [message #549019 is a reply to message #548900] Fri, 23 July 2010 13:17 Go to previous messageGo to next message
As Tom mentioned, both a Handled tool item and direct tool item work by
querying the handler's @CanExecute method (where the direct tool item
handler is simply a contribution object).
If you are the handler, you can return true/false from your @CanExecute
method.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Enable/Disable ToolItem [message #549076 is a reply to message #548901] Fri, 23 July 2010 23:10 Go to previous messageGo to next message
My xwt contains the following
<ToolBar x:style="SWT.NONE">
<ToolItem x:Data="test" x:style="SWT.PUSH" SelectionEvent="onTI1Clicked"
image="/icons/sample.gif" Loaded="performToolItemLoaded"></ToolItem>
<ToolItem x:Data="test1" x:style="SWT.PUSH"
SelectionEvent="onTI2Clicked"
</ToolBar>
The ToolItem getControl is null as demonstrated with this snippet.
Map oM = new HashMap ( ) ;
public void performToolItemLoaded(Object object, Event event) {
ToolItem oTI = (ToolItem) event.widget;
System.out.println ( oTI.getData() ) ;
oM.put(oTI.getData(), oTI) ;
public void onTI1Clicked(Object object, Event event) {
oTI = ( ToolItem ) oM.get ( "test1" ) ;
if ( oTI.getControl ( ) == null )
System.err.println ( "test1 control: " + oTI.getControl ( ) ) ;
else
oTI.getControl().setEnabled(false) ;
public void onTI2Clicked(Object object, Event event) {
How do I disable a tool item when another tool item is clicked ?
- Walter
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:i2c1sm$13s$1@build.eclipse.org...
> Tom
>> - Walter.
Re: Enable/Disable ToolItem [message #549086 is a reply to message #549076] Sat, 24 July 2010 04:11 Go to previous message
Ok you should have been more specific in your question. The answer from
me and Paul was about the e4-Workbench-ToolItems while you are talking
about XWT.
I'd suggest for the future that people use [xwt] in the subject if their
question is on this topic.
Tom
Am 24.07.10 05:10, schrieb Walter Prabhakar:
> </ToolBar>
> else
> Thanks
> - Walter
>> Tom
>>> - Walter.
Re: Enable/Disable ToolItem [message #579264 is a reply to message #548900] Fri, 23 July 2010 08:28 Go to previous message
Tom
> - Walter.
Re: Enable/Disable ToolItem [message #579372 is a reply to message #548900] Fri, 23 July 2010 13:17 Go to previous message
method.
PW
Paul Webster
Re: Enable/Disable ToolItem [message #579396 is a reply to message #548901] Fri, 23 July 2010 23:10 Go to previous message
</ToolBar>
else
- Walter
> Tom
>> - Walter.
Re: Enable/Disable ToolItem [message #579408 is a reply to message #549076] Sat, 24 July 2010 04:11 Go to previous message
about XWT.
Tom
> </ToolBar>
> else
> Thanks
> - Walter
>> Tom
>>> - Walter.
Previous Topic:How to get a View dynamically
Next Topic:Retrieving a child datacontext
Current Time: Sun Jul 27 02:14:58 EDT 2025
Powered by FUDForum. Page generated in 0.06591 seconds
