Home » Archived » M2M (model-to-model transformation) » Call helper inside a rule and overgive parameter
Call helper inside a rule and overgive parameter [message #548554] Thu, 22 July 2010 06:53 Go to next message
Hi all
Is it possible to call a helper in a rule? I need it to get the name attribute from another class.
My rule is:
-- Rule 13 / 11a with conditionalExpression
rule ConditionExpression {
from
e : EPK!ControlFlow (e.isConditionExpression())
to
b : BPMN!SequenceFlow
name <- e.name
conditionExpression <- con
con : BPMN!ConditionExpression(
name <- thisModule.getConditionName( overgive id, take back name)
My helper looks:
--Make two level - Rule 13 with conditionalExpression
helper context EPK!ControlFlow def: getConditionName(take id, give back name ) : Sequence(String) =
EPK!Event.allInstances()-> select(e | e.target=self.id)->collect(e | e.name);
but how can I overgive and get back this parameters?
Thanks for your help.
Cheers Roger
[Updated on: Thu, 22 July 2010 06:56] by Moderator
Re: Call helper inside a rule and overgive parameter [message #548572 is a reply to message #548554] Thu, 22 July 2010 07:30 Go to previous messageGo to next message
Le 22/07/2010 12:53, Roger80 a écrit :
> Hi all
> My rule is:
> from
> to
> name <- e.name
> My helper looks:
> e.name);
> Cheers Roger
I am sorry but I understand lesser than ever what is your problem.
Can you present the types of the input and output metamodels, with their
containing attributes and contained types?
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: Call helper inside a rule and overgive parameter [message #548582 is a reply to message #548554] Thu, 22 July 2010 08:06 Go to previous messageGo to next message
I can provide you my meta models, but they are huge. My only problem is that I want to call a helper in a rule. Is that possible?
If yes, is it also possible to hand over some parameters?
Like:
helper context... def (get parameter, hand over parameter)
do something
rule
from
to
binding a <- call helper(hand over parameter, get back parameter)
Thank you....cheers
Roger
Re: Call helper inside a rule and overgive parameter [message #548596 is a reply to message #548582] Thu, 22 July 2010 08:26 Go to previous messageGo to next message
> Like:
> do something
> rule
> from
> to
a <- thisModule.helper(param1, param2, ...)
will put in a the return value of the helper (but only in match rules
and other helpers).
It seems you expect 2 return values from the helper???
If it is the case, then your helper should return a Tuple (x, y) so you
may call it and store the result in the "using" section. You could then
access to the parts of the Tuple in the "to" section.
> Thank you....cheers
> Roger
Cordialement
Vincent MAHÉ
Re: Call helper inside a rule and overgive parameter [message #548641 is a reply to message #548596] Thu, 22 July 2010 10:44 Go to previous messageGo to next message
>will put in a the return value of the helper (but only in match >rules
>and other helpers).
So, when I want to use a helper in a rule I have to use a matched rule, right?
Is it true that a match rule has a structure like below?
rule rule_name{
from in: MM1!MetaClass(<matching condition>)
using{<variable definitions>}
to out1: MM2!MetaClass1(
<bindings1>
out2: MM2!MetaClass2(
<bindings2>
do{<imperative block>}
What is the <matching condition>, the <variable definitions> and the <imperative block> for?
>If it is the case, then your helper should return a Tuple (x, y) so >you
>may call it and store the result in the "using" section. You could >then
No, I just want one return value. Smile
Thanks and cheers
Roger
[Updated on: Thu, 22 July 2010 10:47] by Moderator
Re: Call helper inside a rule and overgive parameter [message #548667 is a reply to message #548641] Thu, 22 July 2010 10:52 Go to previous messageGo to next message
> right?
> rule rule_name{
> <bindings1>
> <bindings2>
> Thanks and cheers
> Roger
You may have a look at some examples of ATL transformations.
Cordialement
Vincent MAHÉ
Re: Call helper inside a rule and overgive parameter [message #548676 is a reply to message #548554] Thu, 22 July 2010 11:57 Go to previous messageGo to next message
These are my settings:
-- Helper:
helper context EPK!ControlFlow def: getConditionName(id : String) : Sequence(OclAny) =
	EPK!Event.allInstances().debug()-> select(g | g.target=self.id)->collect(g | g.name);
-- Rule:
from
	e : EPK!ControlFlow (e.isConditionExpression()) -- and he.isConditionExpressionEvent() and not e.isStarter() and e.isNotEventEndEvent())
to
	 	name <- e.name
		--conditionExpression <- con
		name <- thisModule.getConditionName(e.id)
But when I execute, the following error occur. Do you understand it, what does it mean?
org.eclipse.m2m.atl.engine.vm.VMException: Could not find operation getConditionName on Module having supertypes: [OclAny]
	at A.__applyConditionExpression(1 : NTransientLink;) : ??(EPL2BPMN.atl[218:11-218:44])
		local variables = {b=OUT!<notnamedyet>, e=IN!<notnamedyet>, link=TransientLink {rule = 'ConditionExpression', sourceElements = {e = IN!<notnamedyet>}, targetElements = {con = OUT!<notnamedyet>, b = OUT!<notnamedyet>}, variables = {}}, self=EPL2BPMN : ASMModule, con=OUT!<notnamedyet>}
		local stack = [OUT!<notnamedyet>, OUT!<notnamedyet>, EPL2BPMN : ASMModule]
Thank you very much for lookinf into it...
