Home » Language IDEs » ServerTools (WTP) » log4j.xml not copied to build folder
log4j.xml not copied to build folder [message #548533] Thu, 22 July 2010 05:45 Go to next message
I have a maven project (using the m2 plugin) configured as dynamic web project. In the folder src/main/resources (which is configured in Build Path properties as one of the source folders) there are several configuration files, one of those is log4j.xml. The Build folder is target/classes.
For some reasons which I don't understand all files in the folder src/main/resources are copied to target/classes but not the log4j.xml.
I always have to copy it manually to target/classes.
My question is: has anybody an explanation about this behaviour or could it be that the file is copied but somehow deleted straight away?
Abid
Re: log4j.xml not copied to build folder [message #548535 is a reply to message #548533] Thu, 22 July 2010 05:49 Go to previous messageGo to next message
I forgot to mention that I use Tomcat 6 together with WTP 3.1.1 on Eclipse 3.5.
Abid
Re: log4j.xml not copied to build folder [message #548634 is a reply to message #548533] Thu, 22 July 2010 09:54 Go to previous messageGo to next message
On 7/22/2010 5:45 AM, Abid Hussain wrote:
> Hello,
> target/classes.
> Best regards,
> Abid
I tried this and it worked for fine for me, though I'm not using maven.
This suggests this behavior is not fundamental to WTP. It could be an
atypical setting in your project or something related to maven. Note
that WTP doesn't handle the "building" of the Java source folder to the
output folder. This is handled by the JDT (Java Development Tools)
portion of Eclipse.
You imply that other configuration files are copied. Are some of these
also xml files or do all have some other extension?
A shot in the dark is to Refresh the src/main/resources folder on the
chance that this file is out of sync with the file system. This could
cause a problem when copying the file.
Larry
Re: log4j.xml not copied to build folder [message #549243 is a reply to message #548634] Mon, 26 July 2010 04:58 Go to previous messageGo to next message
Thanks for you hints.
There are also other xml-files in the folder src/main/resources which are all copied properly to target/classes.
Also when I add a new file (dummy.txt or whatever) it is copied to the build folder.
But even when I delete the log4j.xml and add it again it is not copied... It seems that only a file with the name log4j.xml ist not copied. It's really strange.
Maybe I should post this question to the JDT forum.
Re: log4j.xml not copied to build folder [message #549325 is a reply to message #548634] Mon, 26 July 2010 09:21 Go to previous messageGo to next message
I solved the problem. See JDT forum.
Re: log4j.xml not copied to build folder [message #549338 is a reply to message #549243] Mon, 26 July 2010 09:27 Go to previous message
> build folder.
It would seem something is deliberately not copying the file. Since
it's not happening for me in a typical Eclipse + WTP environment, I
wouldn't exclude maven from the list of possible culprits. You may want
to experiment by creating a non-maven dynamic web project and see if it
has the same issue. If not, you could try to compare settings with the
maven project add see if you can find something that is different that
might be the cause.
Larry
Previous Topic:Possibility of embedding WTP XML Editor in a web app
Next Topic:Does eclipse has a feature of auto usage finder on selecting a part of code ?
Current Time: Sun Aug 31 15:14:25 EDT 2025
Powered by FUDForum. Page generated in 0.04639 seconds
