Home » Archived » M2M (model-to-model transformation) » Call helper inside a rule and overgive parameter
| Call helper inside a rule and overgive parameter [message #548554] |
Thu, 22 July 2010 06:53  |
Hi all
Is it possible to call a helper in a rule? I need it to get the name attribute from another class.
My rule is:
-- Rule 13 / 11a with conditionalExpression
rule ConditionExpression {
from
e : EPK!ControlFlow (e.isConditionExpression())
to
b : BPMN!SequenceFlow
name <- e.name
conditionExpression <- con
con : BPMN!ConditionExpression(
name <- thisModule.getConditionName( overgive id, take back name)
My helper looks:
--Make two level - Rule 13 with conditionalExpression
helper context EPK!ControlFlow def: getConditionName(take id, give back name ) : Sequence(String) =
EPK!Event.allInstances()-> select(e | e.target=self.id)->collect(e | e.name);
but how can I overgive and get back this parameters?
Thanks for your help.
Cheers Roger
[Updated on: Thu, 22 July 2010 06:56] by Moderator
| Re: Call helper inside a rule and overgive parameter [message #548596 is a reply to message #548582] |
Thu, 22 July 2010 08:26   |
Le 22/07/2010 14:06, Roger80 a écrit :
> I can provide you my meta models, but they are huge. My only problem is
> that I want to call a helper in a rule. Is that possible?
> If yes, is it also possible to hand over some parameters?
> Like:
> helper context... def (get parameter, hand over parameter)
> do something
> rule
> from
> to
> binding a <- call helper(hand over parameter, get back parameter)
a <- thisModule.helper(param1, param2, ...)
will put in a the return value of the helper (but only in match rules
and other helpers).
It seems you expect 2 return values from the helper???
If it is the case, then your helper should return a Tuple (x, y) so you
may call it and store the result in the "using" section. You could then
access to the parts of the Tuple in the "to" section.
> Thank you....cheers
> Roger
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
| Re: Call helper inside a rule and overgive parameter [message #548641 is a reply to message #548596] |
Thu, 22 July 2010 10:44   |
>will put in a the return value of the helper (but only in match >rules
>and other helpers).
So, when I want to use a helper in a rule I have to use a matched rule, right?
Is it true that a match rule has a structure like below?
rule rule_name{
from in: MM1!MetaClass(<matching condition>)
using{<variable definitions>}
to out1: MM2!MetaClass1(
<bindings1>
out2: MM2!MetaClass2(
<bindings2>
do{<imperative block>}
What is the <matching condition>, the <variable definitions> and the <imperative block> for?
>If it is the case, then your helper should return a Tuple (x, y) so >you
>may call it and store the result in the "using" section. You could >then
No, I just want one return value.
Thanks and cheers
Roger
[Updated on: Thu, 22 July 2010 10:47] by Moderator
| Re: Call helper inside a rule and overgive parameter [message #548676 is a reply to message #548554] |
Thu, 22 July 2010 11:57   |
These are my settings:
-- Helper:
helper context EPK!ControlFlow def: getConditionName(id : String) : Sequence(OclAny) =
EPK!Event.allInstances().debug()-> select(g | g.target=self.id)->collect(g | g.name);
-- Rule:
from
e : EPK!ControlFlow (e.isConditionExpression()) -- and he.isConditionExpressionEvent() and not e.isStarter() and e.isNotEventEndEvent())
to
name <- e.name
--conditionExpression <- con
name <- thisModule.getConditionName(e.id)
But when I execute, the following error occur. Do you understand it, what does it mean?
org.eclipse.m2m.atl.engine.vm.VMException: Could not find operation getConditionName on Module having supertypes: [OclAny]
at A.__applyConditionExpression(1 : NTransientLink;) : ??(EPL2BPMN.atl[218:11-218:44])
local variables = {b=OUT!<notnamedyet>, e=IN!<notnamedyet>, link=TransientLink {rule = 'ConditionExpression', sourceElements = {e = IN!<notnamedyet>}, targetElements = {con = OUT!<notnamedyet>, b = OUT!<notnamedyet>}, variables = {}}, self=EPL2BPMN : ASMModule, con=OUT!<notnamedyet>}
local stack = [OUT!<notnamedyet>, OUT!<notnamedyet>, EPL2BPMN : ASMModule]
Thank you very much for lookinf into it...
Cheers Roger
| Re: Call helper inside a rule and overgive parameter [message #548684 is a reply to message #548676] |
Thu, 22 July 2010 12:15   |
> -- Helper:
> Sequence(OclAny) = EPK!Event.allInstances().debug()-> select(g |
> -- Rule:
> from
> to
> b : BPMN!SequenceFlow (
> name <- e.name
> --conditionExpression <- con ),
name <- e.getConditionName(e.id)
because you defined your helper on the ControlFlow type
> what does it mean?
> Cheers Roger
Cordialement
Vincent MAHÉ
| Re: Call helper inside a rule and overgive parameter [message #548819 is a reply to message #548815] |
Fri, 23 July 2010 03:41   |
Le 23/07/2010 09:34, Roger80 a écrit :
> Please help, *I am starring since hours on it*, but I do not find
> anything. I call my helper from:
> name <- e.getConditionName(e.target)
> e is the class ControlFlow with the attributes: id, name, source, target
as you write, "e" is a ControlFlow, but getConditionName is defined on Event
> I push the parameter target to the helper "getConditionName".
> The helper: In the helper (getConditionName) I use the target
> (self.target) to identify the "id" of the event class and to get
> afterwards the "name" attribute of the event class. The name is then the
> result which should be used in the rule.
> Atributes of event: name and id
> helper context EPK!Event def: getConditionName(target : String) :
The way you wrote it, this helper applies only on Event instances!!!
> Sequence(String) =
> EPK!ControlFlow.allInstances()-> select(g |
> g.id=self.target.debug())->collect(g | g.name);
> Is everything correct, what do you think?
> Cheers Roger
Cordialement
Vincent MAHÉ
| Re: Call helper inside a rule and overgive parameter [message #548871 is a reply to message #548845] |
Fri, 23 July 2010 07:00  |
Le 23/07/2010 11:38, Roger80 a écrit :
> Hello Vincent
> Thank you for your help... :) I get now the correct information, but I
> know now, why I got the error, it is becasue something is wrong in my
> Meta model. You already told me that I have to check my Meta model and
> to adapt the references on my meta model. You also gave me advise how to
> do:
> Class SequenceFlow
> reference conditionExpressionLevel
> containment = true
> eType = ConditionExpression
> I try to do it but still the same error occur:
> 2m.atl.engine.vm.VMException: Feature ConditionExpressionLevel does not
'C' -> 'c'
> exist on BPMN!SequenceFlow
> Can you check my meta model settings? And tell me what is wrong? That
> would help me I think, here are the illustrations:
You get a wrong case in the feature name (see above)
Cordialement
Vincent MAHÉ
Current Time: Mon Nov 03 12:46:17 EST 2025
Powered by FUDForum. Page generated in 0.05217 seconds