Cheers Roger
Re: Call helper inside a rule and overgive parameter [message #548684 is a reply to message #548676] Thu, 22 July 2010 12:15 Go to previous messageGo to next message
> -- Helper:
> Sequence(OclAny) = EPK!Event.allInstances().debug()-> select(g |
> -- Rule:
> from
> to
> b : BPMN!SequenceFlow (
> name <- e.name
> --conditionExpression <- con ),
name <- e.getConditionName(e.id)
because you defined your helper on the ControlFlow type
> what does it mean?
> Cheers Roger
Cordialement
Vincent MAHÉ
Re: Call helper inside a rule and overgive parameter [message #548695 is a reply to message #548684] Thu, 22 July 2010 12:47 Go to previous messageGo to next message
It still give me the same error, really, really strange.
When I just give back a String like 'Hello' it works.
But then I try with parameters or more complex statements he starts complaining and always with the same error.
This is the beginning of the error:
SWhat does he talk about module and supertypes: [OclAny]. Should I provide the whole error?
Thank you, I feel close but I don't know...
Cheers Roger
Addition:
In the documentation I found a hint, but I don't know what to do with it. I added a 'do' part at the end of my rule, without any success.
ATL Called Rules Troubles
* Trouble: ERROR: could not find operation including on Module having supertypes: [OclAny]) on a called rule
Cause: Your called rule doesn't return the good type (problably any)
Solution: Add a return type on your called rule by adding the do clause
e.g.
rule myCalledRule() {
to
out : XML!Element -- ...
do {
out;
[Updated on: Thu, 22 July 2010 13:02] by Moderator
Re: Call helper inside a rule and overgive parameter [message #548806 is a reply to message #548695] Fri, 23 July 2010 02:33 Go to previous messageGo to next message
It means sometimes the getConditionName() is applied on something which
is not of the Type defined as its context.
Cordialement
Vincent MAHÉ
Re: Call helper inside a rule and overgive parameter [message #548815 is a reply to message #548806] Fri, 23 July 2010 03:34 Go to previous messageGo to next message
Please help, *I am starring since hours on it*, but I do not find anything. I call my helper from:
name <- e.getConditionName(e.target)
e is the class ControlFlow with the attributes: id, name, source, target
I push the parameter target to the helper "getConditionName".
The helper:
In the helper (getConditionName) I use the target (self.target) to identify the "id" of the event class and to get afterwards the "name" attribute of the event class. The name is then the result which should be used in the rule.
Atributes of event: name and id
helper context EPK!Event def: getConditionName(target : String) : Sequence(String) =
	EPK!ControlFlow.allInstances()-> select(g | g.id=self.target.debug())->collect(g | g.name);
Is everything correct, what do you think?
Cheers Roger
Re: Call helper inside a rule and overgive parameter [message #548819 is a reply to message #548815] Fri, 23 July 2010 03:41 Go to previous messageGo to next message
as you write, "e" is a ControlFlow, but getConditionName is defined on Event
> The helper: In the helper (getConditionName) I use the target
The way you wrote it, this helper applies only on Event instances!!!
> Sequence(String) =
> Cheers Roger
Cordialement
Vincent MAHÉ
Re: Call helper inside a rule and overgive parameter [message #548845 is a reply to message #548819] Fri, 23 July 2010 05:38 Go to previous messageGo to next message
Hello Vincent
Thank you for your help... Smile I get now the correct information, but I know now, why I got the error, it is becasue something is wrong in my Meta model. You already told me that I have to check my Meta model and to adapt the references on my meta model. You also gave me advise how to do:
Class SequenceFlow
reference conditionExpressionLevel
containment = true
eType = ConditionExpression
I try to do it but still the same error occur:
2m.atl.engine.vm.VMException: Feature ConditionExpressionLevel does not exist on BPMN!SequenceFlow
Can you check my meta model settings? And tell me what is wrong? That would help me I think, here are the illustrations:
http://www.haar-em.ch/test/mm1.jpg
http://www.haar-em.ch/test/mm2.jpg
http://www.haar-em.ch/test/mm3.jpg
Thanks and cheers
Roger
[Updated on: Fri, 23 July 2010 05:39] by Moderator
Re: Call helper inside a rule and overgive parameter [message #548871 is a reply to message #548845] Fri, 23 July 2010 07:00 Go to previous message
Le 23/07/2010 11:38, Roger80 a écrit :
> Hello Vincent
> Thank you for your help... :) I get now the correct information, but I
> do:
> Class SequenceFlow
> containment = true
'C' -> 'c'
You get a wrong case in the feature name (see above)
Cordialement
Vincent MAHÉ
Previous Topic:[ATL] Problem with UML property
Next Topic:AtlEMFModelHandler
Current Time: Sun Nov 02 19:29:10 EST 2025
Powered by FUDForum. Page generated in 0.26264 seconds
