Home » Archived » BIRT » concurrent report generation(how to limit number of concurrent report generation for BIRT Viewer Example deployed in tomcat 5.5?)
concurrent report generation [message #548746] Thu, 22 July 2010 15:47 Go to next message
Does any one know how i can limit number of concurrent report generation for BIRT Viewer Example deployed in tomcat 5.5?
Re: concurrent report generation [message #548947 is a reply to message #548746] Fri, 23 July 2010 09:50 Go to previous messageGo to next message
Maybe you could do this with tomcat configuration:
http://tomcat.apache.org/tomcat-5.5-doc/config/http.html
Check maxThreads and acceptCount
Jason
> Thanks
Re: concurrent report generation [message #548948 is a reply to message #548947] Fri, 23 July 2010 09:56 Go to previous messageGo to next message
You can also look at the viewer properties file:
# Maximum number of simultaneous viewing sessions that can be open at the
# same time, to prevent cache overflowing through multiple requests.
# A value of 0 means no limit.
viewer.session.maximumSessionCount=0
# Behavior that must be used once the maximum session count is reached
# (if different than 0):
# - A value of 0 will use the "Discard new session" policy that will show
# an error message for all the newer sessions.
# - A value of 1 will use the "Discard the oldest session" policy that will
# try to discard the oldest session, even if it has not expired yet.
# Note that "busy" sessions (for example downloading results) won't be
# cleant by this mechanism.
viewer.session.maximumSessionCountPolicy=1
Jason
> Jason
>> Thanks
Re: concurrent report generation [message #550448 is a reply to message #548948] Fri, 30 July 2010 08:09 Go to previous message
Thank you Jason.
I updated viewer.session.maximumSessionCount=5 in web-inf/viewer.properties and it works like a charm!
Previous Topic:CSS Highlight property
Next Topic:Sequence with OnRender
Current Time: Sat Jul 26 11:04:37 EDT 2025
Powered by FUDForum. Page generated in 0.06675 seconds
